Just starting an 8800c build - 9 slot motherboard questions
Postby alank2 » May 11th, 2021, 10:49 am
I noticed in Mike's video he mentions not making the motherboard active, but leaving it passive. What components should be loaded on the board then? Power connector? Fuses? Any capacitors?
alank2
Re: Just starting an 8800c build - 9 slot motherboard questi
Postby toml_12953 » May 12th, 2021, 3:53 am
alank2 wrote:I noticed in Mike's video he mentions not making the motherboard active, but leaving it passive. What components should be loaded on the board then? Power connector? Fuses? Any capacitors?
I have just the power connectors (and S-100 sockets, of course!) on mine. Nothing else. It's been working fine with eight boards on it for a couple years now.
Altair 8800 CPU board
Mike's FP interface board
FDC+ board (64K RAM and floppy interface)
Altair 88-UIO board with serial and cassette interface
Altair 88-VI RTC interrupt/RTC board
Altair 88-C700 printer interface board
Two 88-2SIOJP serial boards
Postby AltairClone » May 13th, 2021, 10:15 pm
Yes, Tom is correct, only S-100 connectors and the power connector. You can jumper across the fuse locations since your switching supplies will protect themselves and the downstream circuits.
