random numbers and delay loops HELP
gio74
Post by gio74 »
I've created a random number generator that outputs number from 1 to 8, and I'd like to use that number to change the time of a delay loop
the problem is that the delay seems to ignore the changes. what am I doing wrong?
; tempo random
; 1 March 2015
               org   	100h
	        mvi	a,03h
	        out 	10h
	        mvi 	a,15
	        out 	10h
           lxi 	h,200h ;initialise random number gen. by reading 200h
start	  mvi	a,'+'		;output an ASCII + to monitor the delay routine
	        out	11h
random	mov 	a,m ;random number generator
   	    rrc
	        add	m
	        rrc
	        mov 	m,a
	        inx	h
	        xra	m
	        mov	m,a
	        ani	7o
	        inr	a
tempo      set	a ;0 to 7 should be assigned to variable "tempo"
	        lxi	d,tempo*5000 ;this is the problem, I've tried also other things like "lxi d,a*5000", no luck
delay        dcx	d
	        mov	a,d
	        ora	e
	        jnz	delay
	        jmp	start
	        end
sorry for the bad formatting, switching between PC and Mac makes some mess
Re: random numbers and delay loops HELP
gio74 wrote:I've created a random number generator that outputs number from 1 to 8, and I'd like to use that number to change the time of a delay loop
; tempo random
; 1 March 2015
               org   	100h
	        mvi	a,03h
	        out 	10h
	        mvi 	a,15
	        out 	10h
	        out	11h
   	    rrc
	        add	m
	        rrc
	        mov 	m,a
	        inx	h
	        xra	m
	        mov	m,a
	        ani	7o
	        inr	a
delay        dcx	d
	        mov	a,d
	        ora	e
	        jnz	delay
	        jmp	start
	        end
Could you be loading the location of tempo rather than the contents at that location?
I'm more familiar with Z-80 code but in order to use the 0 - 7, you'd have to
do something like this:
ld hl,(tempo)*5000
Tom Lake
Gio,
I see a few problems that need to be solved. One is that "lxi hl" loads the actual value specified in the right column - the right column is not an address from which hl is loaded. Second, the "set" mnemonic is a directive to the assembler used to set the value of a symbol during assembly - it is not an 8080 instruction.
Post the algorithm in some sort of pseudo-code and we can help convert it into 8080 assembly with you.
gio74
Post by gio74 »
oh thanks Mike!
the random gen works great, the only problem I have is to use that number to change the delay loop time
Ok I misunderstood, lxi loads a 16 bit address and not its content, nevertheless the random gen works
mhh I need to understand this. I used set before in another program and it worked. What is exactly a directive? the 8080 manual does not explain this.
anyway the program is basically this
10 initialise the serial port
20 print "X"
30 generate a random number between 1 and 8
40 assign random number to variable A$
50 perform loop delay
loop delay time = lxi d,...x..... where x = A$*5000
60 goto 20
Here are some comments and updates to help you along:
; tempo random
; 1 March 2015
	org	100h
	mvi	a,03h
	out	10h
	mvi	a,15
	out	10h
; Moved lxi h,200h inside the loop, otherwise, hl increments forever.
;    Also changed absolute address reference to a symbol
start	lxi	h,rndVal		;hl->rndVal where 16 bit random number is
updated
	out	11h
random	mov	a,m
	rrc
	add	m
	rrc
	mov	m,a
	inx	h
	xra	m
	mov	m,a
	ani	7		;a = msb and 7
	inr	a		;a = 1 - 8 (not 0-7 as stated below)
; This just sets the symbol "tempo" to a fixed value of 7 at assembly time.
;   In many 8080 instructions, "a" has the value of 7 in the bit field of
;   the instruction that identifies the register to be used
; tempo	set	a 		;0 to 7 should be assigned to variable "tempo"
; This sets the value loaded into d to the fixed value of 7*5000 which when
;    wrapped to 16 bits is 88B8h. There is not a multiply instruction in the 8080.
;	lxi	d,tempo*5000
; compute de = a*4096 (instead of a*5000) by shifting a to the left 12 bits.
	rlc			;move lower nibble to upper nibble
	rlc
	rlc
	rlc
	mov	d,a		;d=msb of a*4096
	mvi	e,0		;de=a*4096
delay	dcx	d
	mov	a,d
	ora	e
	jnz	delay
	jmp	start
; Variables
rndVal	ds	2		;16 bit random value variable
	end
gio74
Post by gio74 »
Great Mike, I will study this very very closely.
thank you very much indeed.
Users browsing this forum: Semrush [Bot] and 28 guests
