Hello all,
I am having a blast playing with my Altair Clone in CP/M.
I have a couple of fun programs that I like to play with whenever I am playing on a new system or playing around with a new programming language. Here's the first one - it figures out how many ways to make US $1.00 from change. This code is for MBASIC on CP/M:
100 REM HOW MANY WAYS TO MAKE $1.00 FROM CHANGE
110 REM
199 C=0
200 FOR P=0 TO 100 STEP 5
210 FOR N=0 TO 20
220 FOR D=0 TO 10
230 FOR Q=0 TO 4
240 IF (P+(N*5)+(D*10)+(Q*25))=100 THEN PRINT P;"PENNIES ";N;"NICKELS ";D;"DIMES ";Q;"QUARTERS" : C=C+1
250 NEXT Q
260 NEXT D
270 NEXT N
280 NEXT P
300 PRINT : PRINT C;"WAYS TO MAKE A DOLLAR FROM CHANGE"
310 END
So give it a try. It's fun to see how long different machines and different languages take to get this done. You can see that I cheated a little bit by putting in a "step 5" in the loop for pennies to shorten up the time a little bit.
What fun programs are you folks playing around with? Maybe you'd like to share one, too?
smp
Fun Programs
Re: Fun Programs
Hi again,
I was wandering around the Internet recently, and I came across a blog where the fellow was also playing around with MBASIC.
http://jefftranter.blogspot.com/2014/03 ... n-cpm.html
Here's a memory dump program that he devised, and I modified a little so it would not simply go on forever:
100 REM Dump memory in hex and ASCII
110 REM
110 A = &H100 : REM Start of transient program area in CP/M
115 L = 0 : REM Line counter
120 A$ = "000" + HEX$(A)
130 A$ = RIGHT$(A$,4)
140 PRINT A$;": ";
150 FOR I = 0 TO 15
160 S$ = "0" +HEX$(PEEK(A+I))
170 S$ = RIGHT$(S$,2)
180 PRINT S$;" ";
190 NEXT I
200 FOR I = 0 TO 15
210 IF PEEK(A+I) >= 32 AND PEEK(A+I) <= 126 THEN PRINT CHR$(PEEK(A+I)); ELSE PRINT".";
220 NEXT I
230 PRINT
233 L = L+1 : REM Increment the line counter
235 IF L>63 GOTO 300 : REM Arbitrary stop after 64 lines of 16 bytes output
240 A = A+16
250 GOTO 120
300 END
This could be a good program to keep in a "toolbox" of programs for looking into what's going on inside the system.
I am looking forward to see what other folks come up with.
smp
110 REM
140 PRINT A$;": ";
150 FOR I = 0 TO 15
180 PRINT S$;" ";
190 NEXT I
200 FOR I = 0 TO 15
220 NEXT I
230 PRINT
240 A = A+16
250 GOTO 120
300 END
smp
Re: Fun Programs
Went through old copies of Computer Notes this weekend and found a demonstration program
with reference to HAL from the movie 50 years ago. Made a few changes so I did not feel
upper cased all over the place.
By having New and Clear a few lines above the top of your source code mbasic will use them as commands before
your code is pasted into your clone.
Kinda nostalgic.
