...and if ckFlsh runs, then shouldn’t it have deselected the drive - even if a flush wasn’t required?
Absolutely. But the problem for me now is that - where I have the call - it happens only after a person presses a key. It isn't in the same position in the flow as yours is, and so I need to change that. In my code - since the 'conin' and 'in$scan' functions are in the BIOSKRNL.asm module, I didn't want to modify it to put the 'ckFlush' function immediately after entry from the BIOS jump table. That's really where we want to put 'ckFlush' but to do that means we modify the invariant BIOSKRNL module. That would certainly be the easiest thing to do, and I may ultimately do that. But for now, I'm going to look for another solution that leaves BIOSKRNL unmodified, if I can. I'll work on it some more next week.
In the meantime, I'm just stoked that it works!
...I moved the ckFlush call out of CI and into CIST, both in CHARIO3.asm. That solved it! So that allows me to leave BIOSKRNL.asm as the unmodified Digital Research file.
Still piddling with a few things, mostly testing, but very nearly done. I do want to live with it for a while before calling it boxed up and ready to go.
I've tested the system for a few evenings now and I'm pretty comfortable with it.
- The IDE sector count is right, in that each track starts on sector 00 and ends on sector 3F. Watched it with the SID debugger and confirmed it with IDEutil.
- The diskette flushing mechanism works as designed, running ckFlush in the CIST function.
So I'm creating a disk image and will post a link for that soon. Still kind of messing around with GENCPM to find the best compromise between data/directory buffers and available TPA. But in the meantime, here are the source modules:
BIOSKRN3.asm:
	title	'ROOT BIOS MODULE FOR CP/M 3.0'
	; version 1.0 15 Sept 82
true	equ -1
false	equ not true
banked	equ FALSE				;<------ BANKED Version
;		  Copyright (C), 1982
;		 Digital Research, Inc
;		     P.O. Box 579
;		Pacific Grove, CA  93950
;   This is the invariant portion of the modular BIOS and is
;	distributed as source for informational purposes only.
;	All desired modifications should be performed by
;	adding or changing externally defined modules.
;	This allows producing "standard" I/O modules that
;	can be combined to support a particular system
;	configuration.
cr	equ 13
lf	equ 10
bell	equ 7
ctlQ	equ 'Q'-'@'
ctlS	equ 'S'-'@'
ccp	equ 0100h	; Console Command Processor gets loaded into the TPA
	cseg		; GENCPM puts CSEG stuff in common memory
    ; variables in system data page
	extrn @covec,@civec,@aovec,@aivec,@lovec ; I/O redirection vectors
	extrn @mxtpa				; addr of system entry point
	extrn @bnkbf				; 128 byte scratch buffer
    ; initialization
	extrn ?init			; general initialization and signon
	extrn ?ldccp,?rlccp		; load & reload CCP for BOOT & WBOOT
    ; user defined character I/O routines
	extrn ?ci,?co,?cist,?cost	; each take device in <B>
	extrn ?cinit			; (re)initialize device in <C>
	extrn @ctbl			; physical character device table
    ; disk communication data items
	extrn @dtbl			; table of pointers to XDPHs
	public @adrv,@rdrv,@trk,@sect	; parameters for disk I/O
	public @dma,@dbnk,@cnt		;    ''       ''   ''  ''
    ; memory control
	public @cbnk			; current bank
	extrn ?xmove,?move		; select move bank, and block move
	extrn ?bank			; select CPU bank
    ; clock support
	extrn ?time			; signal time operation
    ; general utility routines
	public ?pmsg,?pdec	; print message, print number from 0 to 65535
	public ?pderr		; print BIOS disk error message header
	maclib modebaud		; define mode bits
    ; External names for BIOS entry points
	public ?boot,?wboot,?const,?conin,?cono,?list,?auxo,?auxi
	public ?home,?sldsk,?sttrk,?stsec,?stdma,?read,?write
	public ?lists,?sctrn
	public ?conos,?auxis,?auxos,?dvtbl,?devin,?drtbl
	public ?mltio,?flush,?mov,?tim,?bnksl,?stbnk,?xmov
    ; BIOS Jump vector.
		; All BIOS routines are invoked by calling these
		;	entry points.
?boot:	jmp boot	; initial entry on cold start
?wboot:	jmp wboot	; reentry on program exit, warm start
?const:	jmp const	; return console input status
?conin:	jmp conin	; return console input character
?cono:	jmp conout	; send console output character
?list:	jmp list	; send list output character
?auxo:	jmp auxout	; send auxilliary output character
?auxi:	jmp auxin	; return auxilliary input character
?home:	jmp home	; set disks to logical home
?sldsk:	jmp seldsk	; select disk drive, return disk parameter info
?sttrk:	jmp settrk	; set disk track
?stsec:	jmp setsec	; set disk sector
?stdma:	jmp setdma	; set disk I/O memory address
?read:	jmp read	; read physical block(s)
?write:	jmp write	; write physical block(s)
?lists:	jmp listst	; return list device status
?sctrn:	jmp sectrn	; translate logical to physical sector
?conos:	jmp conost	; return console output status
?auxis:	jmp auxist	; return aux input status
?auxos:	jmp auxost	; return aux output status
?dvtbl:	jmp devtbl	; return address of device def table
?devin:	jmp ?cinit	; change baud rate of device
?drtbl:	jmp getdrv	; return address of disk drive table
?mltio:	jmp multio	; set multiple record count for disk I/O
?flush:	jmp flush	; flush BIOS maintained disk caching
?mov:	jmp ?move	; block move memory to memory
?tim:	jmp ?time	; Signal Time and Date operation
?bnksl:	jmp bnksel	; select bank for code execution and default DMA
?stbnk:	jmp setbnk	; select different bank for disk I/O DMA operations.
?xmov:	jmp ?xmove	; set source and destination banks for one operation
	jmp 0		; reserved for future expansion
	; BOOT
	;	Initial entry point for system startup.
	dseg	; this part can be banked
boot:
	lxi sp,boot$stack
	mvi c,15	; initialize all 16 character devices
c$init$loop:
	push b ! call ?cinit ! pop b
	dcr c ! jp c$init$loop
	call ?init	; perform any additional system initialization
			; and print signon message
	lxi b,16*256+0 ! lxi h,@dtbl	; init all 16 logical disk drives
d$init$loop:
	push b		; save remaining count and abs drive
	mov e,m ! inx h ! mov d,m ! inx h	; grab @drv entry
	mov a,e ! ora d ! jz d$init$next	; if null, no drive
	push h					; save @drv pointer
	xchg					; XDPH address in <HL>
	dcx h ! dcx h ! mov a,m ! sta @RDRV	; get relative drive code
	mov a,c ! sta @ADRV			; get absolute drive code
	dcx h					; point to init pointer
	mov d,m ! dcx h ! mov e,m		; get init pointer
	xchg ! call ipchl			; call init routine
	pop h					; recover @drv pointer
d$init$next:
	pop b					; recover counter and drive #
	inr c ! dcr b ! jnz d$init$loop		; and loop for each drive
	jmp boot$1
	cseg	; following in resident memory
boot$1:
	call set$jumps
	call ?ldccp				; fetch CCP for first time
	jmp ccp
	; WBOOT
	;	Entry for system restarts.
wboot:
	lxi sp,boot$stack
	call set$jumps		; initialize page zero
	call ?rlccp		; reload CCP
	jmp ccp			; then reset jmp vectors and exit to ccp
set$jumps:
  if banked
	mvi a,1 ! call ?bnksl
  endif
	mvi a,JMP
	sta 0 ! sta 5		; set up jumps in page zero
	lxi h,?wboot ! shld 1	; BIOS warm start entry
	lhld @MXTPA ! shld 6	; BDOS system call entry
	ret
		ds 64
boot$stack	equ $
	; DEVTBL
	;	Return address of character device table
devtbl:
	lxi h,@ctbl ! ret
	; GETDRV
	;	Return address of drive table
getdrv:
	lxi h,@dtbl ! ret
	; CONOUT
	;	Console Output.  Send character in <C>
	;			to all selected devices
conout:
	lhld @covec	; fetch console output bit vector
	jmp out$scan
	; AUXOUT
	;	Auxiliary Output. Send character in <C>
auxout:
	lhld @aovec	; fetch aux output bit vector
	jmp out$scan
	; LIST
	;	List Output.  Send character in <C>
	;			to all selected devices.
list:
	lhld @lovec	; fetch list output bit vector
out$scan:
	mvi b,0		; start with device 0
co$next:
	dad h		; shift out next bit
	jnc not$out$device
	push h		; save the vector
	push b		; save the count and character
not$out$ready:
	call coster ! ora a ! jz not$out$ready
	pop b ! push b	; restore and resave the character and device
	call ?co	; if device selected, print it
	pop b		; recover count and character
	pop h		; recover the rest of the vector
not$out$device:
	inr b		; next device number
	mov a,h ! ora l	; see if any devices left
	jnz co$next	; and go find them...
	ret
	; CONOST
	;	Console Output Status.  Return true if
	;		all selected console output devices
	;		are ready.
conost:
	lhld @covec	; get console output bit vector
	jmp ost$scan
	; AUXOST
	;	Auxiliary Output Status.  Return true if
	;		all selected auxiliary output devices
	;		are ready.
auxost:
	lhld @aovec	; get aux output bit vector
	jmp ost$scan
	; LISTST
	;	List Output Status.  Return true if
	;		all selected list output devices
	;		are ready.
listst:
	lhld @lovec	; get list output bit vector
ost$scan:
cos$next:
	dad h		; check next bit
	mvi a,0FFh	; assume device ready
	cc coster	; check status for this device
	pop h		; recover bit vector
	ora a		; see if device ready
	rz		; if any not ready, return false
	inr b		; drop device number
	mov a,h ! ora l	; see if any more selected devices
	jnz cos$next
	ori 0FFh	; all selected were ready, return true
	ret
coster:		; check for output device ready, including optional
		;	xon/xoff support
	mov l,b ! mvi h,0	; make device code 16 bits
	push h			; save it in stack
	dad h ! dad h ! dad h	; create offset into device characteristics tbl
	lxi d,@ctbl+6 ! dad d	; make address of mode byte
	mov a,m ! ani mb$xonxoff
	pop h			; recover console number in <HL>
	jz ?cost		; not a xon device, go get output status direct
	lxi d,xofflist ! dad d	; make pointer to proper xon/xoff flag
	call cist1		; see if this keyboard has character
	mov a,m ! cnz ci1	; get flag or read key if any
	cpi ctlq ! jnz not$q	; if its a ctl-Q,
	mvi a,0FFh 		;	set the flag ready
not$q:
	cpi ctls ! jnz not$s	; if its a ctl-S,
	mvi a,00h		;	clear the flag
not$s:
	mov m,a			; save the flag
	call cost1		; get the actual output status,
	ana m			; and mask with ctl-Q/ctl-S flag
	ret			; return this as the status
cist1:			; get input status with <BC> and <HL> saved
	push b ! push h
	call ?cist
	pop h ! pop b
	ora a
	ret
cost1:			; get output status, saving <BC> & <HL>
	push b ! push h
	call ?cost
	pop h ! pop b
	ora a
	ret
ci1:			; get input, saving <BC> & <HL>
	push b ! push h
	call ?ci
	pop h ! pop b
	ret
	; CONST
	;	Console Input Status.  Return true if
	;		any selected console input device
	;		has an available character.
const:
	lhld @civec	; get console input bit vector
	jmp ist$scan
	; AUXIST
	;	Auxiliary Input Status.  Return true if
	;		any selected auxiliary input device
auxist:
	lhld @aivec	; get aux input bit vector
ist$scan:
cis$next:
	mvi a,0		; assume device not ready
	cc cist1	; check status for this device
	ora a ! rnz	; if any ready, return true
	jnz cis$next
	xra a		; all selected were not ready, return false
	ret
	; CONIN
	;	Console Input.  Return character from first
	;		ready console input device.
conin:
	lhld @civec
	jmp in$scan
	; AUXIN
	;	Auxiliary Input.  Return character from first
	;		ready auxiliary input device.
auxin:
	lhld @aivec
in$scan:
	push h		; save bit vector
	mvi b,0
ci$next:
	mvi a,0		; insure zero a  (nonexistant device not ready).
	cc cist1	; see if the device has a character
	ora a
	jnz ci$rdy	; this device has a character
	inr b		; else, next device
	mov a,h ! ora l	; see if any more devices
	jnz ci$next	; go look at them
	jmp in$scan	; loop til we find a character
ci$rdy:
	pop h		; discard extra stack
	jmp ?ci
;	Utility Subroutines
ipchl:		; vectored CALL point
	pchl
?pmsg:		; print message @<HL> up to a null
		; saves <BC> & <DE>
	push b
	push d
pmsg$loop:
	mov a,m ! ora a ! jz pmsg$exit
	mov c,a ! push h
	call ?cono ! pop h
	inx h ! jmp pmsg$loop
pmsg$exit:
	pop d
	pop b
	ret
?pdec:		; print binary number 0-65535 from <HL>
	lxi b,table10! lxi d,-10000
next:
	mvi a,'0'-1
pdecl:
	push h! inr a! dad d! jnc stoploop
	inx sp! inx sp! jmp pdecl
stoploop:
	push d! push b
	mov c,a! call ?cono
	pop b! pop d
nextdigit:
	pop h
	ldax b! mov e,a! inx b
	ldax b! mov d,a! inx b
	mov a,e! ora d! jnz next
	ret
table10:
	dw	-1000,-100,-10,-1,0
?pderr:
	lxi h,drive$msg ! call ?pmsg			; error header
	lda @adrv ! adi 'A' ! mov c,a ! call ?cono	; drive code
	lxi h,track$msg ! call ?pmsg			; track header
	lhld @trk ! call ?pdec				; track number
	lxi h,sector$msg ! call ?pmsg			; sector header
	lhld @sect ! call ?pdec				; sector number
	ret
	; BNKSEL
	;	Bank Select.  Select CPU bank for further execution.
bnksel:
	sta @cbnk 			; remember current bank
	jmp ?bank			; and go exit through users
					; physical bank select routine
xofflist	db	-1,-1,-1,-1,-1,-1,-1,-1		; ctl-s clears to zero
	dseg	; following resides in banked memory
;	Disk I/O interface routines
	; SELDSK
	;	Select Disk Drive.  Drive code in <C>.
	;		Invoke login procedure for drive
	;		if this is first select.  Return
	;		address of disk parameter header
	;		in <HL>
seldsk:
	mov a,c ! sta @adrv			; save drive select code
	mov l,c ! mvi h,0 ! dad h		; create index from drive code
	lxi b,@dtbl ! dad b			; get pointer to dispatch table
	mov a,m ! inx h ! mov h,m ! mov l,a	; point at disk descriptor
	ora h ! rz 				; if no entry in table, no disk
	mov a,e ! ani 1 ! jnz not$first$select	; examine login bit
	push h ! xchg				; put pointer in stack & <DE>
	lxi h,-2 ! dad d ! mov a,m ! sta @RDRV	; get relative drive
	lxi h,-6 ! dad d			; find LOGIN addr
	mov a,m ! inx h ! mov h,m ! mov l,a	; get address of LOGIN routine
	call ipchl				; call LOGIN
	pop h					; recover DPH pointer
not$first$select:
	ret
	; HOME
	;	Home selected drive.  Treated as SETTRK(0).
home:
	lxi b,0		; same as set track zero
	; SETTRK
	;	Set Track. Saves track address from <BC>
	;		in @TRK for further operations.
settrk:
	mov l,c ! mov h,b
	shld @trk
	ret
	; SETSEC
	;	Set Sector.  Saves sector number from <BC>
	;		in @sect for further operations.
setsec:
	mov l,c ! mov h,b
	shld @sect
	ret
	; SETDMA
	;	Set Disk Memory Address.  Saves DMA address
	;		from <BC> in @DMA and sets @DBNK to @CBNK
	;		so that further disk operations take place
	;		in current bank.
setdma:
	mov l,c ! mov h,b
	shld @dma
	lda @cbnk	; default DMA bank is current bank
			; fall through to set DMA bank
	; SETBNK
	;	Set Disk Memory Bank.  Saves bank number
	;		in @DBNK for future disk data
	;		transfers.
setbnk:
	sta @dbnk
	ret
	; SECTRN
	;	Sector Translate.  Indexes skew table in <DE>
	;		with sector in <BC>.  Returns physical sector
	;		in <HL>.  If no skew table (<DE>=0) then
	;		returns physical=logical.
sectrn:
	mov l,c ! mov h,b
	mov a,d ! ora e ! rz
	xchg ! dad b ! mov l,m ! mvi h,0
	ret
	; READ
	;	Read physical record from currently selected drive.
