Source for 517-D3433-5302-AR interface board connector?
Posted:
April 27th, 2022, 5:36 pm
by Curto
Does anyone know a source for the 517-D3433-5302-AR right angle 50 pin connector for the interface board? I have searched high and low and cannot find stock. The only places I find with stock are with unknown sources overseas. I have to order from any "sketchy" places. I don't necessarily mind ordering from overseas if someone has past experience with a distributor...
Will accept any help.
Curt.
Re: Source for 517-D3433-5302-AR interface board connector?
Posted:
April 27th, 2022, 6:13 pm
It’s relatively generic - you can substitute.
Posted:
April 27th, 2022, 6:56 pm
by Curto
Posted:
April 27th, 2022, 9:30 pm
by BillO
Yeah, generic. I got a bag of them off ebay for a couple of dollars. Just used a .1" double row 90 degree header. The kind you can cut to any length. I used quite a lot of them in other projects. Sure, there are no locks, and if you tried very hard you could get the cable in the wrong way around, but you would have to try hard. As to the no locks, My 8800c has been running continuously for over a month without a hiccup. It doesn't have to move much.
Sorta like this --
https://www.ebay.ca/itm/181918596973?hash=item2a5b317f6d:g:2tsAAOSwaB5Xmu71
Posted:
April 27th, 2022, 9:35 pm
by BillO
Should work, if you want to be fancy :)
