RAM/PROM board for early S100 computers
For anyone who may have missed this in other forums, here’s a link to the FLEX64K RAM/PROM board that is designed to work around all the memory fragmentation that is common in early S-100 systems: https://deramp.com/flex64k.html
Re: RAM/PROM board for early S100 computers
What a great board that you made.
I would of watched the video a few times now. :) It's help me get a Sub system B setup close to running.
I've got Mikes Flex64K board and a VDM-1 2021 board plus the 3S+P serial and have attach a ASCII keyboard plus serial port to the laptop.
I've now got Cuter to boot to the prompt and can dump memory etc, then tested a transfer of a program of to the Altair 8800c it's very slow transfer at 300 BAUD. Think I change this to 9600 over the weekend. Still learning about the CUTER Monitor, I also need to find a way to get ALS8 into EPROM next, I can not seem to find a BIN/HEX file for this.?
Still great fun.
Cheers
Vernon
Still great fun.
Cheers
Vernon
That's awesome, guys!
Love that memory board!
Love that system!
Love that system!
Here’s a link where you can find cassette ALS8 (loads into RAM). I’ll find the patches I made to it to make an EPROM version and post that as well.
https://deramp.com/downloads/processor_ ... sol20.org/
That's great.
I might Disable ROM and ENABLE RAM at D000- FFFF and try the tape version. So easy to do this on the Flex64k board. I've now changed over my 3P +S for 9600 now. I see there is added a note that you added a 100ms delay for transfer at the sol20.org.
Just out of interest did you need to patch CUTER13.HEX from your download page it's the one I used in my system.?
Cheers
Vernon
Cheers
Vernon
Vernon,
No, I did not have to patch CUTER. Here’s a link to the ALS8 I put into EEPROM for the FLEX64K demo:
https://deramp.com/downloads/processor ... patch).HEX
This version takes keyboard input from the serial port on the 3P+S and outputs to the VDM board. Jump to E024 to start and to E060 to re-enter.
Thank you Mike,
That seems to have gone very easy thanks to your pre made hex file. Is it much work to make a .hex file for ASCII input for the 3P+S board and out to the VDM-1.?
I have only read though the ALS8 Assembler manual once so far, then typed in your example from your video. I got close. I'm guessing I have a space
or something not quite right as I had a error on line 0050, it's fun playing with these old assemblers.
Cheers
Vernon
Cheers
Vernon
Yes I have the 3P+S board connected to a ASCII keyboard and would like to use that to type on and display on the VDM-1, I have the serial connected to do transfers if needed.
Vernon
Vernon
Try this using ALS-8 to assemble it. This should echo everything typed to the screen. Exit by pressing ESC (1Bh)
LOOP CALL 0C01FH
JZ LOOP
CPI 1BH
RZ
MOV B,A
CALL 0C019H
JMP LOOP
Users browsing this forum: Amazon [Bot] and 3 guests
