Disk Sound Effects Board
Recently, I've spent a lot of time working on a new floppy disk controller for real Altair computers. Because of this, I'm now very accustomed to the particular sounds the drives make as I run through various computer activities. But now when I use the Altair Clone, the lack of disk sounds disappoints me!
A disk sound effects board for the Altair Clone would best be implemented in a manner very similar to the cassette interface board. In fact, the board would have to provide both functions. The audio output connector of the new board would come through the same hole in the rear of the Altair Clone as the cassette audio output. This output then connects to either 1) an amplified speaker for disk sound effects (e.g., computer speaker, iPod/iPhone/MP3 speaker), or 2) the microphone input on a cassette recorder when using it as a cassette interface.
Thoughts? Suggestions?
Re: Disk Sound Effects Board
Sounds great! As long as the shipping to Australia is reasonable I'll buy 1. :)
No chance of a third jack just for disk sounds? I don't like the idea of plugging and unplugging connections so often and I use the cassette interface a lot (probably the only one who does, though)!AltairClone wrote:Recently, I've spent a lot of time working on a new floppy disk controller for real Altair computers. Because of this, I'm now very accustomed to the particular sounds the drives make as I run through various computer activities. But now when I use the Altair Clone, the lack of disk sounds disappoints me!
A separate output on the board for disk sound effects isn't a problem, but there are only two audio connector holes on the rear of an Altair and the Altair Clone. I guess I could make a plate that mounts in a DB-25 opening with a hole for a headphone jack. I've seen that before on an Altair 680 cabinet.
As Jean-Luc Picard said to Commander Riker when he saw an antique Singer machine for the first time, "Make it sew!"AltairClone wrote:A separate output on the board for disk sound effects isn't a problem, but there are only two audio connector holes on the rear of an Altair and the Altair Clone. I guess I could make a plate that mounts in a DB-25 opening with a hole for a headphone jack. I've seen that before on an Altair 680 cabinet.
Sounds very nice Mike!
I was wondering what about a dedicate speaker with a 0.7Watt amp to be mounted inside the chassis?
would do a better job (as sound effect) than audio output, also this would keep free the cassette jack output.
Beside this, my suggestion to record the Diskette Driver sound is to use a contact microphone (e.g.: Schertler DYN E)
Contact mics can do a better job when it came to the recording of mechanical noises,
than common mics (like a dynamic or condenser).
I would find having the sounds of a floppy drive but not the drive itself frustrating.
No chance of making an actual interface for floppy drives, I suppose? I see that there are plenty of old 5.25 inch drives going cheap on Ebay.
Good luck with that! I've been coaxing, urging, cajoling and otherwise being a PITA about it for a long time. It's a limitation of the chip he used. Unless he redesigns the whole thing, there's no chance.mail@gabrielegan.com wrote:I would find having the sounds of a floppy drive but not the drive itself frustrating.
I've recently been using 5.25" Teac 55-GFR drives as 8 inch drives with my real Altairs. You can't hear drive activity at all over the drive cabinet fan and the Altair fan. Maybe I should just sell a louder fan with the Clone and say it's just drowning out the drive noises ;)
LOL! As a comedian you make a brilliant hardware designer! :)AltairClone wrote:I've recently been using 5.25" Teac 55-GFR drives as 8 inch drives with my real Altairs. You can't hear drive activity at all over the drive cabinet fan and the Altair fan. Maybe I should just sell a louder fan with the Clone and say it's just drowning out the drive noises ;)
Like you, that's the way I'll end up using your disk interface board if you start selling it.
Users browsing this forum: Ahrefs [Bot] and 9 guests
