More fun with my 8800C
This is a port of a program I wrote some years back on my Tandy COCO 3 to try out working with stacks.
It implements an RPN (Reverse Polish Notation) scientific calculator. All through university I used HP RPN calculators and to me it's the most natural way to do long complex calculations. I actually use it quite a bit. Anytime I'm doing calculations for some electronics project, it up and ready to work for me.
I imagined that implementing it in BASIC-80 with it's double precision FP would give me a better calculator, however the value for "e" is wrong in BASIC-80 so natural logarithms are calculated incorrectly. Some day I may write a fix for this, but here it is for y'all to play around with in the meantime. Requires an ANSI compatible terminal for cursor placement and screen management as written.
10 REM RPN CALCULATOR
20 REM PORTED AND UPDATED FROM A PROGRAM I WROTE FOR THE TRS-80 COCO 3
30 REM REQUIRES AN ANSI COMPLIANT TERMINAL FOR CURSOR PLACEMENT
40 REM 2022/05/19
50 REM
60 REM *** DEFINE CONTANTS ***
70 SV%=11
80 SV%=10
90 ES%=23
100 SH$="6"
110 PV$="8"
120 PH$="4"
130 EV$=RIGHT$(STR$(SV%),2)
140 EH$="30"
150 N%=ES%-SV%
160 REM
170 REM *** INITIALIZE VARS AND ARRAYS ***
180 REM
190 I%=0
200 DIM ST#(256)
210 REM
220 REM *** PAINT INITIAL SCREEN ***
230 REM
240 PRINT CHR$(27)+"[2J";:PRINT CHR$(27)+"[0;0H";
250 PRINT "AVAILABLE OPERATIONS                              | AVAILABLE COMMANDS"
260 PRINT "  +       %               LN (NATUAL LOG)   SIN   |   CL (CLEAR STACK)"
270 PRINT "  -       P (EXPONENT)    LOG               COS   |   PT (POP TOP OF STACK)"
280 PRINT "  *       EX (NAT EXP)    ! (FACTORIAL)     TAN   |"
290 PRINT "  /       S (SQR ROOT)    N (NEGATE)              |   ZZ  (QUIT)"
300 REM
310 REM *** TOKEN INPUT LOOP ***
320 REM
330 OP$="N"
340 PRINT CHR$(27)+"["+PV$+";"+PH$+"H";:PRINT "                   ";
350 PRINT CHR$(27)+"["+PV$+";"+PH$+"H";:INPUT A$
360 IF A$="CL" THEN GOSUB 1050:GOTO 570
370 IF A$="PT" THEN GOSUB 1040:GOTO 570
380 IF A$="+" THEN GOSUB 620
390 IF A$="-" THEN GOSUB 640
400 IF A$="*" THEN GOSUB 660
410 IF A$="/" THEN GOSUB 680
420 IF A$="P" THEN GOSUB 710
430 IF A$="%" THEN GOSUB 730
440 IF A$="EX" THEN GOSUB 760
450 IF A$="COS" THEN GOSUB 790
460 IF A$="SIN" THEN GOSUB 840
470 IF A$="S" THEN GOSUB 810
480 IF A$="TAN" THEN GOSUB 860
490 IF A$="!" THEN GOSUB 880
500 IF A$="LN" THEN GOSUB 920
510 IF A$="LOG" THEN GOSUB 950
520 IF A$="N" THEN ST#(I%)=-ST#(I%):OP$="Y"
530 IF A$="E" THEN A#=EXP(1):GOSUB 1010:OP$="Y"
540 IF A$="PI" THEN A#=3.141592653589794#:GOSUB 1010:OP$="Y"
550 IF A$="ZZ" THEN PRINT CHR$(27)+"[2J";:PRINT CHR$(27)+"[0;0H";:END
560 IF OP$="N" THEN A#=VAL(A$):GOSUB 1010
570 GOSUB 1200
580 GOTO 330
590 REM
600 REM *** FUNCTION AND OPERATION IMPLEMENTATION ***
610 REM
620 IF I%<2 THEN GOTO 1100
