...and if ckFlsh runs, then shouldn’t it have deselected the drive - even if a flush wasn’t required?
Absolutely. But the problem for me now is that - where I have the call - it happens only after a person presses a key. It isn't in the same position in the flow as yours is, and so I need to change that. In my code - since the 'conin' and 'in$scan' functions are in the BIOSKRNL.asm module, I didn't want to modify it to put the 'ckFlush' function immediately after entry from the BIOS jump table. That's really where we want to put 'ckFlush' but to do that means we modify the invariant BIOSKRNL module. That would certainly be the easiest thing to do, and I may ultimately do that. But for now, I'm going to look for another solution that leaves BIOSKRNL unmodified, if I can. I'll work on it some more next week.
In the meantime, I'm just stoked that it works!
...I moved the ckFlush call out of CI and into CIST, both in CHARIO3.asm. That solved it! So that allows me to leave BIOSKRNL.asm as the unmodified Digital Research file.
Still piddling with a few things, mostly testing, but very nearly done. I do want to live with it for a while before calling it boxed up and ready to go.
I've tested the system for a few evenings now and I'm pretty comfortable with it.
- The IDE sector count is right, in that each track starts on sector 00 and ends on sector 3F. Watched it with the SID debugger and confirmed it with IDEutil.
- The diskette flushing mechanism works as designed, running ckFlush in the CIST function.
So I'm creating a disk image and will post a link for that soon. Still kind of messing around with GENCPM to find the best compromise between data/directory buffers and available TPA. But in the meantime, here are the source modules:
BIOSKRN3.asm:
SCB3.asm:
BOOT3.asm:
CHARIO3.asm:
MOVE3.asm:
BIOSKRN3.asm:
title 'ROOT BIOS MODULE FOR CP/M 3.0'
; version 1.0 15 Sept 82
true equ -1
false equ not true
banked equ FALSE ;<------ BANKED Version
; Copyright (C), 1982
; Digital Research, Inc
; P.O. Box 579
; Pacific Grove, CA 93950
; This is the invariant portion of the modular BIOS and is
; distributed as source for informational purposes only.
; All desired modifications should be performed by
; adding or changing externally defined modules.
; This allows producing "standard" I/O modules that
; can be combined to support a particular system
; configuration.
cr equ 13
lf equ 10
bell equ 7
ctlQ equ 'Q'-'@'
ctlS equ 'S'-'@'
ccp equ 0100h ; Console Command Processor gets loaded into the TPA
cseg ; GENCPM puts CSEG stuff in common memory
; variables in system data page
extrn @covec,@civec,@aovec,@aivec,@lovec ; I/O redirection vectors
extrn @mxtpa ; addr of system entry point
extrn @bnkbf ; 128 byte scratch buffer
; initialization
extrn ?init ; general initialization and signon
extrn ?ldccp,?rlccp ; load & reload CCP for BOOT & WBOOT
; user defined character I/O routines
extrn ?ci,?co,?cist,?cost ; each take device in <B>
extrn ?cinit ; (re)initialize device in <C>
extrn @ctbl ; physical character device table
; disk communication data items
extrn @dtbl ; table of pointers to XDPHs
public @adrv,@rdrv,@trk,@sect ; parameters for disk I/O
public @dma,@dbnk,@cnt ; '' '' '' ''
; memory control
public @cbnk ; current bank
extrn ?xmove,?move ; select move bank, and block move
extrn ?bank ; select CPU bank
; clock support
extrn ?time ; signal time operation
; general utility routines
public ?pmsg,?pdec ; print message, print number from 0 to 65535
public ?pderr ; print BIOS disk error message header
maclib modebaud ; define mode bits
; External names for BIOS entry points
public ?boot,?wboot,?const,?conin,?cono,?list,?auxo,?auxi
public ?home,?sldsk,?sttrk,?stsec,?stdma,?read,?write
public ?lists,?sctrn
public ?conos,?auxis,?auxos,?dvtbl,?devin,?drtbl
public ?mltio,?flush,?mov,?tim,?bnksl,?stbnk,?xmov
; BIOS Jump vector.
; All BIOS routines are invoked by calling these
; entry points.
?boot: jmp boot ; initial entry on cold start
?wboot: jmp wboot ; reentry on program exit, warm start
?const: jmp const ; return console input status
?conin: jmp conin ; return console input character
?cono: jmp conout ; send console output character
?list: jmp list ; send list output character
?auxo: jmp auxout ; send auxilliary output character
?auxi: jmp auxin ; return auxilliary input character
?home: jmp home ; set disks to logical home
?sldsk: jmp seldsk ; select disk drive, return disk parameter info
?sttrk: jmp settrk ; set disk track
?stsec: jmp setsec ; set disk sector
?stdma: jmp setdma ; set disk I/O memory address
?read: jmp read ; read physical block(s)
?write: jmp write ; write physical block(s)
?lists: jmp listst ; return list device status
?sctrn: jmp sectrn ; translate logical to physical sector
?conos: jmp conost ; return console output status
?auxis: jmp auxist ; return aux input status
?auxos: jmp auxost ; return aux output status
?dvtbl: jmp devtbl ; return address of device def table
?devin: jmp ?cinit ; change baud rate of device
?drtbl: jmp getdrv ; return address of disk drive table
?mltio: jmp multio ; set multiple record count for disk I/O
?flush: jmp flush ; flush BIOS maintained disk caching
?mov: jmp ?move ; block move memory to memory
?tim: jmp ?time ; Signal Time and Date operation
?bnksl: jmp bnksel ; select bank for code execution and default DMA
?stbnk: jmp setbnk ; select different bank for disk I/O DMA operations.
?xmov: jmp ?xmove ; set source and destination banks for one operation
jmp 0 ; reserved for future expansion
; BOOT
; Initial entry point for system startup.
dseg ; this part can be banked
boot:
lxi sp,boot$stack
mvi c,15 ; initialize all 16 character devices
c$init$loop:
push b ! call ?cinit ! pop b
dcr c ! jp c$init$loop
call ?init ; perform any additional system initialization
; and print signon message
lxi b,16*256+0 ! lxi h,@dtbl ; init all 16 logical disk drives
d$init$loop:
push b ; save remaining count and abs drive
mov e,m ! inx h ! mov d,m ! inx h ; grab @drv entry
mov a,e ! ora d ! jz d$init$next ; if null, no drive
push h ; save @drv pointer
xchg ; XDPH address in <HL>
dcx h ! dcx h ! mov a,m ! sta @RDRV ; get relative drive code
mov a,c ! sta @ADRV ; get absolute drive code
dcx h ; point to init pointer
mov d,m ! dcx h ! mov e,m ; get init pointer
xchg ! call ipchl ; call init routine
pop h ; recover @drv pointer
d$init$next:
pop b ; recover counter and drive #
inr c ! dcr b ! jnz d$init$loop ; and loop for each drive
jmp boot$1
cseg ; following in resident memory
boot$1:
call set$jumps
call ?ldccp ; fetch CCP for first time
jmp ccp
; WBOOT
; Entry for system restarts.
wboot:
lxi sp,boot$stack
call set$jumps ; initialize page zero
call ?rlccp ; reload CCP
jmp ccp ; then reset jmp vectors and exit to ccp
set$jumps:
if banked
mvi a,1 ! call ?bnksl
endif
mvi a,JMP
sta 0 ! sta 5 ; set up jumps in page zero
lxi h,?wboot ! shld 1 ; BIOS warm start entry
lhld @MXTPA ! shld 6 ; BDOS system call entry
ret
ds 64
boot$stack equ $
; DEVTBL
; Return address of character device table
devtbl:
lxi h,@ctbl ! ret
; GETDRV
; Return address of drive table
getdrv:
lxi h,@dtbl ! ret
; CONOUT
; Console Output. Send character in <C>
; to all selected devices
conout:
lhld @covec ; fetch console output bit vector
jmp out$scan
; AUXOUT
; Auxiliary Output. Send character in <C>
auxout:
lhld @aovec ; fetch aux output bit vector
jmp out$scan
; LIST
; List Output. Send character in <C>
; to all selected devices.
list:
lhld @lovec ; fetch list output bit vector
out$scan:
mvi b,0 ; start with device 0
co$next:
dad h ; shift out next bit
jnc not$out$device
push h ; save the vector
push b ; save the count and character
not$out$ready:
call coster ! ora a ! jz not$out$ready
pop b ! push b ; restore and resave the character and device
call ?co ; if device selected, print it
pop b ; recover count and character
pop h ; recover the rest of the vector
not$out$device:
inr b ; next device number
mov a,h ! ora l ; see if any devices left
jnz co$next ; and go find them...
ret
; CONOST
; Console Output Status. Return true if
; all selected console output devices
; are ready.
conost:
lhld @covec ; get console output bit vector
jmp ost$scan
; AUXOST
; Auxiliary Output Status. Return true if
; all selected auxiliary output devices
; are ready.
auxost:
lhld @aovec ; get aux output bit vector
jmp ost$scan
; LISTST
; List Output Status. Return true if
; all selected list output devices
; are ready.
listst:
lhld @lovec ; get list output bit vector
ost$scan:
cos$next:
dad h ; check next bit
mvi a,0FFh ; assume device ready
cc coster ; check status for this device
pop h ; recover bit vector
ora a ; see if device ready
rz ; if any not ready, return false
inr b ; drop device number
mov a,h ! ora l ; see if any more selected devices
jnz cos$next
ori 0FFh ; all selected were ready, return true
ret
coster: ; check for output device ready, including optional
; xon/xoff support
mov l,b ! mvi h,0 ; make device code 16 bits
push h ; save it in stack
dad h ! dad h ! dad h ; create offset into device characteristics tbl
lxi d,@ctbl+6 ! dad d ; make address of mode byte
mov a,m ! ani mb$xonxoff
pop h ; recover console number in <HL>
jz ?cost ; not a xon device, go get output status direct
lxi d,xofflist ! dad d ; make pointer to proper xon/xoff flag
call cist1 ; see if this keyboard has character
mov a,m ! cnz ci1 ; get flag or read key if any
cpi ctlq ! jnz not$q ; if its a ctl-Q,
mvi a,0FFh ; set the flag ready
not$q:
cpi ctls ! jnz not$s ; if its a ctl-S,
mvi a,00h ; clear the flag
not$s:
mov m,a ; save the flag
call cost1 ; get the actual output status,
ana m ; and mask with ctl-Q/ctl-S flag
ret ; return this as the status
cist1: ; get input status with <BC> and <HL> saved
push b ! push h
call ?cist
pop h ! pop b
ora a
ret
cost1: ; get output status, saving <BC> & <HL>
push b ! push h
call ?cost
pop h ! pop b
ora a
ret
ci1: ; get input, saving <BC> & <HL>
push b ! push h
call ?ci
pop h ! pop b
ret
; CONST
; Console Input Status. Return true if
; any selected console input device
; has an available character.
const:
lhld @civec ; get console input bit vector
jmp ist$scan
; AUXIST
; Auxiliary Input Status. Return true if
; any selected auxiliary input device
auxist:
lhld @aivec ; get aux input bit vector
ist$scan:
cis$next:
mvi a,0 ; assume device not ready
cc cist1 ; check status for this device
ora a ! rnz ; if any ready, return true
jnz cis$next
xra a ; all selected were not ready, return false
ret
; CONIN
; Console Input. Return character from first
; ready console input device.
conin:
lhld @civec
jmp in$scan
; AUXIN
; Auxiliary Input. Return character from first
; ready auxiliary input device.
auxin:
lhld @aivec
in$scan:
push h ; save bit vector
mvi b,0
ci$next:
mvi a,0 ; insure zero a (nonexistant device not ready).
cc cist1 ; see if the device has a character
ora a
jnz ci$rdy ; this device has a character
inr b ; else, next device
mov a,h ! ora l ; see if any more devices
jnz ci$next ; go look at them
jmp in$scan ; loop til we find a character
ci$rdy:
pop h ; discard extra stack
jmp ?ci
; Utility Subroutines
ipchl: ; vectored CALL point
pchl
?pmsg: ; print message @<HL> up to a null
; saves <BC> & <DE>
push b
push d
pmsg$loop:
mov a,m ! ora a ! jz pmsg$exit
mov c,a ! push h
call ?cono ! pop h
inx h ! jmp pmsg$loop
pmsg$exit:
pop d
pop b
ret
?pdec: ; print binary number 0-65535 from <HL>
lxi b,table10! lxi d,-10000
next:
mvi a,'0'-1
pdecl:
push h! inr a! dad d! jnc stoploop
inx sp! inx sp! jmp pdecl
stoploop:
push d! push b
mov c,a! call ?cono
pop b! pop d
nextdigit:
pop h
ldax b! mov e,a! inx b
ldax b! mov d,a! inx b
mov a,e! ora d! jnz next
ret
table10:
dw -1000,-100,-10,-1,0
?pderr:
lxi h,drive$msg ! call ?pmsg ; error header
lda @adrv ! adi 'A' ! mov c,a ! call ?cono ; drive code
lxi h,track$msg ! call ?pmsg ; track header
lhld @trk ! call ?pdec ; track number
lxi h,sector$msg ! call ?pmsg ; sector header
lhld @sect ! call ?pdec ; sector number
ret
; BNKSEL
; Bank Select. Select CPU bank for further execution.
bnksel:
sta @cbnk ; remember current bank
jmp ?bank ; and go exit through users
; physical bank select routine
xofflist db -1,-1,-1,-1,-1,-1,-1,-1 ; ctl-s clears to zero
dseg ; following resides in banked memory
; Disk I/O interface routines
; SELDSK
; Select Disk Drive. Drive code in <C>.
; Invoke login procedure for drive
; if this is first select. Return
; address of disk parameter header
; in <HL>
seldsk:
mov a,c ! sta @adrv ; save drive select code
mov l,c ! mvi h,0 ! dad h ; create index from drive code
lxi b,@dtbl ! dad b ; get pointer to dispatch table
mov a,m ! inx h ! mov h,m ! mov l,a ; point at disk descriptor
ora h ! rz ; if no entry in table, no disk
mov a,e ! ani 1 ! jnz not$first$select ; examine login bit
push h ! xchg ; put pointer in stack & <DE>
lxi h,-2 ! dad d ! mov a,m ! sta @RDRV ; get relative drive
lxi h,-6 ! dad d ; find LOGIN addr
mov a,m ! inx h ! mov h,m ! mov l,a ; get address of LOGIN routine
call ipchl ; call LOGIN
pop h ; recover DPH pointer
not$first$select:
ret
; HOME
; Home selected drive. Treated as SETTRK(0).
home:
lxi b,0 ; same as set track zero
; SETTRK
; Set Track. Saves track address from <BC>
; in @TRK for further operations.
settrk:
mov l,c ! mov h,b
shld @trk
ret
; SETSEC
; Set Sector. Saves sector number from <BC>
; in @sect for further operations.
setsec:
mov l,c ! mov h,b
shld @sect
ret
; SETDMA
; Set Disk Memory Address. Saves DMA address
; from <BC> in @DMA and sets @DBNK to @CBNK
; so that further disk operations take place
; in current bank.
setdma:
mov l,c ! mov h,b
shld @dma
lda @cbnk ; default DMA bank is current bank
; fall through to set DMA bank
; SETBNK
; Set Disk Memory Bank. Saves bank number
; in @DBNK for future disk data
; transfers.
setbnk:
sta @dbnk
ret
; SECTRN
; Sector Translate. Indexes skew table in <DE>
; with sector in <BC>. Returns physical sector
; in <HL>. If no skew table (<DE>=0) then
; returns physical=logical.
sectrn:
mov l,c ! mov h,b
mov a,d ! ora e ! rz
xchg ! dad b ! mov l,m ! mvi h,0
ret
; READ
; Read physical record from currently selected drive.
