AltairClone wrote:Looks like you need to turn on the “Jump Start” switch on SW3. Also, since you have a front panel machine, you should turn off the “Sense Switch Enable” switch and remove the MWRITE jumper. I can’t see your reset/POC jumpers clearly to see if that is correct. Hopefully you’ve got a local copy of the manual for the board you can refer to to see what else may need to change. It’s a very configurable board. Right now the manual is missing from Martin’s folder on DeRamp.com.
No combination of switches seems to start AMON. I even tried both methods of disabling RAM by setting the switch
and putting a jumper on PHANTOM. Fortunately your front panel allows me to jump to F800. That starts AMON ok. The ROM disable works, though. Once I start BASIC, I can peek and poke into the last 2K bytes of RAM.