630 R#=ST#(I%-1)+ST#(I%):GOTO 1020
640 IF I%<2 THEN GOTO 1100
650 R#=ST#(I%-1)-ST#(I%):GOTO 1020
660 IF I%<2 THEN GOTO 1100
670 R#=ST#(I%-1)*ST#(I%):GOTO 1020
680 IF I%<2 THEN GOTO 1100
690 IF ST#(I%)=0 THEN GOTO 1130
700 R#=ST#(I%-1)/ST#(I%):GOTO 1020
710 IF I%<2 THEN GOTO 1100
720 R#=ST#(I%-1)^ST#(I%):GOTO 1020
730 IF I%<2 THEN GOTO 1100
740 IF ST#(I%)=0 THEN GOTO 1130
750 R#=ST#(I%-1)/(ST#(I%)/100):GOTO 1020
760 IF I%<1 THEN GOTO 1100
770 IF ST#(I%)>87.3365 THEN GOTO 1130
780 R#=EXP(ST#(I%)):GOTO 1030
790 IF I%<1 THEN GOTO 1100
800 R#=COS(ST#(I%)):GOTO 1030
810 IF I%<1 THEN GOTO 1100
820 IF ST#(I%)<0 THEN GOTO 1130
830 R#=SQR(ST#(I%)):GOTO 1030
840 IF I%<1 THEN GOTO 1100
850 R#=SIN(ST#(I%)):GOTO 1030
860 IF I%<1 THEN GOTO 1100
870 R#=TAN(ST#(I%)):GOTO 1030
880 IF I%<1 THEN GOTO 1100
890 IF ST#(I%)-ABS(INT(ST#(I%)))<>0 THEN GOTO 1110
900 IF ST#(I%)>33 THEN GOTO 1120
910 R#=1:FOR Q%=1 TO ST#(I%):R#=R#*Q%:NEXT Q%:GOTO 1030
920 IF I%<1 THEN GOTO 1100
930 IF ST#(I%)<0 THEN GOTO 1130
940 R#=LOG(ST#(I%)):GOTO 1030
950 IF I%<1 THEN GOTO 1100
960 IF ST#(I%)<0 THEN GOTO 1130
970 R#=LOG(ST#(I%))/LOG(10):GOTO 1030
980 REM
990 REM *** STACK MANIPULATION ***
1000 REM
1010 I%=I%+1:ST#(I%)=A#:RETURN
1020 I%=I%-1
1030 ST#(I%)=R#:GOTO 1060
1040 ST#(I%)=0:IF I%>0 THEN I%=I%-1:GOTO 1060
1050 FOR I%=256 TO 0 STEP -1:ST#(I%)=0:NEXT I%:I%=0
1060 OP$="Y":RETURN
1070 REM
1080 REM *** ERROR HANDLING ***
1090 REM
1100 MS$="INSUFFICISNT VALUES ON STACK FOR OPERATION":GOTO 1140
1110 MS$="OPERAND MUST BE A POSITIVE INTEGER":GOTO 1140
1120 MS$="OPERAND TOO LARGE":GOTO 1140
1130 MS$=STR$(ST#(I%))+" IS NOT A VALID OPERAND"
1140 PRINT CHR$(27)+"["+EV$+";"+EH$+"H";:PRINT MS$:GOSUB 1270
1150 PRINT CHR$(27)+"["+EV$+";"+EH$+"H";:PRINT "                                                           ";
1160 OP$="Y":RETURN
1170 REM
1180 REM *** SCREEN MANAGEMENT ***
1190 REM
1200 PRINT CHR$(27)+"["+RIGHT$(STR$(SV%),2)+";"+SH$+"H";:PRINT CHR$(27)+"[J";
1210 K%=SV%-1:M%=1:IF I%>N% THEN M%=I%-N%
1220 IF I%>0 THEN FOR J%=I% TO M% STEP -1:K%=K%+1:K$=RIGHT$(STR$(K%),2):PRINT CHR$(27)+"["+K$+";"+SH$+"H";:PRINT ST#(J%):NEXT J%
1230 RETURN
1240 REM
1250 REM *** TIMERS ***
1260 REM
1270 FOR T=0 TO 1500:NEXT T:RETURN
Edit: I should also mention that if you enter "E" you'll get (the wrong) value for e (the base of the natural log), if you enter "PI" you get the value of PI and if you enter anything other than a listed operation, command, constant (E or PI) or a number you will get zero. It actually really surprises me that Microsoft did not catch the bad value for e. Neither did the rest of the world as I can find no reference to it being bad. I saw it immediately. Go figure.
Re: More fun with my 8800C
Fixed a couple of bugs. The code above has ben corrected. Below are the corrected lines.
and
Users browsing this forum: No registered users and 7 guests