; Finds address of proper read routine from
; extended disk parameter header (XDPH).
read:
lhld @adrv ! mvi h,0 ! dad h ; get drive code and double it
lxi d,@dtbl ! dad d ; make address of table entry
mov a,m ! inx h ! mov h,m ! mov l,a ; fetch table entry
push h ; save address of table
lxi d,-8 ! dad d ; point to read routine address
jmp rw$common ; use common code
; WRITE
; Write physical sector from currently selected drive.
; Finds address of proper write routine from
write:
lxi d,-10 ! dad d ; point to write routine address
rw$common:
mov a,m ! inx h ! mov h,m ! mov l,a ; get address of routine
pop d ; recover address of table
dcx d ! dcx d ; point to relative drive
ldax d ! sta @rdrv ; get relative drive code and post it
inx d ! inx d ; point to DPH again
pchl ; leap to driver
; MULTIO
; Set multiple sector count. Saves passed count in
; @CNT
multio:
sta @cnt ! ret
; FLUSH
; BIOS deblocking buffer flush. Not implemented.
flush:
xra a ! ret ; return with no error
; error message components
drive$msg db cr,lf,bell,'BIOS Error on ',0
track$msg db ': T-',0
sector$msg db ', S-',0
@adrv ds 1 ; currently selected disk drive
@rdrv ds 1 ; controller relative disk drive
@trk ds 2 ; current track number
@sect ds 2 ; current sector number
@dma ds 2 ; current DMA address
@cnt db 0 ; record count for multisector transfer
@dbnk db 0 ; bank for DMA operations
cseg ; common memory
@cbnk db 0 ; bank for processor operations
end
TITLE 'SYSTEM CONTROL BLOCK DEFINITION FOR CP/M 3.0'
PUBLIC @CIVEC, @COVEC, @AIVEC, @AOVEC, @LOVEC, @BNKBF
PUBLIC @CRDMA, @CRDSK, @VINFO, @RESEL, @FX, @USRCD
PUBLIC @MLTIO, @ERMDE, @ERDSK, @MEDIA, @BFLGS
PUBLIC @DATE, @HOUR, @MIN, @SEC, ?ERJMP, @MXTPA
SCB$BASE EQU 0FE00H ; BASE OF THE SCB
@CIVEC EQU SCB$BASE+22H ; CONSOLE INPUT REDIRECTION
; VECTOR (WORD, R/W)
@COVEC EQU SCB$BASE+24H ; CONSOLE OUTPUT REDIRECTION
@AIVEC EQU SCB$BASE+26H ; AUXILIARY INPUT REDIRECTION
@AOVEC EQU SCB$BASE+28H ; AUXILIARY OUTPUT REDIRECTION
@LOVEC EQU SCB$BASE+2AH ; LIST OUTPUT REDIRECTION
@BNKBF EQU SCB$BASE+35H ; ADDRESS OF 128 BYTE BUFFER
; FOR BANKED BIOS (WORD, R/O)
@CRDMA EQU SCB$BASE+3CH ; CURRENT DMA ADDRESS
; (WORD, R/O)
@CRDSK EQU SCB$BASE+3EH ; CURRENT DISK (BYTE, R/O)
@VINFO EQU SCB$BASE+3FH ; BDOS VARIABLE "INFO"
; (WORD, R/O)
@RESEL EQU SCB$BASE+41H ; FCB FLAG (BYTE, R/O)
@FX EQU SCB$BASE+43H ; BDOS FUNCTION FOR ERROR
; MESSAGES (BYTE, R/O)
@USRCD EQU SCB$BASE+44H ; CURRENT USER CODE (BYTE, R/O)
@MLTIO EQU SCB$BASE+4AH ; CURRENT MULTI-SECTOR COUNT
; (BYTE,R/W)
@ERMDE EQU SCB$BASE+4BH ; BDOS ERROR MODE (BYTE, R/O)
@ERDSK EQU SCB$BASE+51H ; BDOS ERROR DISK (BYTE,R/O)
@MEDIA EQU SCB$BASE+54H ; SET BY BIOS TO INDICATE
; OPEN DOOR (BYTE,R/W)
@BFLGS EQU SCB$BASE+57H ; BDOS MESSAGE SIZE FLAG (BYTE,R/O)
@DATE EQU SCB$BASE+58H ; DATE IN DAYS SINCE 1 JAN 78
; (WORD, R/W)
@HOUR EQU SCB$BASE+5AH ; HOUR IN BCD (BYTE, R/W)
@MIN EQU SCB$BASE+5BH ; MINUTE IN BCD (BYTE, R/W)
@SEC EQU SCB$BASE+5CH ; SECOND IN BCD (BYTE, R/W)
?ERJMP EQU SCB$BASE+5FH ; BDOS ERROR MESSAGE JUMP
; (WORD, R/W)
@MXTPA EQU SCB$BASE+62H ; TOP OF USER TPA
; (ADDRESS AT 6,7)(WORD, R/O)
END
TITLE 'BOOT LOADER MODULE FOR CP/M 3.0'
; BOOT3.ASM v.1.0 02/22/2023
; Written by Wayne Parham (wayne@parhamdata.com)
; Four drive support:
; Drives 0 and 1 are 330Kb diskettes
; Drives 2 and 3 are 8Mb IDE drives
; DEFINE LOGICAL VALUES:
TRUE EQU -1
FALSE EQU NOT TRUE
; DETERMINE IF FOR BANK SELECT OR NOT:
BANKED EQU FALSE ;<--------------- BANKED VERSION
; DEFINE PUBLIC LABELS:
PUBLIC ?INIT,?LDCCP,?RLCCP,?TIME
PUBLIC OUT$BLOCKS
; EXTERNALLY DEFINED ENTRY POINTS AND LABELS:
EXTRN ?PMSG,?CONIN
EXTRN @CIVEC,@COVEC,@AIVEC,@AOVEC,@LOVEC
EXTRN @CBNK,?BNKSL
IF BANKED
EXTRN BANKBUF ;128 BYTE BUFFER IN MOVE MODULE FOR USE
; DURING COLD AND WARM BOOTS
ENDIF
EXTRN @SEC,@MIN,@HOUR,@DATE ;FIELDS HOLDING CURRENT TIME AND DATE
; INCLUDE Z-80 MACROS:
MACLIB Z80
; SOME MISCELLANEOUS EQUATES:
BDOS EQU 5
CR EQU 13 ;ASCII CARRIAGE RETURN
LF EQU 10 ;ASCII LINEFEED
; WE CAN DO INITIALIZATION FROM BANKED MEMORY (IF WE HAVE IT):
IF BANKED
DSEG ; INIT DONE FROM BANKED MEMORY
ELSE
CSEG ; INIT TO BE DONE FROM COMMON MEMORY
ENDIF
;;;;; ?INIT
; HARDWARE INITIALIZATION OTHER THAN CHARACTER AND DISK I/O:
?INIT:
; ASSIGN CONSOLE INPUT AND OUTPUT TO CRT:
LXI H,8000H ;SIGNIFIES DEVICE 0
SHLD @CIVEC ;CONSOLE INPUT VECTOR
SHLD @COVEC ;CONSOLE OUTPUT VECTOR
; ASSIGN PRINTER TO LPT:
LXI H,4000H ;SIGNIFIES DEVICE 1
SHLD @LOVEC ;LIST OUTPUT VECTOR
; ASSIGN AUX TO CRT1:
LXI H,02000H ;SIGNIFIES DEVICE 2
SHLD @AIVEC ;AUXILLIARY INPUT VECTOR
SHLD @AOVEC ;AUXILLIARY OUTPUT VECTOR
; PRINT THE SIGN-ON MESSAGE:
LXI H,SIGNON$MSG ;POINT TO IT
JMP ?PMSG ;AND PRINT IT
;;;;; OUT$BLOCKS
; ROUTINE OUTPUTS SPECIFIED # BYTES TO SPECIFIED OUTPUT PORTS:
IF BANKED
CSEG ;WE WANT THIS ROUTINE IN COMMON MEMORY
ENDIF
OUT$BLOCKS:
MOV A,M ;GET A BYTE FROM THE BLOCK
ORA A ;END OF OUTPUT BLOCK ?
RZ ;THEN DONE!!
MOV B,A ;ELSE PUT # BYTES TO SEND OUT IN [B]
INX H ;POINT TO PORT TO SEND TO
MOV C,M ;GET IT TO [C]
INX H ;POINT TO 1ST BYTE OF BLOCK TO SEND OUT
OUTIR ;Z-80 BLOCK OUTPUT
JR OUT$BLOCKS
;;;;; ?LDCCP
; THIS ROUTINE IS ENTERED TO LOAD THE CCP.COM FILE INTO THE TPA BANK
; AT SYSTEM COLD START:
?LDCCP:
; SET UP THE FCB FOR THE FILE OPERATION:
XRA A ;ZERO EXTENT
STA CCP$FCB+15
LXI H,0 ;START AT BEGINNING OF FILE
SHLD FCB$NR
; TRY TO OPEN THE CCP.COM FILE:
LXI D,CCP$FCB ;POINT TO FCB
CALL OPEN ;ATTEMPT THE OPEN OPERATION
INR A ;WAS IT ON THE DISK ?
; JRNZ CCP$FOUND ;YES -- GO LOAD IT
JNZ CCP$FOUND ;YES -- GO LOAD IT
; WE ARRIVE HERE WHEN CCP.COM FILE WASN'T FOUND:
LXI H,CCP$MSG ;REPORT THE ERROR
CALL ?PMSG
CALL ?CONIN ;GET A RESPONSE
JR ?LDCCP ;AND TRY AGAIN
; FILE WAS OPENED OK -- READ IT IN:
CCP$FOUND:
LXI D,0100H ;LOAD AT BOTTOM OF TPA
CALL SETDMA ;BY SETTING THE NEXT DMA ADDRESS
LXI D,128 ;SET MULTI SECTOR I/O COUNT
CALL SETMULTI ; TO ALLOW UP TO 16K BYTES IN ONE OPERATION
LXI D,CCP$FCB ;POINT TO THE FCB
CALL READ ;AND READ THE CCP IN
; FOLLOWING CODE FOR BANKED SYSTEMS -- MOVES CCP IMAGE TO BANK 2
; FOR LATER RELOADING AT WARM STARTS:
IF BANKED
LXI H,0100H ;GET CCP IMAGE FROM START OF TPA
MVI B,25 ;TRANSFER 25 LOGICAL SECTORS
LDA @CBNK ;GET CURRENT BANK
PUSH PSW ;AND SAVE IT
LD$1:
PUSH B ;SAVE SECTOR COUNT
MVI A,1 ;SELECT TPA BANK
CALL ?BNKSL
LXI B,128 ;TRANSFER 128 BYTES TO TEMPORARY BUFFER
LXI D,BANKBUF ;TEMPORARY BUFFER ADDR IN [DE]
PUSH H ;SAVE SOURCE ADDRESS
PUSH D ;AND DESTINATION
PUSH B ;AND COUNT
LDIR ;BLOCK MOVE SECTOR TO TEMPORARY BUFFER
MVI A,2 ;SELECT BANK TO SAVE CCP IN
CALL ?BNKSL
POP B ;GET BACK COUNT
POP H ;LAST DESTINATION WILL BE NEW SOURCE ADDR
POP D ;LAST SOURCE WILL BE NEW DESTINATION
LDIR ;BLOCK MOVE SECTOR FROM BUFFER TO ALTERNATE
; BANK
XCHG ;NEXT ADDR WILL BE NEW SOURCE ADDR
POP B ;GET BACK SECTOR COUNT
DJNZ LD$1 ;DROP SECTOR COUNT AND LOOP TILL DONE...
POP PSW ;WHEN DONE -- RESTORE ORIGINAL BANK
JMP ?BNKSL
ELSE
; IF NON-BANKED WE RETURN THROUGH HERE:
RET
ENDIF
;;;;; ?RLCCP
; ROUTINE RELOADS CCP IMAGE FROM BANK 2 IF BANKED SYSTEM OR FROM THE
; DISK IF NON-BANKED VERSION:
?RLCCP:
IF BANKED
; FOLLOWING CODE FOR BANKED VERSION:
LXI H,0100H ;GET CCP IMAGE FROM START OF ALTERNATE BUFFER
RL$1:
MVI A,2 ;SELECT ALTERNATE BANK
CALL ?BNKSL
PUSH B ;AND COUNT
MVI A,1 ;PUT CCP TO TPA BANK
CALL ?BNKSL
LDIR ;BLOCK MOVE SECTOR FROM BUFFER TO TPA BANK
DJNZ RL$1 ;DROP SECTOR COUNT AND LOOP TILL DONE...
POP PSW ;GET BACK LAST CURRENT BANK #
JMP ?BNKSL ;SELECT IT AND RETURN
ELSE
; FOLLOWING CODE IS FOR NON-BANKED VERSIONS:
JMP ?LDCCP ;JUST DO LOAD AS THOUGH COLD BOOT
ENDIF
;;;;; ?TIME
; ROUTINE SETS/GETS TIME:
?TIME:
RET ;Just return in this simple version
IF BANKED
CSEG
ENDIF
; CP/M BDOS FUNCTION INTERFACES
; OPEN FILE:
OPEN:
MVI C,15 ! JMP BDOS ; OPEN FILE CONTROL BLOCK
; SET DMA ADDRESS:
SETDMA:
MVI C,26 ! JMP BDOS ; SET DATA TRANSFER ADDRESS
; SET MULTI SECTOR I/O COUNT:
SETMULTI:
MVI C,44 ! JMP BDOS ; SET RECORD COUNT
; READ FILE RECORD:
READ:
MVI C,20 ! JMP BDOS ; READ RECORDS
; CCP NOT FOUND ERROR MESSAGE:
CCP$MSG:
DB CR,LF,'BIOS ERR ON A: NO CCP.COM FILE',0
; FCB FOR CCP.COM FILE LOADING:
CCP$FCB:
DB 1 ;AUTO-SELECT DRIVE A
DB 'CCP COM' ;FILE NAME AND TYPE
DB 0,0,0,0
DS 16
FCB$NR: DB 0,0,0
; SYSTEM SIGN-ON MESSAGE:
SIGNON$MSG:
db CR,LF,LF,'CP/M Plus v3.0hd',CR,LF,LF,LF,0
END
TITLE 'SIO AND 2SIO MODULE FOR CP/M 3.0'
; CHARIO3.ASM v.1.0 02/22/2023
; Character device driver module for Altair computers.
; Supports SIO and 2SIO async boards and compatibles
; such as Martin Eberhard's 88-2SIOJP.
; Note that the CIST function calls ckFlush from the
; diskette module. This allows delayed track flushing.