	;		Finds address of proper read routine from
	;		extended disk parameter header (XDPH).
read:
	lhld @adrv ! mvi h,0 ! dad h	; get drive code and double it
	lxi d,@dtbl ! dad d		; make address of table entry
	mov a,m ! inx h ! mov h,m ! mov l,a	; fetch table entry
	push h				; save address of table
	lxi d,-8 ! dad d		; point to read routine address
	jmp rw$common			; use common code
	; WRITE
	;	Write physical sector from currently selected drive.
	;		Finds address of proper write routine from
write:
	lxi d,-10 ! dad d		; point to write routine address
rw$common:
	mov a,m ! inx h ! mov h,m ! mov l,a	; get address of routine
	pop d				; recover address of table
	dcx d ! dcx d			; point to relative drive
	ldax d ! sta @rdrv		; get relative drive code and post it
	inx d ! inx d			; point to DPH again
	pchl				; leap to driver
	; MULTIO
	;	Set multiple sector count. Saves passed count in
	;		@CNT
multio:
	sta @cnt ! ret
	; FLUSH
	;	BIOS deblocking buffer flush.  Not implemented.
flush:
	xra a ! ret		; return with no error
	; error message components
drive$msg	db	cr,lf,bell,'BIOS Error on ',0
track$msg	db	': T-',0
sector$msg	db	', S-',0
@adrv	ds	1		; currently selected disk drive
@rdrv	ds	1		; controller relative disk drive
@trk	ds	2		; current track number
@sect	ds	2		; current sector number
@dma	ds	2		; current DMA address
@cnt	db	0		; record count for multisector transfer
@dbnk	db	0		; bank for DMA operations
	cseg	; common memory
@cbnk	db	0		; bank for processor operations
	end
SCB3.asm:
	TITLE 'SYSTEM CONTROL BLOCK DEFINITION FOR CP/M 3.0'
	PUBLIC @CIVEC, @COVEC, @AIVEC, @AOVEC, @LOVEC, @BNKBF
	PUBLIC @CRDMA, @CRDSK, @VINFO, @RESEL, @FX, @USRCD
        PUBLIC @MLTIO, @ERMDE, @ERDSK, @MEDIA, @BFLGS
	PUBLIC @DATE, @HOUR, @MIN, @SEC, ?ERJMP, @MXTPA
SCB$BASE EQU    0FE00H          ; BASE OF THE SCB
@CIVEC  EQU     SCB$BASE+22H    ; CONSOLE INPUT REDIRECTION
                                ; VECTOR (WORD, R/W)
@COVEC  EQU     SCB$BASE+24H    ; CONSOLE OUTPUT REDIRECTION
@AIVEC  EQU     SCB$BASE+26H    ; AUXILIARY INPUT REDIRECTION
@AOVEC  EQU     SCB$BASE+28H    ; AUXILIARY OUTPUT REDIRECTION
@LOVEC  EQU     SCB$BASE+2AH    ; LIST OUTPUT REDIRECTION
@BNKBF  EQU     SCB$BASE+35H    ; ADDRESS OF 128 BYTE BUFFER
                                ; FOR BANKED BIOS (WORD, R/O)
@CRDMA  EQU     SCB$BASE+3CH    ; CURRENT DMA ADDRESS
                                ; (WORD, R/O)
@CRDSK  EQU     SCB$BASE+3EH    ; CURRENT DISK (BYTE, R/O)
@VINFO  EQU     SCB$BASE+3FH    ; BDOS VARIABLE "INFO"
                                ; (WORD, R/O)
@RESEL  EQU     SCB$BASE+41H    ; FCB FLAG (BYTE, R/O)
@FX     EQU     SCB$BASE+43H    ; BDOS FUNCTION FOR ERROR
                                ; MESSAGES (BYTE, R/O)
@USRCD  EQU     SCB$BASE+44H    ; CURRENT USER CODE (BYTE, R/O)
@MLTIO	EQU	SCB$BASE+4AH	; CURRENT MULTI-SECTOR COUNT
				; (BYTE,R/W)
@ERMDE  EQU     SCB$BASE+4BH    ; BDOS ERROR MODE (BYTE, R/O)
@ERDSK	EQU	SCB$BASE+51H	; BDOS ERROR DISK (BYTE,R/O)
@MEDIA	EQU	SCB$BASE+54H	; SET BY BIOS TO INDICATE
				; OPEN DOOR (BYTE,R/W)
@BFLGS  EQU     SCB$BASE+57H    ; BDOS MESSAGE SIZE FLAG (BYTE,R/O)
@DATE   EQU     SCB$BASE+58H    ; DATE IN DAYS SINCE 1 JAN 78
                                ; (WORD, R/W)
@HOUR   EQU     SCB$BASE+5AH    ; HOUR IN BCD (BYTE, R/W)
@MIN    EQU     SCB$BASE+5BH    ; MINUTE IN BCD (BYTE, R/W)
@SEC    EQU     SCB$BASE+5CH    ; SECOND IN BCD (BYTE, R/W)
?ERJMP  EQU     SCB$BASE+5FH    ; BDOS ERROR MESSAGE JUMP
                                ; (WORD, R/W)
@MXTPA  EQU     SCB$BASE+62H    ; TOP OF USER TPA
                                ; (ADDRESS AT 6,7)(WORD, R/O)
	END
BOOT3.asm:
	TITLE	'BOOT LOADER MODULE FOR CP/M 3.0'
	; BOOT3.ASM  v.1.0  02/22/2023
	; Written by Wayne Parham  (wayne@parhamdata.com)
	; Four drive support:
	; Drives 0 and 1 are 330Kb diskettes
	; Drives 2 and 3 are 8Mb IDE drives
	; DEFINE LOGICAL VALUES:
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; DETERMINE IF FOR BANK SELECT OR NOT:
BANKED		EQU	FALSE	;<--------------- BANKED VERSION
	; DEFINE PUBLIC LABELS:
	PUBLIC	?INIT,?LDCCP,?RLCCP,?TIME
	PUBLIC	OUT$BLOCKS
	; EXTERNALLY DEFINED ENTRY POINTS AND LABELS:
	EXTRN	?PMSG,?CONIN
	EXTRN	@CIVEC,@COVEC,@AIVEC,@AOVEC,@LOVEC
	EXTRN 	@CBNK,?BNKSL
	IF	BANKED
	EXTRN	BANKBUF		;128 BYTE BUFFER IN MOVE MODULE FOR USE
				; DURING COLD AND WARM BOOTS
	ENDIF
	EXTRN	@SEC,@MIN,@HOUR,@DATE	;FIELDS HOLDING CURRENT TIME AND DATE
	; INCLUDE Z-80 MACROS:
	MACLIB	Z80
	; SOME MISCELLANEOUS EQUATES:
BDOS		EQU	5
CR		EQU	13	;ASCII CARRIAGE RETURN
LF		EQU	10	;ASCII LINEFEED
	; WE CAN DO INITIALIZATION FROM BANKED MEMORY (IF WE HAVE IT):
	IF	BANKED
	DSEG	; INIT DONE FROM BANKED MEMORY
	ELSE
	CSEG	; INIT TO BE DONE FROM COMMON MEMORY
	ENDIF
	;;;;; ?INIT
	; HARDWARE INITIALIZATION OTHER THAN CHARACTER AND DISK I/O:
?INIT:
	; ASSIGN CONSOLE INPUT AND OUTPUT TO CRT:
	LXI	H,8000H		;SIGNIFIES DEVICE 0
	SHLD	@CIVEC		;CONSOLE INPUT VECTOR
	SHLD	@COVEC		;CONSOLE OUTPUT VECTOR
	; ASSIGN PRINTER TO LPT:
	LXI	H,4000H		;SIGNIFIES DEVICE 1
	SHLD	@LOVEC		;LIST OUTPUT VECTOR
	; ASSIGN AUX TO CRT1:
	LXI	H,02000H	;SIGNIFIES DEVICE 2
	SHLD	@AIVEC		;AUXILLIARY INPUT VECTOR
	SHLD	@AOVEC		;AUXILLIARY OUTPUT VECTOR
	; PRINT THE SIGN-ON MESSAGE:
	LXI	H,SIGNON$MSG	;POINT TO IT
	JMP	?PMSG		;AND PRINT IT
	;;;;; OUT$BLOCKS
	; ROUTINE OUTPUTS SPECIFIED # BYTES TO SPECIFIED OUTPUT PORTS:
	IF	BANKED
	CSEG			;WE WANT THIS ROUTINE IN COMMON MEMORY
	ENDIF
OUT$BLOCKS:
	MOV	A,M		;GET A BYTE FROM THE BLOCK
	ORA	A		;END OF OUTPUT BLOCK ?
	RZ			;THEN DONE!!
	MOV	B,A		;ELSE PUT # BYTES TO SEND OUT IN [B]
	INX	H		;POINT TO PORT TO SEND TO
	MOV	C,M		;GET IT TO [C]
	INX	H		;POINT TO 1ST BYTE OF BLOCK TO SEND OUT
	OUTIR			;Z-80 BLOCK OUTPUT
	JR	OUT$BLOCKS
	;;;;; ?LDCCP
	; THIS ROUTINE IS ENTERED TO LOAD THE CCP.COM FILE INTO THE TPA BANK
	;  AT SYSTEM COLD START:
?LDCCP:
	; SET UP THE FCB FOR THE FILE OPERATION:
	XRA	A		;ZERO EXTENT
	STA	CCP$FCB+15
	LXI	H,0		;START AT BEGINNING OF FILE
	SHLD	FCB$NR
	; TRY TO OPEN THE CCP.COM FILE:
	LXI	D,CCP$FCB	;POINT TO FCB
	CALL	OPEN		;ATTEMPT THE OPEN OPERATION
	INR	A		;WAS IT ON THE DISK ?
;	JRNZ	CCP$FOUND	;YES -- GO LOAD IT
	JNZ	CCP$FOUND	;YES -- GO LOAD IT
	; WE ARRIVE HERE WHEN CCP.COM FILE WASN'T FOUND:
	LXI	H,CCP$MSG	;REPORT THE ERROR
	CALL	?PMSG
	CALL	?CONIN		;GET A RESPONSE
	JR	?LDCCP		;AND TRY AGAIN
	; FILE WAS OPENED OK -- READ IT IN:
CCP$FOUND:
	LXI	D,0100H		;LOAD AT BOTTOM OF TPA
	CALL	SETDMA		;BY SETTING THE NEXT DMA ADDRESS
	LXI	D,128		;SET MULTI SECTOR I/O COUNT
	CALL	SETMULTI	; TO ALLOW UP TO 16K BYTES IN ONE OPERATION
	LXI	D,CCP$FCB	;POINT TO THE FCB
	CALL	READ		;AND READ THE CCP IN
	; FOLLOWING CODE FOR BANKED SYSTEMS -- MOVES CCP IMAGE TO BANK 2
	;  FOR LATER RELOADING AT WARM STARTS:
	IF	BANKED
	LXI	H,0100H		;GET CCP IMAGE FROM START OF TPA
	MVI	B,25		;TRANSFER 25 LOGICAL SECTORS
	LDA	@CBNK		;GET CURRENT BANK
	PUSH	PSW		;AND SAVE IT
LD$1:
	PUSH	B		;SAVE SECTOR COUNT
	MVI	A,1		;SELECT TPA BANK
	CALL	?BNKSL
	LXI	B,128		;TRANSFER 128 BYTES TO TEMPORARY BUFFER
	LXI	D,BANKBUF	;TEMPORARY BUFFER ADDR IN [DE]
	PUSH	H		;SAVE SOURCE ADDRESS
	PUSH	D		;AND DESTINATION
	PUSH	B		;AND COUNT
	LDIR			;BLOCK MOVE SECTOR TO TEMPORARY BUFFER
	MVI	A,2		;SELECT BANK TO SAVE CCP IN
	CALL	?BNKSL
	POP	B		;GET BACK COUNT
	POP	H		;LAST DESTINATION WILL BE NEW SOURCE ADDR
	POP	D		;LAST SOURCE WILL BE NEW DESTINATION
	LDIR			;BLOCK MOVE SECTOR FROM BUFFER TO ALTERNATE
				; BANK
	XCHG			;NEXT ADDR WILL BE NEW SOURCE ADDR
	POP	B		;GET BACK SECTOR COUNT
	DJNZ	LD$1		;DROP SECTOR COUNT AND LOOP TILL DONE...
	POP	PSW		;WHEN DONE -- RESTORE ORIGINAL BANK
	JMP	?BNKSL
	ELSE
	; IF NON-BANKED WE RETURN THROUGH HERE:
	RET
	ENDIF
	;;;;; ?RLCCP
	; ROUTINE RELOADS CCP IMAGE FROM BANK 2 IF BANKED SYSTEM OR FROM THE
	;  DISK IF NON-BANKED VERSION:
?RLCCP:
	IF	BANKED
	; FOLLOWING CODE FOR BANKED VERSION:
	LXI	H,0100H		;GET CCP IMAGE FROM START OF ALTERNATE BUFFER
RL$1:
	MVI	A,2		;SELECT ALTERNATE BANK
	CALL	?BNKSL
	PUSH	B		;AND COUNT
	MVI	A,1		;PUT CCP TO TPA BANK
	CALL	?BNKSL
	LDIR			;BLOCK MOVE SECTOR FROM BUFFER TO TPA BANK
	DJNZ	RL$1		;DROP SECTOR COUNT AND LOOP TILL DONE...
	POP	PSW		;GET BACK LAST CURRENT BANK #
	JMP	?BNKSL		;SELECT IT AND RETURN
	ELSE
	; FOLLOWING CODE IS FOR NON-BANKED VERSIONS:
	JMP	?LDCCP		;JUST DO LOAD AS THOUGH COLD BOOT
	ENDIF
	;;;;; ?TIME
	; ROUTINE SETS/GETS TIME:
?TIME:
	RET			;Just return in this simple version
	IF	BANKED
	CSEG
	ENDIF
	; CP/M BDOS FUNCTION INTERFACES
	; OPEN FILE:
OPEN:
	MVI C,15 ! JMP BDOS		; OPEN FILE CONTROL BLOCK
	; SET DMA ADDRESS:
SETDMA:
	MVI C,26 ! JMP BDOS		; SET DATA TRANSFER ADDRESS
	; SET MULTI SECTOR I/O COUNT:
SETMULTI:
	MVI C,44 ! JMP BDOS		; SET RECORD COUNT
	; READ FILE RECORD:
READ:
	MVI C,20 ! JMP BDOS		; READ RECORDS
	; CCP NOT FOUND ERROR MESSAGE:
CCP$MSG:
	DB	CR,LF,'BIOS ERR ON A: NO CCP.COM FILE',0
	; FCB FOR CCP.COM FILE LOADING:
CCP$FCB:
	DB	1		;AUTO-SELECT DRIVE A
	DB	'CCP     COM'	;FILE NAME AND TYPE
	DB	0,0,0,0
	DS	16
FCB$NR:	DB	0,0,0
	; SYSTEM SIGN-ON MESSAGE:
SIGNON$MSG:
	db	CR,LF,LF,'CP/M Plus v3.0hd',CR,LF,LF,LF,0
	END
CHARIO3.asm:
	TITLE	'SIO AND 2SIO MODULE FOR CP/M 3.0'
	; CHARIO3.ASM  v.1.0  02/22/2023
	; Character device driver module for Altair computers.
	; Supports SIO and 2SIO async boards and compatibles
	; such as Martin Eberhard's 88-2SIOJP.
	; Note that the CIST function calls ckFlush from the
	; diskette module.  This allows delayed track flushing.
