I was too busy through the holidays to work on the BIOS for the IDE card. Still pretty busy, but I did at least get a chance to take a first swipe at it.
I chose to use the modular approach, with separate files for BIOSKRNL.asm, SCB3.asm, BOOT3.asm, CHARIO3.asm, MOVE3.asm, DRVTBL3.asm, FLP3.asm and IDE3.asm. All but the last three are files distributed by Digital Research. The last three have the hardware-specific code in them.
The files all assemble and link properly using RMAC and LINK. There are no assembly errors or undefined symbols. But it still fails to boot, giving the following message:
CP/M V3.0 Loader
Copyright (C) 1982, Digital Research
CPMLDR error: failed to read CPM3.SYS
As an attempt to reduce system complexity, I removed the IDE3.asm file and did a BIOS3.SPR build. When IDE3 is in place, the GENCPM utility asks questions to setup the blocking/deblocking buffers for drives C: and D:, which is what I assigned for the IDE drives. But when the IDE3 code is removed, GENCPM doesn't ask about them. So I'm working that way for starters, just to get a modular BIOS running with only Mike's FDC code in it. After I get that working, I will put the IDE3 code back in place.
My next step is to debug the BIOS, using the method described in the CP/M 3.0 System Guide. It suggests setting a break point at the jump table, and to start with the boot function. I'll do that.
I'm sure I left stuff out of the FLP3.asm file. I copied the FDC diskette functions from Mike's 3.0 BIOS code, but probably missed some stuff.
This is what my files look like at this point:
BIOSKRNL.asm
	title	'Root module of relocatable BIOS for CP/M 3.0'
	; version 1.0 15 Sept 82
true	equ -1
false	equ not true
banked	equ FALSE				;<------ BANKED Version
;		  Copyright (C), 1982
;		 Digital Research, Inc
;		     P.O. Box 579
;		Pacific Grove, CA  93950
;   This is the invariant portion of the modular BIOS and is
;	distributed as source for informational purposes only.
;	All desired modifications should be performed by
;	adding or changing externally defined modules.
;	This allows producing "standard" I/O modules that
;	can be combined to support a particular system
;	configuration.
cr	equ 13
lf	equ 10
bell	equ 7
ctlQ	equ 'Q'-'@'
ctlS	equ 'S'-'@'
ccp	equ 0100h	; Console Command Processor gets loaded into the TPA
	cseg		; GENCPM puts CSEG stuff in common memory
    ; variables in system data page
	extrn @covec,@civec,@aovec,@aivec,@lovec ; I/O redirection vectors
	extrn @mxtpa				; addr of system entry point
	extrn @bnkbf				; 128 byte scratch buffer
    ; initialization
	extrn ?init			; general initialization and signon
	extrn ?ldccp,?rlccp		; load & reload CCP for BOOT & WBOOT
    ; user defined character I/O routines
	extrn ?ci,?co,?cist,?cost	; each take device in <B>
	extrn ?cinit			; (re)initialize device in <C>
	extrn @ctbl			; physical character device table
    ; disk communication data items
	extrn @dtbl			; table of pointers to XDPHs
	public @adrv,@rdrv,@trk,@sect	; parameters for disk I/O
	public @dma,@dbnk,@cnt		;    ''       ''   ''  ''
    ; memory control
	public @cbnk			; current bank
	extrn ?xmove,?move		; select move bank, and block move
	extrn ?bank			; select CPU bank
    ; clock support
	extrn ?time			; signal time operation
    ; general utility routines
	public ?pmsg,?pdec	; print message, print number from 0 to 65535
	public ?pderr		; print BIOS disk error message header
	maclib modebaud		; define mode bits
    ; External names for BIOS entry points
	public ?boot,?wboot,?const,?conin,?cono,?list,?auxo,?auxi
	public ?home,?sldsk,?sttrk,?stsec,?stdma,?read,?write
	public ?lists,?sctrn
	public ?conos,?auxis,?auxos,?dvtbl,?devin,?drtbl
	public ?mltio,?flush,?mov,?tim,?bnksl,?stbnk,?xmov
    ; BIOS Jump vector.
		; All BIOS routines are invoked by calling these
		;	entry points.
?boot:	jmp boot	; initial entry on cold start
?wboot:	jmp wboot	; reentry on program exit, warm start
?const:	jmp const	; return console input status
?conin:	jmp conin	; return console input character
?cono:	jmp conout	; send console output character
?list:	jmp list	; send list output character
?auxo:	jmp auxout	; send auxilliary output character
?auxi:	jmp auxin	; return auxilliary input character
?home:	jmp home	; set disks to logical home
?sldsk:	jmp seldsk	; select disk drive, return disk parameter info
?sttrk:	jmp settrk	; set disk track
?stsec:	jmp setsec	; set disk sector
?stdma:	jmp setdma	; set disk I/O memory address
?read:	jmp read	; read physical block(s)
?write:	jmp write	; write physical block(s)
?lists:	jmp listst	; return list device status
?sctrn:	jmp sectrn	; translate logical to physical sector
?conos:	jmp conost	; return console output status
?auxis:	jmp auxist	; return aux input status
?auxos:	jmp auxost	; return aux output status
?dvtbl:	jmp devtbl	; return address of device def table
?devin:	jmp ?cinit	; change baud rate of device
?drtbl:	jmp getdrv	; return address of disk drive table
?mltio:	jmp multio	; set multiple record count for disk I/O
?flush:	jmp flush	; flush BIOS maintained disk caching
?mov:	jmp ?move	; block move memory to memory
?tim:	jmp ?time	; Signal Time and Date operation
?bnksl:	jmp bnksel	; select bank for code execution and default DMA
?stbnk:	jmp setbnk	; select different bank for disk I/O DMA operations.
?xmov:	jmp ?xmove	; set source and destination banks for one operation
	jmp 0		; reserved for future expansion
	; BOOT
	;	Initial entry point for system startup.
	dseg	; this part can be banked
boot:
	lxi sp,boot$stack
	mvi c,15	; initialize all 16 character devices
c$init$loop:
	push b ! call ?cinit ! pop b
	dcr c ! jp c$init$loop
	call ?init	; perform any additional system initialization
			; and print signon message
	lxi b,16*256+0 ! lxi h,@dtbl	; init all 16 logical disk drives
d$init$loop:
	push b		; save remaining count and abs drive
	mov e,m ! inx h ! mov d,m ! inx h	; grab @drv entry
	mov a,e ! ora d ! jz d$init$next	; if null, no drive
	push h					; save @drv pointer
	xchg					; XDPH address in <HL>
	dcx h ! dcx h ! mov a,m ! sta @RDRV	; get relative drive code
	mov a,c ! sta @ADRV			; get absolute drive code
	dcx h					; point to init pointer
	mov d,m ! dcx h ! mov e,m		; get init pointer
	xchg ! call ipchl			; call init routine
	pop h					; recover @drv pointer
d$init$next:
	pop b					; recover counter and drive #
	inr c ! dcr b ! jnz d$init$loop		; and loop for each drive
	jmp boot$1
	cseg	; following in resident memory
boot$1:
	call set$jumps
	call ?ldccp				; fetch CCP for first time
	jmp ccp
	; WBOOT
	;	Entry for system restarts.
wboot:
	lxi sp,boot$stack
	call set$jumps		; initialize page zero
	call ?rlccp		; reload CCP
	jmp ccp			; then reset jmp vectors and exit to ccp
set$jumps:
  if banked
	mvi a,1 ! call ?bnksl
  endif
	mvi a,JMP
	sta 0 ! sta 5		; set up jumps in page zero
	lxi h,?wboot ! shld 1	; BIOS warm start entry
	lhld @MXTPA ! shld 6	; BDOS system call entry
	ret
		ds 64
boot$stack	equ $
	; DEVTBL
	;	Return address of character device table
devtbl:
	lxi h,@ctbl ! ret
	; GETDRV
	;	Return address of drive table
getdrv:
	lxi h,@dtbl ! ret
	; CONOUT
	;	Console Output.  Send character in <C>
	;			to all selected devices
conout:
	lhld @covec	; fetch console output bit vector
	jmp out$scan
	; AUXOUT
	;	Auxiliary Output. Send character in <C>
auxout:
	lhld @aovec	; fetch aux output bit vector
	jmp out$scan
	; LIST
	;	List Output.  Send character in <C>
	;			to all selected devices.
list:
	lhld @lovec	; fetch list output bit vector
out$scan:
	mvi b,0		; start with device 0
co$next:
	dad h		; shift out next bit
	jnc not$out$device
	push h		; save the vector
	push b		; save the count and character
not$out$ready:
	call coster ! ora a ! jz not$out$ready
	pop b ! push b	; restore and resave the character and device
	call ?co	; if device selected, print it
	pop b		; recover count and character
	pop h		; recover the rest of the vector
not$out$device:
	inr b		; next device number
	mov a,h ! ora l	; see if any devices left
	jnz co$next	; and go find them...
	ret
	; CONOST
	;	Console Output Status.  Return true if
	;		all selected console output devices
	;		are ready.
conost:
	lhld @covec	; get console output bit vector
	jmp ost$scan
	; AUXOST
	;	Auxiliary Output Status.  Return true if
	;		all selected auxiliary output devices
	;		are ready.
auxost:
	lhld @aovec	; get aux output bit vector
	jmp ost$scan
	; LISTST
	;	List Output Status.  Return true if
	;		all selected list output devices
	;		are ready.
listst:
	lhld @lovec	; get list output bit vector
ost$scan:
cos$next:
	dad h		; check next bit
	mvi a,0FFh	; assume device ready
	cc coster	; check status for this device
	pop h		; recover bit vector
	ora a		; see if device ready
	rz		; if any not ready, return false
	inr b		; drop device number
	mov a,h ! ora l	; see if any more selected devices
	jnz cos$next
	ori 0FFh	; all selected were ready, return true
	ret
coster:		; check for output device ready, including optional
		;	xon/xoff support
	mov l,b ! mvi h,0	; make device code 16 bits
	push h			; save it in stack
	dad h ! dad h ! dad h	; create offset into device characteristics tbl
	lxi d,@ctbl+6 ! dad d	; make address of mode byte
	mov a,m ! ani mb$xonxoff
	pop h			; recover console number in <HL>
	jz ?cost		; not a xon device, go get output status direct
	lxi d,xofflist ! dad d	; make pointer to proper xon/xoff flag
	call cist1		; see if this keyboard has character
	mov a,m ! cnz ci1	; get flag or read key if any
	cpi ctlq ! jnz not$q	; if its a ctl-Q,
	mvi a,0FFh 		;	set the flag ready
not$q:
	cpi ctls ! jnz not$s	; if its a ctl-S,
	mvi a,00h		;	clear the flag
not$s:
	mov m,a			; save the flag
	call cost1		; get the actual output status,
	ana m			; and mask with ctl-Q/ctl-S flag
	ret			; return this as the status
cist1:			; get input status with <BC> and <HL> saved
	push b ! push h
	call ?cist
	pop h ! pop b
	ora a
	ret
cost1:			; get output status, saving <BC> & <HL>
	push b ! push h
	call ?cost
	pop h ! pop b
	ora a
	ret
ci1:			; get input, saving <BC> & <HL>
	push b ! push h
	call ?ci
	pop h ! pop b
	ret
	; CONST
	;	Console Input Status.  Return true if
	;		any selected console input device
	;		has an available character.
const:
	lhld @civec	; get console input bit vector
	jmp ist$scan
	; AUXIST
	;	Auxiliary Input Status.  Return true if
	;		any selected auxiliary input device
auxist:
	lhld @aivec	; get aux input bit vector
ist$scan:
cis$next:
	mvi a,0		; assume device not ready
	cc cist1	; check status for this device
	ora a ! rnz	; if any ready, return true
	jnz cis$next
	xra a		; all selected were not ready, return false
	ret
	; CONIN
	;	Console Input.  Return character from first
	;		ready console input device.
conin:
	lhld @civec
	jmp in$scan
	; AUXIN
	;	Auxiliary Input.  Return character from first
	;		ready auxiliary input device.
auxin:
	lhld @aivec
in$scan:
	push h		; save bit vector
	mvi b,0
ci$next:
	mvi a,0		; insure zero a  (nonexistant device not ready).
	cc cist1	; see if the device has a character
	ora a
	jnz ci$rdy	; this device has a character
	inr b		; else, next device
	mov a,h ! ora l	; see if any more devices
	jnz ci$next	; go look at them
	jmp in$scan	; loop til we find a character
ci$rdy:
	pop h		; discard extra stack
	jmp ?ci
;	Utility Subroutines
ipchl:		; vectored CALL point
	pchl
?pmsg:		; print message @<HL> up to a null
		; saves <BC> & <DE>
	push b
	push d
pmsg$loop:
	mov a,m ! ora a ! jz pmsg$exit
	mov c,a ! push h
	call ?cono ! pop h
	inx h ! jmp pmsg$loop
pmsg$exit:
	pop d
	pop b
	ret
?pdec:		; print binary number 0-65535 from <HL>
	lxi b,table10! lxi d,-10000
next:
	mvi a,'0'-1
pdecl:
	push h! inr a! dad d! jnc stoploop
	inx sp! inx sp! jmp pdecl
stoploop:
	push d! push b
	mov c,a! call ?cono
	pop b! pop d
nextdigit:
	pop h
	ldax b! mov e,a! inx b
	ldax b! mov d,a! inx b
	mov a,e! ora d! jnz next
	ret
table10:
	dw	-1000,-100,-10,-1,0
?pderr:
	lxi h,drive$msg ! call ?pmsg			; error header
	lda @adrv ! adi 'A' ! mov c,a ! call ?cono	; drive code
	lxi h,track$msg ! call ?pmsg			; track header
	lhld @trk ! call ?pdec				; track number
	lxi h,sector$msg ! call ?pmsg			; sector header
	lhld @sect ! call ?pdec				; sector number
	ret
	; BNKSEL
	;	Bank Select.  Select CPU bank for further execution.
bnksel:
	sta @cbnk 			; remember current bank
	jmp ?bank			; and go exit through users
					; physical bank select routine
xofflist	db	-1,-1,-1,-1,-1,-1,-1,-1		; ctl-s clears to zero
	dseg	; following resides in banked memory
;	Disk I/O interface routines
	; SELDSK
	;	Select Disk Drive.  Drive code in <C>.
	;		Invoke login procedure for drive
	;		if this is first select.  Return
	;		address of disk parameter header
	;		in <HL>
seldsk:
	mov a,c ! sta @adrv			; save drive select code
	mov l,c ! mvi h,0 ! dad h		; create index from drive code
	lxi b,@dtbl ! dad b			; get pointer to dispatch table
	mov a,m ! inx h ! mov h,m ! mov l,a	; point at disk descriptor
	ora h ! rz 				; if no entry in table, no disk
	mov a,e ! ani 1 ! jnz not$first$select	; examine login bit
	push h ! xchg				; put pointer in stack & <DE>
	lxi h,-2 ! dad d ! mov a,m ! sta @RDRV	; get relative drive
	lxi h,-6 ! dad d			; find LOGIN addr
	mov a,m ! inx h ! mov h,m ! mov l,a	; get address of LOGIN routine
	call ipchl				; call LOGIN
	pop h					; recover DPH pointer
not$first$select:
	ret
	; HOME
	;	Home selected drive.  Treated as SETTRK(0).
home:
	lxi b,0		; same as set track zero
	; SETTRK
	;	Set Track. Saves track address from <BC>
	;		in @TRK for further operations.
settrk:
	mov l,c ! mov h,b
	shld @trk
	ret
	; SETSEC
	;	Set Sector.  Saves sector number from <BC>
	;		in @sect for further operations.
setsec:
	mov l,c ! mov h,b
	shld @sect
	ret
	; SETDMA
	;	Set Disk Memory Address.  Saves DMA address
	;		from <BC> in @DMA and sets @DBNK to @CBNK
	;		so that further disk operations take place
	;		in current bank.
setdma:
	mov l,c ! mov h,b
	shld @dma
	lda @cbnk	; default DMA bank is current bank
			; fall through to set DMA bank
	; SETBNK
	;	Set Disk Memory Bank.  Saves bank number
	;		in @DBNK for future disk data
	;		transfers.
setbnk:
	sta @dbnk
	ret
	; SECTRN
	;	Sector Translate.  Indexes skew table in <DE>
	;		with sector in <BC>.  Returns physical sector
	;		in <HL>.  If no skew table (<DE>=0) then
	;		returns physical=logical.
sectrn:
	mov l,c ! mov h,b
	mov a,d ! ora e ! rz
	xchg ! dad b ! mov l,m ! mvi h,0
	ret
	; READ
	;	Read physical record from currently selected drive.
	;		Finds address of proper read routine from
	;		extended disk parameter header (XDPH).
read:
	lhld @adrv ! mvi h,0 ! dad h	; get drive code and double it
	lxi d,@dtbl ! dad d		; make address of table entry
	mov a,m ! inx h ! mov h,m ! mov l,a	; fetch table entry
	push h				; save address of table
	lxi d,-8 ! dad d		; point to read routine address
	jmp rw$common			; use common code
	; WRITE
	;	Write physical sector from currently selected drive.
	;		Finds address of proper write routine from
write:
	lxi d,-10 ! dad d		; point to write routine address
rw$common:
	mov a,m ! inx h ! mov h,m ! mov l,a	; get address of routine
	pop d				; recover address of table
	dcx d ! dcx d			; point to relative drive
	ldax d ! sta @rdrv		; get relative drive code and post it
	inx d ! inx d			; point to DPH again
	pchl				; leap to driver
	; MULTIO
	;	Set multiple sector count. Saves passed count in
	;		@CNT
multio:
	sta @cnt ! ret
	; FLUSH
	;	BIOS deblocking buffer flush.  Not implemented.
flush:
	xra a ! ret		; return with no error
	; error message components
drive$msg	db	cr,lf,bell,'BIOS Error on ',0
track$msg	db	': T-',0
sector$msg	db	', S-',0
@adrv	ds	1		; currently selected disk drive
@rdrv	ds	1		; controller relative disk drive
@trk	ds	2		; current track number
@sect	ds	2		; current sector number
@dma	ds	2		; current DMA address
@cnt	db	0		; record count for multisector transfer
@dbnk	db	0		; bank for DMA operations
	cseg	; common memory
@cbnk	db	0		; bank for processor operations
	end
SCB3.asm
	TITLE 'SYSTEM CONTROL BLOCK DEFINITION FOR CP/M3 BIOS'
	PUBLIC @CIVEC, @COVEC, @AIVEC, @AOVEC, @LOVEC, @BNKBF
	PUBLIC @CRDMA, @CRDSK, @VINFO, @RESEL, @FX, @USRCD
        PUBLIC @MLTIO, @ERMDE, @ERDSK, @MEDIA, @BFLGS
	PUBLIC @DATE, @HOUR, @MIN, @SEC, ?ERJMP, @MXTPA
SCB$BASE EQU    0FE00H          ; BASE OF THE SCB
@CIVEC  EQU     SCB$BASE+22H    ; CONSOLE INPUT REDIRECTION
                                ; VECTOR (WORD, R/W)
@COVEC  EQU     SCB$BASE+24H    ; CONSOLE OUTPUT REDIRECTION
@AIVEC  EQU     SCB$BASE+26H    ; AUXILIARY INPUT REDIRECTION
@AOVEC  EQU     SCB$BASE+28H    ; AUXILIARY OUTPUT REDIRECTION
@LOVEC  EQU     SCB$BASE+2AH    ; LIST OUTPUT REDIRECTION
@BNKBF  EQU     SCB$BASE+35H    ; ADDRESS OF 128 BYTE BUFFER
                                ; FOR BANKED BIOS (WORD, R/O)
@CRDMA  EQU     SCB$BASE+3CH    ; CURRENT DMA ADDRESS
                                ; (WORD, R/O)
@CRDSK  EQU     SCB$BASE+3EH    ; CURRENT DISK (BYTE, R/O)
@VINFO  EQU     SCB$BASE+3FH    ; BDOS VARIABLE "INFO"
                                ; (WORD, R/O)
@RESEL  EQU     SCB$BASE+41H    ; FCB FLAG (BYTE, R/O)
@FX     EQU     SCB$BASE+43H    ; BDOS FUNCTION FOR ERROR
                                ; MESSAGES (BYTE, R/O)
@USRCD  EQU     SCB$BASE+44H    ; CURRENT USER CODE (BYTE, R/O)
@MLTIO	EQU	SCB$BASE+4AH	; CURRENT MULTI-SECTOR COUNT
				; (BYTE,R/W)
@ERMDE  EQU     SCB$BASE+4BH    ; BDOS ERROR MODE (BYTE, R/O)
@ERDSK	EQU	SCB$BASE+51H	; BDOS ERROR DISK (BYTE,R/O)
@MEDIA	EQU	SCB$BASE+54H	; SET BY BIOS TO INDICATE
				; OPEN DOOR (BYTE,R/W)
@BFLGS  EQU     SCB$BASE+57H    ; BDOS MESSAGE SIZE FLAG (BYTE,R/O)
@DATE   EQU     SCB$BASE+58H    ; DATE IN DAYS SINCE 1 JAN 78
                                ; (WORD, R/W)
@HOUR   EQU     SCB$BASE+5AH    ; HOUR IN BCD (BYTE, R/W)
@MIN    EQU     SCB$BASE+5BH    ; MINUTE IN BCD (BYTE, R/W)
@SEC    EQU     SCB$BASE+5CH    ; SECOND IN BCD (BYTE, R/W)
?ERJMP  EQU     SCB$BASE+5FH    ; BDOS ERROR MESSAGE JUMP
                                ; (WORD, R/W)
@MXTPA  EQU     SCB$BASE+62H    ; TOP OF USER TPA
                                ; (ADDRESS AT 6,7)(WORD, R/O)
	END
BOOT3.asm
	TITLE	'BOOT LOADER MODULE FOR CP/M 3.0'
	; DEFINE LOGICAL VALUES:
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; DETERMINE IF FOR BANK SELECT OR NOT:
BANKED		EQU	FALSE	;<--------------- BANKED VERSION
	; DEFINE PUBLIC LABELS:
	PUBLIC	?INIT,?LDCCP,?RLCCP,?TIME
	PUBLIC	OUT$BLOCKS
	; EXTERNALLY DEFINED ENTRY POINTS AND LABELS:
	EXTRN	?PMSG,?CONIN
	EXTRN	@CIVEC,@COVEC,@AIVEC,@AOVEC,@LOVEC
	EXTRN 	@CBNK,?BNKSL
	IF	BANKED
	EXTRN	BANKBUF		;128 BYTE BUFFER IN MOVE MODULE FOR USE
				; DURING COLD AND WARM BOOTS
	ENDIF
	EXTRN	@SEC,@MIN,@HOUR,@DATE	;FIELDS HOLDING CURRENT TIME AND DATE
	; INCLUDE Z-80 MACROS:
	MACLIB	Z80
	; SOME MISCELLANEOUS EQUATES:
BDOS		EQU	5
CR		EQU	13	;ASCII CARRIAGE RETURN
LF		EQU	10	;ASCII LINEFEED
	; WE CAN DO INITIALIZATION FROM BANKED MEMORY (IF WE HAVE IT):
	IF	BANKED
	DSEG	; INIT DONE FROM BANKED MEMORY
	ELSE
	CSEG	; INIT TO BE DONE FROM COMMON MEMORY
	ENDIF
	;;;;; ?INIT
	; HARDWARE INITIALIZATION OTHER THAN CHARACTER AND DISK I/O:
?INIT:
	; ASSIGN CONSOLE INPUT AND OUTPUT TO CRT:
	LXI	H,8000H		;SIGNIFIES DEVICE 0
	SHLD	@CIVEC		;CONSOLE INPUT VECTOR
	SHLD	@COVEC		;CONSOLE OUTPUT VECTOR
	; ASSIGN PRINTER TO LPT:
	LXI	H,4000H		;SIGNIFIES DEVICE 1
	SHLD	@LOVEC		;LIST OUTPUT VECTOR
	; ASSIGN AUX TO CRT1:
	LXI	H,02000H	;SIGNIFIES DEVICE 2
	SHLD	@AIVEC		;AUXILLIARY INPUT VECTOR
	SHLD	@AOVEC		;AUXILLIARY OUTPUT VECTOR
	; PRINT THE SIGN-ON MESSAGE:
	LXI	H,SIGNON$MSG	;POINT TO IT
	JMP	?PMSG		;AND PRINT IT
	;;;;; OUT$BLOCKS
	; ROUTINE OUTPUTS SPECIFIED # BYTES TO SPECIFIED OUTPUT PORTS:
	IF	BANKED
	CSEG			;WE WANT THIS ROUTINE IN COMMON MEMORY
	ENDIF
OUT$BLOCKS:
	MOV	A,M		;GET A BYTE FROM THE BLOCK
	ORA	A		;END OF OUTPUT BLOCK ?
	RZ			;THEN DONE!!