TRUE EQU -1
FALSE EQU NOT TRUE
; Equates used by FDC for flushing during system inactivity (during char I/O)
UNDEF EQU 0FFH
MINIDSK EQU FALSE ;Set TRUE for Altair Mini-Disk (see FDC3.asm)
cHDUNLD EQU 08H ;head unload
DRVCMD EQU 09H ;drive command register (out)
BANKED EQU FALSE ;<------------------- BANKED VERSION
PUBLIC ?CINIT,?CI,?CO,?CIST,?COST
PUBLIC @CTBL
; DEFINE EXTERNAL LABELS AND ENTRY POINTS:
IF BANKED
EXTRN @CBNK
EXTRN ?BNKSL
ENDIF
EXTRN OUT$BLOCKS ;BLOCK OUTPUT ROUTINE TO I/O PORTS
EXTRN ?PMSG
; FDC external labels:
EXTRN bfDrive ;Buffered drive
EXTRN ckFlush ;Disk buffer flush routine
MACLIB Z80
; 2SIO Serial Board Equates
SIO1CTL EQU 10h ;1st port on 2SIO board - control register
SIO1DAT EQU 11h ;1st port on 2SIO board - data register
SIO2CTL EQU 12h ;2nd port on 2SIO board - control register
SIO2DAT EQU 13h ;2nd port on 2SIO board - data register
SIORDRF EQU 01h ;read data register full flag
SIOTDRE EQU 02h ;transmit data register empty flag
; SIO Serial Board Equates
SIOCTL EQU 00h ;SIO board at 0 - control register
SIODAT EQU 01h ;SIO board at 0 - data register
ACRCTL EQU 06h ;SIO board at 6 - control register (cassette)
ACRDAT EQU 07h ;SIO board at 6 - data register (cassette)
SIORCV EQU 01h ;data received bit (inverted)
SIOXMT EQU 80h ;read to transmit (inverted)
; EQUATES FOR MODE BYTE BIT FIELDS
MB$INPUT EQU 0000$0001B ; DEVICE MAY DO INPUT
MB$OUTPUT EQU 0000$0010B ; DEVICE MAY DO OUTPUT
MB$IN$OUT EQU MB$INPUT+MB$OUTPUT
MB$SOFT$BAUD EQU 0000$0100B ; SOFTWARE SELECTABLE BAUD RATES
MB$SERIAL EQU 0000$1000B ; DEVICE MAY USE PROTOCOL
MB$XON$XOFF EQU 0001$0000B ; XON/XOFF PROTOCOL ENABLED
BAUD$NONE EQU 0 ; NO BAUD RATE ASSOCIATED WITH THIS DEVICE
BAUD$50 EQU 1 ; 50 BAUD
BAUD$75 EQU 2 ; 75 BAUD
BAUD$110 EQU 3 ; 110 BAUD
BAUD$134 EQU 4 ; 134.5 BAUD
BAUD$150 EQU 5 ; 150 BAUD
BAUD$300 EQU 6 ; 300 BAUD
BAUD$600 EQU 7 ; 600 BAUD
BAUD$1200 EQU 8 ; 1200 BAUD
BAUD$1800 EQU 9 ; 1800 BAUD
BAUD$2400 EQU 10 ; 2400 BAUD
BAUD$3600 EQU 11 ; 3600 BAUD
BAUD$4800 EQU 12 ; 4800 BAUD
BAUD$7200 EQU 13 ; 7200 BAUD
BAUD$9600 EQU 14 ; 9600 BAUD
BAUD$19200 EQU 15 ; 19.2K BAUD
; WILL START OFF IN COMMON MEMORY FOR BANKED OR NON-BANKED SYSTEMS:
CSEG
IF BANKED
; WE PROVIDE ALTERNATE DEFINITIONS OF THE ROUTINE ENTRY POINTS IF
; WE ARE RUNNING A BANKED SYSTEM VERSUS A NON-BANKED SYSTEM:
;;;;; ?CINIT
; ENTER HERE FOR BANKED SYSTEMS FOR DEVICE INITIALIZATIONS:
?CINIT:
LXI H,BCINIT ;POINT TO BANKED ROUTINE ADDRESS
JR BANKIO ;GO TO DISPATCHER
;;;;; ?CI
; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT:
?CI: LXI H,BCI ;POINT TO BANKED ROUTINE ADDRESS
;;;;; ?CO
; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT:
?CO: LXI H,BCO ;POINT TO BANKED ROUTINE ADDRESS
;;;;; ?CIST
; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT STATUS:
?CIST: LXI H,BCIST ;POINT TO BANKED ROUTINE ADDRESS
;;;;; ?COST
; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT STATUS:
?COST: LXI H,BCOST ;POINT TO BANKED ROUTINE ADDRESS
;;;;; BANKIO
; ROUTINE DISPATCHES TO BANKED PORTION OF CHARACTER I/O ROUTINES:
BANKIO:
SSPD SPSAVE ;SAVE CURRENT STACK POINTER
LXI SP,IOSP ; AND USE LOCAL STACK FOR I/O
PUSH PSW ;SAVE ON LOCAL STACK
XRA A ;WE WILL SELECT BANK 0 (OP SYS)
CALL ?BNKSL
LXI D,BIORET ;RETURN ADDRESS IN [DE]
PUSH D ;PUT IT ON STACK FOR RETURN
PCHL ;DISPATCH TO BANKED PART OF ROUTINE
; ARRIVE HERE AFTER DEVICE HANDLER FINISHED:
BIORET:
POP D ;GET PREVIOUS CURRENT BANK TO [D]
PUSH PSW ;SAVE HANDLER RETURNED RESULT (IF ANY)
MOV A,D ;RESELECT PREVIOUS CURRENT BANK
CALL ?BNKSL
POP PSW ;GET BACK RESULT CODE TO [A]
LSPD SPSAVE ;RESTORE PREVIOUS STACK
RET ;AND RETURN...
ENDIF
;;;;; ACTUAL DEVICE HANDLERS
;;;;; ?CINIT (BCINIT FOR BANKED)
; PHYSICAL CODE FOR DEVICE INITIALIZATION:
IF BANKED
DSEG ;CAN PUT IN BANKED SEGMENT IF BANKED
BCINIT:
ELSE
?CINIT:
ENDIF
MOV B,C ;ON ENTRY DEVICE # IS IN [C] BUT WE NEED
; IT IN [B]
CALL DEV$DISPATCH ;GO TO CORRECT INIT ROUTINE
DW CINIT0 ;INIT FOR DEVICE 0
DW CINIT1 ;INIT FOR DEVICE 1
DW CINIT2 ;INIT FOR DEVICE 2
DW CINIT3 ;INIT FOR DEVICE 3
DW NULL$INIT ;INIT FOR DEVICE 4
DW NULL$INIT ;INIT FOR DEVICE 5
DW NULL$INIT ;INIT FOR DEVICE 6
DW NULL$INIT ;INIT FOR DEVICE 7
DW NULL$INIT ;INIT FOR DEVICE 8
DW NULL$INIT ;INIT FOR DEVICE 9
DW NULL$INIT ;INIT FOR DEVICE 10
DW NULL$INIT ;INIT FOR DEVICE 11
DW NULL$INIT ;INIT FOR DEVICE 12
DW NULL$INIT ;INIT FOR DEVICE 13
DW NULL$INIT ;INIT FOR DEVICE 14
DW NULL$INIT ;INIT FOR DEVICE 15
;;;;; ?CI (BCI FOR BANKED)
; PHYSICAL CODE FOR DEVICE INPUT:
IF BANKED
BCI:
ELSE
?CI:
ENDIF
CALL DEV$DISPATCH
DW CI0 ;DEVICE 0 INPUT
DW CI1 ;DEVICE 1 INPUT
DW CI2 ;DEVICE 2 INPUT
DW CI3 ;DEVICE 3 INPUT
DW NULL$CI ;DEVICE 4 INPUT
DW NULL$CI ;DEVICE 5 INPUT
DW NULL$CI ;DEVICE 6 INPUT
DW NULL$CI ;DEVICE 7 INPUT
DW NULL$CI ;DEVICE 8 INPUT
DW NULL$CI ;DEVICE 9 INPUT
DW NULL$CI ;DEVICE 10 INPUT
DW NULL$CI ;DEVICE 11 INPUT
DW NULL$CI ;DEVICE 12 INPUT
DW NULL$CI ;DEVICE 13 INPUT
DW NULL$CI ;DEVICE 14 INPUT
DW NULL$CI ;DEVICE 15 INPUT
;;;;; ?CO (BCO FOR BANKED)
; PHYSICAL CODE FOR DEVICE OUTPUT:
IF BANKED
BCO:
ELSE
?CO:
ENDIF
CALL DEV$DISPATCH ;GO TO CORRECT DEVICE OUTPUT HANDLER
DW CO0 ;DEVICE 0 OUTPUT
DW CO1 ;DEVICE 1 OUTPUT
DW CO2 ;DEVICE 2 OUTPUT
DW CO3 ;DEVICE 3 OUTPUT
DW NULL$CO ;DEVICE 4 OUTPUT
DW NULL$CO ;DEVICE 5 OUTPUT
DW NULL$CO ;DEVICE 6 OUTPUT
DW NULL$CO ;DEVICE 7 OUTPUT
DW NULL$CO ;DEVICE 8 OUTPUT
DW NULL$CO ;DEVICE 9 OUTPUT
DW NULL$CO ;DEVICE 10 OUTPUT
DW NULL$CO ;DEVICE 11 OUTPUT
DW NULL$CO ;DEVICE 12 OUTPUT
DW NULL$CO ;DEVICE 13 OUTPUT
DW NULL$CO ;DEVICE 14 OUTPUT
DW NULL$CO ;DEVICE 15 OUTPUT
;;;;; ?CIST (BCIST FOR BANKED)
; PHYSICAL CODE FOR DEVICE INPUT STATUS:
IF BANKED
BCIST:
ELSE
?CIST:
ENDIF
;;;;; System is relatively idle during char input, so do some FDC housecleaning
mvi a,UNDEF ;invalidate track buffer
sta bfDrive
call ckFlush ;flush the track if needed
ei ;restore interrupts
IF NOT MINIDSK
mvi a,cHDUNLD ;unload head
out DRVCMD
ENDIF
CALL DEV$DISPATCH
DW CIST0 ;DEVICE 0 INPUT STATUS
DW CIST1 ;DEVICE 1 INPUT STATUS
DW CIST2 ;DEVICE 2 INPUT STATUS
DW CIST3 ;DEVICE 3 INPUT STATUS
DW NULL$CIST ;DEVICE 4 INPUT STATUS
DW NULL$CIST ;DEVICE 5 INPUT STATUS
DW NULL$CIST ;DEVICE 6 INPUT STATUS
DW NULL$CIST ;DEVICE 7 INPUT STATUS
DW NULL$CIST ;DEVICE 8 INPUT STATUS
DW NULL$CIST ;DEVICE 9 INPUT STATUS
DW NULL$CIST ;DEVICE 10 INPUT STATUS
DW NULL$CIST ;DEVICE 11 INPUT STATUS
DW NULL$CIST ;DEVICE 12 INPUT STATUS
DW NULL$CIST ;DEVICE 13 INPUT STATUS
DW NULL$CIST ;DEVICE 14 INPUT STATUS
DW NULL$CIST ;DEVICE 15 INPUT STATUS
;;;;; ?COST (BCOST FOR BANKED)
; PHYSICAL CODE FOR DEVICE OUTPUT STATUS:
IF BANKED
BCOST:
ELSE
?COST:
ENDIF
CALL DEV$DISPATCH ;GO TO CONSOLE OUTPUT STATUS HANDLER
DW COST0 ;DEVICE 0 OUTPUT STATUS
DW COST1 ;DEVICE 1 OUTPUT STATUS
DW COST2 ;DEVICE 2 OUTPUT STATUS
DW COST3 ;DEVICE 3 OUTPUT STATUS
DW NULL$COST ;DEVICE 4 OUTPUT STATUS
DW NULL$COST ;DEVICE 5 OUTPUT STATUS
DW NULL$COST ;DEVICE 6 OUTPUT STATUS
DW NULL$COST ;DEVICE 7 OUTPUT STATUS
DW NULL$COST ;DEVICE 8 OUTPUT STATUS
DW NULL$COST ;DEVICE 9 OUTPUT STATUS
DW NULL$COST ;DEVICE 10 OUTPUT STATUS
DW NULL$COST ;DEVICE 11 OUTPUT STATUS
DW NULL$COST ;DEVICE 12 OUTPUT STATUS
DW NULL$COST ;DEVICE 13 OUTPUT STATUS
DW NULL$COST ;DEVICE 14 OUTPUT STATUS
DW NULL$COST ;DEVICE 15 OUTPUT STATUS
;;;;; DEV$DISPATCH
; ROUTINE JUMPS TO CORRECT DEVICE HANDLER:
DEV$DISPATCH:
MOV A,B ;GET DEVICE # TO [A]
STA DEV$CODE ;SAVE FOR LATER USE
ADD A ;X2 FOR WORD OFFSET
POP H ;RETURN ADDRESS IS 1ST PARAMETER ADDRESS
MOV E,A ;SET UP OFFSET IN [DE]
MVI D,0
DAD D ;[HL] = PTR TO HANDLER ADDRESS
MOV E,M ;GET HANDLER ADDRESS TO [DE]
INX H
MOV D,M
MOV A,C ;PUT CHAR TO SEND INTO A
XCHG ;PUT HANDLER ADDRESS IN [HL]
PCHL ;AND DISPATCH TO IT...
;;;;; PHYSICAL DEVICE HANDLER CODE:
; Initialize serial ports
CINIT0:
mvi a,03h ;reset 2SIO ports
out SIO1CTL
out SIO2CTL
mvi a,11h ;select 8N2
out SIO1CTL
out SIO2CTL
CINIT1:
CINIT2:
CINIT3:
ret
; Input status routines. Return FFh if character ready, else zero
CIST0:
sio1IS in SIO1CTL ;read 2SIO #1 status/control register
ani SIORDRF ;data present?
rz ;no, return zero
mvi a,0FFh ;else return FFh
ret
CIST1:
sio2IS in SIO2CTL ;read 2SIO #2 status/control register
rz ;no, return zero
ret
CIST2:
sioIS in SIOCTL ;read SIO status/control register
xri 0FFh ;convert to positive logic
ani SIORCV ;data present?
rz ;no, return zero
ret
CIST3:
acrIS in ACRCTL ;read ACR (SIO) control register
rz ;no, return zero
ret
; Character input routines (character ready assumed)
CI0:
sio1In in SIO1DAT ;read and return the character
ret
CI1:
sio2In in SIO2DAT ;read and return the character
ret
CI2:
sioIn in SIODAT ;read and return the character
ret
CI3:
acrIn in ACRDAT ;read and return the character
ret
; Output status routines. Return FFh if ready to send, else zero
COST0:
sio1OS in SIO1CTL ;read 2SIO #1 status/control register
ani SIOTDRE ;0=busy
rz ;not ready, return 0
ret
COST1:
sio2OS in SIO2CTL ;read 2SIO #2 status/control register
ani SIOTDRE ;0=busy
ret
COST2:
sioOS in SIOCTL ;read SIO status/control register
ani SIOXMT ;0=busy
ret
COST3:
acrOS in ACRCTL ;read SIO status/control register
ani SIOXMT ;0=busy
ret
; Character output routines (transmit ready assumed)
CO0:
sio1Out out SIO1DAT ;send character
ret
CO1:
sio2Out out SIO2DAT ;send character
ret
CO2:
sioOut out SIODAT ;send character
ret
CO3:
acrOut out ACRDAT ;send character
ret
;;;;; NULL ROUTINES:
NULL$CIST:
NULL$COST:
XRA A ;RETURN A FALSE STATUS RESULT
JR NULL$RET
NULL$CI:
MVI A,1AH ;FOR INPUT RETURN A CNTL-Z (EOF)
NULL$INIT:
NULL$CO:
NULL$RET:
RET ;HARMLESS RETURN
; STORAGE FOR DEVICE CODE -- CAN RESIDE IN SAME SEGMENT AS THE BULK
; OF CHARACTER I/O ROUTINES:
DEV$CODE: DS 1
;;;;; CHRTBL
; CHARACTER DEVICE TABLE
CSEG ;MUST RESIDE IN COMMON MEMORY
@CTBL:
db '2SIOA ' ; device 0, 2SIO at 10h/11h
db mb$in$out+mb$serial
db baud$none
db '2SIOB ' ; device 1, 2SIO at 12h/13h
db baud$none
db 'SIO ' ; device 2, SIO at 0/1
db baud$none
db 'ACR ' ; device 3, SIO at 6/7 (ACR)
db baud$none
db 0 ; table terminator
MAX$DEVICES EQU ($-@CTBL)/8 ;# DEVICES IN TABLE
DB 0 ;TABLE TERMINATOR
; OTHER DATA AREAS:
DS 24 ;CHARACTER I/O LOCAL STACK
IOSP EQU $
SPSAVE DS 2
END
TITLE 'BANK & MOVE MODULE FOR CP/M 3.0'
; MOVE3.ASM v.1.0 02/22/2023
; Memory copy routines for the Altair 8800 computer.