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; Equates used by FDC for flushing during system inactivity (during char I/O)
UNDEF		EQU	0FFH
MINIDSK		EQU	FALSE		;Set TRUE for Altair Mini-Disk (see FDC3.asm)
cHDUNLD		EQU	08H		;head unload
DRVCMD		EQU	09H		;drive command register (out)
BANKED		EQU	FALSE	;<------------------- BANKED VERSION
	PUBLIC	?CINIT,?CI,?CO,?CIST,?COST
	PUBLIC	@CTBL
	; DEFINE EXTERNAL LABELS AND ENTRY POINTS:
	IF	BANKED
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	EXTRN	OUT$BLOCKS	;BLOCK OUTPUT ROUTINE TO I/O PORTS
	EXTRN	?PMSG
	; FDC external labels:
	EXTRN	bfDrive		;Buffered drive
	EXTRN	ckFlush		;Disk buffer flush routine
	MACLIB	Z80
	; 2SIO Serial Board Equates
SIO1CTL	EQU	10h		;1st port on 2SIO board - control register
SIO1DAT	EQU	11h		;1st port on 2SIO board - data register
SIO2CTL	EQU	12h		;2nd port on 2SIO board - control register
SIO2DAT	EQU	13h		;2nd port on 2SIO board - data register
SIORDRF	EQU	01h		;read data register full flag
SIOTDRE	EQU	02h		;transmit data register empty flag
	; SIO Serial Board Equates
SIOCTL	EQU	00h		;SIO board at 0 - control register
SIODAT	EQU	01h		;SIO board at 0 - data register
ACRCTL	EQU	06h		;SIO board at 6 - control register (cassette)
ACRDAT	EQU	07h		;SIO board at 6 - data register (cassette)
SIORCV	EQU	01h		;data received bit (inverted)
SIOXMT	EQU	80h		;read to transmit (inverted)
	; EQUATES FOR MODE BYTE BIT FIELDS
MB$INPUT	EQU 0000$0001B	; DEVICE MAY DO INPUT
MB$OUTPUT	EQU 0000$0010B	; DEVICE MAY DO OUTPUT
MB$IN$OUT	EQU MB$INPUT+MB$OUTPUT
MB$SOFT$BAUD	EQU 0000$0100B	; SOFTWARE SELECTABLE BAUD RATES
MB$SERIAL	EQU 0000$1000B	; DEVICE MAY USE PROTOCOL
MB$XON$XOFF	EQU 0001$0000B	; XON/XOFF PROTOCOL ENABLED
BAUD$NONE	EQU 0		; NO BAUD RATE ASSOCIATED WITH THIS DEVICE
BAUD$50		EQU 1		; 50 BAUD
BAUD$75		EQU 2		; 75 BAUD
BAUD$110	EQU 3		; 110 BAUD
BAUD$134	EQU 4		; 134.5 BAUD
BAUD$150	EQU 5		; 150 BAUD
BAUD$300	EQU 6		; 300 BAUD
BAUD$600	EQU 7		; 600 BAUD
BAUD$1200	EQU 8		; 1200 BAUD
BAUD$1800	EQU 9		; 1800 BAUD
BAUD$2400	EQU 10		; 2400 BAUD
BAUD$3600	EQU 11		; 3600 BAUD
BAUD$4800	EQU 12		; 4800 BAUD
BAUD$7200	EQU 13		; 7200 BAUD
BAUD$9600	EQU 14		; 9600 BAUD
BAUD$19200	EQU 15		; 19.2K BAUD
	; WILL START OFF IN COMMON MEMORY FOR BANKED OR NON-BANKED SYSTEMS:
	CSEG
	IF	BANKED
	; WE PROVIDE ALTERNATE DEFINITIONS OF THE ROUTINE ENTRY POINTS IF
	;  WE ARE RUNNING A BANKED SYSTEM VERSUS A NON-BANKED SYSTEM:
	;;;;; ?CINIT
	; ENTER HERE FOR BANKED SYSTEMS FOR DEVICE INITIALIZATIONS:
?CINIT:
	LXI	H,BCINIT	;POINT TO BANKED ROUTINE ADDRESS
	JR	BANKIO		;GO TO DISPATCHER
	;;;;; ?CI
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT:
?CI:	LXI	H,BCI		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CO
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT:
?CO:	LXI	H,BCO		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CIST
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT STATUS:
?CIST:	LXI	H,BCIST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?COST
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT STATUS:
?COST:	LXI	H,BCOST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; BANKIO
	; ROUTINE DISPATCHES TO BANKED PORTION OF CHARACTER I/O ROUTINES:
BANKIO:
	SSPD	SPSAVE		;SAVE CURRENT STACK POINTER
	LXI	SP,IOSP		; AND USE LOCAL STACK FOR I/O
	PUSH	PSW		;SAVE ON LOCAL STACK
	XRA	A		;WE WILL SELECT BANK 0 (OP SYS)
	CALL	?BNKSL
	LXI	D,BIORET	;RETURN ADDRESS IN [DE]
	PUSH	D		;PUT IT ON STACK FOR RETURN
	PCHL			;DISPATCH TO BANKED PART OF ROUTINE
	; ARRIVE HERE AFTER DEVICE HANDLER FINISHED:
BIORET:
	POP	D		;GET PREVIOUS CURRENT BANK TO [D]
	PUSH	PSW		;SAVE HANDLER RETURNED RESULT (IF ANY)
	MOV	A,D		;RESELECT PREVIOUS CURRENT BANK
	CALL	?BNKSL
	POP	PSW		;GET BACK RESULT CODE TO [A]
	LSPD	SPSAVE		;RESTORE PREVIOUS STACK
	RET			;AND RETURN...
	ENDIF
	;;;;; ACTUAL DEVICE HANDLERS
	;;;;; ?CINIT (BCINIT FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INITIALIZATION:
	IF	BANKED
	DSEG			;CAN PUT IN BANKED SEGMENT IF BANKED
BCINIT:
	ELSE
?CINIT:
	ENDIF
	MOV	B,C		;ON ENTRY DEVICE # IS IN [C] BUT WE NEED
				; IT IN [B]
	CALL	DEV$DISPATCH	;GO TO CORRECT INIT ROUTINE
	DW	CINIT0		;INIT FOR DEVICE 0
	DW	CINIT1		;INIT FOR DEVICE 1
	DW	CINIT2		;INIT FOR DEVICE 2
	DW	CINIT3		;INIT FOR DEVICE 3
	DW	NULL$INIT	;INIT FOR DEVICE 4
	DW	NULL$INIT	;INIT FOR DEVICE 5
	DW	NULL$INIT	;INIT FOR DEVICE 6
	DW	NULL$INIT	;INIT FOR DEVICE 7
	DW	NULL$INIT	;INIT FOR DEVICE 8
	DW	NULL$INIT	;INIT FOR DEVICE 9
	DW	NULL$INIT	;INIT FOR DEVICE 10
	DW	NULL$INIT	;INIT FOR DEVICE 11
	DW	NULL$INIT	;INIT FOR DEVICE 12
	DW	NULL$INIT	;INIT FOR DEVICE 13
	DW	NULL$INIT	;INIT FOR DEVICE 14
	DW	NULL$INIT	;INIT FOR DEVICE 15
	;;;;; ?CI (BCI FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT:
	IF	BANKED
BCI:
	ELSE
?CI:
	ENDIF
	CALL	DEV$DISPATCH
	DW	CI0		;DEVICE 0 INPUT
	DW	CI1		;DEVICE 1 INPUT
	DW	CI2		;DEVICE 2 INPUT
	DW	CI3		;DEVICE 3 INPUT
	DW	NULL$CI		;DEVICE 4 INPUT
	DW	NULL$CI		;DEVICE 5 INPUT
	DW	NULL$CI		;DEVICE 6 INPUT
	DW	NULL$CI		;DEVICE 7 INPUT
	DW	NULL$CI		;DEVICE 8 INPUT
	DW	NULL$CI		;DEVICE 9 INPUT
	DW	NULL$CI		;DEVICE 10 INPUT
	DW	NULL$CI		;DEVICE 11 INPUT
	DW	NULL$CI		;DEVICE 12 INPUT
	DW	NULL$CI		;DEVICE 13 INPUT
	DW	NULL$CI		;DEVICE 14 INPUT
	DW	NULL$CI		;DEVICE 15 INPUT
	;;;;; ?CO (BCO FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT:
	IF	BANKED
BCO:
	ELSE
?CO:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CORRECT DEVICE OUTPUT HANDLER
	DW	CO0		;DEVICE 0 OUTPUT
	DW	CO1		;DEVICE 1 OUTPUT
	DW	CO2		;DEVICE 2 OUTPUT
	DW	CO3		;DEVICE 3 OUTPUT
	DW	NULL$CO		;DEVICE 4 OUTPUT
	DW	NULL$CO		;DEVICE 5 OUTPUT
	DW	NULL$CO		;DEVICE 6 OUTPUT
	DW	NULL$CO		;DEVICE 7 OUTPUT
	DW	NULL$CO		;DEVICE 8 OUTPUT
	DW	NULL$CO		;DEVICE 9 OUTPUT
	DW	NULL$CO		;DEVICE 10 OUTPUT
	DW	NULL$CO		;DEVICE 11 OUTPUT
	DW	NULL$CO		;DEVICE 12 OUTPUT
	DW	NULL$CO		;DEVICE 13 OUTPUT
	DW	NULL$CO		;DEVICE 14 OUTPUT
	DW	NULL$CO		;DEVICE 15 OUTPUT
	;;;;; ?CIST (BCIST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT STATUS:
	IF	BANKED
BCIST:
	ELSE
?CIST:
	ENDIF
	;;;;; System is relatively idle during char input, so do some FDC housecleaning
	mvi	a,UNDEF		;invalidate track buffer
	sta	bfDrive
	call	ckFlush		;flush the track if needed
	ei			;restore interrupts
	IF	NOT MINIDSK
	mvi	a,cHDUNLD	;unload head
	out	DRVCMD
	ENDIF
	CALL	DEV$DISPATCH
	DW	CIST0		;DEVICE 0 INPUT STATUS
	DW	CIST1		;DEVICE 1 INPUT STATUS
	DW	CIST2		;DEVICE 2 INPUT STATUS
	DW	CIST3		;DEVICE 3 INPUT STATUS
	DW	NULL$CIST	;DEVICE 4 INPUT STATUS
	DW	NULL$CIST	;DEVICE 5 INPUT STATUS
	DW	NULL$CIST	;DEVICE 6 INPUT STATUS
	DW	NULL$CIST	;DEVICE 7 INPUT STATUS
	DW	NULL$CIST	;DEVICE 8 INPUT STATUS
	DW	NULL$CIST	;DEVICE 9 INPUT STATUS
	DW	NULL$CIST	;DEVICE 10 INPUT STATUS
	DW	NULL$CIST	;DEVICE 11 INPUT STATUS
	DW	NULL$CIST	;DEVICE 12 INPUT STATUS
	DW	NULL$CIST	;DEVICE 13 INPUT STATUS
	DW	NULL$CIST	;DEVICE 14 INPUT STATUS
	DW	NULL$CIST	;DEVICE 15 INPUT STATUS
	;;;;; ?COST (BCOST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT STATUS:
	IF	BANKED
BCOST:
	ELSE
?COST:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CONSOLE OUTPUT STATUS HANDLER
	DW	COST0		;DEVICE 0 OUTPUT STATUS
	DW	COST1		;DEVICE 1 OUTPUT STATUS
	DW	COST2		;DEVICE 2 OUTPUT STATUS
	DW	COST3		;DEVICE 3 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 4 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 5 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 6 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 7 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 8 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 9 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 10 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 11 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 12 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 13 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 14 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 15 OUTPUT STATUS
	;;;;; DEV$DISPATCH
	; ROUTINE JUMPS TO CORRECT DEVICE HANDLER:
DEV$DISPATCH:
	MOV	A,B		;GET DEVICE # TO [A]
	STA	DEV$CODE	;SAVE FOR LATER USE
	ADD	A		;X2 FOR WORD OFFSET
	POP	H		;RETURN ADDRESS IS 1ST PARAMETER ADDRESS
	MOV	E,A		;SET UP OFFSET IN [DE]
	MVI	D,0
	DAD	D		;[HL] = PTR TO HANDLER ADDRESS
	MOV	E,M		;GET HANDLER ADDRESS TO [DE]
	INX	H
	MOV	D,M
	MOV	A,C		;PUT CHAR TO SEND INTO A
	XCHG			;PUT HANDLER ADDRESS IN [HL]
	PCHL			;AND DISPATCH TO IT...
	;;;;; PHYSICAL DEVICE HANDLER CODE:
; Initialize serial ports
CINIT0:
	mvi	a,03h		;reset 2SIO ports
	out	SIO1CTL
	out	SIO2CTL
	mvi	a,11h		;select 8N2
	out	SIO1CTL
	out	SIO2CTL
CINIT1:
CINIT2:
CINIT3:
	ret
; Input status routines. Return FFh if character ready, else zero
CIST0:
sio1IS  in	SIO1CTL		;read 2SIO #1 status/control register
	ani	SIORDRF		;data present?
	rz			;no, return zero
	mvi	a,0FFh		;else return FFh
	ret
CIST1:
sio2IS	in	SIO2CTL		;read 2SIO #2 status/control register
	rz			;no, return zero
	ret
CIST2:
sioIS	in	SIOCTL		;read SIO status/control register
	xri	0FFh		;convert to positive logic
	ani	SIORCV		;data present?
	rz			;no, return zero
	ret
CIST3:
acrIS	in	ACRCTL		;read ACR (SIO) control register
	rz			;no, return zero
	ret
; Character input routines (character ready assumed)
CI0:
sio1In	in	SIO1DAT		;read and return the character
	ret
CI1:
sio2In	in	SIO2DAT		;read and return the character
	ret
CI2:
sioIn	in	SIODAT		;read and return the character
	ret
CI3:
acrIn	in	ACRDAT		;read and return the character
	ret
; Output status routines. Return FFh if ready to send, else zero
COST0:
sio1OS	in	SIO1CTL		;read 2SIO #1 status/control register
	ani	SIOTDRE		;0=busy
	rz			;not ready, return 0
	ret
COST1:
sio2OS	in	SIO2CTL		;read 2SIO #2 status/control register
	ani	SIOTDRE		;0=busy
	ret
COST2:
sioOS	in	SIOCTL		;read SIO status/control register
	ani	SIOXMT		;0=busy
	ret
COST3:
acrOS	in	ACRCTL		;read SIO status/control register
	ani	SIOXMT		;0=busy
	ret
; Character output routines (transmit ready assumed)
CO0:
sio1Out	out	SIO1DAT		;send character
	ret
CO1:
sio2Out	out	SIO2DAT		;send character
	ret
CO2:
sioOut	out	SIODAT		;send character
	ret
CO3:
acrOut	out	ACRDAT		;send character
	ret
	;;;;; NULL ROUTINES:
NULL$CIST:
NULL$COST:
	XRA	A		;RETURN A FALSE STATUS RESULT
	JR	NULL$RET
NULL$CI:
	MVI	A,1AH		;FOR INPUT RETURN A CNTL-Z (EOF)
NULL$INIT:
NULL$CO:
NULL$RET:
	RET			;HARMLESS RETURN
	; STORAGE FOR DEVICE CODE -- CAN RESIDE IN SAME SEGMENT AS THE BULK
	;  OF CHARACTER I/O ROUTINES:
DEV$CODE:	DS	1
	;;;;; CHRTBL
	; CHARACTER DEVICE TABLE
	CSEG			;MUST RESIDE IN COMMON MEMORY
@CTBL:
	db '2SIOA '		; device 0, 2SIO at 10h/11h
	db mb$in$out+mb$serial
	db baud$none
	db '2SIOB '		; device 1, 2SIO at 12h/13h
	db baud$none
	db 'SIO   '		; device 2, SIO at 0/1
	db baud$none
	db 'ACR   '		; device 3, SIO at 6/7 (ACR)
	db baud$none
	db 0			; table terminator
MAX$DEVICES	EQU	($-@CTBL)/8	;# DEVICES IN TABLE
	DB	0			;TABLE TERMINATOR
	; OTHER DATA AREAS:
	DS	24		;CHARACTER I/O LOCAL STACK
IOSP	EQU	$
SPSAVE	DS	2
	END
MOVE3.asm:
	TITLE 'BANK & MOVE MODULE FOR CP/M 3.0'
	; MOVE3.ASM  v.1.0  02/22/2023
	; Memory copy routines for the Altair 8800 computer.
	; Only non-banked code is 8080-compatible.  If a
	; banked-memory system is employed, the drivers in
	; this module can be used as a starting point but
	; obviously cannot be used in a stock Altair.
