mpastor
Post by mpastor »
In this website we can find the altair connected to internet. this is possible?
http://www.micronick.com/altair/
can I transmit a message from one to another altair?
Greetings.
You could transfer files (containing a message!) between two Altairs using XMODEM, KERMIT, etc.
Synoptic
Post by Synoptic »
I'm the owner of that clone on the internet.
I use a small linux computer to do this and a program that listen on a TCP port dans transfer everything back and forth to the serial port of the linux to the Serial port of the altair.
Mike helped me making a boot disk on the altair that presents a menu.
jibanes
Post by jibanes »
Nice, can you perform a reset remotely as well?
Synoptic
Post by Synoptic »
jibanes wrote:Nice, can you perform a reset remotely as well?
No!
virtualaltair
Post by virtualaltair »
My Altair and Altair Clone are connected to the internet using a GW312 Serial to Ethernet Server. The server can use simple Telnet or Telnet COM Port Control RFC 2217.
https://www.neteon.net/products/serial- ... gw312.html
Mike Douglas ported BYE.ASM and XMODEM.ASM to use Altair 2SIO port 2 with CTS enabled. BYE & XMODEM for a simple Remote CP/M (RCP/M) that can be operated remotely using Telnet. The RCP/M can load a program, for example a BBS program.
Tom
jibanes
Post by jibanes »
What would be indeed interesting is to "link" all our altair(clones) together using similar means, some kind of altairnet, with where a common "chatroom" exists and is shared on freenode as well and perhaps a way to share files.
The "gateway" between altair and internet doesn't have to speak tcp/ip to the altair of course, maybe some kermit-like protocol.
Synoptic
Post by Synoptic »
jibanes wrote:What would be indeed interesting is to "link" all our altair(clones) together using similar means, some kind of altairnet, with where a common "chatroom" exists and is shared on freenode as well and perhaps a way to share files.
I am all in for an "AltairNet"
gio74
Post by gio74 »
hey I would love an altairnet
Post by TomXP411 »
You can also use a WiModem to connect to the Internet. The WiModem is a microcontroller with an RS-232 interface, and it's very useful on systems like the Altair Clone. I've started using one, since it lets me connect to the Altair from across the room, and I can leave the system on my dresser, where it lives these days.
I use this unit by Jim Drew:
here's an example:
Users browsing this forum: Ahrefs [Bot] and 22 guests