; Only non-banked code is 8080-compatible. If a
; banked-memory system is employed, the drivers in
; this module can be used as a starting point but
; obviously cannot be used in a stock Altair.
TRUE EQU -1
FALSE EQU NOT TRUE
BANKED EQU FALSE ;<----------------Banked VERSION
MPURR0 EQU 0D2H ;Z80 BOARD RELOCATION PORT
MPURR1 EQU 0D3H ;Z80 BOARD RELOCATION PORT
PUBLIC ?MOVE,?XMOVE,?BANK
; PUBLIC LABELS AND EXTERNALS FOR BANKED SYSTEMS:
IF BANKED
PUBLIC CURRR0,CURRR1 ;CURRENT WINDOW RELOCATION SEGMENTS
PUBLIC BANKBUF ;TEMPORARY 128 BYTE BUFFER OTHER ROUTINES
; MAY USE FOR TRANSIENT PURPOSES
PUBLIC WIN$LOW$2BITS ;LOWER 2 BITS FOR EACH RELOCATION REGISTER
PUBLIC DOXMOV,XMOV$BANKS ;EXTENDED BANK MOVE VARIABLES
EXTRN @CBNK
EXTRN ?BNKSL
ENDIF
MACLIB Z80
; LOCATE CODE IN THE COMMON SEGMENT:
CSEG
;;;;; ldir
; An 8080-compatiple replacement for the Z80 LDIR instruction
; Copies [BC] bytes from the address starting at [HL] to [DE]
ldir:
xchg ;Make [DE] be source and [HL] be target
call memcpy ;Copy data block
xchg ;Make [DE] be target and [DE] be source
ret
;;;;; memcpy
; Copies [BC] bytes from the address starting at [DE] to [HL]
memcpy: ldax d ;Get byte byte
mov m,a ;Store byte
inx h ;Increment target address
inx d ;Increment source address
dcx b ;Decrement byte count
mov a,b ;move btye count to accumulator
ora c ;test for zero
jnz memcpy ;loop until done
ret
;;;;; ?XMOVE
; ROUTINE SETS UP AN INTER-BANK MOVE OF 128 BYTES ON THE NEXT CALL
; TO ?MOVE:
?XMOVE:
IF BANKED
MVI A,0FFH ;SET EXTENDED MOVE FLAG
STA DOXMOV
SBCD XMOV$BANKS ;AND STORE BANKS FOR THE EXTENDED MOVE
ENDIF
RET
;;;;; ?MOVE
; ROUTINE PERFORMS INTRA-BANK MOVES IF ?XMOVE WAS NOT CALLED PRIOR TO
; THIS CALL TO ?MOVE ELSE A 128 BYTE TRANSFER IS CONDUCTED BETWEEN
; DIFFERENT BANKS:
?MOVE:
IF BANKED
LDA DOXMOV ;GET EXTENDED MOVE FLAG
ORA A ;IS IT SET ?
MVI A,0 ;RESET FOR NEXT TIME ANYWAY
STA DOXMOV
JRZ MOVE$IT
; HAVE TO IMPLEMENT INTER-BANK MOVE:
LDA @CBNK ;REMEMBER CURRENT BANK
PUSH PSW
LDA XMOV$BANKS ;GET SOURCE BANK
CALL ?BNKSL ; AND SELECT IT
PUSH H ;SAVE DESTINATION ADDRESS
PUSH B ;AND THE COUNT
XCHG ;[HL] = SOURCE
LXI D,BANKBUF ;[DE] = LOCAL TEMPORARY BUFFER
LDIR ;BLOCK MOVE TO TEMP BUFFER
POP B ;RESTORE COUNT
POP D ;[DE] = ORIGINAL DESTINATION
PUSH H ;SAVE NEXT SOURCE ADDRESS
LXI H,BANKBUF ;[HL] = SOURCE = TEMP BUFFER
LDA XMOV$BANKS+1 ;GET DESTINATION BANK
CALL ?BNKSL ;AND SELECT IT
LDIR ;BLOCK MOVE FROM TEMP BUFFER TO DESTINATION
POP H ;RESTORE NEXT SOURCE
XCHG ;RETURN SWAP
POP PSW ;GET BACK PREVIOUS CURRENT BANK
; ARRIVE HERE FOR INTRA-BANK MEMORY MOVE:
MOVE$IT:
ENDIF
; XCHG ;WE ARE PASSED SOURCE IN DE AND DEST IN HL
; LDIR ;USE Z80 BLOCK MOVE INSTRUCTION
; XCHG ;NEED NEXT ADDRESSES IN SAME REGS
; RET
jmp memcpy ;Use 8080-compatible memcpy for move
;;;;; ?BANK
; ROUTINE SWITCHES IN PHYSICAL BANK:
?BANK:
IF BANKED
CPI 2 ;BANK 2 OR HIGHER ?
JRNC BNK1$SWITCH ;GO DIRECTLY TO CODE TO CALCULATE THE
; PHYSICAL ADDRESS...
ORA A ;ELSE SWAP BANK 0 AND 1 VALUES
MVI A,1 ;IF BANK 0 MAKE BANK 1
JRZ BNK1$SWITCH
XRA A ;ELSE IF BANK 1 MAKE BANK 0
JR BNK2$SWITCH
; HERE TO GET MPU-80 SEGMENT # FOR THE BANK WE NEED:
BNK1$SWITCH:
DCR A ;NORMALIZE BANK # RELATIVE TO 0
ADD A ;X2
ADD A ;X4 FOR 16K / WINDOW
ADD A ;X8 FOR 32K / BANK
ADI 10H ;BANKS 1-15 START ABOVE 1ST 64K
; DO PHYSICAL BANK SWITCHING HERE:
BNK2$SWITCH:
PUSH B ;SAVE [BC]
LBCD WIN$LOW$2BITS ;GET LOWER 2 BITS FOR EACH RELOCATION REGISTER
DI ;CRITICAL SECTION -- NO INTERRUPTS HERE
STA CURRR0 ;SAVE SEGMENT ADDR. OF LOWER WINDOW
ORA B ;[A] = WINDOW SEG + LOW 2 BITS
OUT MPURR0 ;RELOCATE LOWER WINDOW NOW
ANI 0FCH ;TAKE OUT LOWER 2 BITS
ADI 4 ;BUMP UP SEG ADDR BY 16K FOR UPPER WINDOW
STA CURRR1 ;SAVE UPPER WINDOW SEGMENT ADDR.
ORA C ;[A] = WINDOW SEG + LOW 2 BITS
OUT MPURR1 ;RELOCATE UPPER WINDOW
;;;; EI ;CAN REENABLE INTERRUPTS NOW
POP B ;RESTORE [BC]
ENDIF
RET
IF BANKED
DOXMOV: DB 0 ;EXTENDED MOVE FLAG -- IF EQUAL TO FFH THEN
; NEXT CALL TO ?MOVE WILL BE AN INTER-BANK
; MOVE.
CURRR0: DB 10H ;CURRENT LOWER WINDOW RELOCATION REGISTER
; VALUE
CURRR1: DB 14H ;CURRENT UPPER WINDOW RELOCATION REGISTER
; VALUE
WIN$LOW$2BITS: DB 1 ;UPPER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
; ADDRESSING ABOVE 1 MEGABYTE OR EPROM SELECT)
DB 1 ;LOWER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
XMOV$BANKS: DS 1 ;STORAGE AREA FOR DESTINATION BANK # FOR
; EXTENDED MOVES
DS 1 ;STORAGE AREA FOR SOURCE BANK # FOR
; EXTENDED MOVES
BANKBUF: DS 128 ;LOCAL TEMPORARY BUFFER FOR EXTENDED MOVES
ENDIF
END
DRVTBL3.asm:
FDC3.asm:
IDE3.asm:
TITLE 'CP/M 3.0 DRIVE TABLES'
; DRVTBL3.ASM v.1.0 02/22/2023
TRUE EQU -1
FALSE EQU NOT TRUE
; DETERMINE IF BANK SELECTING:
BANKED EQU FALSE ;<-------------- NON BANKED VERSION
PUBLIC @DTBL
; DECLARE EXTERNAL LABELS:
EXTRN DPH0, DPH1, DPH2, DPH3
; INCLUDE CP/M 3.0 MACRO LIBRARY:
MACLIB CPM3
IF BANKED
DSEG ;BANKED SYSTEMS CAN HAVE DRIVE TABLE IN THE
; OP SYS BANK
ELSE
CSEG ;NON-BANKED SYSTEMS HAVE NO CHOICE BUT TO PUT
; IT IN THE COMMON MEMORY AREA
ENDIF
@DTBL: DTBL <DPH0,DPH1,DPH2,DPH3,0,0,0,0,0,0,0,0,0,0,0,0>
END
TITLE 'FDC MODULE FOR CP/M 3.0'
; FDC3.ASM v.1.0 02/22/2023
; Diskette device driver module for Altair computers.
; Supports Altair floppy disk controller and compatibles
; such as the FDC+ provided by DeRamp.com.
; Implemented by Wayne Parham (wayne@parhamdata.com)
; Ported into the CP/M 3.0 modular BIOS format
; Written by Mike Douglas (AltairClone.com)
TRUE equ -1
FALSE equ not TRUE
;Diskette parameter equates
MINIDSK equ FALSE ;set TRUE for Altair Mini-Disk
NUMTRK equ 77 ;number of tracks on the disk
NUMSEC equ 32 ;sectors per track
DATATRK equ 6 ;1st data format track
SECMASK equ 1Fh ;five bit sector numbers
BLS equ 1024 ;allocation unit size
BSH equ 4 ;allocation block shift factor
BLM equ 0Fh ;allocation block mask
EXM equ 0 ;extent mask
DSM equ 149 ;max block number (150 blocks of 2K bytes)
NDIRS equ 64 ;number of directory entries (64)
DRM equ 63 ;max directory entry number
AL0 equ 0C0h ;directory allocation block bits byte 0
AL1 equ 0 ;directory allocation block bits byte 1
RESTRK equ 2 ;reserved tracks for boot image
CKS equ (DRM+1)/4 ;directory check space
NUMDISK equ 2 ;Two drives supported
CSECLEN equ 128 ;CP/M sector length
SSECLEN equ 133 ;Altair system sector length
DSECLEN equ 136 ;Altair data sector length
TSECLEN equ DSECLEN+1 ;length of sector in track table
; System tracks (0-5) sector format
SYSTRK equ 0 ;offset of track number
SYSDATA equ 3 ;offset of 128 byte data payload
SYSSTOP equ 131 ;offset of stop byte (FFh)
SYSCSUM equ 132 ;offset of checksum
; Data tracks (6-76) sector format
DATTRK equ 0 ;offset of track number
DATSEC equ 1 ;offset of sector number
DATCSUM equ 4 ;offset of checksum
DATDATA equ 7 ;offset of 128 byte data payload
DATSTOP equ 135 ;offset of stop byte (FFh)
; Altair disk controller
DRVSLCT equ 08h ;drive select register (out)
cDSLCT equ 80h ;deselect drive
DRVSTAT equ 08h ;drive status register (in)
sENWD equ 01h ;enter new write data flag
sMOVEOK equ 02h ;OK to move head
sHDSTAT equ 04h ;head status flag
sDSKEN equ 08h ;disk is selected and enabled
sINTEN equ 20h ;processor interrupts enabled
sTRACK0 equ 40h ;on track zero flag
sNRDA equ 80h ;new read data available
DRVCMD equ 09h ;drive command register (out)
cSTEPI equ 01h ;step in
cSTEPO equ 02h ;step out
cHDLOAD equ 04h ;head load
cRESTMR equ 04h ;restart motor-off timer (MINIDSK)
cHDUNLD equ 08h ;head unload
cINTEN equ 10h ;interrupt enable
cINTDIS equ 20h ;interrupt disable
cHCSON equ 40h ;reduce head current switch
cWRTEN equ 80h ;write enable
DRVSEC equ 09h ;drive sector position (in)
sNEWSEC equ 01h ;new sector flag (sector true)
DRVDATA equ 0Ah ;drive read/write data (in/out)
; BDOS equates
GETCH equ 1 ;get character
PRINT equ 9 ;display string
OPEN equ 15 ;open file
READSEQ equ 20 ;read sequential
DMA equ 26 ;set address for file read
SETMULT equ 44 ;set multi-record I/O
; RAM equates
TPA equ 100h
DFFCB equ 5Ch
STACK equ 100h
BDOS equ 5
WBOOTV equ 00h ;warm boot vector location
BDOSV equ 05h ;bdos entry vector location
; Misc equates
NUMCDEV equ 4 ;number of character I/O devices
RDTRIES equ 6 ;read tries (must be <= 8)
VFTRIES equ 4 ;verify tries per write (must be <= 8)
WRTRIES equ 3 ;track writes to try
UNDEF equ 0FFh ;undefined value
CR equ 13 ;ascii for carriage return
LF equ 10 ;ascii for line feed
EOF equ 01Ah ;ctrl-z
; External references
maclib CPM3 ;CP/M 3.0 disk definition macros
maclib Z80 ;Z80 translation macro library
maclib modebaud ;Character I/O equates
extrn @civec,@covec,@aivec,@aovec,@lovec,@mxtpa
cseg ;Put DPBs in common memory
; Disk Parameter Headers
PUBLIC DPH0, DPH1 ;FLOPPY DISK PARAMETER HEADERS
PUBLIC bfDrive ;Buffered drive
PUBLIC ckFlush ;Disk buffer flush routine
; DEFINE EXTERNAL LABELS:
EXTRN @ADRV,@RDRV
EXTRN @DMA,@TRK,@SECT
EXTRN @CBNK
EXTRN @DBNK ;BANK FOR DMA OPERATION
EXTRN @ERMDE ;BDOS ERROR MODE
EXTRN ?WBOOT ;WARM BOOT VECTOR
EXTRN ?SLDSK ;SELECT DISK
EXTRN ?PMSG ;PRINT MESSAGE @<HL> UP TO 00, SAVES [BC] AND [DE]
EXTRN ?PDERR ;PRINT BIOS DISK ERROR HEADER
EXTRN ?CONIN,?CONO ;CONSOLE IN AND OUT
EXTRN ?CONST ;CONSOLE STATUS
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 0:
DW fdWrite ;FD SEC WRITE ROUTINE
DW fdRead ;FD SEC READ ROUTINE
DW fdLogin ;FLOPPY DISK "A:" LOGIN PROCEDURE
DW fdInit ;FLOPPY DISK "A:" INITIALIZATION ROUTINE
DB 0 ;RELATIVE DRIVE 0 ON THIS CONTROLLER
DB 0 ;DRIVE TYPE (UNUSED BY CP/M)
dph0 dw tranTbl,0,0,0,0,0,fd$dpb,csv0,alv0,fd$bcb,-1,-1
db 0
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 1:
DW fdLogin ;FLOPPY DISK "B:" LOGIN PROCEDURE
DW fdInit ;FLOPPY DISK "B:" INITIALIZATION ROUTINE
DB 1 ;RELATIVE DRIVE 1 ON THIS CONTROLLER
dph1 dw tranTbl,0,0,0,0,0,fd$dpb,csv1,alv1,fd$bcb,-1,-1
db 0
; fd$dpb - Disk Parameter Block. This table gives a block size of 1024 bytes
; and 64 directory entries.
fd$dpb dw NUMSEC ;sectors per track
db BSH ;allocation block shift factor (BSH)
db BLM ;data location block mask (BLM)
db EXM ;extent mask (EXM)
dw DSM ;maximum block number (DSM 242)
dw DRM ;maximum directory entry number (DRM 63)
db AL0,AL1 ;AL0, AL1
dw CKS ;CKS=(DRM+1)/4
dw RESTRK ;reserved tracks for CPM and bootloader
db 0 ;physical=logical sector (128 bytes)
; fd$bcb - Directory Buffer Control Block (BCB)
fd$bcb db 0FFh ;drive number (FF means not used yet)
db 0,0,0 ;record position
db 0 ;dirty (write) flag
db 0 ;scratch byte
dw 0 ;track
dw 0 ;sector
dw dirBuf ;buffer address
dw 0 ;bank
dw 0 ;link to next BCB (none)
if MINIDSK
tranTbl db 1,3,5,7,9,11,13,15,2,4,6,8,10,12,14,16
endif
if NOT MINIDSK
tranTbl db 01,09,17,25,03,11,19,27,05,13,21,29,07,15,23,31
db 02,10,18,26,04,12,20,28,06,14,22,30,08,16,24,32
endif
; Floppy init (noop)
fdInit:
ret
; Floppy login (noop)
fdLogin:
ret
; fdRead - Read sector BIOS entry. Read one sector using the @RDRV,
; @TRK, @SECT, and @DMA previously specified.
