Altair 8800c S/N 13219 Build Thread
Re: Altair 8800c S/N 13219 Build Thread
Postby Sirius Arcturus » September 30th, 2022, 11:59 pm
Tom if you’d want to let me test that prototype board in my 8800c I’d be more than happy :)
Also I’ve visited your site now — so much to see there! I’ll get back to you about it after I’ve consumed more. But I can already recommend http://www.virtualaltair.com to anyone who hasn’t seen it yet.
And to all, I’ve just completed this 88-VI(RTC) board from one of the bare reproduction boards available from JM Precision Components in the UK. Finding all the parts was like going on a journey, but not too bad at all and kind of fun.
I’m hoping to get Timesharing BASIC going with it.
88-VI(RTC) Front
88-VI(RTC) Back
Sirius Arcturus
Postby Wayne Parham » October 1st, 2022, 9:08 am
Very nice!
Postby Sirius Arcturus » October 7th, 2022, 10:21 pm
Thanks, Wayne!
And I can now report I did in fact get Timesharing BASIC 1.1 running successfully with some input from Mike. He pointed out I needed to change the RTC division jumper from “AD” to “CD” to divide the 10 kHz signal from CF to provide a 100 Hz clock which works. This allows me to run TS BASIC on the 8800x which is very enjoyable.
Additionally, as I am using the 88-2SIOJP with default address settings, I needed to set terminal 1 to 1 device at address 16, and terminal 2 to 1 device at address 18. Thanks, Mike, for your help.
Since then, I’ve now completed building up one of JM Precision’s reproduction 88-16MCS memory boards. This was an ultra fun build and I ended up with only one bad 4200 chip. The memory test at 046 allowed me to recognize it was in bank “C”, and then I swapped out chips in “C” until I found it. I also could have examined the bit patterns of the failing data and identified the exact chip in “C”, but I did not do that.
I am beginning now a build of a second one of these.
Here are photos of the completed one.
Sirius
88-16MCS front
88-16MCS reverse
Sirius Arcturus
Postby Wayne Parham » October 8th, 2022, 9:31 am
Very cool. I love the new PCB versions of original boards. Just very cool.
I built a couple of Jerry's 64K battery-backup "core" boards. They are a simple design 'cause they use newer chips. But they aren't Altair-reproduction boards like yours.
And I'm using the RAM on the FDC+ board, so my "battery core" boards aren't being used. I keep thinkin' I'll disable the FDC+ memory and put in the core boards, but I haven't yet.
I might have to get boards like yours so I can make a closer-to-1970s Altair, maybe put it in my "red" system.
Postby Sirius Arcturus » October 8th, 2022, 11:56 am
Wayne,
I know which 64K board you mean. Jerry makes very nice boards. The two different boards of his I’ve built were a joy to work on.
I agree, it’s been so nice to have the FDC+ memory. It took some “explaining” for my wife to finally (sort of) get it why I’d want to build (and pay for the parts for) an old school board — which only holds 1/4 the max RAM — whenever I already have the max RAM in a single chip which will never, ever, ever fail a memory test. Lol
Truth is, I’ve begun building a second one now. I have enough 4200 chips for a second one and a third one, depending on how many are actually good.
I did the same thing you mentioned and that is I set 16K board to be the first 16k, and set the FDC+ to start at 4000H. Hoping to be able to switch it to 8000H soon :)
Oh also I’ve been meaning to mention I’m using the same 5.25” FD enclosure you are using two of. After seeing yours I looked and found one on eBay. Nice and easy to use with power supply and fan already built in.
Sirius Arcturus
Postby Sirius Arcturus » October 8th, 2022, 2:58 pm
Here is a current operating photo.
8800c operating
Sirius Arcturus
Postby virtualaltair » October 9th, 2022, 6:31 pm
What software are you using for a memory test of the 88-16MCS? What do you estimate for the parts cost of a single 16K memory board? I think an original 16K board would be $300 on eBay. That makes the FDC+ 64K a bargain.
virtualaltair
Postby Wayne Parham » October 10th, 2022, 9:08 am
Your system looks awesome! Really nice job!
Postby toml_12953 » October 11th, 2022, 1:37 am
Sirius Arcturus wrote:Thanks, Wayne!
You really want Timesharing BASIC 2.0. With version 1.1, you can't open files, among its other limitations.
It's available in the same place you can get 1.1.
Postby Sirius Arcturus » October 16th, 2022, 1:17 pm
virtualaltair wrote:What software are you using for a memory test of the 88-16MCS? What do you estimate for the parts cost of a single 16K memory board? I think an original 16K board would be $300 on eBay. That makes the FDC+ 64K a bargain.
Hi Tom,
I used the memory test located at 046Q on the 8800c. There is firmware on the front panel microcontroller that has a few small programs you can deposit with setting an address and depressing AUX Left. The memory test is one of them. This AUX Left behavior is of course a modern addition and as such can be enabled or disabled as desired.
I also have AMON in PROM which has a memory test too. It runs quite a few passes and then returns to the AMON prompt, whereas the (version of the) one I have on the front panel runs passes continuously until you reset the machine.
Both let you choose start end endpoints.
The parts and board weren’t too much, and I had many of the parts already. The style of sockets I chose are kind of high, but the real expense was the 4200 chips. I need a minimum of 5 more and I can fully populate a third board! If anyone has 5 or so to sell please PM me :)
I just finished board number two and miraculously, this one ran the first time with zero errors! No bad RAM at all!
88-16MCS repro build #2 (front)
88-16MCS repro build #2 (reverse)
4200 RAM top
Sirius Arcturus
PreviousNext
