Postby mpastor » July 6th, 2014, 6:40 am
In this website we can find the altair connected to internet. this is possible?
http://www.micronick.com/altair/
can I transmit a message from one to another altair?
Greetings.
mpastor
Postby AltairClone » July 9th, 2014, 6:57 pm
You could transfer files (containing a message!) between two Altairs using XMODEM, KERMIT, etc.
Postby Synoptic » July 15th, 2014, 11:56 am
I'm the owner of that clone on the internet.
I use a small linux computer to do this and a program that listen on a TCP port dans transfer everything back and forth to the serial port of the linux to the Serial port of the altair.
Mike helped me making a boot disk on the altair that presents a menu.
Synoptic
Postby jibanes » July 15th, 2014, 12:59 pm
Nice, can you perform a reset remotely as well?
jibanes
Postby Synoptic » July 15th, 2014, 7:34 pm
jibanes wrote:Nice, can you perform a reset remotely as well?
No!
Synoptic
Postby virtualaltair » December 1st, 2016, 11:23 am
My Altair and Altair Clone are connected to the internet using a GW312 Serial to Ethernet Server. The server can use simple Telnet or Telnet COM Port Control RFC 2217.
https://www.neteon.net/products/serial-ethernet-device-servers/gw312.html
Mike Douglas ported BYE.ASM and XMODEM.ASM to use Altair 2SIO port 2 with CTS enabled. BYE & XMODEM for a simple Remote CP/M (RCP/M) that can be operated remotely using Telnet. The RCP/M can load a program, for example a BBS program.
Tom
virtualaltair
Postby jibanes » January 27th, 2017, 11:20 am
What would be indeed interesting is to "link" all our altair(clones) together using similar means, some kind of altairnet, with where a common "chatroom" exists and is shared on freenode as well and perhaps a way to share files.
The "gateway" between altair and internet doesn't have to speak tcp/ip to the altair of course, maybe some kermit-like protocol.
jibanes
Postby Synoptic » January 30th, 2017, 1:40 pm
jibanes wrote:What would be indeed interesting is to "link" all our altair(clones) together using similar means, some kind of altairnet, with where a common "chatroom" exists and is shared on freenode as well and perhaps a way to share files.
I am all in for an "AltairNet"
Synoptic
Postby gio74 » November 19th, 2018, 9:31 am
hey I would love an altairnet
gio74
Postby TomXP411 » December 3rd, 2018, 4:06 pm
You can also use a WiModem to connect to the Internet. The WiModem is a microcontroller with an RS-232 interface, and it's very useful on systems like the Altair Clone. I've started using one, since it lets me connect to the Altair from across the room, and I can leave the system on my dresser, where it lives these days.
I use this unit by Jim Drew:
here's an example:
