Help with Video #6 - Serial I/O Echo Routines
alfonzo
Post by alfonzo »
I am having lots of fun playing with my Altair 8800 clone. As a newbie I am trying to follow along with the excellent videos. However video 6 has me stumped.
https://youtu.be/70l6CE0mWbs
When stepping through the program, when the input instruction on port zero executes, not only does D0 go to one, but the entire data bus goes to one. I.e. D0-7 are all one. It seems that the input instruction itself is correctly executing since the INP indicator is on. But for some reason D0-7 are all one as well.
I have tried entering the program multiple times, but always get the same result. I am pretty sure that the connection is okay because all other videos have worked until now and I even was able to do some basic serial communication between my clone and my TI-99/4a. I even turned on my old Acer laptop and connected directly to an old serial port instead of using a USB to serial adapter just to be sure, but I keep seeing the same behavior.
Any ideas for a newbie would be appreciated. Thanks!
Re: Help with Video #6 - Serial I/O Echo Routines
The video is accessing an 88-SIO at I/O address 0. Sounds like you’ve got the 88-2SIO at I/O address 20 (octal) enabled instead. Go into the configuration monitor and enable the 88-SIO port at 0.
alfonzo
Post by alfonzo »
Hey Mike!
Sorry for not responding sooner. You were exactly correct and now looking at the top of the program listing, I see that it says (very clearly) "SIO (not 2SIO) echo test". Thanks for pointing me in the right direction! Once I enabled the 88-SIO port at 0, everything worked perfectly.
Users browsing this forum: No registered users and 11 guests
