Just starting an 8800c build - 9 slot motherboard questions
I noticed in Mike's video he mentions not making the motherboard active, but leaving it passive. What components should be loaded on the board then? Power connector? Fuses? Any capacitors?
Re: Just starting an 8800c build - 9 slot motherboard questi
I have just the power connectors (and S-100 sockets, of course!) on mine. Nothing else. It's been working fine with eight boards on it for a couple years now.alank2 wrote:I noticed in Mike's video he mentions not making the motherboard active, but leaving it passive. What components should be loaded on the board then? Power connector? Fuses? Any capacitors?
Altair 8800 CPU board
Mike's FP interface board
FDC+ board (64K RAM and floppy interface)
Altair 88-UIO board with serial and cassette interface
Altair 88-VI RTC interrupt/RTC board
Altair 88-C700 printer interface board
Two 88-2SIOJP serial boards
Yes, Tom is correct, only S-100 connectors and the power connector. You can jumper across the fuse locations since your switching supplies will protect themselves and the downstream circuits.
