I have been experimenting with my Altair clone. I am trying to produce some code that will take input from the console keyboard and echo it verbatim out the second serial I/O port. This is a preamble to being able to have a program send output to some other display device while still having the console attached to my normal laptop running TerraTerm.
Anyway, I thought this would be an easy one to start with. I grabbed the source file for PCGET.ASM because I was going to strip out all the XMODEM stuff, and all I was really after was the proper way to initialize the Altair SIO ports.
Here is my code:
; SIO-EXPR - THIS PROGRAM TAKES INPUT FROM THE CONSOLE PORT
; AND SENDS THE INPUT VERBATIM OUT SERIAL PORT B.
; SERIAL PORT EQUATES
0010 = SIOACR EQU 010H ;2SIO PORT A CONTROL REGISTER
0011 = SIOADR EQU 011H ;2SIO PORT A DATA REGISTER
0012 = SIOBCR EQU 012H ;2SIO PORT B CONTROL REGISTER
0013 = SIOBDR EQU 013H ;2SIO PORT B DATA REGISTER
0002 = MODEM$SEND$MASK EQU 2
0002 = SEND$READY EQU 2 ;VALUE WHEN READY
0001 = MODEM$RECV$MASK EQU 1
0001 = RECV$READY EQU 1 ;BIT ON WHEN READY
; TRANSFER RELATED EQUATES
0001 = SOH EQU 1
0004 = EOT EQU 4
0006 = ACK EQU 6
0015 = NAK EQU 15H
0003 = CTRLC EQU 3 ;CONTROL-C
000A = LF EQU 10
000D = CR EQU 13
0100 ORG 100H
; SWITCH TO LOCAL STACK AND DO THE TRANSFER
0100 210000 DOXFER LXI H,0 ;HL=0
0103 39 DAD SP ;HL=STACK FROM CP/M
0104 224702 SHLD STACK ;SAVE IT
0107 314702 LXI SP,STACK ;SP=MY STACK
010A CD4D01 CALL INIT$ACIA ;MASTER RESET THE ACIA
010D 115A01 LXI D,MSEND ;POINT TO SIGN ON MESSAGE
0110 0E09 MVI C,PRINT ;PRINT THE SEND MESSAGE
0112 CD0500 CALL BDOS ;PRINT ID MESSAGE
0115 CD2E01 LOOP CALL RECV
0118 FE03 CPI CTRLC ;EXIT IF ABORT REQUESTED
011A CA0602 JZ ABORT
011D CD3F01 CALL SEND
0120 C31501 JMP LOOP
; S U B R O U T I N E S
;EXIT PRINTING MESSAGE FOLLOWING 'CALL ERXIT'
0123 D1 ERXIT POP D ;GET MESSAGE
0124 0E09 MVI C,PRINT
0126 CD0500 CALL BDOS ;PRINT MESSAGE
0129 2A4702 EXIT LHLD STACK ;GET ORIGINAL STACK
012C F9 SPHL ;RESTORE IT
012D C9 RET ;--EXIT-- TO CP/M
;SIO RECV FROM CONSOLE
012E D5 RECV PUSH D ;SAVE
; PORT A INPUT
012F DB10 MWTI IN SIOACR
0131 E601 ANI MODEM$RECV$MASK
0133 FE01 CPI RECV$READY
0135 CA3B01 JZ MCHAR ;GOT CHAR
0138 C32F01 JMP MWTI
; GOT AN INPUT FROM CONSOLE
013B DB11 MCHAR IN SIOADR
013D D1 POP D ;RESTORE DE
013E C9 RET
;SIO SEND CHAR TO PORT B
013F F5 SEND PUSH PSW ;SAVE THE OUTPUT CHARACTER
0140 DB12 SENDWB IN SIOBCR
0142 E602 ANI MODEM$SEND$MASK
0144 FE02 CPI SEND$READY
0146 C24001 JNZ SENDWB
0149 F1 POP PSW ;GET CHAR
014A D313 OUT SIOBDR
014C C9 RET
; INITITIALIZE THE SERIAL PORT
INIT$ACIA:
; INITA - INIT PORT A
; MVI A,003H ;DON'T RESET CONSOLE PORT
; OUT SIOACR
014D 3E15 MVI A,015H ;RTS ON, 8N1
014F D310 OUT SIOACR