; On Entry
; @RDRV = drive to read from
; @TRK = track to read from
; @SECT = sector number to read (0-31)
; @DMA = address of buffer to read into
; On Exit
; If read successful
; sector read into @DMA
; HL = @DMA + CSECLEN
; A=0, Z flag set true
; Else
; A=1, Z flag set false
; Interrupts enabled
; Clobbers all
fdRead:
call decSec ;convert to zero-index
call ckFlush ;flush track buffer if needed
ei ;re-enable interrupts
call readTrk ;fill track buffer if needed
jnz exitDio ;track read error, exit
call movRead ;move sector to @DMA
exitDio mvi a,0 ;if zero is true, return zero
rz
inr a ;else return A<>0, Z false
ret
; fdWrite - Write sector BIOS entry. Write one sector using the @RDRV,
; @TRK, @SECT and @DMA specified.
; On Entry
; @RDRV = drive to write
; @TRK = track to write
; @SECT = sector number to write (0-31)
; @DMA = address of buffer to write from
; On Exit
; If successful
; sector written to trkBuf from @DMA
; Else
; Clobbers all
fdWrite:
jmp movWrt ;move @DMA to sector and exit
; movRead - Move sector data from track buffer to @DMA for a
; CPM read request
; On Entry
; On Exit
; If successful (good sector)
; sector data moved to @DMA, Z flag set true
; Else (sector flagged as bad)
; Z flag set false
; Clobbers all
movRead:
call altSkew ;@SECT to hard sector in A
call dSecAdr ;HL->sector in trkBuf
mov a,m ;A=sector valid flag
ora a
rnz ;bad sector, return error
lxi d,DATDATA+1 ;DE=offset to data portion of sector
lda @TRK ;on a data track?
cpi DATATRK
jnc mrMove ;yes, data track (DE already correct)
lxi d,SYSDATA+1 ;DE=offset to data portion of sector
mrMove dad d ;HL->data portion of sector
xchg ;DE->data portion of sector
lhld @DMA ;HL->destination for data
mvi b,CSECLEN ;B=number of bytes to move
mrLoop ldax d ;move sector from trkBuf to @DMA
mov m,a
inx h ;increment pointers
inx d
dcr b ;loop count
jnz mrLoop
ret ;exit with zero status
; movWrt - Move sector data from @DMA to track buffer and create
; metadata for the sector for a CPM write request.
; On Entry
; On Exit
; Sector data moved to trkBuf from @DMA
; A=0, Z status true
; Clobbers all
movWrt:
mvi m,0 ;flag sector as good
inx h ;HL->track
lda @TRK ;A=track
ori 80h ;set sync bit
mov m,a ;set track in sector
inx h ;HL->byte after track
cpi DATATRK+80h ;on a system or data track?
jnc wDatTrk ;data track 6-76 (mini disk 4-34)
; Create Altair sector for system tracks 0-5 (mini disk 0-3)
xra a ;put 0100h (16 bit) at offset 1,2
mov m,a
inx h ;HL->offset 2
inr a ;A=1
mov m,a
inx h ;HL->128 byte CPM sector in Altair sector
call mwMove ;move @DMA to sector in trkBuf
mvi m,0FFh ;offset 131 is stop byte (0FFh)
inx h ;offset 132 is checksum
mov m,b ;store checksum at offset 132
jmp mwExit ;exit
; wDatTrk- Create Altair sector for tracks 6-76 (mindisk 4-34)
wDatTrk:
lda @SECT ;A = sector (low byte) before Altair skew
mov m,a ;store Altair logical sector number
inx h ;HL->offset 2 in sector
xra a ;store zero at offsets 2-6
mov m,a ;offset 2
inx h
mov m,a ;zero at offset 3
inx h
push h ;save address of offset 4 = checksum
inx h
mov m,a ;zero at offset 5
inx h
mov m,a ;zero at offset 6
mvi m,0FFh ;offset 135 is stop byte (0FFh)
pop h ;HL->checksum byte in Altair sector
mov m,b ;store the checksum
; mwExit - set dirty flag true, return success status
mwExit:
mvi a,0FFh ;set dirty flag true
sta bfDirty
xra a ;return success status
ret
; mwMove - Move sector buffer (128 bytes) from @DMA to (HL) as part
; of a CPM write command. Compute checksum on all bytes moved and return
; the checksum in B.
; On Entry
; HL->destination sector in trkBuf
; @DMA = address of buffer to move from
; On Exit
; 128 bytes moved from @DMA to (HL)
; HL = HL + 128
; B = checksum of the 128 bytes moved
; Clobbers all
mwMove:
xchg ;DE->destination CPM sector in trkBuf
lhld @DMA ;HL->source buffer
lxi b,CSECLEN ;B=checksum (0), C=128 byte count
mwLoop: mov a,m ;move from (HL) to (DE)
stax d
add b ;add byte to checksum
mov b,a
inx d ;increment both pointers
inx h
dcr c ;decrement character count
jnz mwLoop ;loop until count = 0
xchg ;return with buffer pointer in HL
ret
; decSec - Decrement sector count to convert 1-indexed CPM physical
; sector to 0-indexed hardware-layer physical sector.
; On Entry
; @SECT = 1-indexed sector number
; On Exit
; @SECT = 0-indexed sector number
; Clobbers A
decSec:
dcr a ;decrement to convert to zero indexed
sta @SECT
ret
; altSkew - Perform Altair skew on the sector number in secNum and return
; the result in A. The skew is based on the track as:
; Tracks 0-5, secOut = secIn
; Tracks 6-76, secOut = (secIn * 17) MOD 32
; The skew computation for tracks 6-76 is implemented as:
; secOut = secIn if secIn is even
; secOut = secIn XOR 10h if secIn is odd
; On Entry
; @TRK = current track
; @SECT = sector number (0-31)
; On Exit
; A = sector number after Altair skew
; Clobbers A,B
altSkew equ $
if MINIDSK
ret ;no skewing done for mini disk
endif
if NOT MINIDSK
cpi DATATRK
lda @SECT ;A = unmodified sector number (low byte)
rc ;system track, no change to sector
mov b,a ;save sector number in B
rrc ;test for even/odd
mov a,b ;restore sector number in A
rnc ;return with sector number if even
xri 10h ;else translate as in comments above
ret
endif
; readTrk- read full track into track buffer if the requested
; drive (@RDRV) or track (@TRK) does not match the buffered
; drive (bfDrive) or buffered track (bfTrack). The status byte
; at the start of each sector is set to zero if the sector is
; good, non-zero if the sector couldn't be read.
; On Entry
; bfDrive = drive from which trkBuf was filled
; bfTrack = track from which trkBuf was filled
; On Exit
; @TRK on @RDRV read into trkBuf
; Zero true if track read or already there, zero false otherwise
; Clobbers all
readTrk:
lhld bfDrive ;L=buffered drive, H=buffered track
lda @RDRV ;A=requested drive
cmp l ;same drive buffered?
jnz rtNew ;drive doesn't match, need a new buffer
lda @TRK ;A=requested track
cmp h ;same track buffered?
rz ;yes, already have this buffer
; rtNew - New track needs to be read
rtNew:
mvi a,UNDEF ;invalidate buffered data
sta bfDrive
call dSelDrv ;select drive, load head
rnz ;drive select failed, exit with error
mvi a,2 ;init restore/seek try counter
sta skRetry
rtRtry: call dSeek ;seek to trkNum (disables interrupts)
rnz ;a restore was required and failed
call initTrk ;init all sectors to "bad" (not read)
lxi d,RDTRIES*NUMSEC*256 + NUMSEC
;D=max sector reads = RDTRIES revolutions
;E=sectors remaining to fill
; Read sector loop - All sectors are originally marked "bad" (unread) and
; a sector counter in E is started at NUMSEC (a full track of sectors).
; Sectors are read until sector counter E reaches zero or the total
; reads counter in D reaches zero (RDTRIES revolutions). The 1st time
; the total reads counter reaches zero, a restore and re-seek is
; performed in case we're on the wrong track. The second time it reaches
; zero, the bad sectors remain marked as bad in the track buffer.
; Within dRead, 152 cycles execute after the last byte is read until we're
; executing the instruction here following the dRead call. An additional
; 78 cycles are executed here until we're in dNxtSec looking for sector
; true. This totals 230 cycles (115us) from the last byte read until
; we're hunting for sector true. Allowing for 200us of index alignment
; error and 10% speed variance, we have at least 180us to get this done.
; For the Mini Disk, a full track is 16 sectors instead of 32 and the time
; available after a sector is read is well over 1000us, so timing is not
; an issue.
rdLoop:
call dNxtSec ;(17) wait for next sector, HL->sector buf
mov a,m ;A=sector flag byte
ora a ;this sector already read?
jz rdNext ;yes, skip it
push h ;save sector address
inx h ;HL->1st read location in sector
call dRead ;read the sector
pop h ;(10) restore sector address in HL
jnz rdNext ;(10) read error
xra a ;(4) set sector flag to zero (good sector)
mov m,a ;(7)
dcr e ;(5) decrement sectors left to fill
jz rtExit ;(10) all sectors read without error
rdNext: dcr d ;(5) decrement total sectors counter
jnz rdLoop ;(10) go read next sector
lxi h,skRetry ;HL->seek retry counter
dcr m ;decrement the counter
jz rtExit ;re-seek(s) done, we're finished
call dRestor ;restore to track zero
jz rtRtry ;start over after the re-seek
ret ;else, exit with error
rtExit: lhld @RDRV ;L=@RDRV, H=@TRK
shld bfDrive ;set the buffered drive and track values
ret ;exit with Z flag true
; initTrk - Set the flag byte in each sector in trkBuf to "bad" to
; indicate none of the sectors have been read.
; On Entry
; On Exit
; All sectors in trkBuf marked "bad" (unread)
; Clobbers all
initTrk:
lxi b,UNDEF*256 + NUMSEC; B=UNDEF (bad), C=NUMSEC
lxi h,trkBuf ;HL->track buffer
lxi d,TSECLEN ;DE=length of each sector in track buffer
itLoop: mov m,b ;mark sector as bad (not read)
dad d ;HL->next sector in trkBuf
dcr c ;repeat for all sectors
jnz itLoop
ret
; ckFlush - Check if track buffer should be flushed. This
; function must be called before any drive selection or seek
; operation. The buffer is flushed if the bfDirty flag is
; set and the drive or track number are different than the
; buffered track.
; On Entry
; Drive still selected and on same track as in trkBuf
; @RDRV, @TRK updated for the new I/O call
; On Exit
; Zero true for no error, zero false if write error occurred
; Clobbers all
ckFlush:
lda bfDirty ;see if track buffer is dirty
ora a
rz ;no, exit with Z set
lda @RDRV ;A=requested drive number
cmp l ;same drive?
jnz wrtTrk ;no, flush
lda @TRK ;A=requested track number
cmp h ;same track?
rz ;yes, no need to flush
wrtTrk equ $
if MINIDSK
mvi a,cRESTMR ;restart motor timeout
out DRVCMD
lda curDrv ;make sure current drive still enabled
out DRVSLCT
endif
mvi e,cWRTEN ;E=write command, normal head current
mvi a,42 ;tracks 0-42 are normal head current
cmp h ;compare 42 - current track
jnc wrtInit ;track is 0-42, E is correct
mvi e,cWRTEN+cHCSON ;E=write command with reduced current
wrtInit xra a ;clear buffer dirty flag
sta bfDirty
mvi a,WRTRIES ;initialize write retry count
sta wrRetry
di ;disable interrupts
; rtryWrt - Write track retry entry point. Write a full track starting
; with any sector. Don't write sectors that are flagged as bad.
rtryWrt:
mvi d,NUMSEC ;D=count of sectors to write
xra a ;zero the count of sectors actually written
sta secCnt
wrtLoop call dNxtSec ;(78) wait for next sector, HL->sector buf
mov a,m ;(7) check sector flag
ora a ;(4)
jnz wrtNext ;(10) skip if bad or previously verified
mov a,e ;(5) issue write command to drive
out DRVCMD ;(10) at 114 cycles 57us
inx h ;point to 1st byte of sector
call dWrite ;write the sector
lxi h,secCnt ;count number of sectors written
inr m
wrtNext dcr d ;decrement write sector count
jnz wrtLoop ;loop until all sectors processed
call dNxtSec ;force a 1 sector delay for trim erase
mvi d,NUMSEC*VFTRIES ;D=maximum number of sector reads
vfyLoop call dNxtSec ;wait for next sector, HL->sector buf
mov a,m ;test sector flag, only good and
ora a ; not previously verified sectors
jnz vfyNext ; are verified
push h ;save pointer to sector flag
call dVerify ;verify the sector
pop h ;HL->sector flag for current sector
jnz vfyNext ;didn't match
mvi m,UNDEF ;set flag to indicate sector is verified
lxi h,secCnt ;HL->sectors left to verify
rz ;track verified, exit
vfyNext dcr d ;decrement sector count
jnz vfyLoop ;loop until all verify tries expired
; Read re-tries expired, decrement the write retry count and write again
lxi h,wrRetry ;decrement the write retry counter
dcr m
jnz rtryWrt ;retry starting with the write
call ?pMsg
db CR,LF,'Delayed Write Error', CR, LF, 0
inr a
ret ;exit with 1 for error
; Altair disk I/O routines
; dSelDrv - Select the drive specified in @RDRV and load the head.
; Save the track (curTrk) the current drive is on into the track table,
; load curTrk for the new drive from the track table.
