Question to the group:
What's your favorite disk drive, and why?
I should probably qualify this question, as I am asking specifically about the disk drives that can be connected to Mike's FDC+ board for the Altair 8800c replica described on his DeRamp.com website.
And a semi-related question:
Anyone here connected a hard disk?
I was looking at options, and found a few controllers for hard disks and one that even connected to IDE drives and compact flash cards. Like this one:
Hard Disk / CF Card adapter
Anyone here have experience with that?
Favorite Disk Drive
Re: Favorite Disk Drive
I have two 5.25" HD TEAC floppy drives in an old Tandy FD-500 case as well as two Shugart SA800 8" drives in an old Epson case. I manually switch between them. For compatibility, I can't beat the Shugarts as I can read and write hard-sectored disks just fine. For everyday use, though, I use the Teacs since it's much easier and cheaper to get replacements for them if I wear them out. Media are also much easier to get in the 5.25" size.Wayne Parham wrote:Question to the group:
Thanks for the tips!
Serial server - 8MB drives are just too useful to pass up on and a decent used PC is much cheaper than 8" floppies. It's like having two HDDs. I'm using a mini Acer Veriton with a 4th-gen i5 I got for nothing. Does the job very well and acts as a serial server for several other systems too.
Good suggestion, thanks!