	MOV	B,A		;ELSE PUT # BYTES TO SEND OUT IN [B]
	INX	H		;POINT TO PORT TO SEND TO
	MOV	C,M		;GET IT TO [C]
	INX	H		;POINT TO 1ST BYTE OF BLOCK TO SEND OUT
	OUTIR			;Z-80 BLOCK OUTPUT
	JR	OUT$BLOCKS
	;;;;; ?LDCCP
	; THIS ROUTINE IS ENTERED TO LOAD THE CCP.COM FILE INTO THE TPA BANK
	;  AT SYSTEM COLD START:
?LDCCP:
	; SET UP THE FCB FOR THE FILE OPERATION:
	XRA	A		;ZERO EXTENT
	STA	CCP$FCB+15
	LXI	H,0		;START AT BEGINNING OF FILE
	SHLD	FCB$NR
	; TRY TO OPEN THE CCP.COM FILE:
	LXI	D,CCP$FCB	;POINT TO FCB
	CALL	OPEN		;ATTEMPT THE OPEN OPERATION
	INR	A		;WAS IT ON THE DISK ?
	JRNZ	CCP$FOUND	;YES -- GO LOAD IT
	; WE ARRIVE HERE WHEN CCP.COM FILE WASN'T FOUND:
	LXI	H,CCP$MSG	;REPORT THE ERROR
	CALL	?PMSG
	CALL	?CONIN		;GET A RESPONSE
	JR	?LDCCP		;AND TRY AGAIN
	; FILE WAS OPENED OK -- READ IT IN:
CCP$FOUND:
	LXI	D,0100H		;LOAD AT BOTTOM OF TPA
	CALL	SETDMA		;BY SETTING THE NEXT DMA ADDRESS
	LXI	D,128		;SET MULTI SECTOR I/O COUNT
	CALL	SETMULTI	; TO ALLOW UP TO 16K BYTES IN ONE OPERATION
	LXI	D,CCP$FCB	;POINT TO THE FCB
	CALL	READ		;AND READ THE CCP IN
	; FOLLOWING CODE FOR BANKED SYSTEMS -- MOVES CCP IMAGE TO BANK 2
	;  FOR LATER RELOADING AT WARM STARTS:
	IF	BANKED
	LXI	H,0100H		;GET CCP IMAGE FROM START OF TPA
	MVI	B,25		;TRANSFER 25 LOGICAL SECTORS
	LDA	@CBNK		;GET CURRENT BANK
	PUSH	PSW		;AND SAVE IT
LD$1:
	PUSH	B		;SAVE SECTOR COUNT
	MVI	A,1		;SELECT TPA BANK
	CALL	?BNKSL
	LXI	B,128		;TRANSFER 128 BYTES TO TEMPORARY BUFFER
	LXI	D,BANKBUF	;TEMPORARY BUFFER ADDR IN [DE]
	PUSH	H		;SAVE SOURCE ADDRESS
	PUSH	D		;AND DESTINATION
	PUSH	B		;AND COUNT
	LDIR			;BLOCK MOVE SECTOR TO TEMPORARY BUFFER
	MVI	A,2		;SELECT BANK TO SAVE CCP IN
	CALL	?BNKSL
	POP	B		;GET BACK COUNT
	POP	H		;LAST DESTINATION WILL BE NEW SOURCE ADDR
	POP	D		;LAST SOURCE WILL BE NEW DESTINATION
	LDIR			;BLOCK MOVE SECTOR FROM BUFFER TO ALTERNATE
				; BANK
	XCHG			;NEXT ADDR WILL BE NEW SOURCE ADDR
	POP	B		;GET BACK SECTOR COUNT
	DJNZ	LD$1		;DROP SECTOR COUNT AND LOOP TILL DONE...
	POP	PSW		;WHEN DONE -- RESTORE ORIGINAL BANK
	JMP	?BNKSL
	ELSE
	; IF NON-BANKED WE RETURN THROUGH HERE:
	RET
	ENDIF
	;;;;; ?RLCCP
	; ROUTINE RELOADS CCP IMAGE FROM BANK 2 IF BANKED SYSTEM OR FROM THE
	;  DISK IF NON-BANKED VERSION:
?RLCCP:
	IF	BANKED
	; FOLLOWING CODE FOR BANKED VERSION:
	LXI	H,0100H		;GET CCP IMAGE FROM START OF ALTERNATE BUFFER
RL$1:
	MVI	A,2		;SELECT ALTERNATE BANK
	CALL	?BNKSL
	PUSH	B		;AND COUNT
	MVI	A,1		;PUT CCP TO TPA BANK
	CALL	?BNKSL
	LDIR			;BLOCK MOVE SECTOR FROM BUFFER TO TPA BANK
	DJNZ	RL$1		;DROP SECTOR COUNT AND LOOP TILL DONE...
	POP	PSW		;GET BACK LAST CURRENT BANK #
	JMP	?BNKSL		;SELECT IT AND RETURN
	ELSE
	; FOLLOWING CODE IS FOR NON-BANKED VERSIONS:
	JMP	?LDCCP		;JUST DO LOAD AS THOUGH COLD BOOT
	ENDIF
	;;;;; ?TIME
	; ROUTINE SETS/GETS TIME:
?TIME:
	RET			;Just return in this simple version
	IF	BANKED
	CSEG
	ENDIF
	; CP/M BDOS FUNCTION INTERFACES
	; OPEN FILE:
OPEN:
	MVI C,15 ! JMP BDOS		; OPEN FILE CONTROL BLOCK
	; SET DMA ADDRESS:
SETDMA:
	MVI C,26 ! JMP BDOS		; SET DATA TRANSFER ADDRESS
	; SET MULTI SECTOR I/O COUNT:
SETMULTI:
	MVI C,44 ! JMP BDOS		; SET RECORD COUNT
	; READ FILE RECORD:
READ:
	MVI C,20 ! JMP BDOS		; READ RECORDS
	; CCP NOT FOUND ERROR MESSAGE:
CCP$MSG:
	DB	CR,LF,'BIOS ERR ON A: NO CCP.COM FILE',0
	; FCB FOR CCP.COM FILE LOADING:
CCP$FCB:
	DB	1		;AUTO-SELECT DRIVE A
	DB	'CCP     COM'	;FILE NAME AND TYPE
	DB	0,0,0,0
	DS	16
FCB$NR:	DB	0,0,0
	; SYSTEM SIGN-ON MESSAGE:
SIGNON$MSG:
	db	CR,LF,LF,'CP/M Plus v3.0hd',CR,LF,LF,0
	END
CHARIO3.asm
	TITLE	'CHARACTER I/O HANDLER FOR CP/M 3.0'
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
BANKED		EQU	FALSE	;<------------------- BANKED VERSION
	PUBLIC	?CINIT,?CI,?CO,?CIST,?COST
	PUBLIC	@CTBL
	; DEFINE EXTERNAL LABELS AND ENTRY POINTS:
	IF	BANKED
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	EXTRN	OUT$BLOCKS	;BLOCK OUTPUT ROUTINE TO I/O PORTS
	EXTRN	?PMSG
	MACLIB	Z80
	; EQUATES FOR MODE BYTE BIT FIELDS
MB$INPUT	EQU 0000$0001B	; DEVICE MAY DO INPUT
MB$OUTPUT	EQU 0000$0010B	; DEVICE MAY DO OUTPUT
MB$IN$OUT	EQU MB$INPUT+MB$OUTPUT
MB$SOFT$BAUD	EQU 0000$0100B	; SOFTWARE SELECTABLE BAUD RATES
MB$SERIAL	EQU 0000$1000B	; DEVICE MAY USE PROTOCOL
MB$XON$XOFF	EQU 0001$0000B	; XON/XOFF PROTOCOL ENABLED
BAUD$NONE	EQU 0		; NO BAUD RATE ASSOCIATED WITH THIS DEVICE
BAUD$50		EQU 1		; 50 BAUD
BAUD$75		EQU 2		; 75 BAUD
BAUD$110	EQU 3		; 110 BAUD
BAUD$134	EQU 4		; 134.5 BAUD
BAUD$150	EQU 5		; 150 BAUD
BAUD$300	EQU 6		; 300 BAUD
BAUD$600	EQU 7		; 600 BAUD
BAUD$1200	EQU 8		; 1200 BAUD
BAUD$1800	EQU 9		; 1800 BAUD
BAUD$2400	EQU 10		; 2400 BAUD
BAUD$3600	EQU 11		; 3600 BAUD
BAUD$4800	EQU 12		; 4800 BAUD
BAUD$7200	EQU 13		; 7200 BAUD
BAUD$9600	EQU 14		; 9600 BAUD
BAUD$19200	EQU 15		; 19.2K BAUD
	; MISCELLANEOUS EQUATES:
CRTSTAT	EQU	0H		;STATUS PORT TO CHECK CRT OUTPUT STATUS
IOBYTE	EQU	0EFH
KEYSTAT	EQU	0H
KEYIN	EQU	01H
KEYOUT	EQU	01H
CENTSTROBE EQU	4
CENTOUT	EQU	5
CENTSTAT EQU	5
	; WILL START OFF IN COMMON MEMORY FOR BANKED OR NON-BANKED SYSTEMS:
	CSEG
	IF	BANKED
	; WE PROVIDE ALTERNATE DEFINITIONS OF THE ROUTINE ENTRY POINTS IF
	;  WE ARE RUNNING A BANKED SYSTEM VERSUS A NON-BANKED SYSTEM:
	;;;;; ?CINIT
	; ENTER HERE FOR BANKED SYSTEMS FOR DEVICE INITIALIZATIONS:
?CINIT:
	LXI	H,BCINIT	;POINT TO BANKED ROUTINE ADDRESS
	JR	BANKIO		;GO TO DISPATCHER
	;;;;; ?CI
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT:
?CI:	LXI	H,BCI		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CO
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT:
?CO:	LXI	H,BCO		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CIST
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT STATUS:
?CIST:	LXI	H,BCIST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?COST
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT STATUS:
?COST:	LXI	H,BCOST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; BANKIO
	; ROUTINE DISPATCHES TO BANKED PORTION OF CHARACTER I/O ROUTINES:
BANKIO:
	SSPD	SPSAVE		;SAVE CURRENT STACK POINTER
	LXI	SP,IOSP		; AND USE LOCAL STACK FOR I/O
	PUSH	PSW		;SAVE ON LOCAL STACK
	XRA	A		;WE WILL SELECT BANK 0 (OP SYS)
	CALL	?BNKSL
	LXI	D,BIORET	;RETURN ADDRESS IN [DE]
	PUSH	D		;PUT IT ON STACK FOR RETURN
	PCHL			;DISPATCH TO BANKED PART OF ROUTINE
	; ARRIVE HERE AFTER DEVICE HANDLER FINISHED:
BIORET:
	POP	D		;GET PREVIOUS CURRENT BANK TO [D]
	PUSH	PSW		;SAVE HANDLER RETURNED RESULT (IF ANY)
	MOV	A,D		;RESELECT PREVIOUS CURRENT BANK
	CALL	?BNKSL
	POP	PSW		;GET BACK RESULT CODE TO [A]
	LSPD	SPSAVE		;RESTORE PREVIOUS STACK
	RET			;AND RETURN...
	ENDIF
	;;;;; ACTUAL DEVICE HANDLERS
	;;;;; ?CINIT (BCINIT FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INITIALIZATION:
	IF	BANKED
	DSEG			;CAN PUT IN BANKED SEGMENT IF BANKED
BCINIT:
	ELSE
?CINIT:
	ENDIF
	MOV	B,C		;ON ENTRY DEVICE # IS IN [C] BUT WE NEED
				; IT IN [B]
	CALL	DEV$DISPATCH	;GO TO CORRECT INIT ROUTINE
	DW	CINIT0		;INIT FOR DEVICE 0
	DW	CINIT1		;INIT FOR DEVICE 1
	DW	NULL$INIT	;INIT FOR DEVICE 2
	DW	NULL$INIT	;INIT FOR DEVICE 3
	DW	NULL$INIT	;INIT FOR DEVICE 4
	DW	NULL$INIT	;INIT FOR DEVICE 5
	DW	NULL$INIT	;INIT FOR DEVICE 6
	DW	NULL$INIT	;INIT FOR DEVICE 7
	DW	NULL$INIT	;INIT FOR DEVICE 8
	DW	NULL$INIT	;INIT FOR DEVICE 9
	DW	NULL$INIT	;INIT FOR DEVICE 10
	DW	NULL$INIT	;INIT FOR DEVICE 11
	DW	NULL$INIT	;INIT FOR DEVICE 12
	DW	NULL$INIT	;INIT FOR DEVICE 13
	DW	NULL$INIT	;INIT FOR DEVICE 14
	DW	NULL$INIT	;INIT FOR DEVICE 15
	;;;;; ?CI (BCI FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT:
	IF	BANKED
BCI:
	ELSE
?CI:
	ENDIF
	CALL	DEV$DISPATCH
	DW	CI0		;DEVICE 0 INPUT
	DW	CI1		;DEVICE 1 INPUT
	DW	NULL$CI		;DEVICE 2 INPUT
	DW	NULL$CI		;DEVICE 3 INPUT
	DW	NULL$CI		;DEVICE 4 INPUT
	DW	NULL$CI		;DEVICE 5 INPUT
	DW	NULL$CI		;DEVICE 6 INPUT
	DW	NULL$CI		;DEVICE 7 INPUT
	DW	NULL$CI		;DEVICE 8 INPUT
	DW	NULL$CI		;DEVICE 9 INPUT
	DW	NULL$CI		;DEVICE 10 INPUT
	DW	NULL$CI		;DEVICE 11 INPUT
	DW	NULL$CI		;DEVICE 12 INPUT
	DW	NULL$CI		;DEVICE 13 INPUT
	DW	NULL$CI		;DEVICE 14 INPUT
	DW	NULL$CI		;DEVICE 15 INPUT
	;;;;; ?CO (BCO FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT:
	IF	BANKED
BCO:
	ELSE
?CO:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CORRECT DEVICE OUTPUT HANDLER
	DW	CO0		;DEVICE 0 OUTPUT
	DW	CO1		;DEVICE 1 OUTPUT
	DW	NULL$CO		;DEVICE 2 OUTPUT
	DW	NULL$CO		;DEVICE 3 OUTPUT
	DW	NULL$CO		;DEVICE 4 OUTPUT
	DW	NULL$CO		;DEVICE 5 OUTPUT
	DW	NULL$CO		;DEVICE 6 OUTPUT
	DW	NULL$CO		;DEVICE 7 OUTPUT
	DW	NULL$CO		;DEVICE 8 OUTPUT
	DW	NULL$CO		;DEVICE 9 OUTPUT
	DW	NULL$CO		;DEVICE 10 OUTPUT
	DW	NULL$CO		;DEVICE 11 OUTPUT
	DW	NULL$CO		;DEVICE 12 OUTPUT
	DW	NULL$CO		;DEVICE 13 OUTPUT
	DW	NULL$CO		;DEVICE 14 OUTPUT
	DW	NULL$CO		;DEVICE 15 OUTPUT
	;;;;; ?CIST (BCIST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT STATUS:
	IF	BANKED
BCIST:
	ELSE
?CIST:
	ENDIF
	CALL	DEV$DISPATCH
	DW	CIST0		;DEVICE 0 INPUT STATUS
	DW	CIST1		;DEVICE 1 INPUT STATUS
	DW	NULL$CIST	;DEVICE 2 INPUT STATUS
	DW	NULL$CIST	;DEVICE 3 INPUT STATUS
	DW	NULL$CIST	;DEVICE 4 INPUT STATUS
	DW	NULL$CIST	;DEVICE 5 INPUT STATUS
	DW	NULL$CIST	;DEVICE 6 INPUT STATUS
	DW	NULL$CIST	;DEVICE 7 INPUT STATUS
	DW	NULL$CIST	;DEVICE 8 INPUT STATUS
	DW	NULL$CIST	;DEVICE 9 INPUT STATUS
	DW	NULL$CIST	;DEVICE 10 INPUT STATUS
	DW	NULL$CIST	;DEVICE 11 INPUT STATUS
	DW	NULL$CIST	;DEVICE 12 INPUT STATUS
	DW	NULL$CIST	;DEVICE 13 INPUT STATUS
	DW	NULL$CIST	;DEVICE 14 INPUT STATUS
	DW	NULL$CIST	;DEVICE 15 INPUT STATUS
	;;;;; ?COST (BCOST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT STATUS:
	IF	BANKED
BCOST:
	ELSE
?COST:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CONSOLE OUTPUT STATUS HANDLER
	DW	COST0		;DEVICE 0 OUTPUT STATUS
	DW	COST1		;DEVICE 1 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 2 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 3 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 4 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 5 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 6 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 7 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 8 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 9 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 10 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 11 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 12 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 13 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 14 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 15 OUTPUT STATUS
	;;;;; DEV$DISPATCH
	; ROUTINE JUMPS TO CORRECT DEVICE HANDLER:
DEV$DISPATCH:
	MOV	A,B		;GET DEVICE # TO [A]
	STA	DEV$CODE	;SAVE FOR LATER USE
	ADD	A		;X2 FOR WORD OFFSET
	POP	H		;RETURN ADDRESS IS 1ST PARAMETER ADDRESS
	MOV	E,A		;SET UP OFFSET IN [DE]
	MVI	D,0
	DAD	D		;[HL] = PTR TO HANDLER ADDRESS
	MOV	E,M		;GET HANDLER ADDRESS TO [DE]
	INX	H
	MOV	D,M
	XCHG			;PUT IN [HL]
	PCHL			;AND DISPATCH TO IT...
	;;;;; PHYSICAL DEVICE HANDLER CODE:
	;;;;; DEVICE 0 HANDLERS (SD SYSTEMS VIDIO BOARD)
CINIT0:	; DEVICE 0 INITIALIZATION
	RET
;<<<<<<<<<<<<<<<<<<< MAIN CONSOL STATUS ROUTINE >>>>>>>>>>>>>>>>>>>>>>
CIST0:				; DEVICE 0 INPUT STATUS:
CSTS:	IN	KEYSTAT
	ANI	02H
	RZ			;RETURN WITH 0 IN [A] IF NOTHING THERE
	DCR	A
	RET			;RETURN WITH 0FFH IN [A] IF SOMETHING
;<<<<<<<<<<<<<<<<<<<< MAIN CONSOL INPUT ROUTINE >>>>>>>>>>>>>>>>>>>>
CI0:				;DEVICE 0 INPUT:
CI:	CALL	CSTS		;NEED CONSTAT TO CLEAN UP SHIFT KEYS ETC
	JRZ	CI
	IN	KEYIN
	ANI	7FH
	RET
;<<<<<<<<<<<<<<<<<<<<<< MAIN CONSOL OUTPUT ROUTINE >>>>>>>>>>>>>>>>>>>>>>>>>
COST0:	; DEVICE 0 OUTPUT STATUS:
	IN	CRTSTAT
	ANI	4H
	RZ
	XRA	A
	DCR	A
	RET
CO0:				; DEVICE 0 OUTPUT:
CO:	IN	IOBYTE
	BIT	0,A		;CHECK IF OUTPUT TO LIST IS ALSO REQ
	JZ	LOX
	BIT	4,A		;KILL LF'S IF THIS IS 0
	JRNZ	SDCONO
	MOV	A,C
	CPI	0AH		;CHECK FOR LF'S
	JRZ	SDCON5		;KILL LF'S
	PUSH	B		;ALL OTHERE CHARACTERS SEND EOL THEN CHAR
	MVI	C,']'-40H	;FOR CLEAR TO END OF LINE
	CALL	SDCONO		;BECAUSE EOL IS SENT FOR EACH CHARACTER THE
	POP	B		;TYPE RATE IS NICELY SLOWED DOWN TO ~ 60 BAUD
	JR	SDCONO		;AT NO FURTHER EXPENSE |
SDCON5:	MOV	A,C
	RET
LOX:	CALL	SDCONO		;OUTPUT TO BOTH PRINTER & CONSOLE
	CALL	LO
	RET
SDCONO:	IN	0H		;SD SYSTEMS VIDIO BOARD PORT
	ANI	4H
	JRZ	SDCONO
	MOV	A,C
	CPI	07H		;IS IT A BELL
	JRZ	BELL1
	CPI	0H		;SD BOARD CANNOT TAKE A NULL!
	RZ
	OUT	1
	IN	IOBYTE
	BIT	5,A		;SEE IF TIME DELAY REQ WITH CONSOL OUTPUT
	JRNZ	SDCON5	;MAKE SURE TO RETURN CHARACTER SENT IN [A]
	PUSH	PSW
	MVI	A,50
	CALL	DELAY
	POP	PSW
	MOV	A,C
	RET			;RETURN CHARACTER SENT IN [A]
BELL1:	MVI	A,06H		;SEND A BELL
	OUT	1H
	MVI	A,0FH
	CALL	DELAY
	MVI	A,07H
	OUT	1H
	JR	SDCON5
DELAY:	DCR	A		;GENERAL COUNT DOWN TIME DELAY
	RZ			;LENGTH SET IN [A]
	PUSH	PSW
	MVI	A,05H
MORE:	DCR	A
	PUSH	PSW
	XRA	A
MORE2:	DCR	A
	JRNZ	MORE2
	POP	PSW
	JRNZ	MORE
	POP	PSW
	JR	DELAY
	;;;;; DEVICE 1 HANDLERS: (Parallel port to printers).
CINIT1:	; DEVICE 1 INITIALIZATIONS
	MVI	A,0FFH		;NEEDED TO CLEAR PRINTER STROBE COMES UP
	OUT	CENTSTROBE	;AFTER A RESET LOW
	RET
CIST1:	; DEVICE 1 INPUT STATUS:
	XRA	A
	RET
COST1:	; DEVICE 1 OUTPUT STATUS:
LSTAT:	IN	CENTSTAT	;FIRST FIND WHICH PRINTER IS SELECTED
	BIT	1,A
	JRNZ	CENSTAT
	BIT	5,A
	JRNZ	TRANSTAT
	XRA	A		;NONE SELECTED
	DCR	A
	RET
CENSTAT:ANI	00001111B	;XXXX0110 IS READY (BIT 3=PAPER BIT 2=FAULT
	CPI	00000110B	;BIT 1=SELECT  BIT 0=BUSY
	JRZ	LSTAT1
	XRA	A
	RET
TRANSTAT:ANI	11110000B	;0110XXX IS READY (BIT 7=ALERT BIT 6=FAULT
	CPI	01100000B	;BIT 5=SELECT BIT 4=BUSY
	JRZ	LSTAT1
	XRA	A
	RET
LSTAT1:	XRA	A		;PUT 0FFH IN [A] IF READY & NO ZERO FLAG
	DCR	A
	RET
CI1:	; DEVICE 1 INPUT:
	MVI	A,1AH
	RET
CO1:	; DEVICE 1 OUTPUT:
;THIS IS THE MAIN DRIVER FOR PRINTER OUTPUT.
LO:	CALL	LSTAT
	JRZ	LO
	MVI	A,0FFH
	OUT	CENTSTROBE
	MOV	A,C
	OUT	CENTOUT
	IN	CENTSTAT
	BIT	1,A
	JRNZ	LCENT
	BIT	5,A
	JRNZ	LTRANS
	RET				;NO STROBE SINCE NOT SELECTED
LCENT:	MVI	A,11111110B		;STROBE FOR CENTRONICS
	JR	OVERLS
LTRANS:	MVI	A,11111101B
OVERLS:	OUT	CENTSTROBE
	MVI	A,0FFH
	OUT	CENTSTROBE
	RET
	;;;;; NULL ROUTINES:
NULL$CIST:
NULL$COST:
	XRA	A		;RETURN A FALSE STATUS RESULT
	JR	NULL$RET
NULL$CI:
	MVI	A,1AH		;FOR INPUT RETURN A CNTL-Z (EOF)
NULL$INIT:
NULL$CO:
NULL$RET:
	RET			;HARMLESS RETURN
	; STORAGE FOR DEVICE CODE -- CAN RESIDE IN SAME SEGMENT AS THE BULK
	;  OF CHARACTER I/O ROUTINES:
DEV$CODE:	DS	1
	;;;;; CHRTBL
	; CHARACTER DEVICE TABLE
	CSEG			;MUST RESIDE IN COMMON MEMORY
@CTBL:
	DB	'CRT   '		;CONSOLE (DEVICE 0)
	DB	MB$IN$OUT
	DB	BAUD$NONE
	DB	'LPT   '		;PRINTER (DEVICE 1)
	DB	MB$OUTPUT
	DB	BAUD$NONE
MAX$DEVICES	EQU	($-@CTBL)/8	;# DEVICES IN TABLE
	DB	0			;TABLE TERMINATOR
	; OTHER DATA AREAS:
	DS	24		;CHARACTER I/O LOCAL STACK
IOSP	EQU	$
SPSAVE	DS	2
	END
MOVE3.asm
	TITLE 'BANK & MOVE MODULE FOR CP/M3 LINKED BIOS'
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
BANKED		EQU	FALSE	;<----------------Banked VERSION
MPURR0	EQU	0D2H		;Z80 BOARD RELOCATION PORT
MPURR1	EQU	0D3H		;Z80 BOARD RELOCATION PORT
	PUBLIC	?MOVE,?XMOVE,?BANK
	; PUBLIC LABELS AND EXTERNALS FOR BANKED SYSTEMS:
	IF	BANKED
	PUBLIC	CURRR0,CURRR1	;CURRENT WINDOW RELOCATION SEGMENTS
	PUBLIC	BANKBUF		;TEMPORARY 128 BYTE BUFFER OTHER ROUTINES
				; MAY USE FOR TRANSIENT PURPOSES
	PUBLIC	WIN$LOW$2BITS	;LOWER 2 BITS FOR EACH RELOCATION REGISTER
	PUBLIC	DOXMOV,XMOV$BANKS	;EXTENDED BANK MOVE VARIABLES
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	MACLIB	Z80
	; LOCATE CODE IN THE COMMON SEGMENT:
	CSEG
	;;;;; ?XMOVE
	; ROUTINE SETS UP AN INTER-BANK MOVE OF 128 BYTES ON THE NEXT CALL
	;  TO ?MOVE:
?XMOVE:
	IF	BANKED
	MVI	A,0FFH		;SET EXTENDED MOVE FLAG
	STA	DOXMOV
	SBCD	XMOV$BANKS	;AND STORE BANKS FOR THE EXTENDED MOVE
	ENDIF
	RET
	;;;;; ?MOVE
	; ROUTINE PERFORMS INTRA-BANK MOVES IF ?XMOVE WAS NOT CALLED PRIOR TO
	;  THIS CALL TO ?MOVE ELSE A 128 BYTE TRANSFER IS CONDUCTED BETWEEN
	;  DIFFERENT BANKS:
?MOVE:
	IF	BANKED
	LDA	DOXMOV		;GET EXTENDED MOVE FLAG
	ORA	A		;IS IT SET ?