; On Entry
; @RDRV = drive to be selected
; curDrv = drive currently selected
; selTime = timeout in seconds to wait for drive select
; curTrk = track the current drive is on
; On Exit
; Drive selected and head loaded
; curDrv = @RDRV
; curTrk = track the newly selected drive is on
; Zero true for success, zero false for error
; Clobbers all
dSelDrv equ $
if MINIDSK
out DRVCMD
endif
lxi h,curDrv ;HL->currently selected drive
mov e,m ;E=currently selected drive
lda @RDRV ;A=desired drive
mov c,a ;save new drive in C
cmp e ;same or different drive?
jnz dNewDrv ;different, go select a new drive
in DRVSTAT ;drive still selected and enabled?
ani sDSKEN
jz dSelExt ;yes, exit
jmp dReSel ;otherwise, re-select the drive
; dNewDrv - Save current track (curTrk) for the current drive to the track
; table, load curTrk for the new drive from the track table
dNewDrv mov m,c ;save new drive in curDrv
mvi d,0 ;DE=currently selected drive
lxi h,trkTbl ;HL->track table
dad d ;HL->trkTbl entry for current drive
lda curTrk ;A=track current drive is on
mov m,a ;save it in the track table
mov e,c ;DE=offset in trkTbl for new drive
dad d ;HL->trkTbl for new drive
mov a,m ;A=track new drive is on
sta curTrk ;update current track
; Select the new drive with the timeout specified in selTime
dReSel lxi h,selTime ;move select timeout in seconds into B
mov b,m
dSelLp1 lxi h,25641 ;HL=count of 78 cycle loops for 1 second
dSelLp mvi a,cDSLCT ;(7) deselect a possibly attached drive
out DRVSLCT ;(10)
mov a,c ;(5) A=drive to select
out DRVSLCT ;(10) select it
in DRVSTAT ;(10) did drive select work?
ani sDSKEN ;(7)
jz dSelExt ;(5) yes, exit
dcx h ;(5) decr 1 sec counter
mov a,h ;(5) test HL counter for zero
ora l ;(4)
jnz dSelLp ;(10) loop for one second
dcr b ;decrement seconds expired
jnz dSelLp1 ;repeat for a new 1 second
inr a ;timeout, return non-zero
ret
dSelExt mvi a,cHDLOAD ;issue head load command
out DRVCMD ;restarts timeout for mini disk
ret ;return with zero status
; dSeek - Seek to track in @TRK
; On Entry
; Drive selected and ready
; @TRK = desired track
; curTrk = current track, UNDEF means we don't know
; On Exit
; curTrk = @TRK
; Interrupts disabled
; Zero true for success, zero false for failure
; (failure is a failed restore to track zero)
; Clobbers A,B,C,H,L
dSeek di ;disable interrupts
lda curTrk ;A=current track
cpi UNDEF ;valid track number?
jnz dTrkVld ;yes, track is valid
call dRestor ;otherwise, restore to track zero
rnz ;exit if restore failed
; dTrkVld - Current track is valid, compute direction and number
; of steps
dTrkVld lxi h,@TRK ;HL<-@TRK
sub m ;A=current-requested
rz ;return if already on correct track
mvi b,cSTEPO ;B=step out (assume requested<current)
jnc dDoSeek ;it is
mvi b,cSTEPI ;B=step in (requested>current)
cma ;compute A=-A
inr a
; Save target track in curTrk, step there, then verify track
dDoSeek mov c,a ;C=number of steps
mov a,m ;save new track in curTrk
sta curTrk
call dStep ;do the seek
xra a ;return zero
ret
; dRestor - Restore to track 0 and then delay to ensure any subsequent
; seek meets the minimum direction change period.
; On Entry
; On Exit
; If successful
; curTrk = 0
; A=0
; Zero true
; else
; curTrk = UNDEF
; Zero false
; Clobbers A,B,C
dRestor xra a
sta curTrk ;set current drive track to zero
in DRVSTAT ;test for track 0
ani sTRACK0
rz ;at track 0, exit
; Step in three tracks, then step out to track 0
mvi c,3 ;C=step in 3 tracks
mvi b,cSTEPI ;B=step in command
call dStep ;do 3 steps in
mvi a,20 ;20ms delay puts us past the 1ms step window
call delayMs ; and ensures proper dir change delay
; Seek back out until track 0 detected
mvi c,NUMTRK+10 ;C=maximum number of step outs to try
mvi b,cSTEPO ;B=step out command
call dStep ;step until track 0 detected
jnz drFail ;restore failed
drFail mvi a,UNDEF ;restore failed, track is still undefined
sta curTrk
ret ;return with non-zero
; dStep - Step head number of steps in C, direction command in B.
; If track zero is detected during a step-out operation, curTrk
; is forced to zero and zero is returned in A.
; On Entry
; C = number of steps > 0
; B = step command (cSTEPO or cSTEPI)
; On Exit
; If stepping out and track zero hit
; curTrk = 0
; A = 0
; Zero true
; else
; Zero false
; Clobbers A,B,C
dStep in DRVSTAT ;loop until OK to move the head
ani sMOVEOK
jnz dStep
in DRVSTAT ;see if we are at track 0
ani sTRACK0 ;at track zero?
jnz dStep1 ;no, go on
mov a,b ;stepping out?
sbi cSTEPO
jz dStep0 ;yes, we've hit track 0
dStep1 mov a,b ;A=step command and direction
out DRVCMD ;issue the step
dcr c ;decrement step counter
jnz dStep ;loop until count reaches zero
inr c ;force non-zero
ret
dStep0 sta curTrk ;curTrk=0
ret ;return with zero true and A=0
; dNxtSec - Wait for next (any) sector. Returns pointer to the sector
; buffer within trkBuf. Control is back to caller at 78 cycles (39us).
; On Entry
; Drive is selected, head loaded
; On Exit
; HL->sector buffer in trkBuf for sector found
dNxtSec equ $
if MINIDSK
out DRVCMD
endif
dnLoop in DRVSEC ;read sector position register
rar ;wait for sector true (0=true)
jc dnLoop
ani SECMASK ;(7) get sector number alone
;fall into dSecAdr
; dSecAdr - Convert hard sector in A to address within trkBuf for
; the specified sector
; On Entry
; A = Hard sector number
; On Exit
dSecAdr lxi h,secAddr ;(10) HL->sector address table
mvi b,0 ;(7) form BC=sector*2
rlc ;(4) A=sector*2 (2 bytes per table entry)
mov c,a ;(5) BC=sector*2
dad b ;(10) HL->address table entry for passed sector
mov a,m ;(7) A=lsb of sector buffer address
inx h ;(5)
mov h,m ;(7) H=msb of sector buffer address
mov l,a ;(5) HL->sector buffer
ret ;(11)
; delayMs - Delay for number of ms specified in A
; On Entry
; A = ms to delay
; On Exit
; A=0
; Zero true
; Clobbers A,B
delayMs mvi b,(2000/19) ;19 cycles in the loop below
delayLp nop ;(4)
dcr b ;(5)
jnz delayLp ;(10)
dcr a ;decrement ms counter
jnz delayMs
ret
; dRead - Read a sector, verify checksum, stop byte, and track number.
; Verification is done after the sector is read in the time between
; the last byte of the sector and before the start of the next sector.
; With index alignment and rotation speed tolerance accounted for,
; we safely have 360 cycles from the last byte of the sector until code
; should be in the sector true hunt loop. The RET is complete from this
; routine 152 cycles worst case after the last byte is read.
; On Entry
; Drive is selected, sector true just detected
; HL->sector buffer
; On Exit
; Sector read to (HL)
; C = track number from disk with sync bit set
; Zero true if no error, Zero false for checksum error, missing
; FF stop byte, or track number error
dRead push h ;(11) save pointer to start of sector
lxi b,256+DSECLEN ;(10) B=chksum (-FF), C=bytes to read
lda curTrk ;(13) A=track we're on
cpi DATATRK ;(7) data track or system track?
jnc drSecWt ;(10) data track, length in C is correct
mvi c,SSECLEN ;(7) C=length of a system sector
; The sector transfer loop is 116 cycles for two bytes read (has to be
; less than 128) and computes checksum over all bytes read. For the
; mini disk, only one byte is read per loop iteration.
drSecWt in DRVSTAT ;(10) get drive status byte
ora a ;(4) wait for NRDA flag true (zero)
jm drSecWt ;(10)
if NOT MINIDSK ;8" reads two bytes per loop
in DRVDATA ;(10) read first byte at 24-48 cycles
mov m,a ;(7) store in buffer
add b ;(4) update checksum
mov b,a ;(5) keep checksum in B
inx h ;(5) increment buffer pointer
dcr c ;(5) decrement byte count
jz drSecDn ;(10) exit if done
endif
in DRVDATA ;(10) read at 70-94 cycles (data at 64 and 128)
jnz drSecWt ;(10) repeat until done
; drSecDn - Sector read is complete, now validate the sector based on whether
; it is from a system track or data track.
drSecDn lda curTrk ;(10) A=track we're supposed to be on
cpi DATATRK ;(7) system or data track?
jnc drDatTk ;(10) data track
; Validate a system track sector. A system track sector is three bytes
; bytes shorter, so this codes starts 3*64 cycles sooner than for a
; data sector. This code completes before a data sector would even
; finish reading. Therefore, a data sector is the worst timing path.
mov a,b ;(5) A=calculated checksum over all bytes
dcx h ;(5) HL->checksum in sector
sub m ;(7) subtract from computed checksum
sub m ;(7) final sum will be zero
dcx h ;(5) HL->stop byte
mov b,m ;(7) B=stop byte
pop h ;(10) restore HL->start of buffer
inr b ;(4) was FF stop byte there?
rnz ;(5/11) no, return error
mov c,m ;(7) C=track number from disk
sub c ;(4) take track out of checksum
inx h ;(5) HL->2nd byte of sector
sub m ;(7) take out of checksum
inx h ;(5) HL->3rd byte of sector
jmp drExit ;(10) do common compares and exit
; Validate a data track sector (125 + 27 cycles for sector type jump)
drDatTk dcx h ;(5) HL->stop byte
mov a,m ;(7) A=stop byte
inr a ;(4) was FF stop byte there?
inx h ;(5) HL->sector number
inx h ;(5) move to checksum byte
inx h ;(5)
inx h ;(5) HL->checksum
sub m ;(7) subtract from checksum
drExit sub m ;(7) checksums match?
rnz ;(5/11) no, exit with error
lda curTrk ;(10) A=track we should be on
ori 80h ;(7) set sync bit
cmp c ;(4) same track as from sector?
ret ;(11) exit with compare status
; dVerify - Verify a sector
; The 2nd read at 67 cycles only gives 3 cycles of headroom (67-64)
; which, in turn, gives about 4% speed tolerance. However, we are
; verifying our own write, so the primary tolerance issue is ISV,
; not the average rotation rate, so tolerance is still within the
; +/-1.5% ISV spec.
; On Entry
; HL->sector buffer to compare against
; On Exit
; Zero true if match, zero false for error
dVerify lxi b,DSECLEN ;(10) B=0, C=data sector length
jnc dVfLoop ;(10) data track, length in C is correct
mvi c,SSECLEN ;(7) set C=length of a system sector
dVfLoop in DRVSTAT ;(10) get drive status byte
jm dVfLoop ;(10)
xra m ;(4) verify data matches buffer
ora b ;(4) accumulate errors in b
mov b,a ;(5)
dcr c ;(5) decrement characters remaining counter
jz dVfDone ;(10) done verifying bytes
endif
in DRVDATA ;(10) read 2nd byte at 67-91 cycles
ora b ;(4) accumlate errors in b
mov b,a ;(5)
dcr c ;(5) decrement byte counter
jnz dVfLoop ;(10) loop for all bytes
dVfDone ora a ;A=zero if all bytes matched
ret ;return status
; dWrite - Write a sector
; The write loop is 61 cycles which gives just 3 cycles (64-61) of
; headroom. However, since the write timing required by the FDC board
; is derived from the 2 MHz CPU/bus clock, this loop is always exactly
; in sync with the FDC write timing. 3 cycles of headroom is plenty.
; On Entry
; Drive is selected, sector true just detected, and
; the write command has already been issued
; HL->sector buffer to write
; On Exit
; Clobbers A,C,H,L
dWrite mvi c,DSECLEN ;C=number of bytes to write
jnc dWrLoop ;(10) data track, length in C is correct
dWrLoop in drvStat ;(10) read drive status register
rrc ;(4) wait for ENWD flag (zero)
jc dWrLoop ;(10)
mov a,m ;(7) A=next byte to write
out drvData ;(10) write 2nd byte at 68-92 cycles
dcr c ;(5) decrement bytes remaining
jnz dWrLoop ;(10) loop until all bytes written
dWrDone in drvStat ;wait for another write flag
rrc
jc dWrDone
xra a ;write a trailing zero
out drvData
ret
; BIOS Data Area
; secAddr - Sector address table. Returns sector buffer address within
; the track buffer when indexed by hard sector number. Each sector
; requires TSECLEN bytes.
secAddr dw trkBuf+00*TSECLEN,trkBuf+01*TSECLEN,trkBuf+02*TSECLEN
dw trkBuf+03*TSECLEN,trkBuf+04*TSECLEN,trkBuf+05*TSECLEN
dw trkBuf+06*TSECLEN,trkBuf+07*TSECLEN,trkBuf+08*TSECLEN
dw trkBuf+09*TSECLEN,trkBuf+10*TSECLEN,trkBuf+11*TSECLEN
dw trkBuf+12*TSECLEN,trkBuf+13*TSECLEN,trkBuf+14*TSECLEN
dw trkBuf+15*TSECLEN
if NOT MINIDSK
dw trkBuf+16*TSECLEN,trkBuf+17*TSECLEN,trkBuf+18*TSECLEN
dw trkBuf+19*TSECLEN,trkBuf+20*TSECLEN,trkBuf+21*TSECLEN
dw trkBuf+22*TSECLEN,trkBuf+23*TSECLEN,trkBuf+24*TSECLEN
dw trkBuf+25*TSECLEN,trkBuf+26*TSECLEN,trkBuf+27*TSECLEN
dw trkBuf+28*TSECLEN,trkBuf+29*TSECLEN,trkBuf+30*TSECLEN
dw trkBuf+31*TSECLEN
endif
; Initialized data
selTime db 7 ;drive select timeout in seconds
coldSt db 0FFh ;FF during cold start, 0 otherwise
curDrv db 0 ;drive number currently selected
curTrk db UNDEF ;track the selected drive is on
trkTbl db UNDEF,UNDEF,UNDEF,UNDEF ;track each drive is on
bfDirty db 0 ;non-zero if buffer has been written to
bfDrive db UNDEF ;drive currently in track buffer
bfTrack db UNDEF ;currently buffered track (MUST follow bfDrive)
; Non-initialized data
secCnt ds 1 ;count of bad sectors remaining in trkBuf
wrRetry ds 1 ;write retry counter
skRetry ds 1 ;restore and seek retry counter
; Disk scratchpad areas defined in the DPH table
dirBuf ds 128 ;BDOS directory scratchpad
alv0 ds (DSM/8 + 1) ;allocation vector storage
csv0 ds CKS ;change disk scratchpad
alv1 ds (DSM/8 + 1)
csv1 ds CKS
; Track buffer. One extra byte is allocated at the start of each sector
; to flag a bad sector (read failure). This byte is zero if the sector
; is good, non-zero if the sector is bad.
trkBuf ds NUMSEC*TSECLEN
end
TITLE 'IDE MODULE FOR CP/M 3.0'
; IDE3.ASM v.1.0 02/22/2023
; IDE disk device driver module for Altair computers.
; Supports the IDE-CF controller provided by
; S100computers.com.
; John Monahan designed the controller board and wrote
; a version of BIOS for his Z80-based systems. The IDE
; interface was based on a design from Peter Faasse.
; Another important contributor is David Fry who recognized
; that the original format left "holes" on the disk because
; it skipped sectors in the LBA translation.
; This version is a re-write that takes all of those things
; and incorporates them in an 8080-compatible format that
; runs on an original Altair and compatible computers.
