Using minicom under linux as terminal program
Postby Synoptic » March 13th, 2014, 12:09 pm
Minicom works very well, excepts, it lacks the binary sending mode.
However, it is possible to add that feature.
Taken from http://www.dannysung.com/wmain/linux/tips/sending-binary-files-via-minicom/
First step is to install pv.
On RPM-based systems, just type:
sudo yum install pv
On Debian-based systems, type:
apt-get install pv
Now create this script, and place it in your ~/bin/ directory as (for example) bin-xfr.
#!/bin/sh
INFILE=/dev/null
OUTFILE=/dev/null
while [ $# -gt 0 ]; do
 case "$1" in
 -i)
 shift
 INFILE="$1"
 -o)
 shift
 OUTFILE="$1"
 -h|--help)
 echo "$0 -i infile -o outfile"
 INFILE="$1"
 esac
 shift
done
cat << EOF
binary-xfer utility for minicom
Sending file ${INFILE} to ${OUTFILE}
EOF
/usr/bin/pv --force -i 0.25 -B 128  ${INFILE}  2>&1 > ${OUTFILE}
# Use the line below if you don't have pv!
# /bin/cat ${INFILE} > ${OUTFILE}
cat << EOF
File transfer complete
EOF
sleep 1
Now go over to minicom and go to the configuration menu (via CTRL-A,O), then “File transfer protocols”. You can add a section there called “binary”, point it at your file, and specify:
    Program: /home/MYUSERNAME/bin/bin-xfer -o %l -i
    U/D:  U
    FullScr: Y
    IO-Red: N
    Multi:N
Then leave the menu and save your options. Next time you send a file (via CTRL-A,S), you should see “Binary” listed as an option.
The only caveat, is the firmware filename should not have special character in its name (space for example).
Synoptic
Re: Using minicom under linux as terminal program
Postby AltairClone » March 13th, 2014, 4:08 pm
Great info -- Thanks!
Users browsing this forum: No registered users and 82 guests