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
BANKED		EQU	FALSE	;<----------------Banked VERSION
MPURR0	EQU	0D2H		;Z80 BOARD RELOCATION PORT
MPURR1	EQU	0D3H		;Z80 BOARD RELOCATION PORT
	PUBLIC	?MOVE,?XMOVE,?BANK
	; PUBLIC LABELS AND EXTERNALS FOR BANKED SYSTEMS:
	IF	BANKED
	PUBLIC	CURRR0,CURRR1	;CURRENT WINDOW RELOCATION SEGMENTS
	PUBLIC	BANKBUF		;TEMPORARY 128 BYTE BUFFER OTHER ROUTINES
				; MAY USE FOR TRANSIENT PURPOSES
	PUBLIC	WIN$LOW$2BITS	;LOWER 2 BITS FOR EACH RELOCATION REGISTER
	PUBLIC	DOXMOV,XMOV$BANKS	;EXTENDED BANK MOVE VARIABLES
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	MACLIB	Z80
	; LOCATE CODE IN THE COMMON SEGMENT:
	CSEG
	;;;;; ldir
	; An 8080-compatiple replacement for the Z80 LDIR instruction
	; Copies [BC] bytes from the address starting at [HL] to [DE]
ldir:
	xchg			;Make [DE] be source and [HL] be target
	call	memcpy		;Copy data block
	xchg			;Make [DE] be target and [DE] be source
	ret
	;;;;; memcpy
	; Copies [BC] bytes from the address starting at [DE] to [HL]
memcpy:	ldax	d		;Get byte byte
	mov	m,a		;Store byte
	inx	h		;Increment target address
	inx	d		;Increment source address
	dcx	b		;Decrement byte count
	mov	a,b		;move btye count to accumulator
	ora	c		;test for zero
	jnz	memcpy		;loop until done
	ret
	;;;;; ?XMOVE
	; ROUTINE SETS UP AN INTER-BANK MOVE OF 128 BYTES ON THE NEXT CALL
	;  TO ?MOVE:
?XMOVE:
	IF	BANKED
	MVI	A,0FFH		;SET EXTENDED MOVE FLAG
	STA	DOXMOV
	SBCD	XMOV$BANKS	;AND STORE BANKS FOR THE EXTENDED MOVE
	ENDIF
	RET
	;;;;; ?MOVE
	; ROUTINE PERFORMS INTRA-BANK MOVES IF ?XMOVE WAS NOT CALLED PRIOR TO
	;  THIS CALL TO ?MOVE ELSE A 128 BYTE TRANSFER IS CONDUCTED BETWEEN
	;  DIFFERENT BANKS:
?MOVE:
	IF	BANKED
	LDA	DOXMOV		;GET EXTENDED MOVE FLAG
	ORA	A		;IS IT SET ?
	MVI	A,0		;RESET FOR NEXT TIME ANYWAY
	STA	DOXMOV
	JRZ	MOVE$IT
	; HAVE TO IMPLEMENT INTER-BANK MOVE:
	LDA	@CBNK		;REMEMBER CURRENT BANK
	PUSH	PSW
	LDA	XMOV$BANKS	;GET SOURCE BANK
	CALL	?BNKSL		; AND SELECT IT
	PUSH	H		;SAVE DESTINATION ADDRESS
	PUSH	B		;AND THE COUNT
	XCHG			;[HL] = SOURCE
	LXI	D,BANKBUF	;[DE] = LOCAL TEMPORARY BUFFER
	LDIR			;BLOCK MOVE TO TEMP BUFFER
	POP	B		;RESTORE COUNT
	POP	D		;[DE] = ORIGINAL DESTINATION
	PUSH	H		;SAVE NEXT SOURCE ADDRESS
	LXI	H,BANKBUF	;[HL] = SOURCE = TEMP BUFFER
	LDA	XMOV$BANKS+1	;GET DESTINATION BANK
	CALL	?BNKSL		;AND SELECT IT
	LDIR			;BLOCK MOVE FROM TEMP BUFFER TO DESTINATION
	POP	H		;RESTORE NEXT SOURCE
	XCHG			;RETURN SWAP
	POP	PSW		;GET BACK PREVIOUS CURRENT BANK
	; ARRIVE HERE FOR INTRA-BANK MEMORY MOVE:
MOVE$IT:
	ENDIF
;	XCHG			;WE ARE PASSED SOURCE IN DE AND DEST IN HL
;	LDIR			;USE Z80 BLOCK MOVE INSTRUCTION
;	XCHG			;NEED NEXT ADDRESSES IN SAME REGS
;	RET
	jmp memcpy		;Use 8080-compatible memcpy for move
	;;;;; ?BANK
	; ROUTINE SWITCHES IN PHYSICAL BANK:
?BANK:
	IF	BANKED
	CPI	2		;BANK 2 OR HIGHER ?
	JRNC	BNK1$SWITCH	;GO DIRECTLY TO CODE TO CALCULATE THE
				; PHYSICAL ADDRESS...
	ORA	A		;ELSE SWAP BANK 0 AND 1 VALUES
	MVI	A,1		;IF BANK 0 MAKE BANK 1
	JRZ	BNK1$SWITCH
	XRA	A		;ELSE IF BANK 1 MAKE BANK 0
	JR	BNK2$SWITCH
	; HERE TO GET MPU-80 SEGMENT # FOR THE BANK WE NEED:
BNK1$SWITCH:
	DCR	A		;NORMALIZE BANK # RELATIVE TO 0
	ADD	A		;X2
	ADD	A		;X4 FOR 16K / WINDOW
	ADD	A		;X8 FOR 32K / BANK
	ADI	10H		;BANKS 1-15 START ABOVE 1ST 64K
	; DO PHYSICAL BANK SWITCHING HERE:
BNK2$SWITCH:
	PUSH	B		;SAVE [BC]
	LBCD	WIN$LOW$2BITS	;GET LOWER 2 BITS FOR EACH RELOCATION REGISTER
	DI			;CRITICAL SECTION -- NO INTERRUPTS HERE
	STA	CURRR0		;SAVE SEGMENT ADDR. OF LOWER WINDOW
	ORA	B		;[A] = WINDOW SEG + LOW 2 BITS
	OUT	MPURR0		;RELOCATE LOWER WINDOW NOW
	ANI	0FCH		;TAKE OUT LOWER 2 BITS
	ADI	4		;BUMP UP SEG ADDR BY 16K FOR UPPER WINDOW
	STA	CURRR1		;SAVE UPPER WINDOW SEGMENT ADDR.
	ORA	C		;[A] = WINDOW SEG + LOW 2 BITS
	OUT	MPURR1		;RELOCATE UPPER WINDOW
;;;;	EI			;CAN REENABLE INTERRUPTS NOW
	POP	B		;RESTORE [BC]
	ENDIF
	RET
	IF	BANKED
DOXMOV:		DB	0	;EXTENDED MOVE FLAG -- IF EQUAL TO FFH THEN
				; NEXT CALL TO ?MOVE WILL BE AN INTER-BANK
				; MOVE.
CURRR0:		DB	10H	;CURRENT LOWER WINDOW RELOCATION REGISTER
				; VALUE
CURRR1:		DB	14H	;CURRENT UPPER WINDOW RELOCATION REGISTER
				; VALUE
WIN$LOW$2BITS:	DB	1	;UPPER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
				; ADDRESSING ABOVE 1 MEGABYTE OR EPROM SELECT)
		DB	1	;LOWER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
XMOV$BANKS:	DS	1	;STORAGE AREA FOR DESTINATION BANK # FOR
				; EXTENDED MOVES
		DS	1	;STORAGE AREA FOR SOURCE BANK # FOR
				; EXTENDED MOVES
BANKBUF:	DS	128	;LOCAL TEMPORARY BUFFER FOR EXTENDED MOVES
	ENDIF
	END
DRVTBL3.asm:
	TITLE	'CP/M 3.0 DRIVE TABLES'
	; DRVTBL3.ASM  v.1.0  02/22/2023
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; DETERMINE IF BANK SELECTING:
BANKED		EQU	FALSE	;<-------------- NON BANKED VERSION
	PUBLIC	@DTBL
	; DECLARE EXTERNAL LABELS:
	EXTRN	DPH0, DPH1, DPH2, DPH3
	; INCLUDE CP/M 3.0 MACRO LIBRARY:
	MACLIB	CPM3
	IF	BANKED
	DSEG			;BANKED SYSTEMS CAN HAVE DRIVE TABLE IN THE
				; OP SYS BANK
	ELSE
	CSEG			;NON-BANKED SYSTEMS HAVE NO CHOICE BUT TO PUT
				; IT IN THE COMMON MEMORY AREA
	ENDIF
@DTBL:	DTBL	<DPH0,DPH1,DPH2,DPH3,0,0,0,0,0,0,0,0,0,0,0,0>
	END
FDC3.asm:
	TITLE	'FDC MODULE FOR CP/M 3.0'
	; FDC3.ASM  v.1.0  02/22/2023
	; Diskette device driver module for Altair computers.
	; Supports Altair floppy disk controller and compatibles
	; such as the FDC+ provided by DeRamp.com.
	; Implemented by Wayne Parham  (wayne@parhamdata.com)
	; Ported into the CP/M 3.0 modular BIOS format
	; Written by Mike Douglas (AltairClone.com)
TRUE	equ	-1
FALSE	equ	not TRUE
;Diskette parameter equates
MINIDSK	equ	FALSE		;set TRUE for Altair Mini-Disk
NUMTRK	equ	77		;number of tracks on the disk
NUMSEC	equ	32		;sectors per track
DATATRK	equ	6		;1st data format track
SECMASK	equ	1Fh		;five bit sector numbers
BLS	equ	1024		;allocation unit size
BSH	equ	4		;allocation block shift factor
BLM	equ	0Fh		;allocation block mask
EXM	equ	0		;extent mask
DSM	equ	149		;max block number (150 blocks of 2K bytes)
NDIRS	equ	64		;number of directory entries (64)
DRM	equ	63		;max directory entry number
AL0	equ	0C0h		;directory allocation block bits byte 0
AL1	equ	0		;directory allocation block bits byte 1
RESTRK	equ	2		;reserved tracks for boot image
CKS	equ	(DRM+1)/4	;directory check space
NUMDISK	equ	2		;Two drives supported
CSECLEN	equ	128		;CP/M sector length
SSECLEN	equ	133		;Altair system sector length
DSECLEN	equ	136		;Altair data sector length
TSECLEN	equ	DSECLEN+1	;length of sector in track table
; System tracks (0-5) sector format
SYSTRK	equ	0		;offset of track number
SYSDATA	equ	3		;offset of 128 byte data payload
SYSSTOP	equ	131		;offset of stop byte (FFh)
SYSCSUM	equ	132		;offset of checksum
; Data tracks (6-76) sector format
DATTRK	equ	0		;offset of track number
DATSEC	equ	1		;offset of sector number
DATCSUM	equ	4		;offset of checksum
DATDATA	equ	7		;offset of 128 byte data payload
DATSTOP	equ	135		;offset of stop byte (FFh)
; Altair disk controller
DRVSLCT	equ	08h		;drive select register (out)
cDSLCT	equ	80h		;deselect drive
DRVSTAT	equ	08h		;drive status register (in)
sENWD	equ	01h		;enter new write data flag
sMOVEOK	equ	02h		;OK to move head
sHDSTAT	equ	04h		;head status flag
sDSKEN	equ	08h		;disk is selected and enabled
sINTEN	equ	20h		;processor interrupts enabled
sTRACK0	equ	40h		;on track zero flag
sNRDA	equ	80h		;new read data available
DRVCMD	equ	09h		;drive command register (out)
cSTEPI	equ	01h		;step in
cSTEPO	equ	02h		;step out
cHDLOAD	equ	04h		;head load
cRESTMR	equ	04h		;restart motor-off timer (MINIDSK)
cHDUNLD	equ	08h		;head unload
cINTEN	equ	10h		;interrupt enable
cINTDIS	equ	20h		;interrupt disable
cHCSON	equ	40h		;reduce head current switch
cWRTEN	equ	80h		;write enable
DRVSEC	equ	09h		;drive sector position (in)
sNEWSEC	equ	01h		;new sector flag (sector true)
DRVDATA	equ	0Ah		;drive read/write data (in/out)
; BDOS equates
GETCH	equ	1		;get character
PRINT	equ	9		;display string
OPEN	equ	15		;open file
READSEQ	equ	20		;read sequential
DMA	equ	26		;set address for file read
SETMULT	equ	44		;set multi-record I/O
; RAM equates
TPA	equ	100h
DFFCB	equ	5Ch
STACK	equ	100h
BDOS	equ	5
WBOOTV	equ	00h		;warm boot vector location
BDOSV	equ	05h		;bdos entry vector location
; Misc equates
NUMCDEV	equ	4		;number of character I/O devices
RDTRIES	equ	6		;read tries (must be <= 8)
VFTRIES	equ	4		;verify tries per write (must be <= 8)
WRTRIES	equ	3		;track writes to try
UNDEF	equ	0FFh		;undefined value
CR	equ	13		;ascii for carriage return
LF	equ	10		;ascii for line feed
EOF	equ	01Ah		;ctrl-z
; External references
	maclib	CPM3		;CP/M 3.0 disk definition macros
	maclib	Z80		;Z80 translation macro library
	maclib	modebaud	;Character I/O equates
	extrn	@civec,@covec,@aivec,@aovec,@lovec,@mxtpa
	cseg			;Put DPBs in common memory
; Disk Parameter Headers
	PUBLIC	DPH0, DPH1		;FLOPPY DISK PARAMETER HEADERS
	PUBLIC	bfDrive			;Buffered drive
	PUBLIC	ckFlush			;Disk buffer flush routine
	; DEFINE EXTERNAL LABELS:
	EXTRN	@ADRV,@RDRV
	EXTRN	@DMA,@TRK,@SECT
	EXTRN	@CBNK
	EXTRN	@DBNK			;BANK FOR DMA OPERATION
	EXTRN	@ERMDE			;BDOS ERROR MODE
	EXTRN	?WBOOT			;WARM BOOT VECTOR
	EXTRN	?SLDSK			;SELECT DISK
	EXTRN	?PMSG			;PRINT MESSAGE @<HL> UP TO 00, SAVES [BC] AND [DE]
	EXTRN	?PDERR			;PRINT BIOS DISK ERROR HEADER
	EXTRN	?CONIN,?CONO		;CONSOLE IN AND OUT
	EXTRN	?CONST			;CONSOLE STATUS
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 0:
	DW	fdWrite			;FD SEC WRITE ROUTINE
	DW	fdRead			;FD SEC READ ROUTINE
	DW	fdLogin			;FLOPPY DISK "A:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "A:" INITIALIZATION ROUTINE
	DB	0			;RELATIVE DRIVE 0 ON THIS CONTROLLER
	DB	0			;DRIVE TYPE (UNUSED BY CP/M)
dph0	dw	tranTbl,0,0,0,0,0,fd$dpb,csv0,alv0,fd$bcb,-1,-1
	db	0
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 1:
	DW	fdLogin			;FLOPPY DISK "B:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "B:" INITIALIZATION ROUTINE
	DB	1			;RELATIVE DRIVE 1 ON THIS CONTROLLER
dph1	dw	tranTbl,0,0,0,0,0,fd$dpb,csv1,alv1,fd$bcb,-1,-1
	db	0
; fd$dpb - Disk Parameter Block. This table gives a block size of 1024 bytes
;   and 64 directory entries.
fd$dpb	dw	NUMSEC		;sectors per track
	db	BSH		;allocation block shift factor (BSH)
	db	BLM		;data location block mask (BLM)
	db	EXM		;extent mask (EXM)
	dw	DSM		;maximum block number (DSM 242)
	dw	DRM		;maximum directory entry number (DRM 63)
	db	AL0,AL1		;AL0, AL1
	dw	CKS		;CKS=(DRM+1)/4
	dw	RESTRK		;reserved tracks for CPM and bootloader
	db	0		;physical=logical sector (128 bytes)
; fd$bcb - Directory Buffer Control Block (BCB)
fd$bcb	db	0FFh		;drive number (FF means not used yet)
	db	0,0,0		;record position
	db	0		;dirty (write) flag
	db	0		;scratch byte
	dw	0		;track
	dw	0		;sector
	dw	dirBuf		;buffer address
	dw	0		;bank
	dw	0		;link to next BCB (none)
   if MINIDSK
tranTbl	db	1,3,5,7,9,11,13,15,2,4,6,8,10,12,14,16
   endif
   if NOT MINIDSK
tranTbl	db	01,09,17,25,03,11,19,27,05,13,21,29,07,15,23,31
	db	02,10,18,26,04,12,20,28,06,14,22,30,08,16,24,32
   endif
;  Floppy init (noop)
fdInit:
	ret
;  Floppy login (noop)
fdLogin:
	ret
; fdRead - Read sector BIOS entry. Read one sector using the @RDRV,
;    @TRK, @SECT, and @DMA previously specified.