;INCLUDE CP/M 3.0 DISK DEFINITION MACROS:
MACLIB CPM3
;INCLUDE Z-80 MACRO LIBRARY:
MACLIB Z80
;Ports for 8255 chip. Change these to specify where the 8255 is addressed,
;and which of the 8255's ports are connected to which IDE signals.
;The first three control which 8255 ports have the control signals,
;upper and lower data bytes. The last one is for mode setting for the
;8255 to configure its ports, which must correspond to the way that
;the first three lines define which ports are connected.
IDEportA EQU 030H ;lower 8 bits of IDE interface
IDEportB EQU 031H ;upper 8 bits of IDE interface
IDEportC EQU 032H ;control lines for IDE interface
IDEportCtrl EQU 033H ;8255 configuration port
IDEDrive EQU 034H ;Bit 0 - 0 for drive 0 and 1 for drive 1
READcfg8255 EQU 10010010b ;Set 8255 IDEportC out, IDEportA/B input
WRITEcfg8255 EQU 10000000b ;Set all three 8255 ports output
;IDE control lines for use with IDEportC. Change these 8
;constants to reflect where each signal of the 8255 each of the
;IDE control signals is connected. All the control signals must
;be on the same port, but these 8 lines let you connect them to
;whichever pins on that port.
IDEa0line EQU 01H ;direct from 8255 to IDE interface
IDEa1line EQU 02H ;direct from 8255 to IDE interface
IDEa2line EQU 04H ;direct from 8255 to IDE interface
IDEcs0line EQU 08H ;inverter between 8255 and IDE interface
IDEcs1line EQU 10H ;inverter between 8255 and IDE interface
IDEwrline EQU 20H ;inverter between 8255 and IDE interface
IDErdline EQU 40H ;inverter between 8255 and IDE interface
IDErstline EQU 80H ;inverter between 8255 and IDE interface
;Symbolic constants for the IDE Drive registers, which makes the
;code more readable than always specifying the address pins
REGdata EQU IDEcs0line
REGerr EQU IDEcs0line + IDEa0line
REGseccnt EQU IDEcs0line + IDEa1line
REGsector EQU IDEcs0line + IDEa1line + IDEa0line
REGcylinderLSB EQU IDEcs0line + IDEa2line
REGcylinderMSB EQU IDEcs0line + IDEa2line + IDEa0line
REGshd EQU IDEcs0line + IDEa2line + IDEa1line ;(0EH)
REGcommand EQU IDEcs0line + IDEa2line + IDEa1line + IDEa0line ;(0FH)
REGstatus EQU IDEcs0line + IDEa2line + IDEa1line + IDEa0line
REGcontrol EQU IDEcs1line + IDEa2line + IDEa1line
REGastatus EQU IDEcs1line + IDEa2line + IDEa1line + IDEa0line
;IDE Command Constants. These should never change.
COMMANDrecal EQU 10H
COMMANDread EQU 20H
COMMANDwrite EQU 30H
COMMANDinit EQU 91H
COMMANDid EQU 0ECH
COMMANDspindown EQU 0E0H
COMMANDspinup EQU 0E1H
MAXSEC EQU 3FH
LBA$MODE EQU 11100000b
; IDE Status Register:
; bit 7: Busy 1=busy, 0=not busy
; bit 6: Ready 1=ready for command, 0=not ready yet
; bit 5: DF 1=fault occured insIDE drive
; bit 4: DSC 1=seek complete
; bit 3: DRQ 1=data request ready, 0=not ready to xfer yet
; bit 2: CORR 1=correctable error occured
; bit 1: IDX vendor specific
; bit 0: ERR 1=error occured
BUSY$FLAG EQU 10000000b
BUSY$DRQ EQU 10001000b
RDY$DRQ EQU 00001000b
BUSY$CMD EQU 11000000b
RDY$CMD EQU 01000000b
; Console ASCII equates
BELL EQU 07H
CR EQU 0DH
LF EQU 0AH
; Public labels exposed:
PUBLIC DPH2, DPH3 ;IDE drive parameter headers
; External labels:
EXTRN @ADRV,@RDRV
EXTRN @CBNK
EXTRN @DBNK
EXTRN @ERMDE ;BDOS error mode
EXTRN ?WBOOT
EXTRN ?PMSG ;Print null-terminated string
EXTRN ?PDERR ;Print BIOS disk error
EXTRN ?CONIN,?CONO ;Console I/O
EXTRN ?CONST ;Console status
; Extended disk parameter header for IDE drive 0:
DW HDWRT ;IDE Drive Write
DW HDRD ;IDE Drive Read
DW SELECT0 ;IDE Login
DW INIT0 ;IDE Init
DB 0 ;Controller drive number
DB 0 ;Media Type
DPH2: DPH 0,IDEHD$DPB,0,
; Extended disk parameter header for IDE drive 1:
DW SELECT1 ;IDE Login
DW INIT1 ;IDE Init
DB 1 ;Controller drive number
DB 0 ;Media Type
DPH3: DPH 0,IDEHD$DPB,0,
; Put DPBs in common memory
CSEG
; 512 byte sectors on hard disk (512 x 64 x 256 = 8,388,608 bytes)
IDEHD$DPB:
DPB 512,64,256,2048,1024,1,8000H
; 2048 allocation unit size, 1024 directory entries
; IDE Initialization / Login
SELECT0: ;Select drive 0
XRA A
JMP SELECTdrive
SELECT1: ;Select drive 1
MVI A, 1
SELECTdrive: ;Select drive [A]
OUT IDEDrive
RET
INIT0:
XRA A
OUT IDEDrive ;Select drive 0
JMP IDEinit
INIT1:
MVI A, 1
OUT IDEDrive ;Select drive 1
IDEinit: ;Initialize the 8255 and drive
MVI A,READcfg8255
OUT IDEportCtrl ;config 8255 chip, READ mode
MVI A,IDErstline
OUT IDEportC ;reset
MVI B, 20H
ResetDelay:
DCR B
JNZ ResetDelay ;delay (reset pulse width)
XRA A
OUT IDEportC ;no IDE control lines asserted (just bit 7 of port C)
CALL DELAY$32
MVI D, LBA$MODE ;11100000B
MVI E, REGshd
CALL IDEwr8D ;write byte to select the MASTER device
MVI B, 0FFH ;set delay time
WaitInit:
MVI E, REGstatus ;get status after initialization
CALL IDErd8D ;check status
MOV A, D
ANI BUSY$FLAG ;check busy flag
JZ DoneInit ;return if ready bit is zero
PUSH B
LXI B, 0FFFFH ;long delay to allow drive to get up to speed
DELAY2: MVI D, 2
DELAY1: DCR D
JNZ DELAY1
DCX B
MOV A,C
ORA B
JNZ DELAY2
POP B
DCR B
JNZ WaitInit
CALL SetErrorFlag ;if not ready by this point, return with NZ flag set
LXI H, MSG$INIT$ERR
CALL ?PMSG
ORI 1
RET
DoneInit:
XRA A ;return with no error
RET
; SECTOR WRITE ROUTINE
HDWRT: ;Write one sector
XRA A
STA ERFLG ;clear error flag
CALL wrlba ;convert track/sector to LBA
CALL IDEwaitnotbusy ;make sure drive is ready
JC SetErrorFlag
MVI D, COMMANDwrite
MVI E, REGcommand
CALL IDEwr8D ;tell drive to write a sector
CALL IDEwaitdrq ;wait unit it wants the data
JC SetErrorFlag ;if problem abort
LHLD @DMA ;DMA address
MVI A, WRITEcfg8255
OUT IDEportCtrl
MVI B,0 ;256x2 bytes
WRSEC1:
MOV A, M
INX H
OUT IDEportA ;LOW byte to port A first
MOV A, M
INX H
OUT IDEportB ;then HIGH byte to port B
MVI A, REGdata
PUSH PSW
OUT IDEportC ;send write command
ORI IDEwrline ;send WR pulse
OUT IDEportC
POP PSW
OUT IDEportC
DCR B
JNZ WRSEC1
MVI A, READcfg8255 ;set 8255 back to read mode
OUT IDEportCtrl
CHECK$RW:
MVI E, REGstatus ;check R/W status when done
CALL IDErd8D
MOV A, D
ANI 01H
STA ERFLG ;return Z if successful
RZ
SetErrorFlag: ;for now just return with error flag set
XRA A
DCR A
STA ERFLG ;return NZ if problem
RET
; SECTOR READ ROUTINE
HDRD: ;Read one sector
XRA A
JC SetErrorFlag ;NZ set if error
MVI D, COMMANDread
MVI E, REGcommand
CALL IDEwr8D ;send sector read command
CALL IDEwaitdrq ;wait until data ready
MVI B, 0
MoreRD16:
MVI A,REGdata ;select data register address
OUT IDEportC
ORI IDErdline ;08H+40H, pulse RD line
OUT IDEportC
IN IDEportA ;read the LOW byte first
MOV M, A
INX H
IN IDEportB ;then the HIGH byte
MOV M,A
INX H
MVI A, REGdata ;deassert RD line
OUT IDEportC
DCR B
JNZ MoreRD16
JMP CHECK$RW
; SUPPORT ROUTINES
wrlba: ;Translate to logical block address
CALL IDEwaitnotbusy ;make sure drive isn't busy
LHLD @TRK ;get the CP/M requested track high and low
MOV A, L ;get low byte of track, interested in bottom two bits
RRC ;shift 'em
RRC ;shift again to the top
ANI 0C0H ;examine those two bits
MOV C, A ;save in [C]
LDA @SECT ;sector number (low byte) into [A]
ANI 03FH ;take only bottom 6 bits
ORA C ;add in top 2 bits of track
MOV D, A ;send info to the drive
MVI E, REGsector
CALL IDEwr8D
MOV A, L ;get low byte of track again
RRC
RRC
ANI 03FH
MOV A, H ;get high byte of track
RRC ;rotate twice, leaving low 2 bits
RRC ;in upper bits of [A]
ANI 0C0H ;mask all but the two bits we want
ORA C ;add in the top 6 bits of the first track byte
MOV D, A ;send Low TRK#
MVI E, REGcylinderLSB
CALL IDEwr8D
RRC ;just the top 6 bits
RRC
ANI 03FH
MOV D, A ;send High TRK#
MVI E, REGcylinderMSB
CALL IDEwr8D
MVI D, 1 ;one sector at a time
MVI E, REGseccnt
CALL IDEwr8D
RET
IDEwaitnotbusy: ;Drive READY if 01000000
MVI B, 0FFH
MVI C, 0FFH ;delay, must be above 80H. Leave longer for slower drives
MoreWait:
MVI E, REGstatus ;wait for RDY bit to be set
CALL IDErd8D
MOV A, D
ANI BUSY$CMD ;11000000B
XRI RDY$CMD ;01000000B
JZ DoneNotbusy
DCR B
JNZ MoreWait
DCR C
JNZ MoreWait
STC ;set carry to indicqate an error
ret
DoneNotBusy:
ORA A ;clear carry it indicate no error
RET
IDEwaitdrq:
MVI B, 0FFH
MVI C, 0FFH ;delay must be above 80H. Leave longer for slower drives
MoreDRQ:
MVI E, REGstatus ;dait for DRQ bit to be set
CALL IDErd8D
MOV A, D
ANI BUSY$DRQ ;10001000B
CPI RDY$DRQ ;00001000B
JZ DoneDRQ
DCR B
JNZ MoreDRQ
DCR C
JNZ MoreDRQ
STC ;set carry to indicate error
RET
DoneDRQ:
ORA A ;clear carry
RET
DELAY$32:
MVI A, 40 ;delay ~32ms
DELAY3:
MVI B, 0
M0:
DCR B
JNZ M0
DCR A
JNZ DELAY3
RET
; Low Level 8 bit R/W to the drive controller. These are the routines that talk
; directly to the drive controller registers, via the 8255 chip.
; Note the 16 bit I/O to the drive (which is only for SEC R/W) is done directly
; in the routines HDRD & HDWRT for speed reasons.
IDErd8D: ;Read byte from IDE register in [E], return info in [D]
MOV A, E
OUT IDEportC ;drive address onto control lines
ORI IDErdline ;RD pulse pin (40H)
OUT IDEportC ;assert read pin
IN IDEportA
MOV D, A ;return with data in [D]
MOV A, E
OUT IDEportC ;deassert RD pin first
XRA A
OUT IDEportC ;zero all port C lines
RET
IDEwr8D: ;Write byte in [D] to IDE register in [E]
MVI A, WRITEcfg8255 ;set 8255 to write mode
OUT IDEportCtrl
MOV A, D ;get data put it in 8255 A port
OUT IDEportA
MOV A, E ;select IDE register
OUT IDEportC
ORI IDEwrline ;lower WR line
OUT IDEportC
MOV A, E
OUT IDEportC ;deassert WR pin first
XRA A ;deselect all lines including WR line
OUT IDEportC
MVI A, READcfg8255 ;config 8255 chip, read mode on return
OUT IDEportCtrl
RET
MSG$INIT$ERR DB 'Initilization of IDE drive failed.',CR,LF,0
ERFLG: DB 0H
Great work!
I've been testing the BIOS for about a week now, and I'm satisfied that it is working properly. So I've created a distribution archive, which contains the source code, executable binaries and a couple of 330Kb bootable image files, one for 48Kb RAM and the other for 63Kb.
This version of CP/M boots from 330Kb diskette and supports two 330Kb diskette drives and two 8Mb IDE drives, either magnetic or compact flash. The diskettes are A and B and the hard drives are C and D.
You can see my troubleshooting steps at the link below. It's essentially the same notes I made that were the subject of this thread. So scroll down to the bottom to see the last stuff I did. It's all kind of a yawner, but might help someone else in the future trying to troubleshoot a new BIOS. At least it'll help me remember if I ever need it.
=== Next Steps ===
I'm pretty happy with this version of CP/M exactly as it stands. But there are a few things that might be useful at some point:
1. A version of BIOS that boots from an IDE drive.
2. BIOS that supports banked memory on the Altair. Of course, we'd need to choose or define and develop memory hardware first.
3. BIOS or tool that changes the CP/M accessible drive from "partition" 00 to any other.
To explain this third idea, you might remember earlier in this thread where I described a feature I added to IDEutil that allows the selection of "partitions." What I did was to logically group the tracks into "partitions," using the most significant byte of the track number.
CP/M tracks are 00-FF and sectors are 00-3F for each of the IDE drives. But the drive is capable of tracks 0000-FFFF. So the first 8Mb is tracks 0000-00FF, the second is 0100-01FF, and so on. IDEutil can access any of these areas, but CP/M can only "see" the first one.
It might be nice to add a feature - tied in through the wrlba function in IDE3.asm - that allows the user to change "partitions" in CP/M, to allow any of 256 to be selected. That would expose an entire 2Gb drive to CP/M.
- CP/M Plus 3.0hd distribution archive, containing source, executables and bootable disk images
=== Next Steps ===
Hello,
I just read the entire thread. What a journey! I've been trying to get the Dual IDE V4 board to work and ran into some issues that have been occupying me for quite some time now. Maybe someone here has ideas or insights as to why I'm having these issues: I'm able to initialize a drive and read/copy data from the drive. The problem that I'm having is that, when the computer runs my code to read and copy data from the drive to RAM, it skips certain words occasionally. It's always the same words (it seems) but whether they are present or not is kind of random. That is - sometimes they are read while other times they are skipped and the next word is actually read from the buffer instead (by "word" I mean the HI and LO byte).
