AltairClone wrote:Front panel deposit works fine for me with the same firmware version.
You mentioned the Turnkey montor ROM, do you also have the Turnkey board enabled? (e.g., auto jump after power on or reset?). If so, that's what you're seeing. Keep in mind that the real Turnkey board takes over the bus after a reset and attempts to force JMP to the start address during the first three bus cycles. Recall also that the front panel on an Altair does an examine operation by executing JMP to the address on the switches (and then remains stopped). Both the Turnkey auto-jump and the front panel examine are walking all over each other when you're doing the first examine, after which, the Turnkey board no longer over-drives the bus since the first three bus cycles are then over due to the examine JMP.
AltairClone wrote:Presently, the Altair Clone does not correctly duplicate all aspects of this behavior. To correct this, I am working on an update to the Clone firmware that I will release in the next few days.
Users browsing this forum: Google [Bot] and 30 guests
