8800c Mainboard problem
I have the 9-slot mainboard suggested in the Altair 8800c docs. I've finally gotten enough time to try to finish it. I wired up the power supplies (also the ones suggested) and when I flip the Front Panel switch ON, I get the correct three voltages at the female connector to the mainboard (I adjusted the power supplies to +8, +16 and -16v). Before I plug any cards in, I like to check to see if the proper voltages are present at the correct S-100 connector pins. Well, they're not. I get no readings from any pin at all. If I connect the DVM to pin 1 and 50, shouldn't I measure +8V? I only installed the S-100 connectors on the mainboard and none of the active termination components. Do I have to add jumpers or something to bypass the missing components? If so what do I need besides the connectors themselves?
Re: 8800c Mainboard problem Mea Culpa
I was in such a hurry, that I forgot to add the three jumpers in F4, 5 and 6. Of course there'd be no voltages on the bus. Adding the jumpers fixed it.
Users browsing this forum: No registered users and 38 guests