; On Entry
;    @RDRV = drive to read from
;    @TRK  = track to read from
;    @SECT = sector number to read (0-31)
;    @DMA  = address of buffer to read into
; On Exit
;    If read successful
;	sector read into @DMA
;	HL = @DMA + CSECLEN
;	A=0, Z flag set true
;    Else
;	A=1, Z flag set false
;    Interrupts enabled
;    Clobbers all
fdRead:
	call	decSec		;convert to zero-index
	call	ckFlush		;flush track buffer if needed
	ei			;re-enable interrupts
	call	readTrk		;fill track buffer if needed
	jnz	exitDio		;track read error, exit
	call	movRead		;move sector to @DMA
exitDio	mvi	a,0		;if zero is true, return zero
	rz
	inr	a		;else return A<>0, Z false
	ret
; fdWrite - Write sector BIOS entry. Write one sector using the @RDRV,
;    @TRK, @SECT and @DMA specified.
; On Entry
;    @RDRV = drive to write
;    @TRK  = track to write
;    @SECT = sector number to write (0-31)
;    @DMA  = address of buffer to write from
; On Exit
;    If successful
;	sector written to trkBuf from @DMA
;    Else
;    Clobbers all
fdWrite:
	jmp	movWrt		;move @DMA to sector and exit
; movRead - Move sector data from track buffer to @DMA for a
;    CPM read request
; On Entry
; On Exit
;    If successful (good sector)
;	sector data moved to @DMA, Z flag set true
;    Else (sector flagged as bad)
;	Z flag set false
;    Clobbers all
movRead:
	call	altSkew		;@SECT to hard sector in A
	call	dSecAdr		;HL->sector in trkBuf
	mov	a,m		;A=sector valid flag
	ora	a
	rnz			;bad sector, return error
	lxi	d,DATDATA+1	;DE=offset to data portion of sector
	lda	@TRK		;on a data track?
	cpi	DATATRK
	jnc	mrMove		;yes, data track (DE already correct)
	lxi	d,SYSDATA+1	;DE=offset to data portion of sector
mrMove	dad	d		;HL->data portion of sector
	xchg			;DE->data portion of sector
	lhld	@DMA		;HL->destination for data
	mvi	b,CSECLEN	;B=number of bytes to move
mrLoop	ldax	d		;move sector from trkBuf to @DMA
	mov	m,a
	inx	h		;increment pointers
	inx	d
	dcr	b		;loop count
	jnz	mrLoop
	ret			;exit with zero	status
; movWrt - Move sector data from @DMA to track buffer and create
;    metadata for the sector for a CPM write request.
; On Entry
; On Exit
;    Sector data moved to trkBuf from @DMA
;    A=0, Z status true
;    Clobbers all
movWrt:
	mvi	m,0		;flag sector as good
	inx	h		;HL->track
	lda	@TRK		;A=track
	ori	80h		;set sync bit
	mov	m,a		;set track in sector
	inx	h		;HL->byte after track
	cpi	DATATRK+80h	;on a system or data track?
	jnc	wDatTrk		;data track 6-76 (mini disk 4-34)
; Create Altair sector for system tracks 0-5 (mini disk 0-3)
	xra	a		;put 0100h (16 bit) at offset 1,2
	mov	m,a
	inx	h		;HL->offset 2
	inr	a		;A=1
	mov	m,a
	inx	h		;HL->128 byte CPM sector in Altair sector
	call	mwMove		;move @DMA to sector in trkBuf
	mvi	m,0FFh		;offset 131 is stop byte (0FFh)
	inx	h		;offset 132 is checksum
	mov	m,b		;store checksum at offset 132
	jmp	mwExit		;exit
; wDatTrk- Create Altair sector for tracks 6-76 (mindisk 4-34)
wDatTrk:
	lda	@SECT		;A = sector (low byte) before Altair skew
	mov	m,a		;store Altair logical sector number
	inx	h		;HL->offset 2 in sector
	xra	a		;store zero at offsets 2-6
	mov	m,a		;offset 2
	inx	h
	mov	m,a		;zero at offset 3
	inx	h
	push	h		;save address of offset 4 = checksum
	inx	h
	mov	m,a		;zero at offset 5
	inx	h
	mov	m,a		;zero at offset 6
	mvi	m,0FFh		;offset 135 is stop byte (0FFh)
	pop	h		;HL->checksum byte in Altair sector
	mov	m,b		;store the checksum
; mwExit - set dirty flag true, return success status
mwExit:
	mvi	a,0FFh		;set dirty flag true
	sta	bfDirty
	xra	a		;return success status
	ret
; mwMove - Move sector buffer (128 bytes) from @DMA to (HL) as part
;   of a CPM write command. Compute checksum on all bytes moved and return
;   the checksum in B.
; On Entry
;    HL->destination sector in trkBuf
;    @DMA = address of buffer to move from
; On Exit
;    128 bytes moved from @DMA to (HL)
;    HL = HL + 128
;    B = checksum of the 128 bytes moved
;    Clobbers all
mwMove:
	xchg			;DE->destination CPM sector in trkBuf
	lhld	@DMA		;HL->source buffer
	lxi	b,CSECLEN	;B=checksum (0), C=128 byte count
mwLoop:	mov	a,m		;move from (HL) to (DE)
	stax	d
	add	b		;add byte to checksum
	mov	b,a
	inx	d		;increment both pointers
	inx	h
	dcr	c		;decrement character count
	jnz	mwLoop		;loop until count = 0
	xchg			;return with buffer pointer in HL
	ret
; decSec - Decrement sector count to convert 1-indexed CPM physical
;    sector to 0-indexed hardware-layer physical sector.
; On Entry
;    @SECT = 1-indexed sector number
; On Exit
;    @SECT = 0-indexed sector number
;    Clobbers A
decSec:
	dcr	a		;decrement to convert to zero indexed
	sta	@SECT
	ret
; altSkew - Perform Altair skew on the sector number in secNum and return
;    the result in A. The skew is based on the track as:
;	Tracks 0-5, secOut = secIn
;	Tracks 6-76, secOut = (secIn * 17) MOD 32
;    The skew computation for tracks 6-76 is implemented as:
;	secOut = secIn if secIn is even
;	secOut = secIn XOR 10h if secIn is odd
; On Entry
;    @TRK  = current track
;    @SECT = sector number (0-31)
; On Exit
;    A = sector number after Altair skew
;    Clobbers A,B
altSkew	equ	$
   if MINIDSK
	ret			;no skewing done for mini disk
   endif
   if NOT MINIDSK
	cpi	DATATRK
	lda	@SECT		;A = unmodified sector number (low byte)
	rc			;system track, no change to sector
	mov	b,a		;save sector number in B
	rrc			;test for even/odd
	mov	a,b		;restore sector number in A
	rnc			;return with sector number if even
	xri	10h		;else translate as in comments above
	ret
   endif
; readTrk- read full track into track buffer if the requested
;    drive (@RDRV) or track (@TRK) does not match the buffered
;    drive (bfDrive) or buffered track (bfTrack). The status byte
;    at the start of each sector is set to zero if the sector is
;    good, non-zero if the sector couldn't be read.
; On Entry
;    bfDrive = drive from which trkBuf was filled
;    bfTrack = track from which trkBuf was filled
; On Exit
;    @TRK on @RDRV read into trkBuf
;    Zero true if track read or already there, zero false otherwise
;    Clobbers all
readTrk:
	lhld	bfDrive		;L=buffered drive, H=buffered track
	lda	@RDRV		;A=requested drive
	cmp	l		;same drive buffered?
	jnz	rtNew		;drive doesn't match, need a new buffer
	lda	@TRK		;A=requested track
	cmp	h		;same track buffered?
	rz			;yes, already have this buffer
; rtNew - New track needs to be read
rtNew:
	mvi	a,UNDEF		;invalidate buffered data
	sta	bfDrive
	call	dSelDrv		;select drive, load head
	rnz			;drive select failed, exit with error
	mvi	a,2		;init restore/seek try counter
	sta	skRetry
rtRtry:	call	dSeek		;seek to trkNum (disables interrupts)
	rnz			;a restore was required and failed
	call	initTrk		;init all sectors to "bad" (not read)
	lxi	d,RDTRIES*NUMSEC*256 + NUMSEC
				;D=max sector reads = RDTRIES revolutions
				;E=sectors remaining to fill
; Read sector loop - All sectors are originally marked "bad" (unread) and
;    a sector counter in E is started at NUMSEC (a full track of sectors).
;    Sectors are read until sector counter E reaches zero or the total
;    reads counter in D reaches zero (RDTRIES revolutions). The 1st time
;    the total reads counter reaches zero, a restore and re-seek is
;    performed in case we're on the wrong track. The second time it reaches
;    zero, the bad sectors remain marked as bad in the track buffer.
; Within dRead, 152 cycles execute after the last byte is read until we're
;    executing the instruction here following the dRead call. An additional
;    78 cycles are executed here until we're in dNxtSec looking for sector
;    true. This totals 230 cycles (115us) from the last byte read until
;    we're hunting for sector true. Allowing for 200us of index alignment
;    error and 10% speed variance, we have at least 180us to get this done.
; For the Mini Disk, a full track is 16 sectors instead of 32 and the time
;    available after a sector is read is well over 1000us, so timing is not
;    an issue.
rdLoop:
	call	dNxtSec		;(17) wait for next sector, HL->sector buf
	mov	a,m		;A=sector flag byte
	ora	a		;this sector already read?
	jz	rdNext		;yes, skip it
	push	h		;save sector address
	inx	h		;HL->1st read location in sector
	call	dRead		;read the sector
	pop	h		;(10) restore sector address in HL
	jnz	rdNext		;(10) read error
	xra	a		;(4) set sector flag to zero (good sector)
	mov	m,a		;(7)
	dcr	e		;(5) decrement sectors left to fill
	jz	rtExit		;(10) all sectors read without error
rdNext:	dcr	d		;(5) decrement total sectors counter
	jnz	rdLoop		;(10) go read next sector
	lxi	h,skRetry	;HL->seek retry counter
	dcr	m		;decrement the counter
	jz	rtExit		;re-seek(s) done, we're finished
	call	dRestor		;restore to track zero
	jz	rtRtry		;start over after the re-seek
	ret			;else, exit with error
rtExit:	lhld	@RDRV		;L=@RDRV, H=@TRK
	shld	bfDrive		;set the buffered drive and track values
	ret			;exit with Z flag true
; initTrk - Set the flag byte in each sector in trkBuf to "bad" to
;    indicate none of the sectors have been read.
; On Entry
; On Exit
;    All sectors in trkBuf marked "bad" (unread)
;    Clobbers all
initTrk:
	lxi	b,UNDEF*256 + NUMSEC;  B=UNDEF (bad), C=NUMSEC
	lxi	h,trkBuf	;HL->track buffer
	lxi	d,TSECLEN	;DE=length of each sector in track buffer
itLoop:	mov	m,b		;mark sector as bad (not read)
	dad	d		;HL->next sector in trkBuf
	dcr	c		;repeat for all sectors
	jnz	itLoop
	ret
; ckFlush - Check if track buffer should be flushed. This
;    function must be called before any drive selection or seek
;    operation. The buffer is flushed if the bfDirty flag is
;    set and the drive or track number are different than the
;    buffered track.
; On Entry
;    Drive still selected and on same track as in trkBuf
;    @RDRV, @TRK updated for the new I/O call
; On Exit
;    Zero true for no error, zero false if write error occurred
;    Clobbers all
ckFlush:
	lda	bfDirty		;see if track buffer is dirty
	ora	a
	rz			;no, exit with Z set
	lda	@RDRV		;A=requested drive number
	cmp	l		;same drive?
	jnz	wrtTrk		;no, flush
	lda	@TRK		;A=requested track number
	cmp	h		;same track?
	rz			;yes, no need to flush
wrtTrk	equ	$
   if MINIDSK
	mvi	a,cRESTMR	;restart motor timeout
	out	DRVCMD
	lda	curDrv		;make sure current drive still enabled
	out	DRVSLCT
   endif
	mvi	e,cWRTEN	;E=write command, normal head current
	mvi	a,42		;tracks 0-42 are normal head current
	cmp	h		;compare 42 - current track
	jnc	wrtInit		;track is 0-42, E is correct
	mvi	e,cWRTEN+cHCSON	;E=write command with reduced current
wrtInit	xra	a		;clear buffer dirty flag
	sta	bfDirty
	mvi	a,WRTRIES	;initialize write retry count
	sta	wrRetry
	di			;disable interrupts
; rtryWrt - Write track retry entry point. Write a full track starting
;    with any sector. Don't write sectors that are flagged as bad.
rtryWrt:
	mvi	d,NUMSEC	;D=count of sectors to write
	xra	a		;zero the count of sectors actually written
	sta	secCnt
wrtLoop	call	dNxtSec		;(78) wait for next sector, HL->sector buf
	mov	a,m		;(7) check sector flag
	ora	a		;(4)
	jnz	wrtNext		;(10) skip if bad or previously verified
	mov	a,e		;(5) issue write command to drive
	out	DRVCMD		;(10) at 114 cycles 57us
	inx 	h		;point to 1st byte of sector
	call	dWrite		;write the sector
	lxi	h,secCnt	;count number of sectors written
	inr	m
wrtNext	dcr	d		;decrement write sector count
	jnz	wrtLoop		;loop until all sectors processed
	call	dNxtSec		;force a 1 sector delay for trim erase
	mvi	d,NUMSEC*VFTRIES   ;D=maximum number of sector reads
vfyLoop	call	dNxtSec		;wait for next sector, HL->sector buf
	mov	a,m		;test sector flag, only good and
	ora	a		;   not previously verified sectors
	jnz	vfyNext		;   are verified
	push	h		;save pointer to sector flag
	call	dVerify		;verify the sector
	pop	h		;HL->sector flag for current sector
	jnz	vfyNext		;didn't match
	mvi	m,UNDEF		;set flag to indicate sector is verified
	lxi	h,secCnt	;HL->sectors left to verify
	rz			;track verified, exit
vfyNext	dcr	d		;decrement sector count
	jnz	vfyLoop		;loop until all verify tries expired
; Read re-tries expired, decrement the write retry count and write again
	lxi	h,wrRetry	;decrement the write retry counter
	dcr	m
	jnz	rtryWrt		;retry starting with the write
	call	?pMsg
	db	CR,LF,'Delayed Write Error', CR, LF, 0
	inr	a
	ret			;exit with 1 for error
; Altair disk I/O routines
; dSelDrv - Select the drive specified in @RDRV and load the head.
;    Save the track (curTrk) the current drive is on into the track table,
;    load curTrk for the new drive from the track table.
