%^!!%^@ORY SI@@!^?
LINEPR@YHD@?
HIGHES43&*&@BER?
&*^@W MAN&&@#*&#$ES?
H&*@@#DOM@@LE&#@?
7342-2 BY@#@!^F#!#
OK
%^!!%^@ORY SI@@!^?
LINEPR@YHD@?
HIGHES43&*&@BER?
H&*@@#DOM@@LE&#@?
7342-2 BY@#@!^F#!#
OK
Yes, I am. I've tried both one and two stop bits with the same results. When I boot from the turnkey module, I have all switches down when I turn on the machine.AltairClone wrote:I can duplicate your symptoms if I run with one stop bit instead of two. Are you setting A15-A12 (leftmost four switches) to zero before depressing run?
You're right again, Mike!AltairClone wrote:I assume this is the same RS-232 to current loop adapter you were using previously? The Altair Clone uses fairly low RS-232 voltage levels (less than +/-5v), so it may be you've been running on the hairy edge of working with your adapter, and now things have moved just a fraction to the not-working side of that hairy edge.
