Text editor
jibanes
Text editor
Post by jibanes »
Is there a simple text editor (or vi-ish, but not ed) I can use to write some C code to be compiled with the Aztec C compiler on CPM/2.2?
I have tried Vedit, but I couldn't even find how to save a file.
Thanks!
Re: Text editor
WordMaster (WM.COM) is on the CP/M disk(s) provided with the Clone. It is an easy to learn screen editor. Uses mostly WordStar conventions for cursor and page movement. Built-in help by pressing Ctrl-J.
The editor directly enters full-screen editing mode when started. Press ESC to drop into command mode. Q to quit without saving, E to exit and save. V re-enters full screen edit mode.
The version of WM on the CP/M disks provided with the Clone expects a VT-100 compatible terminal. Other terminal control versions can be found if needed.
jibanes
Re: Text editor
Post by jibanes »
Thank you, this works great.
Re: Text editor
Maybe we can use the BDS C compiler to port a version of "vi" to CP/M!
I've looked and looked for vi ready to run under CP/M, but haven't had any luck.
barney
Re: Text editor
Post by barney »
I have Vedit (Vplus8C) up and running on the Altair and using it for C programs on the Aztec compiler. If there is interest, I can post the floppy image and a .pdf user guide.
Users browsing this forum: Google [Bot] and 16 guests
