Using Old Tandy Printers
Postby Tech » January 14th, 2022, 11:22 pm
I understand that Altair Clone does not have a parallel port, only serials. Many old Tandy printers have DIN 4 serial ports, like the one in attachment. Can Altair print on such printers, using an adopted cable of course?
Tech
Re: Using Old Tandy Printers
Postby AltairClone » January 15th, 2022, 8:47 am
This should be pretty easy to make work. Connect pins 3, 4, and 7 of the bottom serial port on the Altair to DIN pins 4, 2, 3 respectively. In the serial port menu on the Clone, make sure the serial port is configured as a 2SIO port and then choose the “CTS, RTS Both Used” handshake option.