I'm using a variant of a bootloader that was present in this thread but I modified it a bit to get it working on my Altair (Intel 8080). The code reads from a CF drive that contains CP/M V3. I can see that it copies most of it into RAM address 0100H but, as I stated above, certain words are skipped. I also read from the CF card on my other computer to see what was on it and those words are present.
For example, here are the first few records. I have tags around the words that are skipped.
The code that reads from the drive and copies to RAM is the following:
Here is the full code:
I would really appreciate some help on this as I've been banging my head for the past few days, if not weeks.
00000200: 3181 02cd 000b 0e0d cd8d 020e 0911 2502 1.............%.
00000210: cd8d 020e 0f11 ab01 cd8d 02fe ff11 cf01 ................
00000220: caa2 0111 8000 cd8f 01cd 9501 2180 0011 ............!...
00000230: 8102 0e06 7e12 1323 0dc2 3401 cd95 010e ....~..#..4.....
00000240: 0911 8000 cd8d 023a 8202 673a 8102 cd73 .......:..g:...s
00000250: 013a 8402 b7ca 5f01 673a 8302 cd73 0121 .:...._.g:...s.!
00000260: 5d00 7efe 24c2 6f01 [b]237e[/b] fe42 cca9 0131 ].~.$.o.#~.B...1
00000270: 8502 c9b7 571e 007c 1767 [b]eb01[/b] 80ff 09eb ....W..|.g......
00000280: d5e5 cd8f 01cd 9501 e1d1 25c2 7a01 c90e ..........%.z...
MoreRD16:
MVI A,REGdata ;REG register address
OUT IDECport
ORI IDErdline ;08H+40H, Pulse RD line
OUT IDECport
IN IDEAport ;read the LOWER byte
MOV M,A
INX H
IN IDEBport ;read the UPPER byte
MOV M,A
INX H
MVI A,REGdata ;Deassert RD line
OUT IDECport
DCR B
JNZ MoreRD16
DCR C
JNZ MoreRD16
MVI E,REGstatus ;Check the R/W status when done
CALL IDErd8D
MOV A,D ;Z80 = Bit 0,D (A is unused)
ANI 01H
JNZ IDEerr1 ;Z if no errors
LXI H,CPMADDRESS
MOV A,M
CPI 31H ;EXPECT TO HAVE 31H @80H IE. MOV SP,80H
JZ CPMADDRESS ;AS THE FIRST INSTRUCTION. IF OK JMP to 100H in RAM
JMP ERRLD1 ;Boot Sector Data incorrect
BELL EQU 07H
CR EQU 0DH
LF EQU 0AH
;-------------- S100Computers I/O BOARD PORT ASSIGNMENTS (A0-AC)
BCTL EQU 10H ;CHANNEL B CONTROL PORT ASSIGNMENTS OF THE ZILOG SCC CHIP
BDTA EQU 11H ;CHANNEL B DATA
;-------------- S100Computers IDE HARD DISK CONTROLLER COMMANDS ETC.
CPMADDRESS EQU 100H ;Will place the CPMMOVR.COM Loader here with
;CPMMOVR.COM will ALWAYS be on TRK 0,SEC2, (LBA Mode)
SECCOUNT EQU 12 ;CPMMOVR.COM requires (currently) 10, 512 byte sectors
IDEAport EQU 030H ;lower 8 bits of IDE interface
IDEBport EQU 031H ;upper 8 bits of IDE interface
IDECport EQU 032H ;control lines for IDE interface
IDECtrl EQU 033H ;8255 configuration port
IDEDrivePort EQU 034H ;To select the 1st or 2nd CF card/drive (Not used with this monitor)
IDEreset EQU 80H ;inverter between 8255 and IDE interface
IDEResetDelay EQU 020H ;Time delay for reset/initilization (~60 uS, with 10MHz Z80, 2 I/O wait states)
RDcfg8255 EQU 10010010B ;Set 8255 IDECport out, IDEAport/B input
WRcfg8255 EQU 10000000B ;Set all three 8255 ports output
REGdata EQU 08H ;IDEcs0line
REGerr EQU 09H ;IDEcs0line + IDEa0line
REGcnt EQU 0AH ;IDEcs0line + IDEa1line
REGsector EQU 0BH ;IDEcs0line + IDEa1line + IDEa0line
REGcyLSB EQU 0CH ;IDEcs0line + IDEa2line
REGcyMSB EQU 0DH ;IDEcs0line + IDEa2line + IDEa0line
REGshd EQU 0EH ;IDEcs0line + IDEa2line + IDEa1line ;(0EH)
REGCMD EQU 0FH ;IDEcs0line + IDEa2line + IDEa1line + IDEa0line ;(0FH)
REGstatus EQU 0FH ;IDEcs0line + IDEa2line + IDEa1line + IDEa0line
DIAGLEDS EQU 5 ;OUT (Will use this port initially for diagnostic LED display)
;IDE CMD Constants. These shouMOV never change.
CMDrecal EQU 10H
CMDread EQU 20H
CMDwrite EQU 30H
CMDinit EQU 91H
CMDid EQU 0ECH
CMDdownspin EQU 0E0H
CMDupspin EQU 0E1H
;-------------- BOOT UP CPM FROM HARD DISK ON S100COMPUTERS IDR BOARD ----------------
;BOOT UP THE 8255/IDE Board HARD DISK/Flash Memory Card
;NOTE CODE IS ALL HERE IN CASE A 2716 IS USED
ORG 0DF00H
INITIALIZE:
MVI A,3 ;RESET 6850 UART
OUT BCTL
MVI A,11H ;8N2
OUT BCTL
HBOOTCPM:
POP H ;CLEAN UP STACK
LXI H,SPEAKCPMMSG ;Announce on speaker
CALL SPEAK
CALL INITILIZEIDEBOARD ;Initilze the 8255 and drive (again just in case)
JC ERRNR ;Carry set to indicate an error, Drive not ready
MVI D,11100000B ;Data for IDE SDH reg (512bytes, LBA mode,single drive)
MVI E,REGshd ;00001110,(0EH) CS0,A2,A1,
CALL IDEwr8D ;Write byte to select the MASTER device
MVI B,0FFH ;Delay time to allow a Hard Disk to get up to speed
WaitInit:
MVI E,REGstatus ;Get status after initilization
CALL IDErd8D ;Check Status (info in [D])
MOV A,D ;Z80 = BIT 7,D (A is not needed)
ANI 80H
JZ SECREAD ;Zero, so all is OK to write to drive
;Delay to allow drive to get up to speed
PUSH B
LXI B,0FFFFH
DXLAY2: MVI D,2 ;May need to adjust delay time to allow coMOV drive to
DXLAY1: DCR D ;to speed
JNZ DXLAY1
DCX B
MOV A,C
ORA B
JNZ DXLAY2
POP B
DCR B
JNZ WaitInit ;If after 0FFH, 0FEH, 0FDH... 0, then drive initilization problem
IDError:
LXI H,DRIVENRERR ;Drive not ready
JMP ABORTERRMSG
SECREAD: ;Note CPMMOVR will ALWAYS be on TRK 0,SEC 1,Head 0
MVI A,11111111B ;FLAG PROGRESS VISUALLY FOR DIAGNOSTIC
OUT DIAGLEDS
CALL IDEwaitnotbusy ;Make sure drive is ready
JC IDError ;NC if ready
MVI D,1 ;Load track 0,sec 1, head 0
MVI E,REGsector ;Send info to drive
CALL IDEwr8D
MVI D,0 ;Send Low TRK#
MVI E,REGcyLSB
CALL IDEwr8D
MVI D,0 ;Send High TRK#
MVI E,REGcyMSB
CALL IDEwr8D
MVI D,SECCOUNT ;Count of CPM sectors we wish to read
MVI E,REGcnt
CALL IDEwr8D
MVI D,CMDread ;Send read CMD
MVI E,REGCMD
CALL IDEwr8D ;Send sec read CMD to drive.
CALL IDEwdrq ;Wait until it's got the data
LXI H,CPMADDRESS ;DMA address where the CPMMOVR resides in RAM
MVI B,0 ;256X2 bytes
MVI C,SECCOUNT ;Count of sectors X 512
MoreRD16:
OUT IDECport
OUT IDECport
MOV M,A
INX H
MOV M,A
INX H
OUT IDECport
DCR B
JNZ MoreRD16
DCR C
JNZ MoreRD16
CALL IDErd8D
ANI 01H
LXI H,CPMADDRESS
MOV A,M
IDEerr1:
LXI H,IDERWERROR ;Drive R/W Error
JMP ABORTERRMSG
; ----- SUPPORT ROUTINES --------------
INITILIZEIDEBOARD: ;Drive Select in [A]. Note leaves selected drive as [A]
MVI A,RDcfg8255 ;Config 8255 chip (10010010B), read mode on return
OUT IDECtrl ;Config 8255 chip, READ mode
;Hard reset the disk drive
;For some reason some CF cards need to the RESET line
;pulsed very carefully. You may need to play around
MVI A,IDEreset ;with the pulse length. Symptoms are: incorrect data coming
OUT IDECport ;back from a sector read (often due to the wrong sector being read)
;I have a (negative)pulse of 60 uSec. (10Mz Z80, two IO wait states).
MVI C,IDEResetDelay ;~60 uS seems to work for the 5 different CF cards I have
ResetDelay:
DCR C
JNZ ResetDelay ;Delay (reset pulse width)
XRA A
OUT IDECport ;No IDE control lines asserted (just bit 7 of port C)
CALL DELAY15 ;Need to delay a little before checking busy status
MVI B,0FFH
MVI C,0FFH ;Delay, must be above 80H for 4MHz Z80. Leave longer for slower drives
MoreWait:
MVI E,REGstatus ;Wait for RDY bit to be set
CALL IDErd8D
MOV A,D
ANI 11000000B
XRI 01000000B
JZ DoneNotbusy
DCR B
JNZ MoreWait
DCR C
JNZ MoreWait
STC ;Set carry to indicate an error
RET
DoneNotBusy:
ORA A ;Clear carry it indicate no error
RET
;Wait for the drive to be ready to transfer data.
IDEwdrq: ;Returns the drive's status in Acc
MVI B,0FFH
MoreDRQ:
MVI E,REGstatus ;wait for DRQ bit to be set
CALL IDErd8D
MOV A,D
ANI 10001000B
CPI 00001000B
JZ DoneDRQ
DCR B
JNZ MoreDRQ
DCR C
JNZ MoreDRQ
STC ;Set carry to indicate error
RET
DoneDRQ:
ORA A ;Clear carry
RET
; Note the 16 bit I/O to the drive (which is only for SEC Read here) is done directly
; in the routine MoreRD16 for speed reasons.
IDErd8D: ;READ 8 bits from IDE register in [E], return info in [D]
MOV A,E
OUT IDECport ;drive address onto control lines
OUT IDECport ;assert read pin
IN IDEAport
MOV D,A ;return with data in [D]
MOV A,E ;Ken Robbins suggestion
OUT IDECport ;Deassert RD pin
XRA A
OUT IDECport ;Zero all port C lines
RET
IDEwr8D: ;WRITE Data in [D] to IDE register in [E]
MVI A,WRcfg8255 ;Set 8255 to write mode
OUT IDECtrl
MOV A,D ;Get data put it in 8255 A port
OUT IDEAport
MOV A,E ;select IDE register
OUT IDECport
OUT IDECport
MOV A,E ;Kens Robbins suggestion, raise WR line
OUT IDECport
XRA A ;Deselect all lines including WR line
OUT IDECport
MVI A,RDcfg8255 ;Config 8255 chip, read mode on return
OUT IDECtrl
RET
SPEAKOUT:
XRA A ;Will try 256 times, then timeout
SPXXX: PUSH PSW
IN BCTL ;(A0), Is SCC TX Buffer empty
ANI 2
JNZ SENDS ;NZ if ready to recieve character
POP PSW
DCR A
JNZ SPXXX
RET
SENDS: POP PSW
MOV A,C
OUT BDTA ;(A2), Send it
RET
;SPEAKTOMM THIS IS A ROUTINE TO SEND A STRING TO TALKER [HL] AT STRING
SPEAK: MOV A,M
CPI '$'
JZ SPEAK1
MOV C,A
CALL SPEAKOUT
INX H
JMP SPEAK
SPEAK1: MVI C,0DH ;MUST END WITH A CR
JMP SPEAKOUT
DELAY: DCR A ;GENERAL COUNT DOWN TIME DELAY
RZ ;LENGTH SET IN [A]
PUSH PSW
MVI A,05H
MORE: DCR A
PUSH PSW
XRA A
MORE2: DCR A
JNZ MORE2
POP PSW
JNZ MORE
POP PSW
JMP DELAY
DELAY15: ;DELAY ~15 MS
MVI A,40
DELAY1: MVI B,0
M0: DCR B
JNZ M0
DCR A
JNZ DELAY1
RET
ERRNR: LXI H,DRIVENRERR ;"DRIVE NOT READY
JMP ABORTERRMSG
ERRLD1:
LXI H,BOOTLD1ERR ;"DATA ERROR IN BOOT SECTOR"
ABORTERRMSG:
CALL SPEAK
JMP HBOOTCPM ;BACK TO START
SPEAKCPMMSG: DB 'LOADING CPM $'
DRIVENRERR: DB BELL,CR,LF
DB 'Drive not Ready.',CR,LF,LF,'$'
BOOTLD1ERR: DB BELL,CR,LF
DB 'BOOT error.',CR,LF,LF,'$'
IDERWERROR: DB CR,LF
DB 'IDE Drive R/W Error'
DB CR,LF,'$'
Nice to see a fellow IDE owner here!
One thing I would probably suggest is to get the latest copy of the bootloader. You may have already done that, but if not, I'd start there.
After that, if you need to troubleshoot further, I'd definitely suggest using SID. As you saw, when I was developing the code for my version of CP/M, I leaned heavily on the SID debugger. I would encourage you to do that too. It's an old debugger, but it does the job.
The real trick for me was finding places to set breakpoints, uh, I meant passpoints. That was always the hardest part. 'Cause once you've entered a loop, you have to step a few hundred or thousand steps to get past it. So the trick is to find places to put passpoints - before functional (iterative) blocks that you're not sure of, and after stuff that you are sure of.
You may have seen my (super-boring) SID flow documents. I used a lot of "P" commands (to set passpoints) and "G" commands to execute up to a passpoint. I also used "L" to list blocks of memory and "T" and "TW" commands to step into and out of an iterative block, treating it sort of like a function that could be stepped through as if it were a single instruction. Took a little while to get the hang of that process, but once I had it, I could really use the SID tool.
Another thing I would suggest is to run IDEutil.com and see if that works for you. If it doesn't, you may have a hardware problem. Might be worthwhile to single-step through IDEutil anyway, just to be sure. I remember when I was first working with the CF board, I spent a lot of time working on IDEutil. The WRLBA function was of particular interest to me, because there were at least two versions of it in Monahan's code, and I was making a third.
Then again, if I've misinterpreted you, if you know that the CF drive initializes, read and writes without error, you'll probably focus on the CP/M code. I would probably blow the dust off the SID traces I made in development, maybe even choose one of the same GENCPM topmem values, so your jump table addresses are the same as mine. That might save some time finding stuff. Then trace through the reads and see what you see.
Or maybe try one thing first - a shotgun approach that misses a lot of detail but just might work - play around with your disk buffer settings when doing GENCPM. You can choose what drives have unique buffers and/or what drives share buffers. I found some settings just plain don't work. So you might focus on that before rolling your sleeves up and running SID.
I'm super-curious about what you find out so please keep us posted!
Hello Wayne,
I appreciate your response. I tried assembling the ideutils.asm file but the assembler does not like this line: DB 0CBH, 0*8+D+40H ;BIT 0, D
It seems to be complaining about the "D". Any ideas?