new
clear
10 CLEAR
20 REM From Computer Notes November 1976 Page 5. Revised to include input
15 REM subroutines, Longer variable names, Flexable U/L case,
17 REM Better Random seeding, 2K larger in size.
30 PRINT TAB(10) "Hi! I'm a 70's computer. my name is HAL. what's yours?"
40 INPUT "(type your name and hit the return key)";YOURNAME$
50 PRINT TAB(10) "Well ";YOURNAME$;" a computer can do a lot of things. For instance, I"
60 PRINT TAB(10) "am a super calculator. Let's try an easy one first."
70 REM ----------------- LETTER COUNTING ----------------------
80 PRINT TAB(10) "Would you like to ADD, SUBTRACT, MULTIPLY, DIVIDE or find"
90 PRINT TAB(10) "a SQUARE or SQUARE ROOT?"
100 INPUT "(type your choice and hit return)"; MATHCHOICE$
110 PASSSTRING$ = MATHCHOICE$
120 GOSUB 960
130 MATHCHOICE$ = PASSSTRING$
140 IF LEFT$(MATHCHOICE$,1) = "D" THEN 220
150 IF LEFT$(MATHCHOICE$,1) = "M" THEN 260
160 IF LEFT$(MATHCHOICE$,1) = "A" THEN 300
170 IF MATHCHOICE$="SUBTRACT" THEN 330
180 IF MATHCHOICE$="SQUARE ROOT" THEN 360
190 IF MATHCHOICE$="SQUARE" THEN 380
200 PRINT TAB(10) "I'm sorry. I don't understand ";MATHCHOICE$;". Please try again" : GOTO 80
210 REM DIVIDE
220 PRINT "First the Numerator you are dividing."
230 PRINT "Not over 16 digits, please"; : INPUT A#
240 INPUT "Now the Denominator (divisor)"; B# : C#=A#/B# : GOSUB 820
250 REM MULTIPLY
260 INPUT "The first number to multiply (not over 16 digits)"; A#
270 REM SQUARE
280 INPUT "The second"; B# : C#=A#*B# : GOSUB 820
290 REM ADD
300 INPUT "The first number to Add (not over 16 digits)"; A#
310 INPUT "The second"; B# : C#=A#+B# : GOSUB 820
320 REM SUBTRACT
330 INPUT "The number you are subtracting from (not over 16 digits)"; A#
340 INPUT "The number you are subtracting"; B# : C#=A#-B# : GOSUB 820
350 REM SQUARE ROOT
360 INPUT "The number you wish to find the square root of";A#
370 C#=SQR(A#) : GOSUB 820
380 INPUT "The number you wish to square";A#
390 C#=A#*A# : GOSUB 820
400 REM --------------- LETTER COUNTING ----------------------
410 PRINT TAB(10) "Had enough arithmetic ";YOURNAME$;" Huh? of course i can do more"
420 PRINT TAB(10) "complicated math too. But enough of that. Tell you what."
430 PRINT "Type me a sentence now:" : LETTERCOUNT=0
440 LINE INPUT SENTENCE$
450 PASSSTRING$ = SENTENCE$
460 GOSUB 900
470 PRINT TAB(10) "Now I'll tell you how many there"
480 PRINT TAB(10) "are of any letter in your sentence."
490 INPUT "What letter should I count";SEARCHLETTER$
500 IF LEN(SEARCHLETTER$)>1 THEN PRINT "Only one character please." : GOTO 490
510 IF SEARCHLETTER$=>"A" AND SEARCHLETTER$<="Z" THEN SEARCHLETTER$ = CHR$(ASC(SEARCHLETTER$) + 32)
520 IF SEARCHLETTER$=>"a" AND SEARCHLETTER$<="z" THEN 540
530 PRINT TAB(10) "Please, a letter." : GOTO 490
540 FOR INDEXCOUNT%=1 TO LEN(SENTENCE$) : IF MID$(PASSSTRING$,INDEXCOUNT%,1)=SEA
RCHLETTER$ THEN LETTERCOUNT=LETTERCOUNT+1
550 NEXT INDEXCOUNT%
560 PRINT TAB(10) "There are";LETTERCOUNT;SEARCHLETTER$;"'s in your sentence:"
570 PRINT TAB(10) SENTENCE$
580 REM ------------------NUMBER GUESING ---------------------
590 PRINT TAB(10) "How bout them apples? Now let's play a simple number"
600 PRINT TAB(10) "guessing game. I'll choose a number between 1 and 100."
610 PRINT TAB(10) "You tell me what you think it is. I'll tell you if"
620 PRINT TAB(10) "you are too high, too low or correct."
630 RANDOMIZE LEN(SENTENCE$)
640 A=INT(99*RND(1)+1) : GUESSES=0
650 PRINT TAB(10) "OK, I've got a number."
660 INPUT "Your guess"; B
670 IF B>A THEN PRINT TAB(10) "Too high" : GUESSES=GUESSES+1 : GOTO 660
680 IF B<A THEN PRINT TAB(10) "Too low" : GUESSES=GUESSES+1 : GOTO 660
690 PRINT TAB(10) "You guessed it - in ";GUESSES;" tries!"
700 INPUT "Try again";YESNOANSWER$
710 GOSUB 790
720 IF LEFT$(YESNOANSWER$,1) = "y" THEN 640
730 IF LEFT$(YESNOANSWER$,1) = "n" THEN 750
740 PRINT TAB(10) "Sorry, i don't understand ";YESNOANSWER$;". please use YES or NO." : GOTO 700
750 PRINT TAB(10) "Now wasn't that marvelous ";YOURNAME$;"? and so ends"
760 PRINT TAB(10) "the demonstration. Good bye my friend." : END
770 REM ------ Subroutines ------
780 REM Yes No answer. Convert first character to lower case
790 YESNOANSWER$ = LEFT$(YESNOANSWER$,1)
800 IF YESNOANSWER$=>"A" AND YESNOANSWER$<="Z" THEN YESNOANSWER$ = CHR$(ASC(YESNOANSWER$) + 32)
810 RETURN
820 REM Full Math answer and continue
830 PRINT TAB(10) "The answer is: ";C#
840 INPUT "Try another calculation (YES or NO)"; YESNOANSWER$
850 GOSUB 790
860 IF LEFT$(YESNOANSWER$,1) = "y" THEN 80
870 IF LEFT$(YESNOANSWER$,1) = "n" THEN 410
880 PRINT TAB(10) "I'm sorry I don't understand "YESNOANSWER$;". Please use YES or NO." : GOTO 840
890 RETURN
900 REM Case Conveter to all lower
910 FOR X%=1 TO LEN(PASSSTRING$)
920 TEMP$=MID$(PASSSTRING$,X%,1)
930 IF TEMP$=>"A" AND TEMP$<="Z" THEN MID$(PASSSTRING$,X%) = CHR$(ASC(TEMP$) + 32)
940 NEXT X%
950 RETURN
960 REM Case Conveter to all UPPER
970 FOR X%=1 TO LEN(PASSSTRING$)
980 TEMP$=MID$(PASSSTRING$,X%,1)
990 IF TEMP$=>"a" AND TEMP$<="z" THEN MID$(PASSSTRING$,X%) = CHR$(ASC(TEMP$) - 32)
1000 NEXT X%
1010 RETURN
Kinda nostalgic.
Users browsing this forum: Ahrefs [Bot] and 15 guests
