DEC terminal
troymc
DEC terminal
Post by troymc »
Does anyone have any experience using a "real" hardware terminal with their clone?
I have a DEC VT102 that I've been using with mine. It works just fine at 9600,8,N,1 under CPM. I also don't see any issues while running WordMaster, etc.
However when I switch over to the Configuration Monitor some of the menus are corrupt. Basically it appears that any menu with more than three items gets truncated, sometimes with the prompt appearing in the middle of a line with some garbage. The truncation appears generally consistent - that is, as I navigate around the same menus are generally truncated the same way each time - and the short menus are never truncated.
I've tried fiddling with flow control options with no effect. And I see no issues with it at all when connecting via serial->USB & using minicom on linux.
Any suggestions? Is this simply the Configuration Monitor not being fully VT100 compatible?
Troy
Re: DEC terminal
is smooth scroll enabled in the VT? If so, turn it off and there should be no problem.
troymc
Re: DEC terminal
Post by troymc »
I do indeed have smooth-scrolling enabled.
I will give that a shot here shortly!
Thanks!
Troy
troymc
Re: DEC terminal
Post by troymc »
Thanks Mike! That was exactly it.
I toggled smooth scrolling off and all menus appear as expected now.
This will sure make swapping disk images easier now!
Troy