	MVI	A,0		;RESET FOR NEXT TIME ANYWAY
	STA	DOXMOV
	JRZ	MOVE$IT
	; HAVE TO IMPLEMENT INTER-BANK MOVE:
	LDA	@CBNK		;REMEMBER CURRENT BANK
	PUSH	PSW
	LDA	XMOV$BANKS	;GET SOURCE BANK
	CALL	?BNKSL		; AND SELECT IT
	PUSH	H		;SAVE DESTINATION ADDRESS
	PUSH	B		;AND THE COUNT
	XCHG			;[HL] = SOURCE
	LXI	D,BANKBUF	;[DE] = LOCAL TEMPORARY BUFFER
	LDIR			;BLOCK MOVE TO TEMP BUFFER
	POP	B		;RESTORE COUNT
	POP	D		;[DE] = ORIGINAL DESTINATION
	PUSH	H		;SAVE NEXT SOURCE ADDRESS
	LXI	H,BANKBUF	;[HL] = SOURCE = TEMP BUFFER
	LDA	XMOV$BANKS+1	;GET DESTINATION BANK
	CALL	?BNKSL		;AND SELECT IT
	LDIR			;BLOCK MOVE FROM TEMP BUFFER TO DESTINATION
	POP	H		;RESTORE NEXT SOURCE
	XCHG			;RETURN SWAP
	POP	PSW		;GET BACK PREVIOUS CURRENT BANK
	; ARRIVE HERE FOR INTRA-BANK MEMORY MOVE:
MOVE$IT:
	ENDIF
	XCHG			;WE ARE PASSED SOURCE IN DE AND DEST IN HL
	LDIR			;USE Z80 BLOCK MOVE INSTRUCTION
	XCHG			;NEED NEXT ADDRESSES IN SAME REGS
	RET
	;;;;; ?BANK
	; ROUTINE SWITCHES IN PHYSICAL BANK:
?BANK:
	IF	BANKED
	CPI	2		;BANK 2 OR HIGHER ?
	JRNC	BNK1$SWITCH	;GO DIRECTLY TO CODE TO CALCULATE THE
				; PHYSICAL ADDRESS...
	ORA	A		;ELSE SWAP BANK 0 AND 1 VALUES
	MVI	A,1		;IF BANK 0 MAKE BANK 1
	JRZ	BNK1$SWITCH
	XRA	A		;ELSE IF BANK 1 MAKE BANK 0
	JR	BNK2$SWITCH
	; HERE TO GET MPU-80 SEGMENT # FOR THE BANK WE NEED:
BNK1$SWITCH:
	DCR	A		;NORMALIZE BANK # RELATIVE TO 0
	ADD	A		;X2
	ADD	A		;X4 FOR 16K / WINDOW
	ADD	A		;X8 FOR 32K / BANK
	ADI	10H		;BANKS 1-15 START ABOVE 1ST 64K
	; DO PHYSICAL BANK SWITCHING HERE:
BNK2$SWITCH:
	PUSH	B		;SAVE [BC]
	LBCD	WIN$LOW$2BITS	;GET LOWER 2 BITS FOR EACH RELOCATION REGISTER
	DI			;CRITICAL SECTION -- NO INTERRUPTS HERE
	STA	CURRR0		;SAVE SEGMENT ADDR. OF LOWER WINDOW
	ORA	B		;[A] = WINDOW SEG + LOW 2 BITS
	OUT	MPURR0		;RELOCATE LOWER WINDOW NOW
	ANI	0FCH		;TAKE OUT LOWER 2 BITS
	ADI	4		;BUMP UP SEG ADDR BY 16K FOR UPPER WINDOW
	STA	CURRR1		;SAVE UPPER WINDOW SEGMENT ADDR.
	ORA	C		;[A] = WINDOW SEG + LOW 2 BITS
	OUT	MPURR1		;RELOCATE UPPER WINDOW
;;;;	EI			;CAN REENABLE INTERRUPTS NOW
	POP	B		;RESTORE [BC]
	ENDIF
	RET
	IF	BANKED
DOXMOV:		DB	0	;EXTENDED MOVE FLAG -- IF EQUAL TO FFH THEN
				; NEXT CALL TO ?MOVE WILL BE AN INTER-BANK
				; MOVE.
CURRR0:		DB	10H	;CURRENT LOWER WINDOW RELOCATION REGISTER
				; VALUE
CURRR1:		DB	14H	;CURRENT UPPER WINDOW RELOCATION REGISTER
				; VALUE
WIN$LOW$2BITS:	DB	1	;UPPER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
				; ADDRESSING ABOVE 1 MEGABYTE OR EPROM SELECT)
		DB	1	;LOWER WINDOW REGISTER LOW 2 BITS (MAY CONTROL
XMOV$BANKS:	DS	1	;STORAGE AREA FOR DESTINATION BANK # FOR
				; EXTENDED MOVES
		DS	1	;STORAGE AREA FOR SOURCE BANK # FOR
				; EXTENDED MOVES
BANKBUF:	DS	128	;LOCAL TEMPORARY BUFFER FOR EXTENDED MOVES
	ENDIF
	END
Last edited by Wayne Parham on January 11th, 2023, 2:58 pm, edited 1 time in total.
And now the hardware-specific code for disk I/O:
DRVTBL3.asm
	TITLE	'CP/M 3.0 DRIVE TABLES'
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; DETERMINE IF BANK SELECTING:
BANKED		EQU	FALSE	;<-------------- NON BANKED VERSION
	PUBLIC	@DTBL
	; DECLARE EXTERNAL LABELS:
	EXTRN	DPH0, DPH1, DPH2, DPH3
	; INCLUDE CP/M 3.0 MACRO LIBRARY:
	MACLIB	CPM3
	IF	BANKED
	DSEG			;BANKED SYSTEMS CAN HAVE DRIVE TABLE IN THE
				; OP SYS BANK
	ELSE
	CSEG			;NON-BANKED SYSTEMS HAVE NO CHOICE BUT TO PUT
				; IT IN THE COMMON MEMORY AREA
	ENDIF
@DTBL:	DTBL	<DPH0,DPH1,DPH2,DPH3,0,0,0,0,0,0,0,0,0,0,0,0>
	END
FLP3.asm
	TITLE	'CPM3 module for floppy drives'
TRUE	equ	-1
FALSE	equ	not TRUE
;Diskette parameter equates
MINIDSK	equ	FALSE		;set TRUE for Altair Mini-Disk
NUMTRK	equ	77		;number of tracks on the disk
NUMSEC	equ	32		;sectors per track
DATATRK	equ	6		;1st data format track
SECMASK	equ	1Fh		;five bit sector numbers
BLS	equ	1024		;allocation unit size
BSH	equ	4		;allocation block shift factor
BLM	equ	0Fh		;allocation block mask
EXM	equ	0		;extent mask
DSM	equ	149		;max block number (150 blocks of 2K bytes)
NDIRS	equ	64		;number of directory entries (64)
DRM	equ	63		;max directory entry number
AL0	equ	0C0h		;directory allocation block bits byte 0
AL1	equ	0		;directory allocation block bits byte 1
RESTRK	equ	2		;reserved tracks for boot image
CKS	equ	(DRM+1)/4	;directory check space
NUMDISK	equ	2		;Two drives supported
CSECLEN	equ	128		;CP/M sector length
SSECLEN	equ	133		;Altair system sector length
DSECLEN	equ	136		;Altair data sector length
TSECLEN	equ	DSECLEN+1	;length of sector in track table
; System tracks (0-5) sector format
SYSTRK	equ	0		;offset of track number
SYSDATA	equ	3		;offset of 128 byte data payload
SYSSTOP	equ	131		;offset of stop byte (FFh)
SYSCSUM	equ	132		;offset of checksum
; Data tracks (6-76) sector format
DATTRK	equ	0		;offset of track number
DATSEC	equ	1		;offset of sector number
DATCSUM	equ	4		;offset of checksum
DATDATA	equ	7		;offset of 128 byte data payload
DATSTOP	equ	135		;offset of stop byte (FFh)
; Altair disk controller
DRVSLCT	equ	08h		;drive select register (out)
cDSLCT	equ	80h		;deselect drive
DRVSTAT	equ	08h		;drive status register (in)
sENWD	equ	01h		;enter new write data flag
sMOVEOK	equ	02h		;OK to move head
sHDSTAT	equ	04h		;head status flag
sDSKEN	equ	08h		;disk is selected and enabled
sINTEN	equ	20h		;processor interrupts enabled
sTRACK0	equ	40h		;on track zero flag
sNRDA	equ	80h		;new read data available
DRVCMD	equ	09h		;drive command register (out)
cSTEPI	equ	01h		;step in
cSTEPO	equ	02h		;step out
cHDLOAD	equ	04h		;head load
cRESTMR	equ	04h		;restart motor-off timer (MINIDSK)
cHDUNLD	equ	08h		;head unload
cINTEN	equ	10h		;interrupt enable
cINTDIS	equ	20h		;interrupt disable
cHCSON	equ	40h		;reduce head current switch
cWRTEN	equ	80h		;write enable
DRVSEC	equ	09h		;drive sector position (in)
sNEWSEC	equ	01h		;new sector flag (sector true)
DRVDATA	equ	0Ah		;drive read/write data (in/out)
; BDOS equates
GETCH	equ	1		;get character
PRINT	equ	9		;display string
OPEN	equ	15		;open file
READSEQ	equ	20		;read sequential
DMA	equ	26		;set address for file read
SETMULT	equ	44		;set multi-record I/O
; RAM equates
TPA	equ	100h
DFFCB	equ	5Ch
STACK	equ	100h
BDOS	equ	5
WBOOTV	equ	00h		;warm boot vector location
BDOSV	equ	05h		;bdos entry vector location
; Misc equates
NUMCDEV	equ	4		;number of character I/O devices
RDTRIES	equ	6		;read tries (must be <= 8)
VFTRIES	equ	4		;verify tries per write (must be <= 8)
WRTRIES	equ	3		;track writes to try
UNDEF	equ	0FFh		;undefined value
CR	equ	13		;ascii for carriage return
LF	equ	10		;ascii for line feed
EOF	equ	01Ah		;ctrl-z
; External references
	maclib	CPM3		;CP/M 3.0 disk definition macros
	maclib	Z80		;Z80 translation macro library
	maclib	modebaud	;Character I/O equates
	extrn	@civec,@covec,@aivec,@aovec,@lovec,@mxtpa
	cseg			;Put DPBs in common memory
; Disk Parameter Headers
	PUBLIC	DPH0, DPH1		;FLOPPY DISK PARAMETER HEADERS
	; DEFINE EXTERNAL LABELS:
	EXTRN	@ADRV,@RDRV
	EXTRN	@DMA,@TRK,@SECT
	EXTRN	@CBNK
	EXTRN	@DBNK			;BANK FOR DMA OPERATION
	EXTRN	@ERMDE			;BDOS ERROR MODE
	EXTRN	?WBOOT			;WARM BOOT VECTOR
	EXTRN	?SLDSK			;SELECT DISK
	EXTRN	?PMSG			;PRINT MESSAGE @<HL> UP TO 00, SAVES [BC] AND [DE]
	EXTRN	?PDERR			;PRINT BIOS DISK ERROR HEADER
	EXTRN	?CONIN,?CONO		;CONSOLE IN AND OUT
	EXTRN	?CONST			;CONSOLE STATUS
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 0:
	DW	fdWrite			;FD SEC WRITE ROUTINE
	DW	fdRead			;FD SEC READ ROUTINE
	DW	selDsk0			;FLOPPY DISK "A:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "A:" INITIALIZATION ROUTINE
	DB	0			;RELATIVE DRIVE 0 ON THIS CONTROLLER
	DB	0			;DRIVE TYPE (UNUSED BY CP/M)
dph0	dw	tranTbl,0,0,0,0,0,fd$dpb,csv0,alv0,fd$bcb,-1,-1
	db	0
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 1:
	DW	selDsk1			;FLOPPY DISK "B:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "B:" INITIALIZATION ROUTINE
	DB	1			;RELATIVE DRIVE 1 ON THIS CONTROLLER
dph1	dw	tranTbl,0,0,0,0,0,fd$dpb,csv1,alv1,fd$bcb,-1,-1
	db	0
; fd$dpb - Disk Parameter Block. This table gives a block size of 1024 bytes
;   and 64 directory entries.
fd$dpb	dw	NUMSEC		;sectors per track
	db	BSH		;allocation block shift factor (BSH)
	db	BLM		;data location block mask (BLM)
	db	EXM		;extent mask (EXM)
	dw	DSM		;maximum block number (DSM 242)
	dw	DRM		;maximum directory entry number (DRM 63)
	db	AL0,AL1		;AL0, AL1
	dw	CKS		;CKS=(DRM+1)/4
	dw	RESTRK		;reserved tracks for CPM and bootloader
	db	0		;physical=logical sector (128 bytes)
; fd$bcb - Directory Buffer Control Block (BCB)
fd$bcb	db	0FFh		;drive number (FF means not used yet)
	db	0,0,0		;record position
	db	0		;dirty (write) flag
	db	0		;scratch byte
	dw	0		;track
	dw	0		;sector
	dw	dirBuf		;buffer address
	dw	0		;bank
	dw	0		;link to next BCB (none)
   if MINIDSK
tranTbl	db	1,3,5,7,9,11,13,15,2,4,6,8,10,12,14,16
   endif
   if NOT MINIDSK
tranTbl	db	01,09,17,25,03,11,19,27,05,13,21,29,07,15,23,31
	db	02,10,18,26,04,12,20,28,06,14,22,30,08,16,24,32
   endif
;  Floppy init (noop)
fdInit:
	ret
; selDsk0 - Select Disk 0.
selDsk0:
	mvi	c,0		;C=drive number
	jmp	?slDsk
; selDsk1 - Select Disk 1.
selDsk1:
	mvi	c,1		;C=drive number
	jmp	?slDsk
; fdRead - Read sector BIOS entry. Read one sector using the drvNum,
;    trkNum, secNum, and dmaAddr previously specified.
; On Entry
;    drvNum = drive to read from
;    trkNum = track to read from
;    secNum = sector number to read (0-31)
;    dmaAddr = address of buffer to read into
; On Exit
;    If read successful
;	sector read into (dmaAddr)
;	HL = (dmaAddr) + CSECLEN
;	A=0, Z flag set true
;    Else
;	A=1, Z flag set false
;    Interrupts enabled
;    Clobbers all
fdRead:
	call	ckFlush		;flush track buffer if needed
	ei			;re-enable interrupts
	call	readTrk		;fill track buffer if needed
	jnz	exitDio		;track read error, exit
	call	movRead		;move sector to (dmaAddr)
exitDio	mvi	a,0		;if zero is true, return zero
	rz
	inr	a		;else return A<>0, Z false
	ret
; fdWrite - Write sector BIOS entry. Write one sector using the drvNum,
;    trkNum, secNum and dmaAddr specified.
; On Entry
;    drvNum = drive to write
;    trkNum = track to write
;    secNum = sector number to write (0-31)
;    dmaAddr = address of buffer to write from
; On Exit
;    If successful
;	sector written to trkBuf from (dmaAddr)
;    Else
;    Clobbers all
fdWrite:
	call	ckFlush		;fluhsh track buffer if needed
	jmp	movWrt		;move (dmaAddr) to sector and exit
; movRead - Move sector data from track buffer to (dmaAddr) for a
;    CPM read request
; On Entry
; On Exit
;    If successful (good sector)
;	sector data moved to (dmaAddr), Z flag set true
;    Else (sector flagged as bad)
;	Z flag set false
;    Clobbers all
movRead	call	altSkew		;secNum to hard sector in A
	call	dSecAdr		;HL->sector in trkBuf
	mov	a,m		;A=sector valid flag
	ora	a
	rnz			;bad sector, return error
	lxi	d,DATDATA+1	;DE=offset to data portion of sector
	lda	trkNum		;on a data track?
	cpi	DATATRK
	jnc	mrMove		;yes, data track (DE already correct)
	lxi	d,SYSDATA+1	;DE=offset to data portion of sector
mrMove	dad	d		;HL->data portion of sector
	xchg			;DE->data portion of sector
	lhld	dmaAddr		;HL->destination for data
	mvi	b,CSECLEN	;B=number of bytes to move
mrLoop	ldax	d		;move sector from trkBuf to (dmaAddr)
	mov	m,a
	inx	h		;increment pointers
	inx	d
	dcr	b		;loop count
	jnz	mrLoop
	ret			;exit with zero	status
; movWrt - Move sector data from (dmaAddr) to track buffer and create
;    metadata for the sector for a CPM write request.
; On Entry
; On Exit
;    Sector data moved to trkBuf from (dmaAddr)
;    A=0, Z status true
;    Clobbers all
movWrt	call	altSkew		;secNum to hard sector in A
	mvi	m,0		;flag sector as good
	inx	h		;HL->track
	lda	trkNum		;A=track
	ori	80h		;set sync bit
	mov	m,a		;set track in sector
	inx	h		;HL->byte after track
	cpi	DATATRK+80h	;on a system or data track?
	jnc	wDatTrk		;data track 6-76 (mini disk 4-34)
; Create Altair sector for system tracks 0-5 (mini disk 0-3)
	xra	a		;put 0100h (16 bit) at offset 1,2
	mov	m,a
	inx	h		;HL->offset 2
	inr	a		;A=1
	mov	m,a
	inx	h		;HL->128 byte CPM sector in Altair sector
	call	mwMove		;move (dmaAddr) to sector in trkBuf
	mvi	m,0FFh		;offset 131 is stop byte (0FFh)
	inx	h		;offset 132 is checksum
	mov	m,b		;store checksum at offset 132
	jmp	mwExit		;exit
; wDatTrk- Create Altair sector for tracks 6-76 (mindisk 4-34)
wDatTrk	lda	secNum		;A=sector before Altair skew
	mov	m,a		;store Altair logical sector number
	inx	h		;HL->offset 2 in sector
	xra	a		;store zero at offsets 2-6
	mov	m,a		;offset 2
	inx	h
	mov	m,a		;zero at offset 3
	inx	h
	push	h		;save address of offset 4 = checksum
	inx	h
	mov	m,a		;zero at offset 5
	inx	h
	mov	m,a		;zero at offset 6
	mvi	m,0FFh		;offset 135 is stop byte (0FFh)
	pop	h		;HL->checksum byte in Altair sector
	mov	m,b		;store the checksum
; mwExit - set dirty flag true, return success status
mwExit	mvi	a,0FFh		;set dirty flag true
	sta	bfDirty
	xra	a		;return success status
	ret
; mwMove - Move sector buffer (128 bytes) from (dmaAddr) to (HL) as part
;   of a CPM write command. Compute checksum on all bytes moved and return
;   the checksum in B.
; On Entry
;    HL->destination sector in trkBuf
;    dmaAddr = address of buffer to move from
; On Exit
;    128 bytes moved from (dmaAddr) to (HL)
;    HL = HL + 128
;    B = checksum of the 128 bytes moved
;    Clobbers all
mwMove	xchg			;DE->destination CPM sector in trkBuf
	lhld	dmaAddr		;HL->source buffer
	lxi	b,CSECLEN	;B=checksum (0), C=128 byte count
mwLoop	mov	a,m		;move from (HL) to (DE)
	stax	d
	add	b		;add byte to checksum
	mov	b,a
	inx	d		;increment both pointers
	inx	h
	dcr	c		;decrement character count
	jnz	mwLoop		;loop until count = 0
	xchg			;return with buffer pointer in HL
	ret
; altSkew - Perform Altair skew on the sector number in secNum and return
;    the result in A. The skew is based on the track as:
;	Tracks 0-5, secOut = secIn
;	Tracks 6-76, secOut = (secIn * 17) MOD 32
;    The skew computation for tracks 6-76 is implemented as:
;	secOut = secIn if secIn is even
;	secOut = secIn XOR 10h if secIn is odd
; On Entry
;    trkNum = current track
;    secNum = sector number (0-31)
; On Exit
;    A = sector number after Altair skew
;    Clobbers A,B
altSkew	equ	$
   if MINIDSK
	lda	secNum		;no skewing done for mini disk
	ret
   endif
   if NOT MINIDSK
	cpi	DATATRK
	lda	secNum		;A=unmodified sector number
	rc			;system track, no change to sector
	mov	b,a		;save secNum in B
	rrc			;test for even/odd
	mov	a,b		;restore secNum in A
	rnc			;return with secNum if even
	xri	10h		;else translate as in comments above
	ret
   endif
; readTrk- read full track into track buffer if the requested
;    drive (drvNum) or track (trkNum) does not match the buffered
;    drive (bfDrive) or buffered track (bfTrack). The status byte
;    at the start of each sector is set to zero if the sector is
;    good, non-zero if the sector couldn't be read.
; On Entry
;    bfDrive = drive from which trkBuf was filled
;    bfTrack = track from which trkBuf was filled
; On Exit
;    trkNum on drvNum read into trkBuf
;    Zero true if track read or already there, zero false otherwise
;    Clobbers all
readTrk	lhld	bfDrive		;L=buffered drive, H=buffered track
	lda	drvNum		;A=requested drive
	cmp	l		;same drive buffered?
	jnz	rtNew		;drive doesn't match, need a new buffer
	lda	trkNum		;A=requested track
	cmp	h		;same track buffered?
	rz			;yes, already have this buffer
; rtNew - New track needs to be read
rtNew	mvi	a,UNDEF		;invalidate buffered data
	sta	bfDrive
	call	dSelDrv		;select drive, load head
	rnz			;drive select failed, exit with error
	mvi	a,2		;init restore/seek try counter
	sta	skRetry
rtRtry	call	dSeek		;seek to trkNum (disables interrupts)
	rnz			;a restore was required and failed
	call	initTrk		;init all sectors to "bad" (not read)
	lxi	d,RDTRIES*NUMSEC*256 + NUMSEC
				;D=max sector reads = RDTRIES revolutions
				;E=sectors remaining to fill
; Read sector loop - All sectors are originally marked "bad" (unread) and
;    a sector counter in E is started at NUMSEC (a full track of sectors).
;    Sectors are read until sector counter E reaches zero or the total
;    reads counter in D reaches zero (RDTRIES revolutions). The 1st time
;    the total reads counter reaches zero, a restore and re-seek is
;    performed in case we're on the wrong track. The second time it reaches
;    zero, the bad sectors remain marked as bad in the track buffer.
; Within dRead, 152 cycles execute after the last byte is read until we're
;    executing the instruction here following the dRead call. An additional
;    78 cycles are executed here until we're in dNxtSec looking for sector
;    true. This totals 230 cycles (115us) from the last byte read until
;    we're hunting for sector true. Allowing for 200us of index alignment
;    error and 10% speed variance, we have at least 180us to get this done.
; For the Mini Disk, a full track is 16 sectors instead of 32 and the time
;    available after a sector is read is well over 1000us, so timing is not
;    an issue.
rdLoop	call	dNxtSec		;(17) wait for next sector, HL->sector buf
	mov	a,m		;A=sector flag byte
	ora	a		;this sector already read?
	jz	rdNext		;yes, skip it
	push	h		;save sector address
	inx	h		;HL->1st read location in sector
	call	dRead		;read the sector
	pop	h		;(10) restore sector address in HL
	jnz	rdNext		;(10) read error
	xra	a		;(4) set sector flag to zero (good sector)
	mov	m,a		;(7)
	dcr	e		;(5) decrement sectors left to fill
	jz	rtExit		;(10) all sectors read without error
rdNext	dcr	d		;(5) decrement total sectors counter
	jnz	rdLoop		;(10) go read next sector
	lxi	h,skRetry	;HL->seek retry counter
	dcr	m		;decrement the counter
	jz	rtExit		;re-seek(s) done, we're finished
	call	dRestor		;restore to track zero
	jz	rtRtry		;start over after the re-seek
	ret			;else, exit with error
rtExit	lhld	drvNum		;L=drvNum, H=trkNum
	shld	bfDrive		;set the buffered drive and track values
	ret			;exit with Z flag true
; initTrk - Set the flag byte in each sector in trkBuf to "bad" to
;    indicate none of the sectors have been read.
; On Entry
; On Exit
;    All sectors in trkBuf marked "bad" (unread)
;    Clobbers all
initTrk	lxi	b,UNDEF*256 + NUMSEC;  B=UNDEF (bad), C=NUMSEC
	lxi	h,trkBuf	;HL->track buffer
	lxi	d,TSECLEN	;DE=length of each sector in track buffer
itLoop	mov	m,b		;mark sector as bad (not read)
	dad	d		;HL->next sector in trkBuf
	dcr	c		;repeat for all sectors
	jnz	itLoop
	ret
; ckFlush - Check if track buffer should be flushed. This
;    function must be called before any drive selection or seek
;    operation. The buffer is flushed if the bfDirty flag is
;    set and the drive or track number are different than the
;    buffered track.
; On Entry
;    Drive still selected and on same track as in trkBuf
;    drvNum, trkNum updated for the new I/O call
; On Exit
;    Zero true for no error, zero false if write error occured
;    Clobbers all
ckFlush	lda	bfDirty		;see if track buffer is dirty
	ora	a
	rz			;no, exit with Z set
	lda	drvNum		;A=requested drive number
	cmp	l		;same drive?
	jnz	wrtTrk		;no, flush
	lda	trkNum		;A=requested track number
	cmp	h		;same track?
	rz			;yes, no need to flush
wrtTrk	equ	$
   if MINIDSK
	mvi	a,cRESTMR	;restart motor timeout
	out	DRVCMD
	lda	curDrv		;make sure current drive still enabled
	out	DRVSLCT
   endif
	mvi	e,cWRTEN	;E=write command, normal head current
	mvi	a,42		;tracks 0-42 are normal head current
	cmp	h		;compare 42 - current track
	jnc	wrtInit		;track is 0-42, E is correct
	mvi	e,cWRTEN+cHCSON	;E=write command with reduced current
wrtInit	xra	a		;clear buffer dirty flag
	sta	bfDirty
	mvi	a,WRTRIES	;initialize write retry count
	sta	wrRetry
	di			;disable interrupts
; rtryWrt - Write track retry entry point. Write a full track starting
;    with any sector. Don't write sectors that are flagged as bad.
rtryWrt	mvi	d,NUMSEC	;D=count of sectors to write
	xra	a		;zero the count of sectors actually written
	sta	secCnt
wrtLoop	call	dNxtSec		;(78) wait for next sector, HL->sector buf
	mov	a,m		;(7) check sector flag
	ora	a		;(4)
	jnz	wrtNext		;(10) skip if bad or previously verified
	mov	a,e		;(5) issue write command to drive
	out	DRVCMD		;(10) at 114 cycles 57us
	inx 	h		;point to 1st byte of sector
	call	dWrite		;write the sector
	lxi	h,secCnt	;count number of sectors written
	inr	m
wrtNext	dcr	d		;decrement write sector count
	jnz	wrtLoop		;loop until all sectors processed
	call	dNxtSec		;force a 1 sector delay for trim erase
	mvi	d,NUMSEC*VFTRIES   ;D=maximum number of sector reads
vfyLoop	call	dNxtSec		;wait for next sector, HL->sector buf
	mov	a,m		;test sector flag, only good and
	ora	a		;   not previously verified sectors
	jnz	vfyNext		;   are verified
	push	h		;save pointer to sector flag
	call	dVerify		;verify the sector
	pop	h		;HL->sector flag for current sector
	jnz	vfyNext		;didn't match
	mvi	m,UNDEF		;set flag to indicate sector is verified
	lxi	h,secCnt	;HL->sectors left to verify
	rz			;track verified, exit
vfyNext	dcr	d		;decrement sector count
	jnz	vfyLoop		;loop until all verify tries expired
; Read re-tries expired, decrement the write retry count and write again
	lxi	h,wrRetry	;decrement the write retry counter
	dcr	m
	jnz	rtryWrt		;retry starting with the write
	call	?pMsg
	db	CR,LF,'Delayed Write Error', CR, LF, 0
	inr	a
	ret			;exit with 1 for error
; Altair disk I/O routines
; dSelDrv - Select the drive specified in drvNum and load the head.
;    Save the track (curTrk) the current drive is on into the track table,
;    load curTrk for the new drive from the track table.
; On Entry
;    drvNum = drive to be selected
;    curDrv = drive currently selected
;    selTime = timeout in seconds to wait for drive select
;    curTrk = track the current drive is on
; On Exit
;    Drive selected and head loaded
;    curDrv = drvNum
;    curTrk = track the newly selected drive is on
;    Zero true for success, zero false for error
;    Clobbers all
dSelDrv	equ	$
   if MINIDSK
	out	DRVCMD
   endif
	lxi	h,curDrv	;HL->currently selected drive
	mov	e,m		;E=currently selected drive
	lda	drvNum		;A=desired drive
	mov	c,a		;save new drive in C
	cmp	e		;same or different drive?
	jnz	dNewDrv		;different, go select a new drive
	in	DRVSTAT		;drive still selected and enabled?
	ani	sDSKEN
	jz	dSelExt		;yes, exit
	jmp	dReSel		;otherwise, re-select the drive
; dNewDrv - Save current track (curTrk) for the current drive to the track
;    table, load curTrk for the new drive from the track table
dNewDrv	mov	m,c		;save new drive in curDrv
	mvi	d,0		;DE=currently selected drive
	lxi	h,trkTbl	;HL->track table
	dad	d		;HL->trkTbl entry for current drive
	lda	curTrk		;A=track current drive is on
	mov	m,a		;save it in the track table
	mov	e,c		;DE=offset in trkTbl for new drive
	dad	d		;HL->trkTbl for new drive
	mov	a,m		;A=track new drive is on
	sta	curTrk		;update current track
; Select the new drive with the timeout specified in selTime
dReSel	lxi	h,selTime	;move select timeout in seconds into B
	mov	b,m
dSelLp1	lxi	h,25641		;HL=count of 78 cycle loops for 1 second
dSelLp	mvi	a,cDSLCT	;(7) deselect a possibly attached drive
	out	DRVSLCT		;(10)
	mov	a,c		;(5) A=drive to select
	out	DRVSLCT		;(10) select it
	in	DRVSTAT		;(10) did drive select work?
	ani	sDSKEN		;(7)
	jz	dSelExt		;(5) yes, exit
	dcx	h		;(5) decr 1 sec counter
	mov	a,h		;(5) test HL counter for zero
	ora	l		;(4)
	jnz	dSelLp		;(10) loop for one second
	dcr	b		;decrement seconds expired
	jnz	dSelLp1		;repeat for a new 1 second
	inr	a		;timeout, return non-zero
	ret
dSelExt	mvi	a,cHDLOAD	;issue head load command
	out	DRVCMD		;restarts timeout for mini disk
	ret			;return with zero status
; dSeek - Seek to track in trkNum
; On Entry
;    Drive selected and ready
;    trkNum = desired track
;    curTrk = current track, UNDEF means we don't know
; On Exit
;    curTrk = trkNum
;    Interrupts disabled
;    Zero true for success, zero false for failure
;	(failure is a failed restore to track zero)
;    Clobbers A,B,C,H,L
dSeek	di			;disable interrupts
	lda	curTrk		;A=current track
	cpi	UNDEF		;valid track number?
	jnz	dTrkVld		;yes, track is valid
	call	dRestor		;otherwise, restore to track zero
	rnz			;exit if restore failed
; dTrkVld - Current track is valid, compute direction and number
;     of steps
dTrkVld	lxi	h,trkNum	;HL->trkNum
	sub	m		;A=current-requested
	rz			;return if already on correct track
	mvi	b,cSTEPO	;B=step out (assume requested<current)
	jnc	dDoSeek		;it is
	mvi	b,cSTEPI	;B=step in (requested>current)
	cma			;compute A=-A
	inr	a
; Save target track in curTrk, step there, then verify track
dDoSeek	mov	c,a		;C=number of steps
	mov	a,m		;save new track in curTrk
	sta	curTrk
	call	dStep		;do the seek
	xra	a		;return zero
	ret
; dRestor - Restore to track 0 and then delay to ensure any subsequent
;    seek meets the minimum direction change period.
; On Entry
; On Exit
;    If successful
;       curTrk = 0
;	A=0
;	Zero true
;    else
;       curTrk = UNDEF
;       Zero false
;    Clobbers A,B,C
dRestor	xra	a
	sta	curTrk		;set current drive track to zero
	in	DRVSTAT		;test for track 0
	ani	sTRACK0
	rz			;at track 0, exit
; Step in three tracks, then step out to track 0
	mvi	c,3		;C=step in 3 tracks
	mvi	b,cSTEPI	;B=step in command
	call	dStep		;do 3 steps in
	mvi	a,20		;20ms delay puts us past the 1ms step window
	call	delayMs		;  and ensures proper dir change delay
; Seek back out until track 0 detected
	mvi	c,NUMTRK+10	;C=maximum number of step outs to try
	mvi	b,cSTEPO	;B=step out command
	call	dStep		;step until track 0 detected
	jnz	drFail		;restore failed
drFail	mvi	a,UNDEF		;restore failed, track is still undefined
	sta	curTrk
	ret			;return with non-zero
; dStep - Step head number of steps in C, direction command in B.
;   If track zero is detected during a step-out operation, curTrk
;   is forced to zero and zero is returned in A.
; On Entry
;    C = number of steps > 0
;    B = step command (cSTEPO or cSTEPI)
; On Exit
;    If stepping out and track zero hit
;	curTrk = 0
;	A = 0
;	Zero true
;    else
;	Zero false
;    Clobbers A,B,C
dStep	in	DRVSTAT		;loop until OK to move the head
	ani	sMOVEOK
	jnz	dStep
	in	DRVSTAT		;see if we are at track 0
	ani	sTRACK0		;at track zero?
	jnz	dStep1		;no, go on
	mov	a,b		;stepping out?
	sbi	cSTEPO
	jz	dStep0		;yes, we've hit track 0
dStep1	mov	a,b		;A=step command and direction
	out	DRVCMD		;issue the step
	dcr	c		;decrement step counter
	jnz	dStep		;loop until count reaches zero
	inr	c		;force non-zero
	ret
dStep0	sta	curTrk		;curTrk=0
	ret			;return with zero true and A=0
; dNxtSec - Wait for next (any) sector. Returns pointer to the sector
;    buffer within trkBuf. Control is back to caller at 78 cycles (39us).
; On Entry
;    Drive is selected, head loaded
; On Exit
;    HL->sector buffer in trkBuf for sector found
dNxtSec	equ	$
   if MINIDSK
	out	DRVCMD
   endif
dnLoop	in	DRVSEC		;read sector position register
	rar			;wait for sector true (0=true)
	jc	dnLoop
	ani	SECMASK		;(7) get sector number alone
				;fall into dSecAdr
; dSecAdr - Convert hard sector in A to address within trkBuf for
;    the specified sector
; On Entry
;    A = Hard sector number
; On Exit
dSecAdr	lxi	h,secAddr  	;(10) HL->sector address table
	mvi	b,0		;(7) form BC=sector*2
	rlc			;(4) A=sector*2 (2 bytes per table entry)
	mov	c,a		;(5) BC=sector*2
	dad	b		;(10) HL->address table entry for passed sector
	mov	a,m		;(7) A=lsb of sector buffer address
	inx	h		;(5)
	mov	h,m		;(7) H=msb of sector buffer address
	mov	l,a		;(5) HL->sector buffer
	ret			;(11)
; delayMs - Delay for number of ms specified in A
; On Entry
;    A = ms to delay
; On Exit
;    A=0
;    Zero true
;    Clobbers A,B
delayMs	mvi	b,(2000/19)	;19 cycles in the loop below
delayLp	nop			;(4)
	dcr	b		;(5)
	jnz	delayLp		;(10)
	dcr	a		;decrement ms counter
	jnz	delayMs
	ret
; dRead - Read a sector, verify checksum, stop byte, and track number.
;    Verification is done after the sector is read in the time between
;    the last byte of the sector and before the start of the next sector.
;    With index alignment and rotation speed tolerance accounted for,
;    we safely have 360 cycles from the last byte of the sector until code
;    should be in the sector true hunt loop. The RET is complete from this
;    routine 152 cycles worst case after the last byte is read.
; On Entry
;    Drive is selected, sector true just detected
;    HL->sector buffer
; On Exit
;    Sector read to (HL)
;    C = track number from disk with sync bit set
;    Zero true if no error, Zero false for checksum error, missing
;	FF stop byte, or track number error
dRead	push	h		;(11) save pointer to start of sector
	lxi	b,256+DSECLEN	;(10) B=chksum (-FF), C=bytes to read
	lda	curTrk		;(13) A=track we're on
	cpi	DATATRK		;(7) data track or system track?
	jnc	drSecWt		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) C=length of a system sector
; The sector transfer loop is 116 cycles for two bytes read (has to be
;     less than 128) and computes checksum over all bytes read. For the
;     mini disk, only one byte is read per loop iteration.
drSecWt	in	DRVSTAT		;(10) get drive status byte
	ora	a		;(4) wait for NRDA flag true (zero)
	jm	drSecWt		;(10)
   if NOT MINIDSK		;8" reads two bytes per loop
	in	DRVDATA		;(10) read first byte at 24-48 cycles
	mov	m,a		;(7) store in buffer
	add	b		;(4) update checksum
	mov	b,a		;(5) keep checksum in B
	inx	h		;(5) increment buffer pointer
	dcr	c		;(5) decrement byte count
	jz	drSecDn		;(10) exit if done
   endif
	in	DRVDATA		;(10) read at 70-94 cycles (data at 64 and 128)
	jnz	drSecWt		;(10) repeat until done
; drSecDn - Sector read is complete, now validate the sector based on whether
;   it is from a system track or data track.
drSecDn	lda	curTrk		;(10) A=track we're supposed to be on
	cpi	DATATRK		;(7) system or data track?
	jnc	drDatTk		;(10) data track
; Validate a system track sector. A system track sector is three bytes
;    bytes shorter, so this codes starts 3*64 cycles sooner than for a
;    data sector. This code completes before a data sector would even
;    finish reading. Therefore, a data sector is the worst timing path.
	mov	a,b		;(5) A=calculated checksum over all bytes
	dcx	h		;(5) HL->checksum in sector
	sub	m		;(7) subtract from computed checksum
	sub	m		;(7) final sum will be zero
	dcx	h		;(5) HL->stop byte
	mov	b,m		;(7) B=stop byte
	pop	h		;(10) restore HL->start of buffer
	inr	b		;(4) was FF stop byte there?
	rnz			;(5/11) no, return error
	mov	c,m		;(7) C=track number from disk
	sub	c		;(4) take track out of checksum
	inx	h		;(5) HL->2nd byte of sector
	sub	m		;(7) take out of checksum
	inx	h		;(5) HL->3rd byte of sector
	jmp	drExit		;(10) do common compares and exit
; Validate a data track sector (125 + 27 cycles for sector type jump)
drDatTk	dcx	h		;(5) HL->stop byte
	mov	a,m		;(7) A=stop byte
	inr	a		;(4) was FF stop byte there?
	inx	h		;(5) HL->sector number
	inx	h		;(5) move to checksum byte
	inx	h		;(5)
	inx	h		;(5) HL->checksum
	sub	m		;(7) subtract from checksum
drExit	sub	m		;(7) checksums match?
	rnz			;(5/11) no, exit with error
	lda	curTrk		;(10) A=track we should be on
	ori	80h		;(7) set sync bit
	cmp	c		;(4) same track as from sector?
	ret			;(11) exit with compare status
; dVerify - Verify a sector
;    The 2nd read at 67 cycles only gives 3 cycles of headroom (67-64)
;    which, in turn, gives about 4% speed tolerance. However, we are
;    verifying our  own write, so the primary tolerance issue is ISV,
;    not the average rotation rate, so tolerance is still within the
;    +/-1.5% ISV spec.
; On Entry
;    HL->sector buffer to compare against
; On Exit
;    Zero true if match, zero false for error
dVerify lxi	b,DSECLEN	;(10) B=0, C=data sector length
	jnc	dVfLoop		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) set C=length of a system sector
dVfLoop	in	DRVSTAT		;(10) get drive status byte
	jm	dVfLoop		;(10)
	xra	m		;(4) verify data matches buffer
	ora	b		;(4) accumulate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement characters remaining counter
	jz	dVfDone		;(10) done verifying bytes
   endif
	in	DRVDATA		;(10) read 2nd byte at 67-91 cycles
	ora	b		;(4) accumlate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement byte counter
	jnz	dVfLoop		;(10) loop for all bytes
dVfDone	ora	a		;A=zero if all bytes matched
	ret			;return status
; dWrite - Write a sector
;    The write loop is 61 cycles which gives just 3 cycles (64-61) of
;    headroom. However, since the write timing required by the FDC board
;    is derived from the 2 MHz CPU/bus clock, this loop is always exactly
;    in sync with the FDC write timing. 3 cycles of headroom is plenty.
; On Entry
;    Drive is selected, sector true just detected, and
;	the write command has already been issued
;    HL->sector buffer to write
; On Exit
;   Clobbers A,C,H,L
dWrite	mvi	c,DSECLEN	;C=number of bytes to write
	jnc	dWrLoop		;(10) data track, length in C is correct
dWrLoop	in	drvStat		;(10) read drive status register
	rrc			;(4) wait for ENWD flag (zero)
	jc	dWrLoop		;(10)
	mov	a,m		;(7) A=next byte to write
	out	drvData		;(10) write 2nd byte at 68-92 cycles
	dcr	c		;(5) decrement bytes remaining
	jnz	dWrLoop		;(10) loop until all bytes written
dWrDone	in	drvStat		;wait for another write flag
	rrc
	jc	dWrDone
	xra	a		;write a trailing zero
	out	drvData
	ret
;   BIOS Data Area
; secAddr - Sector address table. Returns sector buffer address within
;    the track buffer when indexed by hard sector number. Each sector
;    requires TSECLEN bytes.
secAddr	dw	trkBuf+00*TSECLEN,trkBuf+01*TSECLEN,trkBuf+02*TSECLEN
	dw	trkBuf+03*TSECLEN,trkBuf+04*TSECLEN,trkBuf+05*TSECLEN
	dw	trkBuf+06*TSECLEN,trkBuf+07*TSECLEN,trkBuf+08*TSECLEN
	dw	trkBuf+09*TSECLEN,trkBuf+10*TSECLEN,trkBuf+11*TSECLEN
	dw	trkBuf+12*TSECLEN,trkBuf+13*TSECLEN,trkBuf+14*TSECLEN
	dw	trkBuf+15*TSECLEN
   if NOT MINIDSK
	dw	trkBuf+16*TSECLEN,trkBuf+17*TSECLEN,trkBuf+18*TSECLEN
	dw	trkBuf+19*TSECLEN,trkBuf+20*TSECLEN,trkBuf+21*TSECLEN
	dw	trkBuf+22*TSECLEN,trkBuf+23*TSECLEN,trkBuf+24*TSECLEN
	dw	trkBuf+25*TSECLEN,trkBuf+26*TSECLEN,trkBuf+27*TSECLEN
	dw	trkBuf+28*TSECLEN,trkBuf+29*TSECLEN,trkBuf+30*TSECLEN
	dw	trkBuf+31*TSECLEN
   endif
; Initialized data
selTime	db	7		;drive select timeout in seconds
coldSt	db	0FFh		;FF during cold start, 0 otherwise
curDrv	db	0		;drive number currently selected
curTrk	db	UNDEF		;track the selected drive is on
trkTbl	db	UNDEF,UNDEF,UNDEF,UNDEF		;track each drive is on
bfDirty	db	0		;non-zero if buffer has been written to
bfDrive	db	UNDEF		;drive currently in track buffer
bfTrack	db	UNDEF		;currently buffered track (MUST follow bfDrive)
; Non-initialized data
drvNum	ds	1		;drive number from CP/M call
trkNum	ds	1		;track number from CP/M call (MUST follow drvNum)
secNum	ds	1		;sector number from CP/M call
dmaAddr	ds	2		;dma address for disk operations from CP/M call
secCnt	ds	1		;count of bad sectors remaining in trkBuf
wrRetry	ds	1		;write retry counter
skRetry	ds	1		;restore and seek retry counter
;  Disk scratchpad areas defined in the DPH table
dirBuf	ds	128		;BDOS directory scratchpad
alv0	ds	(DSM/8 + 1)	;allocation vector storage
csv0	ds	CKS		;change disk scratchpad
alv1	ds	(DSM/8 + 1)
csv1	ds	CKS
; Track buffer. One extra byte is allocated at the start of each sector
;    to flag a bad sector (read failure). This byte is zero if the sector
;    is good, non-zero if the sector is bad.
trkBuf	ds	NUMSEC*TSECLEN
	end
IDE3.asm
	TITLE	'CPM3 module for IDE drive.'
;INCLUDE CP/M 3.0 DISK DEFINITION MACROS:
MACLIB	CPM3
;INCLUDE Z-80 MACRO LIBRARY:
MACLIB	Z80
;Ports for 8255 chip. Change these to specify where the 8255 is addressed,
;and which of the 8255's ports are connected to which IDE signals.
;The first three control which 8255 ports have the control signals,
;upper and lower data bytes.  The last one is for mode setting for the
;8255 to configure its ports, which must correspond to the way that
;the first three lines define which ports are connected.
IDEportA	EQU	030H		;lower 8 bits of IDE interface
IDEportB	EQU	031H		;upper 8 bits of IDE interface
IDEportC	EQU	032H		;control lines for IDE interface
IDEportCtrl	EQU	033H		;8255 configuration port
READcfg8255	EQU	10010010b	;Set 8255 IDEportC out, IDEportA/B input
WRITEcfg8255	EQU	10000000b	;Set all three 8255 ports output
;IDE control lines for use with IDEportC.  Change these 8
;constants to reflect where each signal of the 8255 each of the
;IDE control signals is connected.  All the control signals must
;be on the same port, but these 8 lines let you connect them to
;whichever pins on that port.
IDEa0line	EQU	01H	;direct from 8255 to IDE interface
IDEa1line	EQU	02H	;direct from 8255 to IDE interface
IDEa2line	EQU	04H	;direct from 8255 to IDE interface
IDEcs0line	EQU	08H	;inverter between 8255 and IDE interface
IDEcs1line	EQU	10H	;inverter between 8255 and IDE interface
IDEwrline	EQU	20H	;inverter between 8255 and IDE interface
IDErdline	EQU	40H	;inverter between 8255 and IDE interface
IDErstline	EQU	80H	;inverter between 8255 and IDE interface
;Symbolic constants for the IDE Drive registers, which makes the
;code more readable than always specifying the address pins
REGdata		EQU	IDEcs0line
REGerr		EQU	IDEcs0line + IDEa0line
REGseccnt	EQU	IDEcs0line + IDEa1line
REGsector	EQU	IDEcs0line + IDEa1line + IDEa0line
REGcylinderLSB	EQU	IDEcs0line + IDEa2line
REGcylinderMSB	EQU	IDEcs0line + IDEa2line + IDEa0line
REGshd		EQU	IDEcs0line + IDEa2line + IDEa1line		;(0EH)
REGcommand	EQU	IDEcs0line + IDEa2line + IDEa1line + IDEa0line	;(0FH)
REGstatus	EQU	IDEcs0line + IDEa2line + IDEa1line + IDEa0line
REGcontrol	EQU	IDEcs1line + IDEa2line + IDEa1line
REGastatus	EQU	IDEcs1line + IDEa2line + IDEa1line + IDEa0line
;IDE Command Constants.  These should never change.