; On Entry
;    @RDRV = drive to be selected
;    curDrv = drive currently selected
;    selTime = timeout in seconds to wait for drive select
;    curTrk = track the current drive is on
; On Exit
;    Drive selected and head loaded
;    curDrv = @RDRV
;    curTrk = track the newly selected drive is on
;    Zero true for success, zero false for error
;    Clobbers all
dSelDrv	equ	$
   if MINIDSK
	out	DRVCMD
   endif
	lxi	h,curDrv	;HL->currently selected drive
	mov	e,m		;E=currently selected drive
	lda	@RDRV		;A=desired drive
	mov	c,a		;save new drive in C
	cmp	e		;same or different drive?
	jnz	dNewDrv		;different, go select a new drive
	in	DRVSTAT		;drive still selected and enabled?
	ani	sDSKEN
	jz	dSelExt		;yes, exit
	jmp	dReSel		;otherwise, re-select the drive
; dNewDrv - Save current track (curTrk) for the current drive to the track
;    table, load curTrk for the new drive from the track table
dNewDrv	mov	m,c		;save new drive in curDrv
	mvi	d,0		;DE=currently selected drive
	lxi	h,trkTbl	;HL->track table
	dad	d		;HL->trkTbl entry for current drive
	lda	curTrk		;A=track current drive is on
	mov	m,a		;save it in the track table
	mov	e,c		;DE=offset in trkTbl for new drive
	dad	d		;HL->trkTbl for new drive
	mov	a,m		;A=track new drive is on
	sta	curTrk		;update current track
; Select the new drive with the timeout specified in selTime
dReSel	lxi	h,selTime	;move select timeout in seconds into B
	mov	b,m
dSelLp1	lxi	h,25641		;HL=count of 78 cycle loops for 1 second
dSelLp	mvi	a,cDSLCT	;(7) deselect a possibly attached drive
	out	DRVSLCT		;(10)
	mov	a,c		;(5) A=drive to select
	out	DRVSLCT		;(10) select it
	in	DRVSTAT		;(10) did drive select work?
	ani	sDSKEN		;(7)
	jz	dSelExt		;(5) yes, exit
	dcx	h		;(5) decr 1 sec counter
	mov	a,h		;(5) test HL counter for zero
	ora	l		;(4)
	jnz	dSelLp		;(10) loop for one second
	dcr	b		;decrement seconds expired
	jnz	dSelLp1		;repeat for a new 1 second
	inr	a		;timeout, return non-zero
	ret
dSelExt	mvi	a,cHDLOAD	;issue head load command
	out	DRVCMD		;restarts timeout for mini disk
	ret			;return with zero status
; dSeek - Seek to track in @TRK
; On Entry
;    Drive selected and ready
;    @TRK   = desired track
;    curTrk = current track, UNDEF means we don't know
; On Exit
;    curTrk = @TRK
;    Interrupts disabled
;    Zero true for success, zero false for failure
;	(failure is a failed restore to track zero)
;    Clobbers A,B,C,H,L
dSeek	di			;disable interrupts
	lda	curTrk		;A=current track
	cpi	UNDEF		;valid track number?
	jnz	dTrkVld		;yes, track is valid
	call	dRestor		;otherwise, restore to track zero
	rnz			;exit if restore failed
; dTrkVld - Current track is valid, compute direction and number
;     of steps
dTrkVld	lxi	h,@TRK		;HL<-@TRK
	sub	m		;A=current-requested
	rz			;return if already on correct track
	mvi	b,cSTEPO	;B=step out (assume requested<current)
	jnc	dDoSeek		;it is
	mvi	b,cSTEPI	;B=step in (requested>current)
	cma			;compute A=-A
	inr	a
; Save target track in curTrk, step there, then verify track
dDoSeek	mov	c,a		;C=number of steps
	mov	a,m		;save new track in curTrk
	sta	curTrk
	call	dStep		;do the seek
	xra	a		;return zero
	ret
; dRestor - Restore to track 0 and then delay to ensure any subsequent
;    seek meets the minimum direction change period.
; On Entry
; On Exit
;    If successful
;       curTrk = 0
;	A=0
;	Zero true
;    else
;       curTrk = UNDEF
;       Zero false
;    Clobbers A,B,C
dRestor	xra	a
	sta	curTrk		;set current drive track to zero
	in	DRVSTAT		;test for track 0
	ani	sTRACK0
	rz			;at track 0, exit
; Step in three tracks, then step out to track 0
	mvi	c,3		;C=step in 3 tracks
	mvi	b,cSTEPI	;B=step in command
	call	dStep		;do 3 steps in
	mvi	a,20		;20ms delay puts us past the 1ms step window
	call	delayMs		;  and ensures proper dir change delay
; Seek back out until track 0 detected
	mvi	c,NUMTRK+10	;C=maximum number of step outs to try
	mvi	b,cSTEPO	;B=step out command
	call	dStep		;step until track 0 detected
	jnz	drFail		;restore failed
drFail	mvi	a,UNDEF		;restore failed, track is still undefined
	sta	curTrk
	ret			;return with non-zero
; dStep - Step head number of steps in C, direction command in B.
;   If track zero is detected during a step-out operation, curTrk
;   is forced to zero and zero is returned in A.
; On Entry
;    C = number of steps > 0
;    B = step command (cSTEPO or cSTEPI)
; On Exit
;    If stepping out and track zero hit
;	curTrk = 0
;	A = 0
;	Zero true
;    else
;	Zero false
;    Clobbers A,B,C
dStep	in	DRVSTAT		;loop until OK to move the head
	ani	sMOVEOK
	jnz	dStep
	in	DRVSTAT		;see if we are at track 0
	ani	sTRACK0		;at track zero?
	jnz	dStep1		;no, go on
	mov	a,b		;stepping out?
	sbi	cSTEPO
	jz	dStep0		;yes, we've hit track 0
dStep1	mov	a,b		;A=step command and direction
	out	DRVCMD		;issue the step
	dcr	c		;decrement step counter
	jnz	dStep		;loop until count reaches zero
	inr	c		;force non-zero
	ret
dStep0	sta	curTrk		;curTrk=0
	ret			;return with zero true and A=0
; dNxtSec - Wait for next (any) sector. Returns pointer to the sector
;    buffer within trkBuf. Control is back to caller at 78 cycles (39us).
; On Entry
;    Drive is selected, head loaded
; On Exit
;    HL->sector buffer in trkBuf for sector found
dNxtSec	equ	$
   if MINIDSK
	out	DRVCMD
   endif
dnLoop	in	DRVSEC		;read sector position register
	rar			;wait for sector true (0=true)
	jc	dnLoop
	ani	SECMASK		;(7) get sector number alone
				;fall into dSecAdr
; dSecAdr - Convert hard sector in A to address within trkBuf for
;    the specified sector
; On Entry
;    A = Hard sector number
; On Exit
dSecAdr	lxi	h,secAddr  	;(10) HL->sector address table
	mvi	b,0		;(7) form BC=sector*2
	rlc			;(4) A=sector*2 (2 bytes per table entry)
	mov	c,a		;(5) BC=sector*2
	dad	b		;(10) HL->address table entry for passed sector
	mov	a,m		;(7) A=lsb of sector buffer address
	inx	h		;(5)
	mov	h,m		;(7) H=msb of sector buffer address
	mov	l,a		;(5) HL->sector buffer
	ret			;(11)
; delayMs - Delay for number of ms specified in A
; On Entry
;    A = ms to delay
; On Exit
;    A=0
;    Zero true
;    Clobbers A,B
delayMs	mvi	b,(2000/19)	;19 cycles in the loop below
delayLp	nop			;(4)
	dcr	b		;(5)
	jnz	delayLp		;(10)
	dcr	a		;decrement ms counter
	jnz	delayMs
	ret
; dRead - Read a sector, verify checksum, stop byte, and track number.
;    Verification is done after the sector is read in the time between
;    the last byte of the sector and before the start of the next sector.
;    With index alignment and rotation speed tolerance accounted for,
;    we safely have 360 cycles from the last byte of the sector until code
;    should be in the sector true hunt loop. The RET is complete from this
;    routine 152 cycles worst case after the last byte is read.
; On Entry
;    Drive is selected, sector true just detected
;    HL->sector buffer
; On Exit
;    Sector read to (HL)
;    C = track number from disk with sync bit set
;    Zero true if no error, Zero false for checksum error, missing
;	FF stop byte, or track number error
dRead	push	h		;(11) save pointer to start of sector
	lxi	b,256+DSECLEN	;(10) B=chksum (-FF), C=bytes to read
	lda	curTrk		;(13) A=track we're on
	cpi	DATATRK		;(7) data track or system track?
	jnc	drSecWt		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) C=length of a system sector
; The sector transfer loop is 116 cycles for two bytes read (has to be
;     less than 128) and computes checksum over all bytes read. For the
;     mini disk, only one byte is read per loop iteration.
drSecWt	in	DRVSTAT		;(10) get drive status byte
	ora	a		;(4) wait for NRDA flag true (zero)
	jm	drSecWt		;(10)
   if NOT MINIDSK		;8" reads two bytes per loop
	in	DRVDATA		;(10) read first byte at 24-48 cycles
	mov	m,a		;(7) store in buffer
	add	b		;(4) update checksum
	mov	b,a		;(5) keep checksum in B
	inx	h		;(5) increment buffer pointer
	dcr	c		;(5) decrement byte count
	jz	drSecDn		;(10) exit if done
   endif
	in	DRVDATA		;(10) read at 70-94 cycles (data at 64 and 128)
	jnz	drSecWt		;(10) repeat until done
; drSecDn - Sector read is complete, now validate the sector based on whether
;   it is from a system track or data track.
drSecDn	lda	curTrk		;(10) A=track we're supposed to be on
	cpi	DATATRK		;(7) system or data track?
	jnc	drDatTk		;(10) data track
; Validate a system track sector. A system track sector is three bytes
;    bytes shorter, so this codes starts 3*64 cycles sooner than for a
;    data sector. This code completes before a data sector would even
;    finish reading. Therefore, a data sector is the worst timing path.
	mov	a,b		;(5) A=calculated checksum over all bytes
	dcx	h		;(5) HL->checksum in sector
	sub	m		;(7) subtract from computed checksum
	sub	m		;(7) final sum will be zero
	dcx	h		;(5) HL->stop byte
	mov	b,m		;(7) B=stop byte
	pop	h		;(10) restore HL->start of buffer
	inr	b		;(4) was FF stop byte there?
	rnz			;(5/11) no, return error
	mov	c,m		;(7) C=track number from disk
	sub	c		;(4) take track out of checksum
	inx	h		;(5) HL->2nd byte of sector
	sub	m		;(7) take out of checksum
	inx	h		;(5) HL->3rd byte of sector
	jmp	drExit		;(10) do common compares and exit
; Validate a data track sector (125 + 27 cycles for sector type jump)
drDatTk	dcx	h		;(5) HL->stop byte
	mov	a,m		;(7) A=stop byte
	inr	a		;(4) was FF stop byte there?
	inx	h		;(5) HL->sector number
	inx	h		;(5) move to checksum byte
	inx	h		;(5)
	inx	h		;(5) HL->checksum
	sub	m		;(7) subtract from checksum
drExit	sub	m		;(7) checksums match?
	rnz			;(5/11) no, exit with error
	lda	curTrk		;(10) A=track we should be on
	ori	80h		;(7) set sync bit
	cmp	c		;(4) same track as from sector?
	ret			;(11) exit with compare status
; dVerify - Verify a sector
;    The 2nd read at 67 cycles only gives 3 cycles of headroom (67-64)
;    which, in turn, gives about 4% speed tolerance. However, we are
;    verifying our  own write, so the primary tolerance issue is ISV,
;    not the average rotation rate, so tolerance is still within the
;    +/-1.5% ISV spec.
; On Entry
;    HL->sector buffer to compare against
; On Exit
;    Zero true if match, zero false for error
dVerify lxi	b,DSECLEN	;(10) B=0, C=data sector length
	jnc	dVfLoop		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) set C=length of a system sector
dVfLoop	in	DRVSTAT		;(10) get drive status byte
	jm	dVfLoop		;(10)
	xra	m		;(4) verify data matches buffer
	ora	b		;(4) accumulate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement characters remaining counter
	jz	dVfDone		;(10) done verifying bytes
   endif
	in	DRVDATA		;(10) read 2nd byte at 67-91 cycles
	ora	b		;(4) accumlate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement byte counter
	jnz	dVfLoop		;(10) loop for all bytes
dVfDone	ora	a		;A=zero if all bytes matched
	ret			;return status
; dWrite - Write a sector
;    The write loop is 61 cycles which gives just 3 cycles (64-61) of
;    headroom. However, since the write timing required by the FDC board
;    is derived from the 2 MHz CPU/bus clock, this loop is always exactly
;    in sync with the FDC write timing. 3 cycles of headroom is plenty.
; On Entry
;    Drive is selected, sector true just detected, and
;	the write command has already been issued
;    HL->sector buffer to write
; On Exit
;   Clobbers A,C,H,L
dWrite	mvi	c,DSECLEN	;C=number of bytes to write
	jnc	dWrLoop		;(10) data track, length in C is correct
dWrLoop	in	drvStat		;(10) read drive status register
	rrc			;(4) wait for ENWD flag (zero)
	jc	dWrLoop		;(10)
	mov	a,m		;(7) A=next byte to write
	out	drvData		;(10) write 2nd byte at 68-92 cycles
	dcr	c		;(5) decrement bytes remaining
	jnz	dWrLoop		;(10) loop until all bytes written
dWrDone	in	drvStat		;wait for another write flag
	rrc
	jc	dWrDone
	xra	a		;write a trailing zero
	out	drvData
	ret
;   BIOS Data Area
; secAddr - Sector address table. Returns sector buffer address within
;    the track buffer when indexed by hard sector number. Each sector
;    requires TSECLEN bytes.
secAddr	dw	trkBuf+00*TSECLEN,trkBuf+01*TSECLEN,trkBuf+02*TSECLEN
	dw	trkBuf+03*TSECLEN,trkBuf+04*TSECLEN,trkBuf+05*TSECLEN
	dw	trkBuf+06*TSECLEN,trkBuf+07*TSECLEN,trkBuf+08*TSECLEN
	dw	trkBuf+09*TSECLEN,trkBuf+10*TSECLEN,trkBuf+11*TSECLEN
	dw	trkBuf+12*TSECLEN,trkBuf+13*TSECLEN,trkBuf+14*TSECLEN
	dw	trkBuf+15*TSECLEN
   if NOT MINIDSK
	dw	trkBuf+16*TSECLEN,trkBuf+17*TSECLEN,trkBuf+18*TSECLEN
	dw	trkBuf+19*TSECLEN,trkBuf+20*TSECLEN,trkBuf+21*TSECLEN
	dw	trkBuf+22*TSECLEN,trkBuf+23*TSECLEN,trkBuf+24*TSECLEN
	dw	trkBuf+25*TSECLEN,trkBuf+26*TSECLEN,trkBuf+27*TSECLEN
	dw	trkBuf+28*TSECLEN,trkBuf+29*TSECLEN,trkBuf+30*TSECLEN
	dw	trkBuf+31*TSECLEN
   endif
; Initialized data
selTime	db	7		;drive select timeout in seconds
coldSt	db	0FFh		;FF during cold start, 0 otherwise
curDrv	db	0		;drive number currently selected
curTrk	db	UNDEF		;track the selected drive is on
trkTbl	db	UNDEF,UNDEF,UNDEF,UNDEF		;track each drive is on
bfDirty	db	0		;non-zero if buffer has been written to
bfDrive	db	UNDEF		;drive currently in track buffer
bfTrack	db	UNDEF		;currently buffered track (MUST follow bfDrive)
; Non-initialized data
secCnt	ds	1		;count of bad sectors remaining in trkBuf
wrRetry	ds	1		;write retry counter
skRetry	ds	1		;restore and seek retry counter
;  Disk scratchpad areas defined in the DPH table
dirBuf	ds	128		;BDOS directory scratchpad
alv0	ds	(DSM/8 + 1)	;allocation vector storage
csv0	ds	CKS		;change disk scratchpad
alv1	ds	(DSM/8 + 1)
csv1	ds	CKS
; Track buffer. One extra byte is allocated at the start of each sector
;    to flag a bad sector (read failure). This byte is zero if the sector
;    is good, non-zero if the sector is bad.
trkBuf	ds	NUMSEC*TSECLEN
	end
IDE3.asm:
	TITLE	'IDE MODULE FOR CP/M 3.0'
	; IDE3.ASM  v.1.0  02/22/2023
	; IDE disk device driver module for Altair computers.
	; Supports the IDE-CF controller provided by
	; S100computers.com.
	; John Monahan designed the controller board and wrote
	; a version of BIOS for his Z80-based systems.  The IDE
	; interface was based on a design from Peter Faasse.
	; Another important contributor is David Fry who recognized
	; that the original format left "holes" on the disk because
	; it skipped sectors in the LBA translation.
	; This version is a re-write that takes all of those things
	; and incorporates them in an 8080-compatible format that
	; runs on an original Altair and compatible computers.
;INCLUDE CP/M 3.0 DISK DEFINITION MACROS:
MACLIB	CPM3
;INCLUDE Z-80 MACRO LIBRARY:
MACLIB	Z80
;Ports for 8255 chip. Change these to specify where the 8255 is addressed,
;and which of the 8255's ports are connected to which IDE signals.
;The first three control which 8255 ports have the control signals,
;upper and lower data bytes.  The last one is for mode setting for the
;8255 to configure its ports, which must correspond to the way that
;the first three lines define which ports are connected.
IDEportA	EQU	030H		;lower 8 bits of IDE interface
IDEportB	EQU	031H		;upper 8 bits of IDE interface
IDEportC	EQU	032H		;control lines for IDE interface
IDEportCtrl	EQU	033H		;8255 configuration port
IDEDrive	EQU	034H	;Bit 0 - 0 for drive 0 and 1 for drive 1
READcfg8255	EQU	10010010b	;Set 8255 IDEportC out, IDEportA/B input
WRITEcfg8255	EQU	10000000b	;Set all three 8255 ports output
;IDE control lines for use with IDEportC.  Change these 8
;constants to reflect where each signal of the 8255 each of the
;IDE control signals is connected.  All the control signals must
;be on the same port, but these 8 lines let you connect them to
;whichever pins on that port.
