“Kill the Bit” displays a bit pattern on the upper eight address lights by repeatedly accessing an address for which the upper byte of the address is the bit pattern to display. For example, given the bit pattern to display in register D, the program loops over and over through a sequence of four “load indirect through register D” instructions as shown below.
LOOP:
LDAX D
LDAX D
LDAX D
LDAX D
LOOP:
INX D
INX D
INX D
DCX D
DCX D
DCX D
The original Kill-the-Bit program and the INX/DCX version can be found here:
http://altairclone.com/downloads/front_ ... LLBITS.ASM
http://altairclone.com/downloads/front_ ... LLBIT2.ASM
Note: You must be running Altair Clone firmware version 1.94 (or newer) to see this effect on the Altair 8800 Clone.
Interestingly, in 8080 processors prior to the 1979 die revision, the 8-bit increment and decrement instructions (INR, DCR) exhibit the same behavior. Even though the per-instruction state table in the 8080 data sheet shows 8-bit inc/dec occurring through the ALU, the 8-bit increments are actually done by the two halves of the 16-bit incrementer. The low registers (C,E,L) are incremented by the lower half of the 16-bit incrementer and always appear on address lines A7-A0. The high registers (B,D,H) are incremented by the upper half of the 16-bit incrementer and always appear on address lines A15-A8. Even though only a single 8-bit register is affected by the INR/DCR instruction, the entire 16-bit register pair appears on the address bus during instruction execution. For example, INR L increments register L by one, however H and L both appear on the address bus during instruction execution.
With the 1979 die revision, the 8-bit increment and decrement instructions use the ALU (as documented in the state table in the data sheet), and therefore, only the 16-bit increment/decrement instructions still affect the address lines. Chips with the 1979 die revision can be identified by the "(c) INTEL '79" stamp on the chip.