COMMANDrecal	EQU	10H
COMMANDread	EQU	20H
COMMANDwrite	EQU	30H
COMMANDinit	EQU	91H
COMMANDid	EQU	0ECH
COMMANDspindown	EQU	0E0H
COMMANDspinup	EQU	0E1H
MAXSEC		EQU	3FH
; IDE Status Register:
;  bit 7: Busy	1=busy, 0=not busy
;  bit 6: Ready 1=ready for command, 0=not ready yet
;  bit 5: DF	1=fault occured insIDE drive
;  bit 4: DSC	1=seek complete
;  bit 3: DRQ	1=data request ready, 0=not ready to xfer yet
;  bit 2: CORR	1=correctable error occured
;  bit 1: IDX	vendor specific
;  bit 0: ERR	1=error occured
; Console ASCII equates
BELL	EQU	07H
CR	EQU	0DH
LF	EQU	0AH
	PUBLIC	DPH2, DPH3		;IDE DRIVE PARAMETER HEADERS
	EXTRN	@ADRV,@RDRV
	EXTRN	@CBNK
					; [BC] AND [DE]
	; EXTENDED DISK PARAMETER HEADER FOR IDE DRIVE 0:
	DW	HDWRT		;IDE Drive Write
	DW	HDRD		;IDE Drive Read
	DW	HDLOGIN		;IDE Login
	DW	HDINIT		;IDE Init
	DB	0		;Controller drive number
	DB	0		;Media Type
DPH2:	DPH	0,IDEHD$DPB,0,
	; EXTENDED DISK PARAMETER HEADER FOR IDE DRIVE 1:
	DW	HDINIT		;IDE Init
	DB	0		;Media Type
DPH3:	DPH	0,IDEHD$DPB,0,
	; MAKE SURE DPB'S ARE IN COMMON MEMORY:
	CSEG
	; 512 BYTE SECTORS ON HARD DISK (512 X 64 X 256 = 8,388,608 Bytes)
IDEHD$DPB:
	DPB	512,64,256,2048,1024,1,8000H	;2048 allocation unit size, 1024 directory entries
; IDE Initialization / Login
HDINIT:	RET
HDLOGIN:				;Initialize the 8255 and drive then do a hard reset
	MVI	A,READcfg8255
	OUT	IDEportCtrl		;Config 8255 chip, READ mode
	MVI	A,IDErstline
	OUT	IDEportC
	MVI	B, 20H
ResetDelay:
	DCR	B
	JNZ	ResetDelay		;Delay (reset pulse width)
	XRA	A
	OUT	IDEportC		;No IDE control lines asserted (just bit 7 of port C)
	CALL	DELAY$32
	MVI	D, 11100000b		;LBA Mode
	MVI	E, REGshd
	CALL	IDEwr8D			;Write byte to select the MASTER device
	MVI	B, 0FFH		;Delay time
WaitInit:
	MVI	E, REGstatus	;Get status after initilization
	CALL	IDErd8D		;Check Status (info in [D])
	BIT	7, D
	JZ	DoneInit	;Return if ready bit is zero
				;Delay to allow drive to get up to speed
	PUSH	B
	LXI	B, 0FFFFH
DELAY2:	MVI	D, 2		;May need to adjust delay time to allow cold drive to
DELAY1:	DCR	D		;to speed
	JNZ	DELAY1
	DCX	B
	MOV	A,C
	ORA	B
	JNZ	DELAY2
	POP	B
	DJNZ	WaitInit
	CALL	SetErrorFlag	;Ret with NZ flag set if error (probably no drive)
	LXI	H, MSG$INIT$ERR	;RESTORE FAILED
	CALL	?PMSG
	ORI	1
	RET
DoneInit:
	XRA	A		;RETURN WITH NO ERROR
	RET
; SECTOR WRITE ROUTINE
HDWRT:	XRA	A
	STA	ERFLG
	CALL	wrlba		;Send to drive the sector we want to read. Converting
				;CPM TRK/SEC info to Drive TRK/SEC/Head
				;send before error check so info is updated
	CALL	IDEwaitnotbusy	;make sure drive is ready
	JC	SetErrorFlag
	MVI	D, COMMANDwrite
	MVI	E, REGcommand
	CALL	IDEwr8D		;tell drive to write a sector
	CALL	IDEwaitdrq	;wait unit it wants the data
	JC	SetErrorFlag	;If problem abort
	LHLD    @DMA		;DMA address
	MVI	A, WRITEcfg8255
	OUT	IDEportCtrl
	MVI	B,0		;256X2 bytes
WRSEC1:	MOV	A, M
	INX	H
	OUT	IDEportA	;LOW byte on A first
	MOV	A, M
	INX	H
	OUT	IDEportB	;then HIGH byte on B
	MVI	A, REGdata
	PUSH	PSW
	OUT	IDEportC	;Send write command
	ORI	IDEwrline	;Send WR pulse
	OUT	IDEportC
	POP	PSW
	OUT	IDEportC
	DJNZ	WRSEC1
	MVI	A, READcfg8255	;Set 8255 back to read mode
	OUT	IDEportCtrl
CHECK$RW:
	MVI	E, REGstatus	;Check R/W status when done
	CALL	IDErd8D
	MOV	A, D
	ANI	01H
	STA	ERFLG		;Ret Z if All OK
	RZ
SetErrorFlag:			;For now just return with error flag set
	XRA	A
	DCR	A
	STA	ERFLG		;Ret NZ if problem
	RET
; SECTOR READ ROUTINE
HDRD:	XRA	A
	STA	ERFLG	     	;CLEAR THE ERROR FLAG
				;Send before error check so info is updated
	JC	SetErrorFlag	;Returned with NZ set if error
	MVI	D, COMMANDread
	MVI	E, REGcommand
	CALL	IDEwr8D		;Send sec read command to drive.
	CALL	IDEwaitdrq	;Wait until it's got the data
	MVI	B, 0
MoreRD16:
	MVI	A,REGdata	;REG regsiter address
	OUT	IDEportC
	ORI	IDErdline	;08H+40H, Pulse RD line
	OUT	IDEportC
	IN	IDEportA	;READ  the LOW byte first
	MOV	M, A
	INX	H
	IN	IDEportB	;THEN the HIGH byte
	MOV	M,A
	INX	H
	MVI	A, REGdata	;Deassert RD line
	OUT	IDEportC
	DJNZ	MoreRD16
	JMP	CHECK$RW
; SUPPORT ROUTINES
wrlba:				;Write the logical block address to the drive's registers
	CALL	IDEwaitnotbusy	;Make sure drive isn't busy
	LHLD	@TRK		;Get the CP/M requested track High & Low
	MOV	A, L		;Get Low byte of track
	RRC			;Get bottom two bits in high bits of A
	RRC
	ANI	0C0H		;Just what were the bottom two bits (now at the top)
	MOV	C, A		;Save in C
	LDA	@SECT		;Sector number in A
	ANI	03FH		;Take only bottom 6 bits
	ORA	C		;Add in top 2 bits of track
	MOV	D, A		;Send info to the drive
	MVI	E, REGsector
	CALL	IDEwr8D
	MOV	A, L		;Get low byte of track again
	RRC
	RRC
	ANI	03FH
	MOV	C, A		;Save in C
	MOV	A, H		;Get high byte of track.
	RRC			;Rotate twice, leaving low 2 bits
	RRC			;In upper bits of A
	ANI	0C0H		;Mask all but the two bits we want
	ORA	C		;Add in the top 6 bits of the first track byte
	MOV	D, A		;Send Low TRK#
	MVI	E, REGcylinderLSB
	CALL	IDEwr8D
	RRC			;Just the top 6 bits
	RRC
	ANI	03FH
	MOV	D, A		;Send High TRK#
	MVI	E, REGcylinderMSB
	CALL	IDEwr8D
	MVI	D, 1		;One sector at a time
	MVI	E, REGseccnt
	CALL	IDEwr8D
	RET
IDEwaitnotbusy:			;Drive READY if 01000000
	MVI	B, 0FFH
	MVI	C, 0FFH		;Delay, must be above 80H. Leave longer for slower drives
MoreWait:
	MVI	E, REGstatus	;Wait for RDY bit to be set
	CALL	IDErd8D
	MOV	A, D
	ANI	11000000B
	XRI	01000000B
	JZ	DoneNotbusy
	DJNZ	MoreWait
	DCR	C
	JNZ	MoreWait
	STC			;Set carry to indicqate an error
	ret
DoneNotBusy:
	ORA	A		;Clear carry it indicate no error
	RET
IDEwaitdrq:
	MVI	B, 0FFH
MoreDRQ:
	MVI	E, REGstatus	;Wait for DRQ bit to be set
	CALL	IDErd8D
	MOV	A, D
	ANI	10001000B
	CPI	00001000B
	JZ	DoneDRQ
	DJNZ	MoreDRQ
	DCR	C
	JNZ	MoreDRQ
	STC			;Set carry to indicate error
	RET
DoneDRQ:
	ORA	A		;Clear carry
	RET
DELAY$32: MVI	A, 40		;DELAY ~32 MS (DOES NOT SEEM TO BE CRITICAL)
DELAY3:	MVI	B, 0
M0:	DJNZ	M0
	DCR	A
	JNZ	DELAY3
	RET
; Low Level 8 bit R/W to the drive controller.  These are the routines that talk
; directly to the drive controller registers, via the 8255 chip.
; Note the 16 bit I/O to the drive (which is only for SEC R/W) is done directly
; in the routines HDRD & HDWRT for speed reasons.
IDErd8D:				;READ 8 bits from IDE register in [E], return info in [D]
	MOV	A, E
	OUT	IDEportC		;drive address onto control lines
	ORI	IDErdline		;RD pulse pin (40H)
	OUT	IDEportC		;assert read pin
	IN	IDEportA
	MOV	D, A			;return with data in [D]
	MOV	A, E
	OUT	IDEportC		;deassert RD pin first
	XRA	A
	OUT	IDEportC		;Zero all port C lines
	RET
IDEwr8D:				;WRITE Data in [D] to IDE register in [E]
	MVI	A, WRITEcfg8255		;Set 8255 to write mode
	OUT	IDEportCtrl
	MOV	A, D			;Get data put it in 8255 A port
	OUT	IDEportA
	MOV	A, E			;select IDE register
	OUT	IDEportC
	ORI	IDEwrline		;lower WR line
	OUT	IDEportC
	MOV	A, E
	OUT	IDEportC		;deassert WR pin first
	XRA	A			;Deselect all lines including WR line
	OUT	IDEportC
	MVI	A, READcfg8255		;Config 8255 chip, read mode on return
	OUT	IDEportCtrl
	RET
MSG$INIT$ERR DB	'Initilization of IDE drive failed.',CR,LF,0
ERFLG:		DB	0H
Wayne Parham wrote:That worked. I replaced the DJNZ instruction in MoreRD16 with the following:
DCR B
JNZ MoreRD16
The IDE identification struct defines a larger byte array for the name, so I'll probably increase that. But the function to iterate through the data buffer on the IDE device works. So sector reads should work too.
Next I'll find all other occurrences of DJNZ and change them to this two-instruction method. Probably do a little bit of cleanup too. Then I'll have IDE code that works on the Altair!
Once that's done, I'll be sure to post it here in this thread.
Is there a S-100 bus Z-80 board replica we can build that works with a front panel (not all do)? Many people prefer the Z-80 over the 8080. I use MITS BASIC so I can't use a Z-80 but it's still nice to have options.
Not sure. I have the original 8080 CPU in mine. Well, actually, I have Kaufman's 8080 CPU PCB.
I think I see one problem with the code I posted above. I didn't see it until I posted it here. The Digital Research code uses globals with names like TRK and SECT but Mike's code uses other variable names, like trkNum and secNum. So I need to change all those variables to match.
I updated FLP3.asm to change variables like trkNum and secNum to @TRK and @SECT, as shown below. This time, the boot process didn't display an error, but it didn't finish either. It appears to be stuck trying to read. So I'll run it with the debugger when I get some time to see what's goin' on.
FLP3.asm
TRUE	equ	-1
FALSE	equ	not TRUE
; BDOS equates
; RAM equates
TPA	equ	100h
DFFCB	equ	5Ch
STACK	equ	100h
BDOS	equ	5
; Misc equates
	; DEFINE PUBLIC LABELS:
	EXTRN	@ADRV,@RDRV
	EXTRN	@CBNK
	db	0
	db	0
	db	0		;scratch byte
	dw	0		;track
	dw	0		;sector
	dw	0		;bank
   if MINIDSK
   endif
   if NOT MINIDSK
   endif
fdInit:
	ret
selDsk0:
	jmp	?slDsk
selDsk1:
	jmp	?slDsk
; fdRead - Read sector BIOS entry. Read one sector using the @RDRV,
;    @TRK, @SECT, and @DMA previously specified.
; On Entry
;    @RDRV = drive to read from
;    @TRK  = track to read from
;    @SECT = sector number to read (0-31)
;    @DMA  = address of buffer to read into
; On Exit
;	sector read into @DMA
;	HL = @DMA + CSECLEN
;    Else
;    Clobbers all
fdRead:
	call	movRead		;move sector to @DMA
	rz
	ret
; fdWrite - Write sector BIOS entry. Write one sector using the @RDRV,
;    @TRK, @SECT and @DMA specified.
; On Entry
;    @RDRV = drive to write
;    @TRK  = track to write
;    @SECT = sector number to write (0-31)
;    @DMA  = address of buffer to write from
; On Exit
;    If successful
;	sector written to trkBuf from @DMA
;    Else
;    Clobbers all
fdWrite:
	jmp	movWrt		;move @DMA to sector and exit
; movRead - Move sector data from track buffer to @DMA for a
;    CPM read request
; On Entry
; On Exit
;	sector data moved to @DMA, Z flag set true
;	Z flag set false
;    Clobbers all
	ora	a
	lda	@TRK		;on a data track?
	cpi	DATATRK
	lhld	@DMA		;HL->destination for data
mrLoop	ldax	d		;move sector from trkBuf to @DMA
	mov	m,a
	inx	d
	dcr	b		;loop count
	jnz	mrLoop
; movWrt - Move sector data from @DMA to track buffer and create
; On Entry
; On Exit
;    Sector data moved to trkBuf from @DMA
;    Clobbers all
	inx	h		;HL->track
	lda	@TRK		;A=track
	mov	m,a
	inx	h		;HL->offset 2
	inr	a		;A=1
	mov	m,a
	call	mwMove		;move @DMA to sector in trkBuf
	jmp	mwExit		;exit
wDatTrk	lda	@SECT		;A=sector before Altair skew
	mov	m,a		;offset 2
	inx	h
	inx	h
	inx	h
	inx	h
	sta	bfDirty
	ret
; mwMove - Move sector buffer (128 bytes) from @DMA to (HL) as part
; On Entry
;    @DMA = address of buffer to move from
; On Exit
;    128 bytes moved from @DMA to (HL)
;    HL = HL + 128
;    Clobbers all
	lhld	@DMA		;HL->source buffer
	stax	d
	mov	b,a
	inx	h
	ret
; On Entry
;    @TRK  = current track
;    @SECT = sector number (0-31)
; On Exit
;    Clobbers A,B
altSkew	equ	$
   if MINIDSK
	lda	@SECT		;no skewing done for mini disk
	ret
   endif
   if NOT MINIDSK
	cpi	DATATRK
	lda	@SECT		;A=unmodified sector number
	ret
   endif
;    drive (@RDRV) or track (@TRK) does not match the buffered
; On Entry
; On Exit
;    @TRK on @RDRV read into trkBuf
;    Clobbers all
	lda	@RDRV		;A=requested drive
	lda	@TRK		;A=requested track
	sta	bfDrive
	sta	skRetry
;    an issue.
	mov	m,a		;(7)
rtExit	lhld	@RDRV		;L=@RDRV, H=@TRK
; On Entry
; On Exit
;    Clobbers all
	jnz	itLoop
	ret
;    buffered track.
; On Entry
;    @RDRV, @TRK updated for the new I/O call
; On Exit
;    Clobbers all
	ora	a
	lda	@RDRV		;A=requested drive number
	cmp	l		;same drive?
	lda	@TRK		;A=requested track number
	cmp	h		;same track?
wrtTrk	equ	$
   if MINIDSK
	out	DRVCMD
	out	DRVSLCT
   endif
	sta	bfDirty
	sta	wrRetry
	sta	secCnt
	ora	a		;(4)
	inr	m
	dcr	m
	call	?pMsg
	inr	a
; dSelDrv - Select the drive specified in @RDRV and load the head.
; On Entry
;    @RDRV = drive to be selected
; On Exit
;    curDrv = @RDRV
;    Clobbers all
dSelDrv	equ	$
   if MINIDSK
	out	DRVCMD
   endif
	lda	@RDRV		;A=desired drive
	ani	sDSKEN
	mov	b,m
	out	DRVSLCT		;(10)
	ani	sDSKEN		;(7)
	ora	l		;(4)
	ret
; On Entry
;    @TRK   = desired track
; On Exit
;    curTrk = @TRK
;     of steps
dTrkVld	lxi	h,@TRK		;HL<-@TRK
	jnc	dDoSeek		;it is
	cma			;compute A=-A
	inr	a
	sta	curTrk
	xra	a		;return zero
	ret
; On Entry
; On Exit
;    If successful
;       curTrk = 0
;	A=0
;	Zero true
;    else
;       curTrk = UNDEF
;       Zero false
;    Clobbers A,B,C
dRestor	xra	a
	ani	sTRACK0
	sta	curTrk
; On Entry
; On Exit
;	curTrk = 0
;	A = 0
;	Zero true
;    else
;	Zero false
;    Clobbers A,B,C
	ani	sMOVEOK
	jnz	dStep
	sbi	cSTEPO
	ret
; On Entry
; On Exit
dNxtSec	equ	$
   if MINIDSK
	out	DRVCMD
   endif
	jc	dnLoop
				;fall into dSecAdr
; On Entry
; On Exit
	inx	h		;(5)
	ret			;(11)
; On Entry
;    A = ms to delay
; On Exit
;    A=0
;    Zero true
;    Clobbers A,B
delayLp	nop			;(4)
	dcr	b		;(5)
	jnz	delayLp		;(10)
	jnz	delayMs
	ret
; On Entry
;    HL->sector buffer
; On Exit
	jm	drSecWt		;(10)
   endif
	inx	h		;(5)
;    +/-1.5% ISV spec.
; On Entry
; On Exit
	jm	dVfLoop		;(10)
	mov	b,a		;(5)
   endif
	mov	b,a		;(5)
	ret			;return status
; On Entry
; On Exit
;   Clobbers A,C,H,L
	jc	dWrLoop		;(10)
	rrc
	jc	dWrDone
	out	drvData
	ret
;   BIOS Data Area
   if NOT MINIDSK
   endif
; Initialized data
alv1	ds	(DSM/8 + 1)
csv1	ds	CKS
	end
Quick note:
The BIOS debugging method described in the CP/M 3.0 System guide describes a process of using the debugger to step through BIOS code, loaded using the stand-alone program, CPMLDR.COM.
But CPMLDR is placed on the system tracks (track 0, sector 2) rather than as a stand-alone program. So to do the debugging method prescribed in the CP/M 3.0 System manual, we need to build CPMLDR.COM using the Douglas FDC 330K diskette BIOS code.
The System guide describes this, but I didn't see it at first. So I'm writing this post as a reminder "bread-crumb" to help remember the process for next time.
Mike - I think you're thinking, "Duh" and snickering.
Just consider this a "note to self" and if it's useful for anyone else, that's awesome.
To build a stand-alone CPMLDR.COM for the Douglas FDC+ 330K diskettes, do the following:
Obtain the Douglas CPM3 BIOS.ASM and SCBLDR.ASM files, and the Digital Research CPMLDR.REL file.
RMAC BIOS
RMAC SCBLDR
LINK CPMLDR[L100]=CPMLDR,SCBLDR,BIOS
That creates a CPMLDR.COM file for FDC+ 330K floppies.
I’ve forgotten most of the details of creating CP/M 3, so leaving notes and “bread crumbs” is a very wise idea!
I was able to spend a couple hours working on the BIOS today, and I learned a couple things:
1. The symbolic debugger works, but the symbol table doesn't. So it reports all addresses in hexadecimal rather than referencing them with their labels. Pretty sure that's 'cause the GENCPM utility relocates the code, so the symbol table no longer matches. I considered calculating an offset and applying it but it appears that the BIOS isn't relocated as a block so a single offset wouldn't work. I see some functions are moved more than other functions, so it appears some re-arranging is happening.
2. My code execution goes off the rails in the COM I/O functions, so we're not even getting to the DISK I/O code yet. I misinterpreted the manual, assuming that COM I/O was standardized and would access the Altair 2SIO boards. But that's not the case. So I need to modify the COMIO3.asm file.
Even though the debugger output doesn't include labels, I could identify the functions from the trace. It runs init() in boot3, then tries to print the sign-on message on the console with pmsg() in bioskrn3. That then calls conout() in bioskrn3 which calls co() in chario3. The co() function uses dev$dispatch() in chario3 which selects the device but that's when it hangs.
I have a busy week ahead of me - actually a pretty busy month - so I'm not sure when I'll have time to dig back into this. Probably do a little here and there on occasional weeknights and weekends. I'll report back when I've made some progress.
Here are some notes that include program output.
Breadcrumbs:
Debugging under CP/M:
SID starting address:   AB00 under CP/M 3.0, CC00 under CP/M 2.2
Found by running SID, and then using the L5 command, which shows the following instruction at location 0005:
0005 JMP AB00 (under CP/M 3.0) or
0005 JMP CC00 (under CP/M 2.2)
Build CPM3.SYS like this:
Using BIOSKRN3.asm, SCB3.asm. BOOT3.asm, CHARIO3.asm, MOVE3.asm, DRVTBL3.asm, FLP3.asm and IDE3.flp
RMAC BIOSKRN3
RMAC SCB3
RMAC BOOT3
RMAC CHARIO3
RMAC MOVE3
RMAC DRVTBL3
RMAC FLP3
RMAC IDE3
LINK BIOS3[q,os]=BIOSKRN3,SCB3,BOOT3,CHARIO3,MOVE3,DRVTBL3,FLP3,IDE3
Creates BIOS3.SPR and BIOS3.SYM
(Actually, the "q" switch is probably unnecessary since the symbol table generated is useless)
GENCPM:  A9 or CA for debugging, FE for production
When GENCPM was set for topmem=A9, the floppy-only CPM3.SYS reported this:
CP/M V3.0 Loader
Copyright (C) 1982, Digital Research
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A8D1	(boot)
  8E03  JMP  8E6C	(wboot)
  8E06  JMP  8F72	(const)
  8E09  JMP  8F8D	(conin)
  8E0C  JMP  8ED5	(conout)
  8E0F  JMP  8EE1	(list)
  8E12  JMP  8EDB	(auxout)
  8E15  JMP  8F93	(auxin)
  8E18  JMP  A93F	(home)
  8E1B  JMP  A910	(seldsk)
  8E1E  JMP  A942	(settrk)
  8E21  JMP  A948	(setsec)
  8E24  JMP  A94E	(setdma)
  8E27  JMP  A965	(read)
  8E2A  JMP  A97B	(write)
  8E2D  JMP  8F0D	(listst)
  8E30  JMP  A95A	(sectrn)
  8E33  JMP  8F01	(conost)
  8E36  JMP  8F78	(auxist)
  8E39  JMP  8F07	(auxost)
  8E3C  JMP  8ECD	(devtbl)
  8E3F  JMP  9104	(devini)
  8E42  JMP  8ED1	(drvtbl)
  8E45  JMP  A99C	(multio)
  8E48  JMP  A9A0	(flush)
  8E4B  JMP  92BF	(move)
  8E4E  JMP  9094	(time)
  8E51  JMP  9020	(selmem)
  8E54  JMP  A956	(setbnk)
  8E57  JMP  92BE	(xmove)
  8E5A  JMP  0000	(userf)
  8E5D  JMP  0000	(reserv1)
  8E60  JMP  0000	(reserv2)
BIOS  8E00  1C00; login message starts at 90ED.