; INITB - INIT PORT B
0151 3E03 INITB MVI A,3
0153 D312 OUT SIOBCR
0155 3E15 MVI A,015H ;RTS ON, 8N1
0157 D312 OUT SIOBCR
0159 C9 RET
015A 0D0A4C4953MSEND DB CR,LF,'LISTENING ON CONSOLE PORT, SENDING TO PORT B...',CR,LF,LF,'$'
018F 0D0A504347MHELP DB CR,LF,'PCGET VER 1.1',CR,LF,LF
01A1 5553414745 DB 'USAGE: PCGET FILE.EXT [B]',CR,LF
01BC 2020202020 DB ' (B SPECIFIES 2SIO PORT B FOR TRANSFER)',CR,LF,'$'
;DONE - CLOSE UP SHOP
XFER$CPLT:
01EC CD2301 CALL ERXIT
01EF 0D0A0A5452 DB 13,10,10,'TRANSFER COMPLETE',13,10,'$'
0206 CD2301 ABORT: CALL ERXIT
0209 0D0A0A5452 DB 13,10,10,'TRANSFER ABORTED',13,10,'$'
021F DS 40 ;STACK AREA
0247 STACK DS 2 ;STACK POINTER
0249 RSECTNO DS 1 ;RECEIVED SECTOR NUMBER
024A SECTNO DS 1 ;CURRENT SECTOR NUMBER
024B FPORTB DS 1 ;FLAG TO USE 2SIO PORT B INSTEAD OF A
; BDOS EQUATES (VERSION 2)
0001 = RDCON EQU 1
0002 = WRCON EQU 2
0009 = PRINT EQU 9
000B = CONST EQU 11 ;CONSOLE STAT
000F = OPEN EQU 15 ;0FFH=NOT FOUND
0010 = CLOSE EQU 16 ; " "
0011 = SRCHF EQU 17 ; " "
0012 = SRCHN EQU 18 ; " "
0013 = ERASE EQU 19 ;NO RET CODE
0014 = READ EQU 20 ;0=OK, 1=EOF
0015 = WRITE EQU 21 ;0=OK, 1=ERR, 2=?, 0FFH=NO DIR SPC
0016 = MAKE EQU 22 ;0FFH=BAD
0017 = REN EQU 23 ;0FFH=BAD
001A = STDMA EQU 26
0005 = BDOS EQU 5
0000 = REIPL EQU 0
005C = FCB EQU 5CH ;DEFAULT FCB
005D = PARAM1 EQU FCB+1 ;COMMAND LINE PARAMETER 1 IN FCB
006D = PARAM2 EQU PARAM1+16 ;COMMAND LINE PARAMETER 2
024C END
You can also see the SIO initialization that is the pertinent pieces taken from the original PCGET.ASM.
You can also see that I have not fully stripped out a bunch of stuff left over from PCGET.ASM. That cleanup was to come later when I start to fill in whatever I come up with next.
None of this is a big deal, but it does not work!
When I have my two laptops hooked up, the console operates like it is supposed to, showing the LISTENING ON CONSOLE PORT, SENDING TO PORT B... message after I execute the program, then not showing any other keystrokes because they're being sent off to port B. Except, nothing shows up on my other laptop computer running Hyperterminal. When I type CTRL-C on the console, I properly get the TRANSFER ABORTED message, and the console returns to CP/M.
So, what's wrong with this picture? I am using tried and true cables, and both laptop computers function properly if I use them as my console device, so I am left wondering about my code. Can anyone take a look at the code and tell me if I have some obvious error? I do not have experience using an Altair 2-SIO board before. All my SIO experience is with more programmable devices such as the 8251 or the Z85C30 chip used on the SIO board from http://www.s100computers.com.
Thanks, in advance, for any suggestions that you may be able to make.
smp
