Hi all,
I've read the supplied BASCOM 5.3 documentation, and searched the web but can't seem to get a file to compile as a stand alone program. Whenever I use the /O switch my programs still say BRUN.COM is missing.
Can someone please give me a heads up in regards to which switches to throw at L80.COM?
Thanks heaps!
Compiling a stand alone program using BASCOM 5.3
Re: Compiling a stand alone program using BASCOM 5.3
You do have BRUN.COM on the same disk as the compiled COM file, right? It has to be on the same disk.
Hi,
Thanks for your reply but I'm trying to construct a standalone COM file that doesn't require BRUN.COM. According to the supplied test files I need to use the /O flag, but as mentioned originally I can't get it to actually work as expected.
Thanks
/O (Newer versions only). Tells the compiler to construct a stand-
alone program instead of one requiring presence of the BRUN.COM
runtime module. This generates much bigger programs because all
of the runtime routines must be included.
Given a basic program saved in ASCII called SAMPLE.BAS:
A>BASCOM SAMPLE=SAMPLE/O
00000 Fatal Error(s)
25542 Bytes Free
A>L80 SAMPLE,SAMPLE/N/E
Link-80 3.44 09-Dec-81 Copyright (c) 1981 Microsoft
Data 0103 2537 < 9268>
34554 Bytes Free
[0118 2537 37]
A>SAMPLE
Sample Compiled BASIC Program
This is line 1
This is line 2
This is line 3
This is line 4
This is line 5
This is line 6
This is line 7
This is line 8
This is line 9
This is line 10
Thanks heaps Mike, I was using the flag on L80.COM.
Users browsing this forum: Ahrefs [Bot] and 18 guests