==> Created BIOS3.sym using PIP BIOS3.sym=BIOSKRN3.sym,SCB3.sym,BOOT3.sym,CHARIO3.sym,MOVE3.sym,DRVTBL3.sym,FLP3.sym,IDE3.sym
==> Don't do this ^ but instead use the BIOS3.sym file created by the linker
==> Actually, neither symbol file has any correlation with what's actually loaded into memory
SID CPMLDR.COM BIOS3.SYM
CP/M 3 SID - Version 3.0
SYMBOLS
NEXT MSZE  PC  END
2500 2500 0100 B62D
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A8D1
#PA8D1
#G8E00
01 PASS A8D1
 -Z-EI A=42 B=0001 D=6F00 H=005E S=027F P=A8D1 LXI  SP,8ECD
*A8D4
#TW#100
 -Z-EI A=42 B=0001 D=6F00 H=005E S=8ECD P=A8D4 MVI  C,0F
 -Z-EI A=42 B=000F D=6F00 H=005E S=8ECD P=A8D6 PUSH B
 -Z-EI A=42 B=000F D=6F00 H=005E S=8ECB P=A8D7 CALL 9104
 ---EI A=1E B=0F0F D=9127 H=9291 S=8ECB P=A8DA POP  B
 ---EI A=1E B=000F D=9127 H=9291 S=8ECD P=A8DB DCR  C
 ----I A=1E B=000E D=9127 H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=1E B=000E D=9127 H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=1E B=000E D=9127 H=9291 S=8ECB P=A8D7 CALL 9104
 ----I A=1C B=0E0E D=9125 H=9291 S=8ECB P=A8DA POP  B
 ----I A=1C B=000E D=9125 H=9291 S=8ECD P=A8DB DCR  C
 ----I A=1C B=000D D=9125 H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=1C B=000D D=9125 H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=1C B=000D D=9125 H=9291 S=8ECB P=A8D7 CALL 9104
 ----I A=1A B=0D0D D=9123 H=9291 S=8ECB P=A8DA POP  B
 ----I A=1A B=000D D=9123 H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=1A B=000C D=9123 H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=1A B=000C D=9123 H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=1A B=000C D=9123 H=9291 S=8ECB P=A8D7 CALL 9104
 ---EI A=18 B=0C0C D=9121 H=9291 S=8ECB P=A8DA POP  B
 ---EI A=18 B=000C D=9121 H=9291 S=8ECD P=A8DB DCR  C
 ----I A=18 B=000B D=9121 H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=18 B=000B D=9121 H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=18 B=000B D=9121 H=9291 S=8ECB P=A8D7 CALL 9104
 ----I A=16 B=0B0B D=911F H=9291 S=8ECB P=A8DA POP  B
 ----I A=16 B=000B D=911F H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=16 B=000A D=911F H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=16 B=000A D=911F H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=16 B=000A D=911F H=9291 S=8ECB P=A8D7 CALL 9104
 ---EI A=14 B=0A0A D=911D H=9291 S=8ECB P=A8DA POP  B
 ---EI A=14 B=000A D=911D H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=14 B=0009 D=911D H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=14 B=0009 D=911D H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=14 B=0009 D=911D H=9291 S=8ECB P=A8D7 CALL 9104
 ---EI A=12 B=0909 D=911B H=9291 S=8ECB P=A8DA POP  B
 ---EI A=12 B=0009 D=911B H=9291 S=8ECD P=A8DB DCR  C
 ----I A=12 B=0008 D=911B H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=12 B=0008 D=911B H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=12 B=0008 D=911B H=9291 S=8ECB P=A8D7 CALL 9104
 ----I A=10 B=0808 D=9119 H=9291 S=8ECB P=A8DA POP  B
 ----I A=10 B=0008 D=9119 H=9291 S=8ECD P=A8DB DCR  C
 ----I A=10 B=0007 D=9119 H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=10 B=0007 D=9119 H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=10 B=0007 D=9119 H=9291 S=8ECB P=A8D7 CALL 9104
 ----- A=0E B=0707 D=9117 H=9291 S=8ECB P=A8DA POP  B
 ----- A=0E B=0007 D=9117 H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=0E B=0006 D=9117 H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=0E B=0006 D=9117 H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=0E B=0006 D=9117 H=9291 S=8ECB P=A8D7 CALL 9104
 ---E- A=0C B=0606 D=9115 H=9291 S=8ECB P=A8DA POP  B
 ---E- A=0C B=0006 D=9115 H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=0C B=0005 D=9115 H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=0C B=0005 D=9115 H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=0C B=0005 D=9115 H=9291 S=8ECB P=A8D7 CALL 9104
 ---E- A=0A B=0505 D=9113 H=9291 S=8ECB P=A8DA POP  B
 ---E- A=0A B=0005 D=9113 H=9291 S=8ECD P=A8DB DCR  C
 ----I A=0A B=0004 D=9113 H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=0A B=0004 D=9113 H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=0A B=0004 D=9113 H=9291 S=8ECB P=A8D7 CALL 9104
 ----- A=08 B=0404 D=9111 H=9291 S=8ECB P=A8DA POP  B
 ----- A=08 B=0004 D=9111 H=9291 S=8ECD P=A8DB DCR  C
 ---EI A=08 B=0003 D=9111 H=9291 S=8ECD P=A8DC JP   A8D6
 ---EI A=08 B=0003 D=9111 H=9291 S=8ECD P=A8D6 PUSH B
 ---EI A=08 B=0003 D=9111 H=9291 S=8ECB P=A8D7 CALL 9104
 ---E- A=06 B=0303 D=910F H=9291 S=8ECB P=A8DA POP  B
 ---E- A=06 B=0003 D=910F H=9291 S=8ECD P=A8DB DCR  C
 ----I A=06 B=0002 D=910F H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=06 B=0002 D=910F H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=06 B=0002 D=910F H=9291 S=8ECB P=A8D7 CALL 9104
 ----- A=04 B=0202 D=910D H=9291 S=8ECB P=A8DA POP  B
 ----- A=04 B=0002 D=910D H=9291 S=8ECD P=A8DB DCR  C
 ----I A=04 B=0001 D=910D H=9291 S=8ECD P=A8DC JP   A8D6
 ----I A=04 B=0001 D=910D H=9291 S=8ECD P=A8D6 PUSH B
 ----I A=04 B=0001 D=910D H=9291 S=8ECB P=A8D7 CALL 9104
 ----- A=FF B=0101 D=910B H=923E S=8ECB P=A8DA POP  B
 ----- A=FF B=0001 D=910B H=923E S=8ECD P=A8DB DCR  C
 -Z-EI A=FF B=0000 D=910B H=923E S=8ECD P=A8DC JP   A8D6
 -Z-EI A=FF B=0000 D=910B H=923E S=8ECD P=A8D6 PUSH B
 -Z-EI A=FF B=0000 D=910B H=923E S=8ECB P=A8D7 CALL 9104
 -Z-E- A=00 B=0000 D=9109 H=91C3 S=8ECB P=A8DA POP  B
 -Z-E- A=00 B=0000 D=9109 H=91C3 S=8ECD P=A8DB DCR  C
 --ME- A=00 B=00FF D=9109 H=91C3 S=8ECD P=A8DC JP   A8D6
 --ME- A=00 B=00FF D=9109 H=91C3 S=8ECD P=A8DF CALL 9037 (init in boot3)
SID CPMLDR.COM
NEXT MSZE  PC  END
2500 2500 0100 B62D
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A8D1
#P9037
#G8E00
01 PASS 9037
 --ME- A=00 B=00FF D=9109 H=91C3 S=8ECB P=9037 LXI  H,8000
*903A
#TW#100
 --ME- A=00 B=00FF D=9109 H=8000 S=8ECB P=903A SHLD 8DBE
 --ME- A=00 B=00FF D=9109 H=8000 S=8ECB P=903D SHLD 8DC0
 --ME- A=00 B=00FF D=9109 H=8000 S=8ECB P=9040 LXI  H,4000
 --ME- A=00 B=00FF D=9109 H=4000 S=8ECB P=9043 SHLD 8DC6
 --ME- A=00 B=00FF D=9109 H=4000 S=8ECB P=9046 LXI  H,2000
 --ME- A=00 B=00FF D=9109 H=2000 S=8ECB P=9049 SHLD 8DC2
 --ME- A=00 B=00FF D=9109 H=2000 S=8ECB P=904C SHLD 8DC4
 --ME- A=00 B=00FF D=9109 H=2000 S=8ECB P=904F LXI  H,90ED	(sign-on message)
 --ME- A=00 B=00FF D=9109 H=90ED S=8ECB P=9052 JMP  8FB2	(jmp ?pmsg in bioskrn3)
 --ME- A=00 B=00FF D=9109 H=90ED S=8ECB P=8FB2 PUSH B
 --ME- A=00 B=00FF D=9109 H=90ED S=8EC9 P=8FB3 PUSH D
 --ME- A=00 B=00FF D=9109 H=90ED S=8EC7 P=8FB4 MOV  A,M
 --ME- A=0D B=00FF D=9109 H=90ED S=8EC7 P=8FB5 ORA  A
 ----- A=0D B=00FF D=9109 H=90ED S=8EC7 P=8FB6 JZ   8FC3	(pmsg$exit)
 ----- A=0D B=00FF D=9109 H=90ED S=8EC7 P=8FB9 MOV  C,A
 ----- A=0D B=000D D=9109 H=90ED S=8EC7 P=8FBA PUSH H
 ----- A=0D B=000D D=9109 H=90ED S=8EC5 P=8FBB CALL 8E0C	(call ?conout)
SID CPMLDR.COM
NEXT MSZE  PC  END
2500 2500 0100 B62D
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A8D1
#P8E0C
#G8E00
01 PASS 8E0C
 ----- A=0D B=000D D=9109 H=90ED S=8EC3 P=8E0C JMP  8ED5	(jmp conout in bioskrn3)
*8ED5
#TW#100
 ----- A=0D B=000D D=9109 H=90ED S=8EC3 P=8ED5 LHLD 8DC0	(@covec)
 ----- A=0D B=000D D=9109 H=8000 S=8EC3 P=8ED8 JMP  8EE4	(jmp out$scan)
 ----- A=0D B=000D D=9109 H=8000 S=8EC3 P=8EE4 MVI  B,00
 ----- A=0D B=000D D=9109 H=8000 S=8EC3 P=8EE6 DAD  H
 C---- A=0D B=000D D=9109 H=0000 S=8EC3 P=8EE7 JNC  8EFA	(not$out$device)
 C---- A=0D B=000D D=9109 H=0000 S=8EC3 P=8EEA PUSH H
 C---- A=0D B=000D D=9109 H=0000 S=8EC1 P=8EEB PUSH B
 C---- A=0D B=000D D=9109 H=0000 S=8EBF P=8EEC CALL 8F27	(not$out$ready: call coster, ora a)
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBF P=8EEF ORA  A
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBF P=8EF0 JZ   8EEC	(not$out$ready)
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBF P=8EF3 POP  B
 --ME- A=FF B=000D D=9195 H=91D5 S=8EC1 P=8EF4 PUSH B
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBF P=8EF5 CALL 914B	(call ?co in chario3)
SID CPMLDR.COM
NEXT MSZE  PC  END
2500 2500 0100 B62D
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A8D1
#P914B
#G8E00
01 PASS 914B
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBD P=914B CALL 91B4	(call dev$dispatch in chario3)
*91B4
#TW#100
 --ME- A=FF B=000D D=9195 H=91D5 S=8EBB P=91B4 MOV  A,B
 --ME- A=00 B=000D D=9195 H=91D5 S=8EBB P=91B5 STA  9292	(dev$code)
 --ME- A=00 B=000D D=9195 H=91D5 S=8EBB P=91B8 ADD  A
 -Z-E- A=00 B=000D D=9195 H=91D5 S=8EBB P=91B9 POP  H
 -Z-E- A=00 B=000D D=9195 H=914E S=8EBD P=91BA MOV  E,A
 -Z-E- A=00 B=000D D=9100 H=914E S=8EBD P=91BB MVI  D,00
 -Z-E- A=00 B=000D D=0000 H=914E S=8EBD P=91BD DAD  D
 -Z-E- A=00 B=000D D=0000 H=914E S=8EBD P=91BE MOV  E,M
 -Z-E- A=00 B=000D D=00DD H=914E S=8EBD P=91BF INX  H
 -Z-E- A=00 B=000D D=00DD H=914F S=8EBD P=91C0 MOV  D,M
 -Z-E- A=00 B=000D D=91DD H=914F S=8EBD P=91C1 XCHG
 -Z-E- A=00 B=000D D=914F H=91DD S=8EBD P=91C2 PCHL		<== run off rails.  dev handler address is junk.
 -Z-E- A=00 B=000D D=914F H=91DD S=8EBD P=91DD IN   EF
 -Z-E- A=FF B=000D D=914F H=91DD S=8EBD P=91DF ??=  CB
So CONIO3.asm needs to be modified to interface with 2SIO boards.
I made a few changes to chario3.asm and to fdc3.asm, which I renamed from flp3.asm. After doing so, I am able to run the loader without hanging, but I still don't see the sign-on message and instead see the error, "CPMLDR error: failed to open CPM3.SYS." Just before that, it shows the TPA size announcement and then outputs a line with what appears to be about 25 spaces, followed a second or so later by 25 or so more spaces. So that's forward motion in that it's not hanging, but not much forward motion.
After making the changes, I did the shotgun approach of linking in all modules and GENning for 63Kb. That created a build that isn't suitable for debugging. I'll remove IDE3 and relink, and then GEN with topmem=A9 so I can watch it with the debugger, to see what the chario3 code is doing.
Below are listings of the two modified files. All the others are unchanged.
CHARIO3.ASM:
	TITLE	'SIO AND 2SIO HANDLER FOR CP/M 3.0'
	; DEFINE LOGICAL VALUES:
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
	; Equates used by FDC for flushing during system inactivity (during char I/O)
UNDEF		EQU	0FFH
MINIDSK		EQU	FALSE		;Set TRUE for Altair Mini-Disk (see FLP3.asm)
cHDUNLD		EQU	08H		;head unload
DRVCMD		EQU	09H		;drive command register (out)
	; DETERMINE IF FOR BANK SELECT OR NOT:
BANKED		EQU	FALSE	;<------------------- BANKED VERSION
	PUBLIC	?CINIT,?CI,?CO,?CIST,?COST
	PUBLIC	@CTBL
	; DEFINE EXTERNAL LABELS AND ENTRY POINTS:
	IF	BANKED
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	EXTRN	OUT$BLOCKS	;BLOCK OUTPUT ROUTINE TO I/O PORTS
	EXTRN	?PMSG
	; FDC external labels:
	EXTRN	bfDrive		;Buffered drive
	EXTRN	ckFlush		;Disk buffer flush routine
	; INCLUDE Z-80 MACROS:
	MACLIB	Z80
	; 2SIO Serial Board Equates
SIO1CTL	EQU	10h		;1st port on 2SIO board - control register
SIO1DAT	EQU	11h		;1st port on 2SIO board - data register
SIO2CTL	EQU	12h		;2nd port on 2SIO board - control register
SIO2DAT	EQU	13h		;2nd port on 2SIO board - data register
SIORDRF	EQU	01h		;read data register full flag
SIOTDRE	EQU	02h		;transmit data register empty flag
	; SIO Serial Board Equates
SIOCTL	EQU	00h		;SIO board at 0 - control register
SIODAT	EQU	01h		;SIO board at 0 - data register
ACRCTL	EQU	06h		;SIO board at 6 - control register (cassette)
ACRDAT	EQU	07h		;SIO board at 6 - data register (cassette)
SIORCV	EQU	01h		;data received bit (inverted)
SIOXMT	EQU	80h		;read to transmit (inverted)
	; EQUATES FOR MODE BYTE BIT FIELDS
MB$INPUT	EQU 0000$0001B	; DEVICE MAY DO INPUT
MB$OUTPUT	EQU 0000$0010B	; DEVICE MAY DO OUTPUT
MB$IN$OUT	EQU MB$INPUT+MB$OUTPUT
MB$SOFT$BAUD	EQU 0000$0100B	; SOFTWARE SELECTABLE BAUD RATES
MB$SERIAL	EQU 0000$1000B	; DEVICE MAY USE PROTOCOL
MB$XON$XOFF	EQU 0001$0000B	; XON/XOFF PROTOCOL ENABLED
BAUD$NONE	EQU 0		; NO BAUD RATE ASSOCIATED WITH THIS DEVICE
BAUD$50		EQU 1		; 50 BAUD
BAUD$75		EQU 2		; 75 BAUD
BAUD$110	EQU 3		; 110 BAUD
BAUD$134	EQU 4		; 134.5 BAUD
BAUD$150	EQU 5		; 150 BAUD
BAUD$300	EQU 6		; 300 BAUD
BAUD$600	EQU 7		; 600 BAUD
BAUD$1200	EQU 8		; 1200 BAUD
BAUD$1800	EQU 9		; 1800 BAUD
BAUD$2400	EQU 10		; 2400 BAUD
BAUD$3600	EQU 11		; 3600 BAUD
BAUD$4800	EQU 12		; 4800 BAUD
BAUD$7200	EQU 13		; 7200 BAUD
BAUD$9600	EQU 14		; 9600 BAUD
BAUD$19200	EQU 15		; 19.2K BAUD
	; WILL START OFF IN COMMON MEMORY FOR BANKED OR NON-BANKED SYSTEMS:
	CSEG
	IF	BANKED
	; WE PROVIDE ALTERNATE DEFINITIONS OF THE ROUTINE ENTRY POINTS IF
	;  WE ARE RUNNING A BANKED SYSTEM VERSUS A NON-BANKED SYSTEM:
	;;;;; ?CINIT
	; ENTER HERE FOR BANKED SYSTEMS FOR DEVICE INITIALIZATIONS:
?CINIT:
	LXI	H,BCINIT	;POINT TO BANKED ROUTINE ADDRESS
	JR	BANKIO		;GO TO DISPATCHER
	;;;;; ?CI
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT:
?CI:	LXI	H,BCI		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CO
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT:
?CO:	LXI	H,BCO		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?CIST
	; ENTER HERE FOR BANKED SYSTEM DEVICE INPUT STATUS:
?CIST:	LXI	H,BCIST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; ?COST
	; ENTER HERE FOR BANKED SYSTEM DEVICE OUTPUT STATUS:
?COST:	LXI	H,BCOST		;POINT TO BANKED ROUTINE ADDRESS
	;;;;; BANKIO
	; ROUTINE DISPATCHES TO BANKED PORTION OF CHARACTER I/O ROUTINES:
BANKIO:
	SSPD	SPSAVE		;SAVE CURRENT STACK POINTER
	LXI	SP,IOSP		; AND USE LOCAL STACK FOR I/O
	LDA	@CBNK		;GET CURRENT BANK
	PUSH	PSW		;SAVE ON LOCAL STACK
	XRA	A		;WE WILL SELECT BANK 0 (OP SYS)
	CALL	?BNKSL
	LXI	D,BIORET	;RETURN ADDRESS IN [DE]
	PUSH	D		;PUT IT ON STACK FOR RETURN
	PCHL			;DISPATCH TO BANKED PART OF ROUTINE
	; ARRIVE HERE AFTER DEVICE HANDLER FINISHED:
BIORET:
	POP	D		;GET PREVIOUS CURRENT BANK TO [D]
	PUSH	PSW		;SAVE HANDLER RETURNED RESULT (IF ANY)
	MOV	A,D		;RESELECT PREVIOUS CURRENT BANK
	CALL	?BNKSL
	POP	PSW		;GET BACK RESULT CODE TO [A]
	LSPD	SPSAVE		;RESTORE PREVIOUS STACK
	RET			;AND RETURN...
	ENDIF
	;;;;; ACTUAL DEVICE HANDLERS
	;;;;; ?CINIT (BCINIT FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INITIALIZATION:
	IF	BANKED
	DSEG			;CAN PUT IN BANKED SEGMENT IF BANKED
BCINIT:
	ELSE
?CINIT:
	ENDIF
	MOV	B,C		;ON ENTRY DEVICE # IS IN [C] BUT WE NEED
				; IT IN [B]
	CALL	DEV$DISPATCH	;GO TO CORRECT INIT ROUTINE
	DW	CINIT0		;INIT FOR DEVICE 0
	DW	CINIT1		;INIT FOR DEVICE 1
	DW	CINIT2		;INIT FOR DEVICE 2
	DW	CINIT3		;INIT FOR DEVICE 3
	DW	NULL$INIT	;INIT FOR DEVICE 4
	DW	NULL$INIT	;INIT FOR DEVICE 5
	DW	NULL$INIT	;INIT FOR DEVICE 6
	DW	NULL$INIT	;INIT FOR DEVICE 7
	DW	NULL$INIT	;INIT FOR DEVICE 8
	DW	NULL$INIT	;INIT FOR DEVICE 9
	DW	NULL$INIT	;INIT FOR DEVICE 10
	DW	NULL$INIT	;INIT FOR DEVICE 11
	DW	NULL$INIT	;INIT FOR DEVICE 12
	DW	NULL$INIT	;INIT FOR DEVICE 13
	DW	NULL$INIT	;INIT FOR DEVICE 14
	DW	NULL$INIT	;INIT FOR DEVICE 15
	;;;;; ?CI (BCI FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT:
	IF	BANKED
BCI:
	ELSE
?CI:
	ENDIF
	;;;;; System is relatively idle during char input, so do some FDC housecleaning
	mvi	a,UNDEF		;invalidate track buffer
	sta	bfDrive
	call	ckFlush		;flush the track if needed
	ei			;restore interrupts
	IF	NOT MINIDSK
	mvi	a,cHDUNLD	;unload head
	out	DRVCMD
	ENDIF
	CALL	DEV$DISPATCH
	DW	CI0		;DEVICE 0 INPUT
	DW	CI1		;DEVICE 1 INPUT
	DW	CI2		;DEVICE 2 INPUT
	DW	CI3		;DEVICE 3 INPUT
	DW	NULL$CI		;DEVICE 4 INPUT
	DW	NULL$CI		;DEVICE 5 INPUT
	DW	NULL$CI		;DEVICE 6 INPUT
	DW	NULL$CI		;DEVICE 7 INPUT
	DW	NULL$CI		;DEVICE 8 INPUT
	DW	NULL$CI		;DEVICE 9 INPUT
	DW	NULL$CI		;DEVICE 10 INPUT
	DW	NULL$CI		;DEVICE 11 INPUT
	DW	NULL$CI		;DEVICE 12 INPUT
	DW	NULL$CI		;DEVICE 13 INPUT
	DW	NULL$CI		;DEVICE 14 INPUT
	DW	NULL$CI		;DEVICE 15 INPUT
	;;;;; ?CO (BCO FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT:
	IF	BANKED
BCO:
	ELSE
?CO:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CORRECT DEVICE OUTPUT HANDLER
	DW	CO0		;DEVICE 0 OUTPUT
	DW	CO1		;DEVICE 1 OUTPUT
	DW	CO2		;DEVICE 2 OUTPUT
	DW	CO3		;DEVICE 3 OUTPUT
	DW	NULL$CO		;DEVICE 4 OUTPUT
	DW	NULL$CO		;DEVICE 5 OUTPUT
	DW	NULL$CO		;DEVICE 6 OUTPUT
	DW	NULL$CO		;DEVICE 7 OUTPUT
	DW	NULL$CO		;DEVICE 8 OUTPUT
	DW	NULL$CO		;DEVICE 9 OUTPUT
	DW	NULL$CO		;DEVICE 10 OUTPUT
	DW	NULL$CO		;DEVICE 11 OUTPUT
	DW	NULL$CO		;DEVICE 12 OUTPUT
	DW	NULL$CO		;DEVICE 13 OUTPUT
	DW	NULL$CO		;DEVICE 14 OUTPUT
	DW	NULL$CO		;DEVICE 15 OUTPUT
	;;;;; ?CIST (BCIST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE INPUT STATUS:
	IF	BANKED
BCIST:
	ELSE
?CIST:
	ENDIF
	CALL	DEV$DISPATCH
	DW	CIST0		;DEVICE 0 INPUT STATUS
	DW	CIST1		;DEVICE 1 INPUT STATUS
	DW	CIST2		;DEVICE 2 INPUT STATUS
	DW	CIST3		;DEVICE 3 INPUT STATUS
	DW	NULL$CIST	;DEVICE 4 INPUT STATUS
	DW	NULL$CIST	;DEVICE 5 INPUT STATUS
	DW	NULL$CIST	;DEVICE 6 INPUT STATUS
	DW	NULL$CIST	;DEVICE 7 INPUT STATUS
	DW	NULL$CIST	;DEVICE 8 INPUT STATUS
	DW	NULL$CIST	;DEVICE 9 INPUT STATUS
	DW	NULL$CIST	;DEVICE 10 INPUT STATUS
	DW	NULL$CIST	;DEVICE 11 INPUT STATUS
	DW	NULL$CIST	;DEVICE 12 INPUT STATUS
	DW	NULL$CIST	;DEVICE 13 INPUT STATUS
	DW	NULL$CIST	;DEVICE 14 INPUT STATUS
	DW	NULL$CIST	;DEVICE 15 INPUT STATUS
	;;;;; ?COST (BCOST FOR BANKED)
	; PHYSICAL CODE FOR DEVICE OUTPUT STATUS:
	IF	BANKED
BCOST:
	ELSE
?COST:
	ENDIF
	CALL	DEV$DISPATCH	;GO TO CONSOLE OUTPUT STATUS HANDLER
	DW	COST0		;DEVICE 0 OUTPUT STATUS
	DW	COST1		;DEVICE 1 OUTPUT STATUS
	DW	COST2		;DEVICE 2 OUTPUT STATUS
	DW	COST3		;DEVICE 3 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 4 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 5 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 6 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 7 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 8 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 9 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 10 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 11 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 12 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 13 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 14 OUTPUT STATUS
	DW	NULL$COST	;DEVICE 15 OUTPUT STATUS
	;;;;; DEV$DISPATCH
	; ROUTINE JUMPS TO CORRECT DEVICE HANDLER:
DEV$DISPATCH:
	MOV	A,B		;GET DEVICE # TO [A]
	STA	DEV$CODE	;SAVE FOR LATER USE
	ADD	A		;X2 FOR WORD OFFSET
	POP	H		;RETURN ADDRESS IS 1ST PARAMETER ADDRESS
	MOV	E,A		;SET UP OFFSET IN [DE]
	MVI	D,0
	DAD	D		;[HL] = PTR TO HANDLER ADDRESS
	MOV	E,M		;GET HANDLER ADDRESS TO [DE]
	INX	H
	MOV	D,M
	XCHG			;PUT IN [HL]
	PCHL			;AND DISPATCH TO IT...
