Hello,
After updating to 1.81, I can't boot cpm anymore; although I think I have uploaded the disk images and proms properly, could you please double check my configuration (I still have access to the System Configuration Monitor:
===== System Configuration Monitor 1.81 =====
1) Floppy Disk Menu
2) PROM Menu
3) Serial Port Menu
4) Load .BIN File
5) Load .HEX File
6) Admin Menu
x) Exit to Altair
Enter Choice: 1
===== Floppy Drive Content =====
(8 inch floppy drives)
Drive 0 - cpm63k
Drive 1 - games 300-5-F
Drive 2 - kermit
Choose Drive Number to Update (x to exit): x
===== PROM Information Table =====
Num Status Addr Length Description
1 ON FF00 02DD DBL.HEX
2 ON FE00 02DD MBL.HEX
3 ON FD00 02DD TURMON.HEX
4 OFF 0000 0000
5 OFF 0000 0000
6 OFF 0000 0000
7 OFF 0000 0000
8 OFF 0000 0000
Enter PROM Number to Update (x to exit): x
1) Floppy Disk Menu
2) PROM Menu
3) Serial Port Menu
4) Load .BIN File
5) Load .HEX File
6) Admin Menu
x) Exit to Altair
Enter Choice: 3
===== Serial Port Settings =====
Port Type I/O Rate Other
1 2SIO 020,021 9600
2 SIO 006,007 9600 8N1
3 2SIO 024,025 9600
Enter Serial Port to Change (x to Exit): x
Could you please double check this and let me know what are the next steps?
Thanks!
Configuration issue
Re: Configuration issue
Hmmm, I solved it, need stronger coffee.
Much better isn't it:
1 ON FF00 0100 DBL
2 ON FE00 0100 MBL
3 ON FD00 0100 TURMON
4 OFF 0000 0000
5 OFF 0000 0000
6 OFF 0000 0000
7 OFF 0000 0000
8 OFF 0000 0000
[...snip...]
63K CP/M
Version 2.2mits (07/28/80)
Copyright 1980 by Burcon Inc.
A>
1 ON FF00 0100 DBL
2 ON FE00 0100 MBL
4 OFF 0000 0000
5 OFF 0000 0000
6 OFF 0000 0000
7 OFF 0000 0000
8 OFF 0000 0000
[...snip...]
63K CP/M
A>
Users browsing this forum: No registered users and 15 guests
