MOUNTing Problem
MOUNTing Problem
In my 8800c, I'm using the FDC+ with two Teac 55-GFR-149 5.25" HD floppy drives configured as 8" drives. When I do a MOUNT 1, I get an I/O error. If I do an UNLOAD then MOUNT 1 again, it always works. The second try always works.
Any idea what's going on?
Re: MOUNTing Problem
I assume you’ve specified two drives during the BASIC startup sequence? What happens if after booting you type MOUNT with no parameters? That should mount drive 1 and then drive 0. Let me know what happens.
Yes, I specified two drives at startup (HIGHEST DISK NUMBER? 1) The first time I mount with no parameters it tries to mount drive 1 first and gets the I/O error. If I unload and mount again, both drives mount OK with drive 1 mounting first.AltairClone wrote:I assume you’ve specified two drives during the BASIC startup sequence? What happens if after booting you type MOUNT with no parameters? That should mount drive 1 and then drive 0. Let me know what happens.
Let me know which disk images you're using on drive 0 and drive 1 and I'll see if I can duplicate your symptoms.
They're "Disk Basic v300-5-F.dsk" in drive 0 and "Games on 300-5-F.dsk" in drive 1AltairClone wrote:Let me know which disk images you're using on drive 0 and drive 1 and I'll see if I can duplicate your symptoms.
both from your downloads area
http://www.altairclone.com/downloads/ba ... py%20Disk/
I copied them to the floppies with your PC2FLOP program. I'll try to copy them again to see if that helps.
What if you do "MOUNT 0" followed by "MOUNT 1" immediately after booting - does either mount fail?
When I first turn on computer:AltairClone wrote:What if you do "MOUNT 0" followed by "MOUNT 1" immediately after booting - does either mount fail?
MOUNT with no parameter hangs the computer. No OK prompt. If I hit reset then try to MOUNT again, I get DISK ALREADY MOUNTED
MOUNT 0 followed by MOUNT 1 gives DISK I/O ERROR when I do drive 1
After I do the first UNLOAD:
MOUNT with no parameters mounts drive 1 then drive 0 with no error
MOUNT 1 mounts drive 1 with no error
I thought there might be a problem in the MOUNT command itself since I got garbage when I tried it on my AltairDuino but it turns out it's the MAX3232 that's flaky.
Swap the drive jumpers on the two drives so that drive 0 becomes drive 1 and vice-versa. Let me know if the problem changes.
Baffling! I switched the drive jumpers but kept the drives on the same drive cable connectors. MOUNT now works in all cases!AltairClone wrote:Swap the drive jumpers on the two drives so that drive 0 becomes drive 1 and vice-versa. Let me know if the problem changes.
I don't see a removable resistor pack on the drives. Is there one? If so, where?
If one drive had the resistors but the other didn't and I didn't have the drive with the resistors on the
last cable position would that explain the problems I was seeing?
*UPDATE* I switched the drives on the cable so that the new drive 0 is where the old drive 0 was and MOUNT still works fine in all cases.
Users browsing this forum: No registered users and 26 guests