	;;;;; PHYSICAL DEVICE HANDLER CODE:
CINIT0:
CINIT1:
CINIT2:
CINIT3:
	RET
; Input status routines. Return FFh if character ready, else zero
CIST0:
sio1IS  in	SIO1CTL		;read 2SIO #1 status/control register
	ani	SIORDRF		;data present?
	rz			;no, return zero
	mvi	a,0FFh		;else return FFh
	ret
CIST1:
sio2IS	in	SIO2CTL		;read 2SIO #2 status/control register
	rz			;no, return zero
	ret
CIST2:
sioIS	in	SIOCTL		;read SIO status/control register
	xri	0FFh		;convert to positive logic
	ani	SIORCV		;data present?
	rz			;no, return zero
	ret
CIST3:
acrIS	in	ACRCTL		;read ACR (SIO) control register
	rz			;no, return zero
	ret
; Character input routines (character ready assumed)
CI0:
sio1In	in	SIO1DAT		;read and return the character
	ret
CI1:
sio2In	in	SIO2DAT		;read and return the character
	ret
CI2:
sioIn	in	SIODAT		;read and return the character
	ret
CI3:
acrIn	in	ACRDAT		;read and return the character
	ret
; Output status routines. Return FFh if ready to send, else zero
COST0:
sio1OS	in	SIO1CTL		;read 2SIO #1 status/control register
	ani	SIOTDRE		;0=busy
	rz			;not ready, return 0
	ret
COST1:
sio2OS	in	SIO2CTL		;read 2SIO #2 status/control register
	ani	SIOTDRE		;0=busy
	ret
COST2:
sioOS	in	SIOCTL		;read SIO status/control register
	ani	SIOXMT		;0=busy
	ret
COST3:
acrOS	in	ACRCTL		;read SIO status/control register
	ani	SIOXMT		;0=busy
	ret
; Character output routines (transmit ready assumed)
CO0:
sio1Out	out	SIO1DAT		;send character
	ret
CO1:
sio2Out	out	SIO2DAT		;send character
	ret
CO2:
sioOut	out	SIODAT		;send character
	ret
CO3:
acrOut	out	ACRDAT		;send character
	ret
	;;;;; NULL ROUTINES:
NULL$CIST:
NULL$COST:
	XRA	A		;RETURN A FALSE STATUS RESULT
	JR	NULL$RET
NULL$CI:
	MVI	A,1AH		;FOR INPUT RETURN A CNTL-Z (EOF)
NULL$INIT:
NULL$CO:
NULL$RET:
	RET			;HARMLESS RETURN
	; STORAGE FOR DEVICE CODE -- CAN RESIDE IN SAME SEGMENT AS THE BULK
	;  OF CHARACTER I/O ROUTINES:
DEV$CODE:	DS	1
	;;;;; CHRTBL
	; CHARACTER DEVICE TABLE
	CSEG			;MUST RESIDE IN COMMON MEMORY
@CTBL:
	db '2SIOA '		; device 0, 2SIO at 10h/11h
	db mb$in$out+mb$serial
	db baud$none
	db '2SIOB '		; device 1, 2SIO at 12h/13h
	db baud$none
	db 'SIO   '		; device 2, SIO at 0/1
	db baud$none
	db 'ACR   '		; device 3, SIO at 6/7 (ACR)
	db baud$none
	db 0			; table terminator
MAX$DEVICES	EQU	($-@CTBL)/8	;# DEVICES IN TABLE
	DB	0			;TABLE TERMINATOR
	; OTHER DATA AREAS:
	DS	24		;CHARACTER I/O LOCAL STACK
IOSP	EQU	$
SPSAVE	DS	2
	END
FDC3.ASM:
	TITLE	'CPM3 module for floppy drives'
TRUE	equ	-1
FALSE	equ	not TRUE
;Diskette parameter equates
MINIDSK	equ	FALSE		;set TRUE for Altair Mini-Disk
NUMTRK	equ	77		;number of tracks on the disk
NUMSEC	equ	32		;sectors per track
DATATRK	equ	6		;1st data format track
SECMASK	equ	1Fh		;five bit sector numbers
BLS	equ	1024		;allocation unit size
BSH	equ	4		;allocation block shift factor
BLM	equ	0Fh		;allocation block mask
EXM	equ	0		;extent mask
DSM	equ	149		;max block number (150 blocks of 2K bytes)
NDIRS	equ	64		;number of directory entries (64)
DRM	equ	63		;max directory entry number
AL0	equ	0C0h		;directory allocation block bits byte 0
AL1	equ	0		;directory allocation block bits byte 1
RESTRK	equ	2		;reserved tracks for boot image
CKS	equ	(DRM+1)/4	;directory check space
NUMDISK	equ	2		;Two drives supported
CSECLEN	equ	128		;CP/M sector length
SSECLEN	equ	133		;Altair system sector length
DSECLEN	equ	136		;Altair data sector length
TSECLEN	equ	DSECLEN+1	;length of sector in track table
; System tracks (0-5) sector format
SYSTRK	equ	0		;offset of track number
SYSDATA	equ	3		;offset of 128 byte data payload
SYSSTOP	equ	131		;offset of stop byte (FFh)
SYSCSUM	equ	132		;offset of checksum
; Data tracks (6-76) sector format
DATTRK	equ	0		;offset of track number
DATSEC	equ	1		;offset of sector number
DATCSUM	equ	4		;offset of checksum
DATDATA	equ	7		;offset of 128 byte data payload
DATSTOP	equ	135		;offset of stop byte (FFh)
; Altair disk controller
DRVSLCT	equ	08h		;drive select register (out)
cDSLCT	equ	80h		;deselect drive
DRVSTAT	equ	08h		;drive status register (in)
sENWD	equ	01h		;enter new write data flag
sMOVEOK	equ	02h		;OK to move head
sHDSTAT	equ	04h		;head status flag
sDSKEN	equ	08h		;disk is selected and enabled
sINTEN	equ	20h		;processor interrupts enabled
sTRACK0	equ	40h		;on track zero flag
sNRDA	equ	80h		;new read data available
DRVCMD	equ	09h		;drive command register (out)
cSTEPI	equ	01h		;step in
cSTEPO	equ	02h		;step out
cHDLOAD	equ	04h		;head load
cRESTMR	equ	04h		;restart motor-off timer (MINIDSK)
cHDUNLD	equ	08h		;head unload
cINTEN	equ	10h		;interrupt enable
cINTDIS	equ	20h		;interrupt disable
cHCSON	equ	40h		;reduce head current switch
cWRTEN	equ	80h		;write enable
DRVSEC	equ	09h		;drive sector position (in)
sNEWSEC	equ	01h		;new sector flag (sector true)
DRVDATA	equ	0Ah		;drive read/write data (in/out)
; BDOS equates
GETCH	equ	1		;get character
PRINT	equ	9		;display string
OPEN	equ	15		;open file
READSEQ	equ	20		;read sequential
DMA	equ	26		;set address for file read
SETMULT	equ	44		;set multi-record I/O
; RAM equates
TPA	equ	100h
DFFCB	equ	5Ch
STACK	equ	100h
BDOS	equ	5
WBOOTV	equ	00h		;warm boot vector location
BDOSV	equ	05h		;bdos entry vector location
; Misc equates
NUMCDEV	equ	4		;number of character I/O devices
RDTRIES	equ	6		;read tries (must be <= 8)
VFTRIES	equ	4		;verify tries per write (must be <= 8)
WRTRIES	equ	3		;track writes to try
UNDEF	equ	0FFh		;undefined value
CR	equ	13		;ascii for carriage return
LF	equ	10		;ascii for line feed
EOF	equ	01Ah		;ctrl-z
; External references
	maclib	CPM3		;CP/M 3.0 disk definition macros
	maclib	Z80		;Z80 translation macro library
	maclib	modebaud	;Character I/O equates
	extrn	@civec,@covec,@aivec,@aovec,@lovec,@mxtpa
	cseg			;Put DPBs in common memory
; Disk Parameter Headers
	PUBLIC	DPH0, DPH1		;FLOPPY DISK PARAMETER HEADERS
	PUBLIC	bfDrive			;Buffered drive
	PUBLIC	ckFlush			;Disk buffer flush routine
	; DEFINE EXTERNAL LABELS:
	EXTRN	@ADRV,@RDRV
	EXTRN	@DMA,@TRK,@SECT
	EXTRN	@CBNK
	EXTRN	@DBNK			;BANK FOR DMA OPERATION
	EXTRN	@ERMDE			;BDOS ERROR MODE
	EXTRN	?WBOOT			;WARM BOOT VECTOR
	EXTRN	?SLDSK			;SELECT DISK
	EXTRN	?PMSG			;PRINT MESSAGE @<HL> UP TO 00, SAVES [BC] AND [DE]
	EXTRN	?PDERR			;PRINT BIOS DISK ERROR HEADER
	EXTRN	?CONIN,?CONO		;CONSOLE IN AND OUT
	EXTRN	?CONST			;CONSOLE STATUS
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 0:
	DW	fdWrite			;FD SEC WRITE ROUTINE
	DW	fdRead			;FD SEC READ ROUTINE
	DW	selDsk0			;FLOPPY DISK "A:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "A:" INITIALIZATION ROUTINE
	DB	0			;RELATIVE DRIVE 0 ON THIS CONTROLLER
	DB	0			;DRIVE TYPE (UNUSED BY CP/M)
dph0	dw	tranTbl,0,0,0,0,0,fd$dpb,csv0,alv0,fd$bcb,-1,-1
	db	0
; EXTENDED DISK PARAMETER HEADER FOR DRIVE 1:
	DW	selDsk1			;FLOPPY DISK "B:" LOGIN PROCEDURE
	DW	fdInit			;FLOPPY DISK "B:" INITIALIZATION ROUTINE
	DB	1			;RELATIVE DRIVE 1 ON THIS CONTROLLER
dph1	dw	tranTbl,0,0,0,0,0,fd$dpb,csv1,alv1,fd$bcb,-1,-1
	db	0
; fd$dpb - Disk Parameter Block. This table gives a block size of 1024 bytes
;   and 64 directory entries.
fd$dpb	dw	NUMSEC		;sectors per track
	db	BSH		;allocation block shift factor (BSH)
	db	BLM		;data location block mask (BLM)
	db	EXM		;extent mask (EXM)
	dw	DSM		;maximum block number (DSM 242)
	dw	DRM		;maximum directory entry number (DRM 63)
	db	AL0,AL1		;AL0, AL1
	dw	CKS		;CKS=(DRM+1)/4
	dw	RESTRK		;reserved tracks for CPM and bootloader
	db	0		;physical=logical sector (128 bytes)
; fd$bcb - Directory Buffer Control Block (BCB)
fd$bcb	db	0FFh		;drive number (FF means not used yet)
	db	0,0,0		;record position
	db	0		;dirty (write) flag
	db	0		;scratch byte
	dw	0		;track
	dw	0		;sector
	dw	dirBuf		;buffer address
	dw	0		;bank
	dw	0		;link to next BCB (none)
   if MINIDSK
tranTbl	db	1,3,5,7,9,11,13,15,2,4,6,8,10,12,14,16
   endif
   if NOT MINIDSK
tranTbl	db	01,09,17,25,03,11,19,27,05,13,21,29,07,15,23,31
	db	02,10,18,26,04,12,20,28,06,14,22,30,08,16,24,32
   endif
;  Floppy init (noop)
fdInit:
	ret
; selDsk0 - Select Disk 0.
selDsk0:
	mvi	c,0		;C=drive number
	jmp	?slDsk
; selDsk1 - Select Disk 1.
selDsk1:
	mvi	c,1		;C=drive number
	jmp	?slDsk
; On Entry
; On Exit
;    If read successful
;	A=0, Z flag set true
;    Else
;	A=1, Z flag set false
;    Interrupts enabled
;    Clobbers all
fdRead:
	call	ckFlush		;flush track buffer if needed
	ei			;re-enable interrupts
	call	readTrk		;fill track buffer if needed
	jnz	exitDio		;track read error, exit
exitDio	mvi	a,0		;if zero is true, return zero
	rz
	inr	a		;else return A<>0, Z false
	ret
; On Entry
; On Exit
;    If successful
;    Else
;    Clobbers all
fdWrite:
;    CPM read request
; On Entry
; On Exit
;    If successful (good sector)
;    Else (sector flagged as bad)
;	Z flag set false
;    Clobbers all
movRead	call	altSkew		;secNum to hard sector in A
	call	dSecAdr		;HL->sector in trkBuf
	mov	a,m		;A=sector valid flag
	ora	a
	rnz			;bad sector, return error
	lxi	d,DATDATA+1	;DE=offset to data portion of sector
	cpi	DATATRK
	jnc	mrMove		;yes, data track (DE already correct)
	lxi	d,SYSDATA+1	;DE=offset to data portion of sector
mrMove	dad	d		;HL->data portion of sector
	xchg			;DE->data portion of sector
	mvi	b,CSECLEN	;B=number of bytes to move
	mov	m,a
	inx	h		;increment pointers
	inx	d
	dcr	b		;loop count
	jnz	mrLoop
	ret			;exit with zero	status
;    metadata for the sector for a CPM write request.
; On Entry
; On Exit
;    A=0, Z status true
;    Clobbers all
movWrt	call	altSkew		;secNum to hard sector in A
	mvi	m,0		;flag sector as good
	inx	h		;HL->track
	lda	@TRK		;A=track
	ori	80h		;set sync bit
	mov	m,a		;set track in sector
	inx	h		;HL->byte after track
	cpi	DATATRK+80h	;on a system or data track?
	jnc	wDatTrk		;data track 6-76 (mini disk 4-34)
; Create Altair sector for system tracks 0-5 (mini disk 0-3)
	xra	a		;put 0100h (16 bit) at offset 1,2
	mov	m,a
	inx	h		;HL->offset 2
	inr	a		;A=1
	mov	m,a
	inx	h		;HL->128 byte CPM sector in Altair sector
	mvi	m,0FFh		;offset 131 is stop byte (0FFh)
	inx	h		;offset 132 is checksum
	mov	m,b		;store checksum at offset 132
	jmp	mwExit		;exit
; wDatTrk- Create Altair sector for tracks 6-76 (mindisk 4-34)
	mov	m,a		;store Altair logical sector number
	inx	h		;HL->offset 2 in sector
	xra	a		;store zero at offsets 2-6
	mov	m,a		;offset 2
	inx	h
	mov	m,a		;zero at offset 3
	inx	h
	push	h		;save address of offset 4 = checksum
	inx	h
	mov	m,a		;zero at offset 5
	inx	h
	mov	m,a		;zero at offset 6
	mvi	m,0FFh		;offset 135 is stop byte (0FFh)
	pop	h		;HL->checksum byte in Altair sector
	mov	m,b		;store the checksum
; mwExit - set dirty flag true, return success status
mwExit	mvi	a,0FFh		;set dirty flag true
	sta	bfDirty
	xra	a		;return success status
	ret
;   of a CPM write command. Compute checksum on all bytes moved and return
;   the checksum in B.
; On Entry
;    HL->destination sector in trkBuf
; On Exit
;    HL = HL + 128
;    B = checksum of the 128 bytes moved
;    Clobbers all
mwMove	xchg			;DE->destination CPM sector in trkBuf
	lxi	b,CSECLEN	;B=checksum (0), C=128 byte count
mwLoop	mov	a,m		;move from (HL) to (DE)
	stax	d
	add	b		;add byte to checksum
	mov	b,a
	inx	d		;increment both pointers
	inx	h
	dcr	c		;decrement character count
	jnz	mwLoop		;loop until count = 0
	xchg			;return with buffer pointer in HL
	ret
; altSkew - Perform Altair skew on the sector number in secNum and return
;    the result in A. The skew is based on the track as:
;	Tracks 0-5, secOut = secIn
;	Tracks 6-76, secOut = (secIn * 17) MOD 32
;    The skew computation for tracks 6-76 is implemented as:
;	secOut = secIn if secIn is even
;	secOut = secIn XOR 10h if secIn is odd
; On Entry
; On Exit
;    A = sector number after Altair skew
;    Clobbers A,B
altSkew	equ	$
   if MINIDSK
	ret
   endif
   if NOT MINIDSK
	cpi	DATATRK
	rc			;system track, no change to sector
	mov	b,a		;save secNum in B
	rrc			;test for even/odd
	mov	a,b		;restore secNum in A
	rnc			;return with secNum if even
	xri	10h		;else translate as in comments above
	ret
   endif
; readTrk- read full track into track buffer if the requested
;    drive (bfDrive) or buffered track (bfTrack). The status byte
;    at the start of each sector is set to zero if the sector is
;    good, non-zero if the sector couldn't be read.
; On Entry
;    bfDrive = drive from which trkBuf was filled
;    bfTrack = track from which trkBuf was filled
; On Exit
;    Zero true if track read or already there, zero false otherwise
;    Clobbers all
readTrk	lhld	bfDrive		;L=buffered drive, H=buffered track
	cmp	l		;same drive buffered?
	jnz	rtNew		;drive doesn't match, need a new buffer
	cmp	h		;same track buffered?
	rz			;yes, already have this buffer
; rtNew - New track needs to be read
rtNew	mvi	a,UNDEF		;invalidate buffered data
	sta	bfDrive
	call	dSelDrv		;select drive, load head
	rnz			;drive select failed, exit with error
	mvi	a,2		;init restore/seek try counter
	sta	skRetry
rtRtry	call	dSeek		;seek to trkNum (disables interrupts)
	rnz			;a restore was required and failed
	call	initTrk		;init all sectors to "bad" (not read)
	lxi	d,RDTRIES*NUMSEC*256 + NUMSEC
				;D=max sector reads = RDTRIES revolutions
				;E=sectors remaining to fill
; Read sector loop - All sectors are originally marked "bad" (unread) and
;    a sector counter in E is started at NUMSEC (a full track of sectors).
;    Sectors are read until sector counter E reaches zero or the total
;    reads counter in D reaches zero (RDTRIES revolutions). The 1st time
;    the total reads counter reaches zero, a restore and re-seek is
;    performed in case we're on the wrong track. The second time it reaches
;    zero, the bad sectors remain marked as bad in the track buffer.
; Within dRead, 152 cycles execute after the last byte is read until we're
;    executing the instruction here following the dRead call. An additional
;    78 cycles are executed here until we're in dNxtSec looking for sector
;    true. This totals 230 cycles (115us) from the last byte read until
;    we're hunting for sector true. Allowing for 200us of index alignment
;    error and 10% speed variance, we have at least 180us to get this done.
; For the Mini Disk, a full track is 16 sectors instead of 32 and the time
;    available after a sector is read is well over 1000us, so timing is not
;    an issue.
rdLoop	call	dNxtSec		;(17) wait for next sector, HL->sector buf
	mov	a,m		;A=sector flag byte
	ora	a		;this sector already read?
	jz	rdNext		;yes, skip it
	push	h		;save sector address
	inx	h		;HL->1st read location in sector
	call	dRead		;read the sector
	pop	h		;(10) restore sector address in HL
	jnz	rdNext		;(10) read error
	xra	a		;(4) set sector flag to zero (good sector)
	mov	m,a		;(7)
	dcr	e		;(5) decrement sectors left to fill
	jz	rtExit		;(10) all sectors read without error
rdNext	dcr	d		;(5) decrement total sectors counter
	jnz	rdLoop		;(10) go read next sector
	lxi	h,skRetry	;HL->seek retry counter
	dcr	m		;decrement the counter
	jz	rtExit		;re-seek(s) done, we're finished
	call	dRestor		;restore to track zero
	jz	rtRtry		;start over after the re-seek
	ret			;else, exit with error
	shld	bfDrive		;set the buffered drive and track values
	ret			;exit with Z flag true
; initTrk - Set the flag byte in each sector in trkBuf to "bad" to
;    indicate none of the sectors have been read.
; On Entry
; On Exit
;    All sectors in trkBuf marked "bad" (unread)
;    Clobbers all
initTrk	lxi	b,UNDEF*256 + NUMSEC;  B=UNDEF (bad), C=NUMSEC
	lxi	h,trkBuf	;HL->track buffer
	lxi	d,TSECLEN	;DE=length of each sector in track buffer
itLoop	mov	m,b		;mark sector as bad (not read)
	dad	d		;HL->next sector in trkBuf
	dcr	c		;repeat for all sectors
	jnz	itLoop
	ret
; ckFlush - Check if track buffer should be flushed. This
;    function must be called before any drive selection or seek
;    operation. The buffer is flushed if the bfDirty flag is
;    set and the drive or track number are different than the
;    buffered track.
; On Entry
;    Drive still selected and on same track as in trkBuf
; On Exit
;    Zero true for no error, zero false if write error occured
;    Clobbers all
ckFlush	lda	bfDirty		;see if track buffer is dirty
	ora	a
	rz			;no, exit with Z set
	cmp	l		;same drive?
	jnz	wrtTrk		;no, flush
	cmp	h		;same track?
	rz			;yes, no need to flush
wrtTrk	equ	$
   if MINIDSK
	mvi	a,cRESTMR	;restart motor timeout
	out	DRVCMD
	lda	curDrv		;make sure current drive still enabled
	out	DRVSLCT
   endif
	mvi	e,cWRTEN	;E=write command, normal head current
	mvi	a,42		;tracks 0-42 are normal head current
	cmp	h		;compare 42 - current track
	jnc	wrtInit		;track is 0-42, E is correct
	mvi	e,cWRTEN+cHCSON	;E=write command with reduced current
wrtInit	xra	a		;clear buffer dirty flag
	sta	bfDirty
	mvi	a,WRTRIES	;initialize write retry count
	sta	wrRetry
	di			;disable interrupts
; rtryWrt - Write track retry entry point. Write a full track starting
;    with any sector. Don't write sectors that are flagged as bad.
rtryWrt	mvi	d,NUMSEC	;D=count of sectors to write
	xra	a		;zero the count of sectors actually written
	sta	secCnt
wrtLoop	call	dNxtSec		;(78) wait for next sector, HL->sector buf
	mov	a,m		;(7) check sector flag
	ora	a		;(4)
	jnz	wrtNext		;(10) skip if bad or previously verified
	mov	a,e		;(5) issue write command to drive
	out	DRVCMD		;(10) at 114 cycles 57us
	inx 	h		;point to 1st byte of sector
	call	dWrite		;write the sector
	lxi	h,secCnt	;count number of sectors written
	inr	m
wrtNext	dcr	d		;decrement write sector count
	jnz	wrtLoop		;loop until all sectors processed
	call	dNxtSec		;force a 1 sector delay for trim erase
	mvi	d,NUMSEC*VFTRIES   ;D=maximum number of sector reads
vfyLoop	call	dNxtSec		;wait for next sector, HL->sector buf
	mov	a,m		;test sector flag, only good and
	ora	a		;   not previously verified sectors
	jnz	vfyNext		;   are verified
	push	h		;save pointer to sector flag
	call	dVerify		;verify the sector
	pop	h		;HL->sector flag for current sector
	jnz	vfyNext		;didn't match
	mvi	m,UNDEF		;set flag to indicate sector is verified
	lxi	h,secCnt	;HL->sectors left to verify
	rz			;track verified, exit
vfyNext	dcr	d		;decrement sector count
	jnz	vfyLoop		;loop until all verify tries expired
; Read re-tries expired, decrement the write retry count and write again
	lxi	h,wrRetry	;decrement the write retry counter
	dcr	m
	jnz	rtryWrt		;retry starting with the write
	call	?pMsg
	db	CR,LF,'Delayed Write Error', CR, LF, 0
	inr	a
	ret			;exit with 1 for error
; Altair disk I/O routines
;    Save the track (curTrk) the current drive is on into the track table,
;    load curTrk for the new drive from the track table.
; On Entry
;    curDrv = drive currently selected
;    selTime = timeout in seconds to wait for drive select
;    curTrk = track the current drive is on
; On Exit
;    Drive selected and head loaded
;    curDrv = @RDRV
;    curTrk = track the newly selected drive is on
;    Zero true for success, zero false for error
;    Clobbers all
dSelDrv	equ	$
   if MINIDSK
	out	DRVCMD
   endif
	lxi	h,curDrv	;HL->currently selected drive
	mov	e,m		;E=currently selected drive
	mov	c,a		;save new drive in C
	cmp	e		;same or different drive?
	jnz	dNewDrv		;different, go select a new drive
	in	DRVSTAT		;drive still selected and enabled?
	ani	sDSKEN
	jz	dSelExt		;yes, exit
	jmp	dReSel		;otherwise, re-select the drive
; dNewDrv - Save current track (curTrk) for the current drive to the track
;    table, load curTrk for the new drive from the track table
dNewDrv	mov	m,c		;save new drive in curDrv
	mvi	d,0		;DE=currently selected drive
	lxi	h,trkTbl	;HL->track table
	dad	d		;HL->trkTbl entry for current drive
	lda	curTrk		;A=track current drive is on
	mov	m,a		;save it in the track table
	mov	e,c		;DE=offset in trkTbl for new drive
	dad	d		;HL->trkTbl for new drive
	mov	a,m		;A=track new drive is on
	sta	curTrk		;update current track
; Select the new drive with the timeout specified in selTime
dReSel	lxi	h,selTime	;move select timeout in seconds into B
	mov	b,m
dSelLp1	lxi	h,25641		;HL=count of 78 cycle loops for 1 second
dSelLp	mvi	a,cDSLCT	;(7) deselect a possibly attached drive
	out	DRVSLCT		;(10)
	mov	a,c		;(5) A=drive to select
	out	DRVSLCT		;(10) select it
	in	DRVSTAT		;(10) did drive select work?
	ani	sDSKEN		;(7)
	jz	dSelExt		;(5) yes, exit
	dcx	h		;(5) decr 1 sec counter
	mov	a,h		;(5) test HL counter for zero
	ora	l		;(4)
	jnz	dSelLp		;(10) loop for one second
	dcr	b		;decrement seconds expired
	jnz	dSelLp1		;repeat for a new 1 second
	inr	a		;timeout, return non-zero
	ret
dSelExt	mvi	a,cHDLOAD	;issue head load command
	out	DRVCMD		;restarts timeout for mini disk
	ret			;return with zero status
; dSeek - Seek to track in trkNum
; On Entry
;    Drive selected and ready
;    curTrk = current track, UNDEF means we don't know
; On Exit
;    curTrk = @TRK
;    Interrupts disabled
;    Zero true for success, zero false for failure
;	(failure is a failed restore to track zero)
;    Clobbers A,B,C,H,L
dSeek	di			;disable interrupts
	lda	curTrk		;A=current track
	cpi	UNDEF		;valid track number?
	jnz	dTrkVld		;yes, track is valid
	call	dRestor		;otherwise, restore to track zero
	rnz			;exit if restore failed
; dTrkVld - Current track is valid, compute direction and number
;     of steps
	sub	m		;A=current-requested
	rz			;return if already on correct track
	mvi	b,cSTEPO	;B=step out (assume requested<current)
	jnc	dDoSeek		;it is
	mvi	b,cSTEPI	;B=step in (requested>current)
	cma			;compute A=-A
	inr	a
; Save target track in curTrk, step there, then verify track
dDoSeek	mov	c,a		;C=number of steps
	mov	a,m		;save new track in curTrk
	sta	curTrk
	call	dStep		;do the seek
	xra	a		;return zero
	ret
; dRestor - Restore to track 0 and then delay to ensure any subsequent
;    seek meets the minimum direction change period.
