Altair Clone Firmware version 1.91
Posted: December 8th, 2015, 12:12 pm
Version 1.91 of the Clone firmware is now on the support page. This release augments the serial port flexibility for the Configuration Monitor that was started in 1.9. Features added in 1.9 and 1.91 are summarized below:
Disk image transfer at 230.4K or 460.8K baud is a bit hit-or-miss depending on the PC used, the OS, the USB-to-serial adapter, the USB-to-serial adapter driver version, and the terminal emulator or XMODEM transfer software used.
- Upon first entry into the Configuration Monitor from normal (Altair) mode, the run-time (Altair) settings for port 1 are used. Once in the monitor, raising AUX-L again forces the monitor to re-start with port 1 set to 9600 baud, 8N1. This allows, for example, using a Teletype as the Altair console and continuing to use the Teletype as the Configuration Monitor console. However, if a 9600 baud console is then connected for use with the Configuration Monitor, a second AUX-L toggle will properly display on the 9600 baud console.
- Allow floppy transfer over serial port 1 (console) or serial port 2.
- Add 230.4K and 460.8K baud options for the floppy transfer rate. (see additional notes below)
- Move the admin menu floppy options into a separate "Floppy Settings" sub-menu within the admin menu. This new menu includes the addition of the option to specify the serial port used for disk image transfer.
- Reduce the verbiage of all menus so they display quicker at slower baud rates.