IDEa0line	EQU	01H	;direct from 8255 to IDE interface
IDEa1line	EQU	02H	;direct from 8255 to IDE interface
IDEa2line	EQU	04H	;direct from 8255 to IDE interface
IDEcs0line	EQU	08H	;inverter between 8255 and IDE interface
IDEcs1line	EQU	10H	;inverter between 8255 and IDE interface
IDEwrline	EQU	20H	;inverter between 8255 and IDE interface
IDErdline	EQU	40H	;inverter between 8255 and IDE interface
IDErstline	EQU	80H	;inverter between 8255 and IDE interface
;Symbolic constants for the IDE Drive registers, which makes the
;code more readable than always specifying the address pins
REGdata		EQU	IDEcs0line
REGerr		EQU	IDEcs0line + IDEa0line
REGseccnt	EQU	IDEcs0line + IDEa1line
REGsector	EQU	IDEcs0line + IDEa1line + IDEa0line
REGcylinderLSB	EQU	IDEcs0line + IDEa2line
REGcylinderMSB	EQU	IDEcs0line + IDEa2line + IDEa0line
REGshd		EQU	IDEcs0line + IDEa2line + IDEa1line		;(0EH)
REGcommand	EQU	IDEcs0line + IDEa2line + IDEa1line + IDEa0line	;(0FH)
REGstatus	EQU	IDEcs0line + IDEa2line + IDEa1line + IDEa0line
REGcontrol	EQU	IDEcs1line + IDEa2line + IDEa1line
REGastatus	EQU	IDEcs1line + IDEa2line + IDEa1line + IDEa0line
;IDE Command Constants.  These should never change.
COMMANDrecal	EQU	10H
COMMANDread	EQU	20H
COMMANDwrite	EQU	30H
COMMANDinit	EQU	91H
COMMANDid	EQU	0ECH
COMMANDspindown	EQU	0E0H
COMMANDspinup	EQU	0E1H
MAXSEC		EQU	3FH
LBA$MODE	EQU	11100000b
; IDE Status Register:
;  bit 7: Busy	1=busy, 0=not busy
;  bit 6: Ready 1=ready for command, 0=not ready yet
;  bit 5: DF	1=fault occured insIDE drive
;  bit 4: DSC	1=seek complete
;  bit 3: DRQ	1=data request ready, 0=not ready to xfer yet
;  bit 2: CORR	1=correctable error occured
;  bit 1: IDX	vendor specific
;  bit 0: ERR	1=error occured
BUSY$FLAG	EQU	10000000b
BUSY$DRQ	EQU	10001000b
RDY$DRQ		EQU	00001000b
BUSY$CMD	EQU	11000000b
RDY$CMD		EQU	01000000b
; Console ASCII equates
BELL	EQU	07H
CR	EQU	0DH
LF	EQU	0AH
	; Public labels exposed:
	PUBLIC	DPH2, DPH3	;IDE drive parameter headers
	; External labels:
	EXTRN	@ADRV,@RDRV
	EXTRN	@CBNK
	EXTRN	@DBNK
	EXTRN	@ERMDE		;BDOS error mode
	EXTRN	?WBOOT
	EXTRN	?PMSG		;Print null-terminated string
	EXTRN	?PDERR		;Print BIOS disk error
	EXTRN	?CONIN,?CONO	;Console I/O
	EXTRN	?CONST		;Console status
	; Extended disk parameter header for IDE drive 0:
	DW	HDWRT		;IDE Drive Write
	DW	HDRD		;IDE Drive Read
	DW	SELECT0		;IDE Login
	DW	INIT0		;IDE Init
	DB	0		;Controller drive number
	DB	0		;Media Type
DPH2:	DPH	0,IDEHD$DPB,0,
	; Extended disk parameter header for IDE drive 1:
	DW	SELECT1		;IDE Login
	DW	INIT1		;IDE Init
	DB	1		;Controller drive number
	DB	0		;Media Type
DPH3:	DPH	0,IDEHD$DPB,0,
	; Put DPBs in common memory
	CSEG
	; 512 byte sectors on hard disk (512 x 64 x 256 = 8,388,608 bytes)
IDEHD$DPB:
	DPB	512,64,256,2048,1024,1,8000H
	; 2048 allocation unit size, 1024 directory entries
; IDE Initialization / Login
SELECT0:			;Select drive 0
	XRA	A
	JMP	SELECTdrive
SELECT1:			;Select drive 1
	MVI	A, 1
SELECTdrive:			;Select drive [A]
	OUT	IDEDrive
	RET
INIT0:
	XRA	A
	OUT	IDEDrive	;Select drive 0
	JMP	IDEinit
INIT1:
	MVI	A, 1
	OUT	IDEDrive	;Select drive 1
IDEinit:			;Initialize the 8255 and drive
	MVI	A,READcfg8255
	OUT	IDEportCtrl	;config 8255 chip, READ mode
	MVI	A,IDErstline
	OUT	IDEportC	;reset
	MVI	B, 20H
ResetDelay:
	DCR	B
	JNZ	ResetDelay	;delay (reset pulse width)
	XRA	A
	OUT	IDEportC	;no IDE control lines asserted (just bit 7 of port C)
	CALL	DELAY$32
	MVI	D, LBA$MODE	;11100000B
	MVI	E, REGshd
	CALL	IDEwr8D		;write byte to select the MASTER device
	MVI	B, 0FFH		;set delay time
WaitInit:
	MVI	E, REGstatus	;get status after initialization
	CALL	IDErd8D		;check status
	MOV	A, D
	ANI	BUSY$FLAG	;check busy flag
	JZ	DoneInit	;return if ready bit is zero
	PUSH	B
	LXI	B, 0FFFFH	;long delay to allow drive to get up to speed
DELAY2:	MVI	D, 2
DELAY1:	DCR	D
	JNZ	DELAY1
	DCX	B
	MOV	A,C
	ORA	B
	JNZ	DELAY2
	POP	B
	DCR	B
	JNZ	WaitInit
	CALL	SetErrorFlag	;if not ready by this point, return with NZ flag set
	LXI	H, MSG$INIT$ERR
	CALL	?PMSG
	ORI	1
	RET
DoneInit:
	XRA	A		;return with no error
	RET
; SECTOR WRITE ROUTINE
HDWRT:				;Write one sector
	XRA	A
	STA	ERFLG		;clear error flag
	CALL	wrlba		;convert track/sector to LBA
	CALL	IDEwaitnotbusy	;make sure drive is ready
	JC	SetErrorFlag
	MVI	D, COMMANDwrite
	MVI	E, REGcommand
	CALL	IDEwr8D		;tell drive to write a sector
	CALL	IDEwaitdrq	;wait unit it wants the data
	JC	SetErrorFlag	;if problem abort
	LHLD    @DMA		;DMA address
	MVI	A, WRITEcfg8255
	OUT	IDEportCtrl
	MVI	B,0		;256x2 bytes
WRSEC1:
	MOV	A, M
	INX	H
	OUT	IDEportA	;LOW byte to port A first
	MOV	A, M
	INX	H
	OUT	IDEportB	;then HIGH byte to port B
	MVI	A, REGdata
	PUSH	PSW
	OUT	IDEportC	;send write command
	ORI	IDEwrline	;send WR pulse
	OUT	IDEportC
	POP	PSW
	OUT	IDEportC
	DCR	B
	JNZ	WRSEC1
	MVI	A, READcfg8255	;set 8255 back to read mode
	OUT	IDEportCtrl
CHECK$RW:
	MVI	E, REGstatus	;check R/W status when done
	CALL	IDErd8D
	MOV	A, D
	ANI	01H
	STA	ERFLG		;return Z if successful
	RZ
SetErrorFlag:			;for now just return with error flag set
	XRA	A
	DCR	A
	STA	ERFLG		;return NZ if problem
	RET
; SECTOR READ ROUTINE
HDRD:				;Read one sector
	XRA	A
	JC	SetErrorFlag	;NZ set if error
	MVI	D, COMMANDread
	MVI	E, REGcommand
	CALL	IDEwr8D		;send sector read command
	CALL	IDEwaitdrq	;wait until data ready
	MVI	B, 0
MoreRD16:
	MVI	A,REGdata	;select data register address
	OUT	IDEportC
	ORI	IDErdline	;08H+40H, pulse RD line
	OUT	IDEportC
	IN	IDEportA	;read the LOW byte first
	MOV	M, A
	INX	H
	IN	IDEportB	;then the HIGH byte
	MOV	M,A
	INX	H
	MVI	A, REGdata	;deassert RD line
	OUT	IDEportC
	DCR	B
	JNZ	MoreRD16
	JMP	CHECK$RW
; SUPPORT ROUTINES
wrlba:				;Translate to logical block address
	CALL	IDEwaitnotbusy	;make sure drive isn't busy
	LHLD	@TRK		;get the CP/M requested track high and low
	MOV	A, L		;get low byte of track, interested in bottom two bits
	RRC			;shift 'em
	RRC			;shift again to the top
	ANI	0C0H		;examine those two bits
	MOV	C, A		;save in [C]
	LDA	@SECT		;sector number (low byte) into [A]
	ANI	03FH		;take only bottom 6 bits
	ORA	C		;add in top 2 bits of track
	MOV	D, A		;send info to the drive
	MVI	E, REGsector
	CALL	IDEwr8D
	MOV	A, L		;get low byte of track again
	RRC
	RRC
	ANI	03FH
	MOV	A, H		;get high byte of track
	RRC			;rotate twice, leaving low 2 bits
	RRC			;in upper bits of [A]
	ANI	0C0H		;mask all but the two bits we want
	ORA	C		;add in the top 6 bits of the first track byte
	MOV	D, A		;send Low TRK#
	MVI	E, REGcylinderLSB
	CALL	IDEwr8D
	RRC			;just the top 6 bits
	RRC
	ANI	03FH
	MOV	D, A		;send High TRK#
	MVI	E, REGcylinderMSB
	CALL	IDEwr8D
	MVI	D, 1		;one sector at a time
	MVI	E, REGseccnt
	CALL	IDEwr8D
	RET
IDEwaitnotbusy:			;Drive READY if 01000000
	MVI	B, 0FFH
	MVI	C, 0FFH		;delay, must be above 80H. Leave longer for slower drives
MoreWait:
	MVI	E, REGstatus	;wait for RDY bit to be set
	CALL	IDErd8D
	MOV	A, D
	ANI	BUSY$CMD	;11000000B
	XRI	RDY$CMD		;01000000B
	JZ	DoneNotbusy
	DCR	B
	JNZ	MoreWait
	DCR	C
	JNZ	MoreWait
	STC			;set carry to indicqate an error
	ret
DoneNotBusy:
	ORA	A		;clear carry it indicate no error
	RET
IDEwaitdrq:
	MVI	B, 0FFH
	MVI	C, 0FFH		;delay must be above 80H. Leave longer for slower drives
MoreDRQ:
	MVI	E, REGstatus	;dait for DRQ bit to be set
	CALL	IDErd8D
	MOV	A, D
	ANI	BUSY$DRQ	;10001000B
	CPI	RDY$DRQ		;00001000B
	JZ	DoneDRQ
	DCR	B
	JNZ	MoreDRQ
	DCR	C
	JNZ	MoreDRQ
	STC			;set carry to indicate error
	RET
DoneDRQ:
	ORA	A		;clear carry
	RET
DELAY$32:
	MVI	A, 40		;delay ~32ms
DELAY3:
	MVI	B, 0
M0:
	DCR	B
	JNZ	M0
	DCR	A
	JNZ	DELAY3
	RET
; Low Level 8 bit R/W to the drive controller.  These are the routines that talk
; directly to the drive controller registers, via the 8255 chip.
; Note the 16 bit I/O to the drive (which is only for SEC R/W) is done directly
; in the routines HDRD & HDWRT for speed reasons.
IDErd8D:			;Read byte from IDE register in [E], return info in [D]
	MOV	A, E
	OUT	IDEportC	;drive address onto control lines
	ORI	IDErdline	;RD pulse pin (40H)
	OUT	IDEportC	;assert read pin
	IN	IDEportA
	MOV	D, A		;return with data in [D]
	MOV	A, E
	OUT	IDEportC	;deassert RD pin first
	XRA	A
	OUT	IDEportC	;zero all port C lines
	RET
IDEwr8D:			;Write byte in [D] to IDE register in [E]
	MVI	A, WRITEcfg8255	;set 8255 to write mode
	OUT	IDEportCtrl
	MOV	A, D		;get data put it in 8255 A port
	OUT	IDEportA
	MOV	A, E		;select IDE register
	OUT	IDEportC
	ORI	IDEwrline	;lower WR line
	OUT	IDEportC
	MOV	A, E
	OUT	IDEportC	;deassert WR pin first
	XRA	A		;deselect all lines including WR line
	OUT	IDEportC
	MVI	A, READcfg8255	;config 8255 chip, read mode on return
	OUT	IDEportCtrl
	RET
MSG$INIT$ERR DB	'Initilization of IDE drive failed.',CR,LF,0
ERFLG:		DB	0H
Great work!
I've been testing the BIOS for about a week now, and I'm satisfied that it is working properly. So I've created a distribution archive, which contains the source code, executable binaries and a couple of 330Kb bootable image files, one for 48Kb RAM and the other for 63Kb.
This version of CP/M boots from 330Kb diskette and supports two 330Kb diskette drives and two 8Mb IDE drives, either magnetic or compact flash. The diskettes are A and B and the hard drives are C and D.
I actually found and fixed one last bug. I had initially placed the drive-selection logic in the "login" function for each drive. But the login function is only called once, immediately after first selection of the drive. So I removed the drive selection logic from the login function and added it at the beginning of the read and write functions.
You can see my troubleshooting steps at the link below. It's essentially the same notes I made that were the subject of this thread. So scroll down to the bottom to see the last stuff I did. It's all kind of a yawner, but might help someone else in the future trying to troubleshoot a new BIOS. At least it'll help me remember if I ever need it.
=== Next Steps ===
I'm pretty happy with this version of CP/M exactly as it stands. But there are a few things that might be useful at some point:
1. A version of BIOS that boots from an IDE drive.
2. BIOS that supports banked memory on the Altair. Of course, we'd need to choose or define and develop memory hardware first.
3. BIOS or tool that changes the CP/M accessible drive from "partition" 00 to any other.
To explain this third idea, you might remember earlier in this thread where I described a feature I added to IDEutil that allows the selection of "partitions." What I did was to logically group the tracks into "partitions," using the most significant byte of the track number.
CP/M tracks are 00-FF and sectors are 00-3F for each of the IDE drives. But the drive is capable of tracks 0000-FFFF. So the first 8Mb is tracks 0000-00FF, the second is 0100-01FF, and so on. IDEutil can access any of these areas, but CP/M can only "see" the first one.
It might be nice to add a feature - tied in through the wrlba function in IDE3.asm - that allows the user to change "partitions" in CP/M, to allow any of 256 to be selected. That would expose an entire 2Gb drive to CP/M.
mr_metra_nilak
Post by mr_metra_nilak »
Hello,
I just read the entire thread. What a journey! I've been trying to get the Dual IDE V4 board to work and ran into some issues that have been occupying me for quite some time now. Maybe someone here has ideas or insights as to why I'm having these issues: I'm able to initialize a drive and read/copy data from the drive. The problem that I'm having is that, when the computer runs my code to read and copy data from the drive to RAM, it skips certain words occasionally. It's always the same words (it seems) but whether they are present or not is kind of random. That is - sometimes they are read while other times they are skipped and the next word is actually read from the buffer instead (by "word" I mean the HI and LO byte).
I'm using a variant of a bootloader that was present in this thread but I modified it a bit to get it working on my Altair (Intel 8080). The code reads from a CF drive that contains CP/M V3. I can see that it copies most of it into RAM address 0100H but, as I stated above, certain words are skipped. I also read from the CF card on my other computer to see what was on it and those words are present.
For example, here are the first few records. I have tags around the words that are skipped.
00000200: 3181 02cd 000b 0e0d cd8d 020e 0911 2502  1.............%.
00000210: cd8d 020e 0f11 ab01 cd8d 02fe ff11 cf01  ................
00000220: caa2 0111 8000 cd8f 01cd 9501 2180 0011  ............!...
00000230: 8102 0e06 7e12 1323 0dc2 3401 cd95 010e  ....~..#..4.....
00000240: 0911 8000 cd8d 023a 8202 673a 8102 cd73  .......:..g:...s
00000250: 013a 8402 b7ca 5f01 673a 8302 cd73 0121  .:...._.g:...s.!
00000260: 5d00 7efe 24c2 6f01 [b]237e[/b] fe42 cca9 0131  ].~.$.o.#~.B...1
00000270: 8502 c9b7 571e 007c 1767 [b]eb01[/b] 80ff 09eb  ....W..|.g......
00000280: d5e5 cd8f 01cd 9501 e1d1 25c2 7a01 c90e  ..........%.z...
The code that reads from the drive and copies to RAM is the following:
MoreRD16:
        MVI     A,REGdata               ;REG register address
        OUT     IDECport
        ORI     IDErdline               ;08H+40H, Pulse RD line
        OUT     IDECport
        IN      IDEAport                ;read the LOWER byte
        MOV     M,A
        INX     H
        IN      IDEBport                ;read the UPPER byte
        MOV     M,A
        INX     H
        MVI     A,REGdata               ;Deassert RD line
        OUT     IDECport
        DCR     B
        JNZ     MoreRD16
        DCR     C
        JNZ     MoreRD16
        MVI     E,REGstatus             ;Check the R/W status when done
        CALL    IDErd8D
        MOV     A,D                     ;Z80 = Bit 0,D  (A is unused)
        ANI     01H
        JNZ     IDEerr1                 ;Z if no errors
        LXI     H,CPMADDRESS
        MOV     A,M
        CPI     31H                     ;EXPECT TO HAVE 31H @80H IE. MOV SP,80H
        JZ      CPMADDRESS              ;AS THE FIRST INSTRUCTION. IF OK JMP to 100H in RAM
        JMP     ERRLD1                  ;Boot Sector Data incorrect
Here is the full code:
BELL    EQU     07H
CR      EQU     0DH
LF      EQU     0AH
;-------------- S100Computers I/O BOARD PORT ASSIGNMENTS  (A0-AC)
BCTL            EQU     10H            ;CHANNEL B CONTROL PORT ASSIGNMENTS OF THE ZILOG SCC CHIP
BDTA            EQU     11H            ;CHANNEL B DATA
;-------------- S100Computers IDE HARD DISK CONTROLLER COMMANDS ETC.
CPMADDRESS      EQU     100H            ;Will place the CPMMOVR.COM Loader here with
                                        ;CPMMOVR.COM will ALWAYS be on TRK 0,SEC2, (LBA Mode)
SECCOUNT        EQU     12              ;CPMMOVR.COM requires (currently) 10, 512 byte sectors
IDEAport        EQU     030H            ;lower 8 bits of IDE interface
IDEBport        EQU     031H            ;upper 8 bits of IDE interface
IDECport        EQU     032H            ;control lines for IDE interface
IDECtrl         EQU     033H            ;8255 configuration port
IDEDrivePort    EQU     034H            ;To select the 1st or 2nd CF card/drive (Not used with this monitor)
IDEreset        EQU     80H             ;inverter between 8255 and IDE interface
IDEResetDelay   EQU     020H            ;Time delay for reset/initilization (~60 uS, with 10MHz Z80, 2 I/O wait states)
RDcfg8255       EQU     10010010B       ;Set 8255 IDECport out, IDEAport/B input
WRcfg8255       EQU     10000000B       ;Set all three 8255 ports output
REGdata         EQU     08H             ;IDEcs0line
REGerr          EQU     09H             ;IDEcs0line + IDEa0line
REGcnt          EQU     0AH             ;IDEcs0line + IDEa1line
REGsector       EQU     0BH             ;IDEcs0line + IDEa1line + IDEa0line
REGcyLSB        EQU     0CH             ;IDEcs0line + IDEa2line
REGcyMSB        EQU     0DH             ;IDEcs0line + IDEa2line + IDEa0line
REGshd          EQU     0EH             ;IDEcs0line + IDEa2line + IDEa1line             ;(0EH)
REGCMD          EQU     0FH             ;IDEcs0line + IDEa2line + IDEa1line + IDEa0line ;(0FH)
REGstatus       EQU     0FH             ;IDEcs0line + IDEa2line + IDEa1line + IDEa0line
DIAGLEDS       EQU     5               ;OUT (Will use this port initially for diagnostic LED display)
;IDE CMD Constants.  These shouMOV never change.
CMDrecal        EQU     10H
CMDread         EQU     20H
CMDwrite        EQU     30H
CMDinit         EQU     91H
CMDid           EQU     0ECH
CMDdownspin     EQU     0E0H
CMDupspin       EQU     0E1H
;-------------- BOOT UP CPM FROM HARD DISK ON S100COMPUTERS IDR BOARD ----------------
;BOOT UP THE 8255/IDE Board HARD DISK/Flash Memory Card
;NOTE CODE IS ALL HERE IN CASE A 2716 IS USED
ORG 0DF00H
INITIALIZE:
        MVI     A,3             ;RESET 6850 UART
        OUT     BCTL
        MVI     A,11H           ;8N2
        OUT     BCTL
HBOOTCPM:
        POP     H                       ;CLEAN UP STACK
        LXI     H,SPEAKCPMMSG           ;Announce on speaker
        CALL    SPEAK
        CALL    INITILIZEIDEBOARD       ;Initilze the 8255 and drive (again just in case)
        JC      ERRNR                   ;Carry set to indicate an error, Drive not ready
        MVI     D,11100000B             ;Data for IDE SDH reg (512bytes, LBA mode,single drive)
        MVI     E,REGshd                ;00001110,(0EH) CS0,A2,A1,
        CALL    IDEwr8D                 ;Write byte to select the MASTER device
        MVI     B,0FFH                  ;Delay time to allow a Hard Disk to get up to speed
WaitInit:
        MVI     E,REGstatus             ;Get status after initilization
        CALL    IDErd8D                 ;Check Status (info in [D])
        MOV     A,D                     ;Z80 = BIT 7,D (A is not needed)
        ANI     80H
        JZ      SECREAD                 ;Zero, so all is OK to write to drive
                                        ;Delay to allow drive to get up to speed
        PUSH    B
        LXI     B,0FFFFH
DXLAY2: MVI     D,2                     ;May need to adjust delay time to allow coMOV drive to
DXLAY1: DCR     D                       ;to speed
        JNZ     DXLAY1
        DCX     B
        MOV     A,C
        ORA     B
        JNZ     DXLAY2
        POP     B
        DCR     B
        JNZ     WaitInit                ;If after 0FFH, 0FEH, 0FDH... 0, then drive initilization problem
IDError:
        LXI     H,DRIVENRERR          ;Drive not ready
        JMP     ABORTERRMSG
SECREAD:                                ;Note CPMMOVR will ALWAYS be on TRK 0,SEC 1,Head 0
        MVI     A,11111111B             ;FLAG PROGRESS VISUALLY FOR DIAGNOSTIC
        OUT     DIAGLEDS
        CALL    IDEwaitnotbusy          ;Make sure drive is ready
        JC      IDError                 ;NC if ready
        MVI     D,1                     ;Load track 0,sec 1, head 0
        MVI     E,REGsector             ;Send info to drive
        CALL    IDEwr8D
        MVI     D,0                     ;Send Low TRK#
        MVI     E,REGcyLSB
        CALL    IDEwr8D
        MVI     D,0                     ;Send High TRK#
        MVI     E,REGcyMSB
        CALL    IDEwr8D
        MVI     D,SECCOUNT              ;Count of CPM sectors we wish to read
        MVI     E,REGcnt
        CALL    IDEwr8D
        MVI     D,CMDread               ;Send read CMD
        MVI     E,REGCMD
        CALL    IDEwr8D                 ;Send sec read CMD to drive.
        CALL    IDEwdrq                 ;Wait until it's got the data
        LXI     H,CPMADDRESS            ;DMA address where the CPMMOVR resides in RAM
        MVI     B,0                     ;256X2 bytes
        MVI     C,SECCOUNT              ;Count of sectors X 512
MoreRD16:
        OUT     IDECport
        OUT     IDECport
        MOV     M,A
        INX     H
        MOV     M,A
        INX     H
        OUT     IDECport
        DCR     B
        JNZ     MoreRD16
        DCR     C
        JNZ     MoreRD16
        CALL    IDErd8D
        ANI     01H
        LXI     H,CPMADDRESS
        MOV     A,M
IDEerr1:
        LXI     H,IDERWERROR            ;Drive R/W Error
        JMP     ABORTERRMSG
;      ----- SUPPORT ROUTINES --------------
INITILIZEIDEBOARD:                      ;Drive Select in [A]. Note leaves selected drive as [A]
        MVI     A,RDcfg8255             ;Config 8255 chip (10010010B), read mode on return
        OUT     IDECtrl                 ;Config 8255 chip, READ mode
                                        ;Hard reset the disk drive
                                        ;For some reason some CF cards need to the RESET line
                                        ;pulsed very carefully. You may need to play around
        MVI     A,IDEreset              ;with the pulse length. Symptoms are: incorrect data coming
        OUT     IDECport                ;back from a sector read (often due to the wrong sector being read)
                                        ;I have a (negative)pulse of 60 uSec. (10Mz Z80, two IO wait states).
        MVI     C,IDEResetDelay         ;~60 uS seems to work for the 5 different CF cards I have
ResetDelay:
        DCR     C
        JNZ     ResetDelay              ;Delay (reset pulse width)
        XRA     A
        OUT     IDECport                ;No IDE control lines asserted (just bit 7 of port C)
        CALL    DELAY15                 ;Need to delay a little before checking busy status
        MVI     B,0FFH
        MVI     C,0FFH                  ;Delay, must be above 80H for 4MHz Z80. Leave longer for slower drives
MoreWait:
        MVI     E,REGstatus             ;Wait for RDY bit to be set
        CALL    IDErd8D
        MOV     A,D
        ANI     11000000B
        XRI     01000000B
        JZ      DoneNotbusy
        DCR     B
        JNZ     MoreWait
        DCR     C
        JNZ     MoreWait
        STC                             ;Set carry to indicate an error
        RET
DoneNotBusy:
        ORA     A                       ;Clear carry it indicate no error
        RET
                                        ;Wait for the drive to be ready to transfer data.
IDEwdrq:                                ;Returns the drive's status in Acc
        MVI     B,0FFH
MoreDRQ:
        MVI     E,REGstatus             ;wait for DRQ bit to be set
        CALL    IDErd8D
        MOV     A,D
        ANI     10001000B
        CPI     00001000B
        JZ      DoneDRQ
        DCR     B
        JNZ     MoreDRQ
        DCR     C
        JNZ     MoreDRQ
        STC                             ;Set carry to indicate error
        RET
DoneDRQ:
        ORA     A                       ;Clear carry
        RET
; Note the 16 bit I/O to the drive (which is only for SEC Read here) is done directly
; in the routine MoreRD16 for speed reasons.
IDErd8D:                                ;READ 8 bits from IDE register in [E], return info in [D]
        MOV     A,E
        OUT     IDECport                ;drive address onto control lines
        OUT     IDECport                ;assert read pin
        IN      IDEAport
        MOV     D,A                     ;return with data in [D]
        MOV     A,E                     ;Ken Robbins suggestion
        OUT     IDECport                ;Deassert RD pin
        XRA     A
        OUT     IDECport                ;Zero all port C lines
        RET
IDEwr8D:                                ;WRITE Data in [D] to IDE register in [E]
        MVI     A,WRcfg8255             ;Set 8255 to write mode
        OUT     IDECtrl
        MOV     A,D                     ;Get data put it in 8255 A port
        OUT     IDEAport
        MOV     A,E                     ;select IDE register
        OUT     IDECport
        OUT     IDECport
        MOV     A,E                     ;Kens Robbins suggestion, raise WR line
        OUT     IDECport
        XRA     A                       ;Deselect all lines including WR line
        OUT     IDECport
        MVI     A,RDcfg8255             ;Config 8255 chip, read mode on return
        OUT     IDECtrl
        RET
SPEAKOUT:
        XRA     A                       ;Will try 256 times, then timeout
SPXXX:  PUSH    PSW
        IN      BCTL                    ;(A0), Is SCC TX Buffer empty
        ANI     2
        JNZ     SENDS                   ;NZ if ready to recieve character
        POP     PSW
        DCR     A
        JNZ     SPXXX
        RET
SENDS:  POP     PSW
        MOV     A,C
        OUT     BDTA                    ;(A2), Send it
        RET
;SPEAKTOMM THIS IS A ROUTINE TO SEND A STRING TO TALKER [HL] AT STRING
SPEAK:  MOV     A,M
        CPI     '$'
        JZ      SPEAK1
        MOV     C,A
        CALL    SPEAKOUT
        INX     H
        JMP     SPEAK
SPEAK1: MVI     C,0DH                   ;MUST END WITH A CR
        JMP     SPEAKOUT
DELAY:  DCR     A                       ;GENERAL COUNT DOWN TIME DELAY
        RZ                              ;LENGTH SET IN [A]
        PUSH    PSW
        MVI     A,05H
MORE:   DCR     A
        PUSH    PSW
        XRA     A
MORE2:  DCR     A
        JNZ     MORE2
        POP     PSW
        JNZ     MORE
        POP     PSW
        JMP     DELAY
DELAY15:                                ;DELAY ~15 MS
        MVI     A,40
DELAY1: MVI     B,0
M0:     DCR     B
        JNZ     M0
        DCR     A
        JNZ     DELAY1
        RET
ERRNR:  LXI     H,DRIVENRERR            ;"DRIVE NOT READY
        JMP     ABORTERRMSG
ERRLD1:
        LXI     H,BOOTLD1ERR            ;"DATA ERROR IN BOOT SECTOR"
ABORTERRMSG:
        CALL    SPEAK
        JMP     HBOOTCPM                ;BACK TO START
SPEAKCPMMSG:    DB      'LOADING CPM $'
DRIVENRERR:     DB      BELL,CR,LF
                DB      'Drive not Ready.',CR,LF,LF,'$'
BOOTLD1ERR:     DB      BELL,CR,LF
                DB      'BOOT error.',CR,LF,LF,'$'
IDERWERROR:     DB      CR,LF
                DB      'IDE Drive R/W Error'
                DB      CR,LF,'$'
I would really appreciate some help on this as I've been banging my head for the past few days, if not weeks.
Nice to see a fellow IDE owner here!
One thing I would probably suggest is to get the latest copy of the bootloader. You may have already done that, but if not, I'd start there.
After that, if you need to troubleshoot further, I'd definitely suggest using SID. As you saw, when I was developing the code for my version of CP/M, I leaned heavily on the SID debugger. I would encourage you to do that too. It's an old debugger, but it does the job.
The real trick for me was finding places to set breakpoints, uh, I meant passpoints. That was always the hardest part. 'Cause once you've entered a loop, you have to step a few hundred or thousand steps to get past it. So the trick is to find places to put passpoints - before functional (iterative) blocks that you're not sure of, and after stuff that you are sure of.
You may have seen my (super-boring) SID flow documents. I used a lot of "P" commands (to set passpoints) and "G" commands to execute up to a passpoint. I also used "L" to list blocks of memory and "T" and "TW" commands to step into and out of an iterative block, treating it sort of like a function that could be stepped through as if it were a single instruction. Took a little while to get the hang of that process, but once I had it, I could really use the SID tool.
Another thing I would suggest is to run IDEutil.com and see if that works for you. If it doesn't, you may have a hardware problem. Might be worthwhile to single-step through IDEutil anyway, just to be sure. I remember when I was first working with the CF board, I spent a lot of time working on IDEutil. The WRLBA function was of particular interest to me, because there were at least two versions of it in Monahan's code, and I was making a third.
Then again, if I've misinterpreted you, if you know that the CF drive initializes, read and writes without error, you'll probably focus on the CP/M code. I would probably blow the dust off the SID traces I made in development, maybe even choose one of the same GENCPM topmem values, so your jump table addresses are the same as mine. That might save some time finding stuff. Then trace through the reads and see what you see.
Or maybe try one thing first - a shotgun approach that misses a lot of detail but just might work - play around with your disk buffer settings when doing GENCPM. You can choose what drives have unique buffers and/or what drives share buffers. I found some settings just plain don't work. So you might focus on that before rolling your sleeves up and running SID.
I'm super-curious about what you find out so please keep us posted!
mr_metra_nilak
Hello Wayne,
I appreciate your response. I tried assembling the ideutils.asm file but the assembler does not like this line: DB 0CBH, 0*8+D+40H ;BIT 0, D
It seems to be complaining about the "D". Any ideas?
Users browsing this forum: Amazon [Bot] and 6 guests