; On Entry
; On Exit
;    If successful
;       curTrk = 0
;	A=0
;	Zero true
;    else
;       curTrk = UNDEF
;       Zero false
;    Clobbers A,B,C
dRestor	xra	a
	sta	curTrk		;set current drive track to zero
	in	DRVSTAT		;test for track 0
	ani	sTRACK0
	rz			;at track 0, exit
; Step in three tracks, then step out to track 0
	mvi	c,3		;C=step in 3 tracks
	mvi	b,cSTEPI	;B=step in command
	call	dStep		;do 3 steps in
	mvi	a,20		;20ms delay puts us past the 1ms step window
	call	delayMs		;  and ensures proper dir change delay
; Seek back out until track 0 detected
	mvi	c,NUMTRK+10	;C=maximum number of step outs to try
	mvi	b,cSTEPO	;B=step out command
	call	dStep		;step until track 0 detected
	jnz	drFail		;restore failed
drFail	mvi	a,UNDEF		;restore failed, track is still undefined
	sta	curTrk
	ret			;return with non-zero
; dStep - Step head number of steps in C, direction command in B.
;   If track zero is detected during a step-out operation, curTrk
;   is forced to zero and zero is returned in A.
; On Entry
;    C = number of steps > 0
;    B = step command (cSTEPO or cSTEPI)
; On Exit
;    If stepping out and track zero hit
;	curTrk = 0
;	A = 0
;	Zero true
;    else
;	Zero false
;    Clobbers A,B,C
dStep	in	DRVSTAT		;loop until OK to move the head
	ani	sMOVEOK
	jnz	dStep
	in	DRVSTAT		;see if we are at track 0
	ani	sTRACK0		;at track zero?
	jnz	dStep1		;no, go on
	mov	a,b		;stepping out?
	sbi	cSTEPO
	jz	dStep0		;yes, we've hit track 0
dStep1	mov	a,b		;A=step command and direction
	out	DRVCMD		;issue the step
	dcr	c		;decrement step counter
	jnz	dStep		;loop until count reaches zero
	inr	c		;force non-zero
	ret
dStep0	sta	curTrk		;curTrk=0
	ret			;return with zero true and A=0
; dNxtSec - Wait for next (any) sector. Returns pointer to the sector
;    buffer within trkBuf. Control is back to caller at 78 cycles (39us).
; On Entry
;    Drive is selected, head loaded
; On Exit
;    HL->sector buffer in trkBuf for sector found
dNxtSec	equ	$
   if MINIDSK
	out	DRVCMD
   endif
dnLoop	in	DRVSEC		;read sector position register
	rar			;wait for sector true (0=true)
	jc	dnLoop
	ani	SECMASK		;(7) get sector number alone
				;fall into dSecAdr
; dSecAdr - Convert hard sector in A to address within trkBuf for
;    the specified sector
; On Entry
;    A = Hard sector number
; On Exit
dSecAdr	lxi	h,secAddr  	;(10) HL->sector address table
	mvi	b,0		;(7) form BC=sector*2
	rlc			;(4) A=sector*2 (2 bytes per table entry)
	mov	c,a		;(5) BC=sector*2
	dad	b		;(10) HL->address table entry for passed sector
	mov	a,m		;(7) A=lsb of sector buffer address
	inx	h		;(5)
	mov	h,m		;(7) H=msb of sector buffer address
	mov	l,a		;(5) HL->sector buffer
	ret			;(11)
; delayMs - Delay for number of ms specified in A
; On Entry
;    A = ms to delay
; On Exit
;    A=0
;    Zero true
;    Clobbers A,B
delayMs	mvi	b,(2000/19)	;19 cycles in the loop below
delayLp	nop			;(4)
	dcr	b		;(5)
	jnz	delayLp		;(10)
	dcr	a		;decrement ms counter
	jnz	delayMs
	ret
; dRead - Read a sector, verify checksum, stop byte, and track number.
;    Verification is done after the sector is read in the time between
;    the last byte of the sector and before the start of the next sector.
;    With index alignment and rotation speed tolerance accounted for,
;    we safely have 360 cycles from the last byte of the sector until code
;    should be in the sector true hunt loop. The RET is complete from this
;    routine 152 cycles worst case after the last byte is read.
; On Entry
;    Drive is selected, sector true just detected
;    HL->sector buffer
; On Exit
;    Sector read to (HL)
;    C = track number from disk with sync bit set
;    Zero true if no error, Zero false for checksum error, missing
;	FF stop byte, or track number error
dRead	push	h		;(11) save pointer to start of sector
	lxi	b,256+DSECLEN	;(10) B=chksum (-FF), C=bytes to read
	lda	curTrk		;(13) A=track we're on
	cpi	DATATRK		;(7) data track or system track?
	jnc	drSecWt		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) C=length of a system sector
; The sector transfer loop is 116 cycles for two bytes read (has to be
;     less than 128) and computes checksum over all bytes read. For the
;     mini disk, only one byte is read per loop iteration.
drSecWt	in	DRVSTAT		;(10) get drive status byte
	ora	a		;(4) wait for NRDA flag true (zero)
	jm	drSecWt		;(10)
   if NOT MINIDSK		;8" reads two bytes per loop
	in	DRVDATA		;(10) read first byte at 24-48 cycles
	mov	m,a		;(7) store in buffer
	add	b		;(4) update checksum
	mov	b,a		;(5) keep checksum in B
	inx	h		;(5) increment buffer pointer
	dcr	c		;(5) decrement byte count
	jz	drSecDn		;(10) exit if done
   endif
	in	DRVDATA		;(10) read at 70-94 cycles (data at 64 and 128)
	jnz	drSecWt		;(10) repeat until done
; drSecDn - Sector read is complete, now validate the sector based on whether
;   it is from a system track or data track.
drSecDn	lda	curTrk		;(10) A=track we're supposed to be on
	cpi	DATATRK		;(7) system or data track?
	jnc	drDatTk		;(10) data track
; Validate a system track sector. A system track sector is three bytes
;    bytes shorter, so this codes starts 3*64 cycles sooner than for a
;    data sector. This code completes before a data sector would even
;    finish reading. Therefore, a data sector is the worst timing path.
	mov	a,b		;(5) A=calculated checksum over all bytes
	dcx	h		;(5) HL->checksum in sector
	sub	m		;(7) subtract from computed checksum
	sub	m		;(7) final sum will be zero
	dcx	h		;(5) HL->stop byte
	mov	b,m		;(7) B=stop byte
	pop	h		;(10) restore HL->start of buffer
	inr	b		;(4) was FF stop byte there?
	rnz			;(5/11) no, return error
	mov	c,m		;(7) C=track number from disk
	sub	c		;(4) take track out of checksum
	inx	h		;(5) HL->2nd byte of sector
	sub	m		;(7) take out of checksum
	inx	h		;(5) HL->3rd byte of sector
	jmp	drExit		;(10) do common compares and exit
; Validate a data track sector (125 + 27 cycles for sector type jump)
drDatTk	dcx	h		;(5) HL->stop byte
	mov	a,m		;(7) A=stop byte
	inr	a		;(4) was FF stop byte there?
	inx	h		;(5) HL->sector number
	inx	h		;(5) move to checksum byte
	inx	h		;(5)
	inx	h		;(5) HL->checksum
	sub	m		;(7) subtract from checksum
drExit	sub	m		;(7) checksums match?
	rnz			;(5/11) no, exit with error
	lda	curTrk		;(10) A=track we should be on
	ori	80h		;(7) set sync bit
	cmp	c		;(4) same track as from sector?
	ret			;(11) exit with compare status
; dVerify - Verify a sector
;    The 2nd read at 67 cycles only gives 3 cycles of headroom (67-64)
;    which, in turn, gives about 4% speed tolerance. However, we are
;    verifying our  own write, so the primary tolerance issue is ISV,
;    not the average rotation rate, so tolerance is still within the
;    +/-1.5% ISV spec.
; On Entry
;    HL->sector buffer to compare against
; On Exit
;    Zero true if match, zero false for error
dVerify lxi	b,DSECLEN	;(10) B=0, C=data sector length
	jnc	dVfLoop		;(10) data track, length in C is correct
	mvi	c,SSECLEN	;(7) set C=length of a system sector
dVfLoop	in	DRVSTAT		;(10) get drive status byte
	jm	dVfLoop		;(10)
	xra	m		;(4) verify data matches buffer
	ora	b		;(4) accumulate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement characters remaining counter
	jz	dVfDone		;(10) done verifying bytes
   endif
	in	DRVDATA		;(10) read 2nd byte at 67-91 cycles
	ora	b		;(4) accumlate errors in b
	mov	b,a		;(5)
	dcr	c		;(5) decrement byte counter
	jnz	dVfLoop		;(10) loop for all bytes
dVfDone	ora	a		;A=zero if all bytes matched
	ret			;return status
; dWrite - Write a sector
;    The write loop is 61 cycles which gives just 3 cycles (64-61) of
;    headroom. However, since the write timing required by the FDC board
;    is derived from the 2 MHz CPU/bus clock, this loop is always exactly
;    in sync with the FDC write timing. 3 cycles of headroom is plenty.
; On Entry
;    Drive is selected, sector true just detected, and
;	the write command has already been issued
;    HL->sector buffer to write
; On Exit
;   Clobbers A,C,H,L
dWrite	mvi	c,DSECLEN	;C=number of bytes to write
	jnc	dWrLoop		;(10) data track, length in C is correct
dWrLoop	in	drvStat		;(10) read drive status register
	rrc			;(4) wait for ENWD flag (zero)
	jc	dWrLoop		;(10)
	mov	a,m		;(7) A=next byte to write
	out	drvData		;(10) write 2nd byte at 68-92 cycles
	dcr	c		;(5) decrement bytes remaining
	jnz	dWrLoop		;(10) loop until all bytes written
dWrDone	in	drvStat		;wait for another write flag
	rrc
	jc	dWrDone
	xra	a		;write a trailing zero
	out	drvData
	ret
;   BIOS Data Area
; secAddr - Sector address table. Returns sector buffer address within
;    the track buffer when indexed by hard sector number. Each sector
;    requires TSECLEN bytes.
secAddr	dw	trkBuf+00*TSECLEN,trkBuf+01*TSECLEN,trkBuf+02*TSECLEN
	dw	trkBuf+03*TSECLEN,trkBuf+04*TSECLEN,trkBuf+05*TSECLEN
	dw	trkBuf+06*TSECLEN,trkBuf+07*TSECLEN,trkBuf+08*TSECLEN
	dw	trkBuf+09*TSECLEN,trkBuf+10*TSECLEN,trkBuf+11*TSECLEN
	dw	trkBuf+12*TSECLEN,trkBuf+13*TSECLEN,trkBuf+14*TSECLEN
	dw	trkBuf+15*TSECLEN
   if NOT MINIDSK
	dw	trkBuf+16*TSECLEN,trkBuf+17*TSECLEN,trkBuf+18*TSECLEN
	dw	trkBuf+19*TSECLEN,trkBuf+20*TSECLEN,trkBuf+21*TSECLEN
	dw	trkBuf+22*TSECLEN,trkBuf+23*TSECLEN,trkBuf+24*TSECLEN
	dw	trkBuf+25*TSECLEN,trkBuf+26*TSECLEN,trkBuf+27*TSECLEN
	dw	trkBuf+28*TSECLEN,trkBuf+29*TSECLEN,trkBuf+30*TSECLEN
	dw	trkBuf+31*TSECLEN
   endif
; Initialized data
selTime	db	7		;drive select timeout in seconds
coldSt	db	0FFh		;FF during cold start, 0 otherwise
curDrv	db	0		;drive number currently selected
curTrk	db	UNDEF		;track the selected drive is on
trkTbl	db	UNDEF,UNDEF,UNDEF,UNDEF		;track each drive is on
bfDirty	db	0		;non-zero if buffer has been written to
bfDrive	db	UNDEF		;drive currently in track buffer
bfTrack	db	UNDEF		;currently buffered track (MUST follow bfDrive)
; Non-initialized data
secCnt	ds	1		;count of bad sectors remaining in trkBuf
wrRetry	ds	1		;write retry counter
skRetry	ds	1		;restore and seek retry counter
;  Disk scratchpad areas defined in the DPH table
dirBuf	ds	128		;BDOS directory scratchpad
alv0	ds	(DSM/8 + 1)	;allocation vector storage
csv0	ds	CKS		;change disk scratchpad
alv1	ds	(DSM/8 + 1)
csv1	ds	CKS
; Track buffer. One extra byte is allocated at the start of each sector
;    to flag a bad sector (read failure). This byte is zero if the sector
;    is good, non-zero if the sector is bad.
trkBuf	ds	NUMSEC*TSECLEN
	end
I made some good progress yesterday.
Looks like chario3 is working now, or at least it prints the sign-on message and accepts keystrokes.
And it also looks like this BIOS will provide 46Kb TPA. Not 100% sure that will be the case, because the BIOS code isn't done yet. But I don't think it will grow in size, and when I've linked in all the modules and GEN'ed for 63Kb, that's the resulting TPA value reported at bootup.
As you may recall, I initially thought the chario3 module supported 2SIO boards and didn't need to be modified. But when I learned the boot process was hanging in the chario section of code, I looked closer and realized that wasn't the case.
Funny, 'cause when I started working on BIOS to support the IDE card, I thought I'd only be focused on IDE code. Turns out I needed to work on all the I/O functions, for the serial interface, the floppy controller and the IDE hard disk.
Having Mike Douglas's CP/M 3.0 BIOS helps a lot though. He ported his CP/M 2.2 BIOS to 3.0, and that provides all the functions for the 2SIO and FDC-driven floppies. But it's a single file containing all the code and I wanted to do a modular approach, because I thought that would make it easier to add the IDE code in its own separate module. It would certainly be easier to modify and maintain going forward. So I had to split out the Douglas FDC code and 2SIO code and insert it into the appropriate modules. That's where I'm at now.
Yesterday, I used the debugger to single-step through the init process up to the point where it printed the sign-on message. In my case, it's the string "CR,LF,LF,'CP/M Plus v3.0hd',CR,LF,LF,0." When it got to the place where it was trying to send the first character, the debugger said this:
-Z-E- A=00 B=000D D=915C H=9225 S=8EBD P=9225 OUT 11
That let me know the code was at least hitting the 2SIO card with the right output port. But it also let me know the accumulator didn't have any data in it to print. And I could see it in the C register.
So I compared Mike's code with the boilerplate code in chario3 and found the problem. Both use a similar function to lookup a vector for the low-level device interface code. The CP/M 3 boilerplate code calls it "dev$dispatch" and Mike's code names that function "doDevIo." They are very similar. But in the boilerplate code, the character to send remains in the C register and it isn't transfered until entering the device-specific output function. That means each function repeats this MOV A,C instruction. Mike chose to put that in the doDevIo/dispatch function, and after examining the surrounding code for conflicts, I decided to do that too. Fewer instructions that way.
After assembling, linking and GENning, the code now spits out the sign-on message.
Now I can move onto the FDC code and begin to troubleshoot that. I'm sure it has the same sort of problem(s), places where the Douglas code and the modular code don't quite coincide. Mike's FDC code provides buffering and monitors SIO to know when the system is quiescent enough to flush the disk buffers, so I need to make sure that's all stitched back together in the modular files too.
The new chario3.asm file is shown below, as is the SID debugger screen output and notes of my troubleshooting steps. Note that the debugger version is GENned for topmem=A9, to leave room for SID. So it reports only having 27Kb TPA. The final version will expose more memory than that.
CHARIO3.asm
	TITLE	'SIO AND 2SIO MODULE FOR CP/M 3.0'
TRUE		EQU	-1
FALSE		EQU	NOT TRUE
UNDEF		EQU	0FFH
MINIDSK		EQU	FALSE		;Set TRUE for Altair Mini-Disk (see FDC3.asm)
	PUBLIC	@CTBL
	IF	BANKED
	EXTRN	@CBNK
	EXTRN	?BNKSL
	ENDIF
	EXTRN	?PMSG
	MACLIB	Z80
	CSEG
	IF	BANKED
	;;;;; ?CINIT
?CINIT:
	;;;;; ?CI
	;;;;; ?CO
	;;;;; ?CIST
	;;;;; ?COST
	;;;;; BANKIO
BANKIO:
	CALL	?BNKSL
BIORET:
	CALL	?BNKSL
	RET			;AND RETURN...
	ENDIF
	IF	BANKED
BCINIT:
	ELSE
?CINIT:
	ENDIF
				; IT IN [B]
	IF	BANKED
BCI:
	ELSE
?CI:
	ENDIF
	sta	bfDrive
	IF	NOT MINIDSK
	out	DRVCMD
	ENDIF
	CALL	DEV$DISPATCH
	IF	BANKED
BCO:
	ELSE
?CO:
	ENDIF
	IF	BANKED
BCIST:
	ELSE
?CIST:
	ENDIF
	CALL	DEV$DISPATCH
	IF	BANKED
BCOST:
	ELSE
?COST:
	ENDIF
	;;;;; DEV$DISPATCH
DEV$DISPATCH:
	MVI	D,0
	INX	H
	MOV	D,M
	MOV	A,C		;PUT CHAR TO SEND INTO A
	XCHG			;PUT HANDLER ADDRESS IN [HL]
CINIT0:
CINIT1:
CINIT2:
CINIT3:
	RET
CIST0:
	rz			;no, return zero
	ret
CIST1:
	rz			;no, return zero
	ret
CIST2:
	rz			;no, return zero
	ret
CIST3:
	rz			;no, return zero
	ret
CI0:
	ret
CI1:
	ret
CI2:
	ret
CI3:
	ret
COST0:
	ani	SIOTDRE		;0=busy
	ret
COST1:
	ani	SIOTDRE		;0=busy
	ret
COST2:
	ani	SIOXMT		;0=busy
	ret
COST3:
	ani	SIOXMT		;0=busy
	ret
CO0:
	ret
CO1:
	ret
CO2:
	ret
CO3:
	ret
NULL$CIST:
NULL$COST:
	JR	NULL$RET
NULL$CI:
NULL$INIT:
NULL$CO:
NULL$RET:
DEV$CODE:	DS	1
	;;;;; CHRTBL
@CTBL:
	db baud$none
	db baud$none
	db baud$none
	db baud$none
	; OTHER DATA AREAS:
IOSP	EQU	$
SPSAVE	DS	2
	END
SID debugger output and notes:
A>b:sid cpmldr.com
NEXT MSZE  PC  END
2500 2500 0100 CBFF
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#L8E00
  8E00  JMP  A887
  8E03  JMP  8E6C
  8E06  JMP  8F72
  8E09  JMP  8F8D
  8E0C  JMP  8ED5
  8E0F  JMP  8EE1
  8E12  JMP  8EDB
  8E15  JMP  8F93
  8E18  JMP  A8F5
  8E1B  JMP  A8C6
  8E1E  JMP  A8F8
  8E21  JMP  A8FE
  8E24  JMP  A904
  8E27  JMP  A91B
  8E2A  JMP  A931
  8E2D  JMP  8F0D
  8E30  JMP  A910
  8E33  JMP  8F01
  8E36  JMP  8F78
  8E39  JMP  8F07
  8E3C  JMP  8ECD
  8E3F  JMP  9104
  8E42  JMP  8ED1
  8E45  JMP  A952
  8E48  JMP  A956
  8E4B  JMP  9275
  8E4E  JMP  9094
  8E51  JMP  9020
  8E54  JMP  A90C
  8E57  JMP  9274
  8E5A  JMP  0000
  8E5D  JMP  0000
  8E60  JMP  0000
#P8E0C                    <====     calls ?cono, which jumps to conout
#G8E00
01 PASS 8E0C
 ----- A=0D B=000D D=9109 H=90ED S=8EC3 P=8E0C JMP  8ED5   (conout)
*8ED5
#TW#10
 ----- A=0D B=000D D=9109 H=8000 S=8EC3 P=8ED8 JMP  8EE4   (out$scan)
 C---- A=0D B=000D D=9109 H=0000 S=8EBF P=8EEC CALL 8F27   (coster)
 ----- A=FF B=000D D=91A2 H=9201 S=8EBF P=8EEF ORA  A
 --ME- A=FF B=000D D=91A2 H=9201 S=8EBF P=8EF0 JZ   8EEC   (not$out$ready)
*8EF3
#TW#10
 --ME- A=FF B=000D D=91A2 H=9201 S=8EBF P=8EF3 POP  B
 --ME- A=FF B=000D D=91A2 H=9201 S=8EC1 P=8EF4 PUSH B
 --ME- A=FF B=000D D=91A2 H=9201 S=8EBF P=8EF5 CALL 9158   (?co)
 -Z-E- A=00 B=000D D=915C H=9225 S=8EBF P=8EF8 POP  B
 -Z-E- A=00 B=000D D=915C H=9225 S=8EC1 P=8EF9 POP  H
 -Z-E- A=00 B=000D D=915C H=0000 S=8EC3 P=8EFA INR  B
 ----- A=00 B=010D D=915C H=0000 S=8EC3 P=8EFB MOV  A,H
 ----- A=00 B=010D D=915C H=0000 S=8EC3 P=8EFC ORA  L
 -Z-E- A=00 B=010D D=915C H=0000 S=8EC3 P=8EFD JNZ  8EE6   (co$next)
 -Z-E- A=00 B=010D D=915C H=0000 S=8EC3 P=8F00 RET     <====     Back to 8FBE, returned from conout
*8FBE
#TW#10
 -Z-E- A=00 B=010D D=915C H=0000 S=8EC5 P=8FBE POP  H
 -Z-E- A=00 B=010D D=915C H=90ED S=8EC7 P=8FBF INX  H
 -Z-E- A=00 B=010D D=915C H=90EE S=8EC7 P=8FC0 JMP  8FB4
 -Z-E- A=00 B=010D D=915C H=90EE S=8EC7 P=8FB4 MOV  A,M
 -Z-E- A=0A B=010D D=915C H=90EE S=8EC7 P=8FB5 ORA  A
 ---E- A=0A B=010D D=915C H=90EE S=8EC7 P=8FB6 JZ   8FC3
 ---E- A=0A B=010D D=915C H=90EE S=8EC7 P=8FB9 MOV  C,A
 ---E- A=0A B=010A D=915C H=90EE S=8EC7 P=8FBA PUSH H
 ---E- A=0A B=010A D=915C H=90EE S=8EC5 P=8FBB CALL 8E0C
01 PASS 8E0C
 ---E- A=0A B=010A D=915C H=90EE S=8EC3 P=8E0C JMP  8ED5
*8ED5
Inside conout (8ED5), we have one jump to out$scan and two calls within that.
The jump is to 8EE4 (out$scan).
The first call is to 8F27 (coster).
Second call is to 9158 (?co).
Sign-on message is at 90ED.
...so let's examine ?co at 9158.
SID CPMLDR.COM
NEXT MSZE  PC  END
2500 2500 0100 CBFF
#I$B
#G
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
*01A9
#P9158                    <====     calls ?co, which then calls dev$dispatch at 91C1
#G8E00
01 PASS 9158
#TW#14
 --ME- A=FF B=000D D=91A2 H=9201 S=8EBD P=9158 CALL 91C1  (dev$dispatch)
 --ME- A=FF B=000D D=91A2 H=9201 S=8EBB P=91C1 MOV  A,B
 --ME- A=00 B=000D D=91A2 H=9201 S=8EBB P=91C2 STA  9237
 --ME- A=00 B=000D D=91A2 H=9201 S=8EBB P=91C5 ADD  A
 -Z-E- A=00 B=000D D=91A2 H=9201 S=8EBB P=91C6 POP  H
 -Z-E- A=00 B=000D D=91A2 H=915B S=8EBD P=91C7 MOV  E,A
 -Z-E- A=00 B=000D D=9100 H=915B S=8EBD P=91C8 MVI  D,00
 -Z-E- A=00 B=000D D=0000 H=915B S=8EBD P=91CA DAD  D
 -Z-E- A=00 B=000D D=0000 H=915B S=8EBD P=91CB MOV  E,M
 -Z-E- A=00 B=000D D=0025 H=915B S=8EBD P=91CC INX  H
 -Z-E- A=00 B=000D D=0025 H=915C S=8EBD P=91CD MOV  D,M
 -Z-E- A=00 B=000D D=9225 H=915C S=8EBD P=91CE XCHG
 -Z-E- A=00 B=000D D=915C H=9225 S=8EBD P=91CF PCHL
*9227
Looks good as far as selecting the output device, but the accumulator
doesn't have the character to print.
#TW
 -Z-E- A=00 B=000D D=915C H=9225 S=8EBD P=9227 RET
01 PASS 9158
 --ME- A=FF B=000A D=91A2 H=9201 S=8EBD P=9158 CALL 91C1
...and then off the rails.
Modified CHARIO3.asm to add a MOV A,C instruction in DEV$DISPATCH.
Upon booting (without SID and CPMLDR.COM) - just straight from the
GENCPM'ed floppy - this is what I now see:
CP/M V3.0 Loader
 BIOS3    SPR  8E00  1C00
 BDOS3    SPR  6F00  1F00
 27K TPA
CP/M Plus v3.0hd
CP/M Error On @: Read/Only Disk
Users browsing this forum: No registered users and 20 guests
